    4. Could not check npm version
      stenmic last edited by stenmic
      nachdem ich meinem Debian bookworm heute ein update/upgrade spendiert habe kommt folgende Fehlermeldung permanent im log.
      Hat jemand einen Tipp?
      host.SmartHome
      	2024-01-02 18:47:31.822	error	Caught by controller[0]: /bin/sh: 1: npm: not found
      host.SmartHome
      	2024-01-02 18:47:31.822	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      host.SmartHome
      	2024-01-02 18:47:31.822	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
      host.SmartHome
      	2024-01-02 18:47:31.822	error	Caught by controller[1]: ^
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
      host.SmartHome
      	2024-01-02 18:47:31.823	error	Caught by controller[1]: Node.js v18.19.0
      host.SmartHome
      	2024-01-02 18:47:31.823	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      • crunchip
        crunchip Forum Testing Most Active @stenmic last edited by
        @stenmic sagte in Could not check npm version:
        lesen
        https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
          stenmic @crunchip last edited by stenmic
          @crunchip sagte in Could not check npm version:
          lesen
          hab ich, ein "iob nodejs-update 18" durchgeführt. Danach immer noch Fehler.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: SmartHome
                 Icon name: computer-vm
                   Chassis: vm 🖴
            Virtualization: kvm
                    Kernel: Linux 6.1.0-17-amd64
              Architecture: x86-64
           Hardware Vendor: QEMU
            Hardware Model: Standard PC _i440FX + PIIX, 1996_
          Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
          model name      : QEMU Virtual CPU version 2.5+
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           19:12:21 up 3 min,  2 users,  load average: 2.10, 1.38, 0.58
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Tue 2024-01-02 19:12:21 CET
                     Universal time: Tue 2024-01-02 18:12:21 UTC
                           RTC time: Tue 2024-01-02 18:12:21
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          micha
          /home/micha
          micha cdrom floppy sudo audio dip video plugdev users netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             12G        4.4G        7.6G        540K        758M        8.1G
          Swap:           1.0G          0B        1.0G
          Total:           13G        4.4G        8.6G
                  11960 M total memory
                   4231 M used memory
                    198 M active memory
                   4178 M inactive memory
                   7268 M free memory
                     58 M buffer memory
                    664 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem               Type      Size  Used Avail Use% Mounted on
          udev                     devtmpfs  5.9G     0  5.9G   0% /dev
          tmpfs                    tmpfs     1.2G  528K  1.2G   1% /run
          /dev/sda1                ext4       62G  7.7G   51G  14% /
          tmpfs                    tmpfs     5.9G     0  5.9G   0% /dev/shm
          tmpfs                    tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                    tmpfs     1.2G     0  1.2G   0% /run/user/1000
          //192.168.178.110/Backup cifs      458G  214G  245G  47% /mnt/backup
          [Tue Jan  2 19:08:25 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Jan  2 19:08:25 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
          TARGET        SOURCE                   FSTYPE OPTIONS
          /             /dev/sda1                ext4   rw,noatime,discard,errors=remount-ro
          `-/mnt/backup //192.168.178.110/Backup cifs   rw,relatime,vers=3.1.1,cache=strict,username=smbuser,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.110,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
          /var:
          1.3G    /var/
          615M    /var/lib
          547M    /var/log
          529M    /var/log/journal/e9726c92410847a19e506da4282d4c65
          Archived and active journals take up 12.3M in the file system.
          /opt/iobroker/backups:
          1.1G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          681M    /opt/iobroker/iobroker-data/
          432M    /opt/iobroker/iobroker-data/files
          169M    /opt/iobroker/iobroker-data/files/vis-2
          169M    /opt/iobroker/iobroker-data/backup-objects
          104M    /opt/iobroker/iobroker-data/files/vis-2/static
          63M     /opt/iobroker/iobroker-data/objects.jsonl
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          28M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.1841b37a.js.map
          27M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.4c41f363.js.map
          27M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /home/iobroker/.diag.sh: line 279: npm: command not found
          /home/iobroker/.diag.sh: line 280: npx: command not found
          /home/iobroker/.diag.sh: line 281: corepack: command not found
          /home/iobroker/.diag.sh: line 290: npm: command not found
          /home/iobroker/.diag.sh: line 291: npx: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 18.19.0+dfsg-6~deb12u1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          /home/iobroker/.diag.sh: line 360: npm: command not found
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          /home/iobroker/.diag.sh: line 375: npm: command not found
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : SmartHome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : SmartHome                                -  enabled
          + system.adapter.backitup.0               : backitup              : SmartHome                                -  enabled
          + system.adapter.bmw.0                    : bmw                   : SmartHome                                -  enabled
          + system.adapter.bshb.0                   : bshb                  : SmartHome                                -  enabled
            system.adapter.coronavirus-statistics.0 : coronavirus-statistics: SmartHome                                - disabled
            system.adapter.daswetter.0              : daswetter             : SmartHome                                -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : SmartHome                                -  enabled
          + system.adapter.discovery.0              : discovery             : SmartHome                                -  enabled
          + system.adapter.geofency.0               : geofency              : SmartHome                                -  enabled, port: 7999, bind: 0.0.0.0
          + system.adapter.ham.0                    : ham                   : SmartHome                                -  enabled
          + system.adapter.harmony.0                : harmony               : SmartHome                                -  enabled
          + system.adapter.hass.0                   : hass                  : SmartHome                                -  enabled, port: 8123
          + system.adapter.homeconnect.0            : homeconnect           : SmartHome                                -  enabled
            system.adapter.homekit-controller.0     : homekit-controller    : SmartHome                                - disabled
          + system.adapter.hue.0                    : hue                   : SmartHome                                -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : SmartHome                                -  enabled
          + system.adapter.influxdb.0               : influxdb              : SmartHome                                -  enabled, port: 8086
          + system.adapter.influxdb.1               : influxdb              : SmartHome                                -  enabled, port: 8086
          + system.adapter.influxdb.2               : influxdb              : SmartHome                                -  enabled, port: 8086
          + system.adapter.influxdb.3               : influxdb              : SmartHome                                -  enabled, port: 8086
            system.adapter.info.0                   : info                  : SmartHome                                -  enabled
          + system.adapter.iot.0                    : iot                   : SmartHome                                -  enabled
          + system.adapter.javascript.0             : javascript            : SmartHome                                -  enabled
          + system.adapter.logparser.0              : logparser             : SmartHome                                -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : SmartHome                                -  enabled, port: 1883, bind: 192.168.178.111
          + system.adapter.netatmo.0                : netatmo               : SmartHome                                -  enabled
          + system.adapter.nuki.0                   : nuki                  : SmartHome                                -  enabled
          + system.adapter.parser.0                 : parser                : SmartHome                                -  enabled
          + system.adapter.ping.0                   : ping                  : SmartHome                                -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : SmartHome                                -  enabled
          + system.adapter.pushover.0               : pushover              : SmartHome                                -  enabled
          + system.adapter.pushover.1               : pushover              : SmartHome                                -  enabled
          + system.adapter.pushover.2               : pushover              : SmartHome                                -  enabled
          + system.adapter.pushover.3               : pushover              : SmartHome                                -  enabled
          + system.adapter.pushover.4               : pushover              : SmartHome                                -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : Schaltschrank                            -  enabled
          + system.adapter.sainlogic.0              : sainlogic             : SmartHome                                -  enabled, port: 1887, bind: 192.168.178.111
          + system.adapter.shelly.0                 : shelly                : SmartHome                                -  enabled, port: 1881, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : SmartHome                                -  enabled, port: 8087, bind: 192.168.178.111, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : Schaltschrank                            -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : SmartHome                                -  enabled
          + system.adapter.tr-064.0                 : tr-064                : SmartHome                                -  enabled
          + system.adapter.upnp.0                   : upnp                  : SmartHome                                -  enabled
          + system.adapter.vesync.0                 : vesync                : SmartHome                                -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : SmartHome                                -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : SmartHome                                - disabled
            system.adapter.vis-map.0                : vis-map               : SmartHome                                - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHome                                - disabled
            system.adapter.vis.0                    : vis                   : SmartHome                                -  enabled
          + system.adapter.vr200.0                  : vr200                 : SmartHome                                -  enabled
          + system.adapter.web.0                    : web                   : SmartHome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.ws.0                     : ws                    : SmartHome                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : SmartHome                                -  enabled, port: tcp://192.168.178.114:6638
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "bmw"          : 2.5.7    , installed 2.6.3
          Adapter    "bshb"         : 0.2.6    , installed 0.2.6
          Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
          Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
          Adapter    "device-watcher": 2.9.6   , installed 2.9.6
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
          Adapter    "homekit-controller": 0.5.8, installed 0.5.8
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "logparser"    : 2.2.0    , installed 2.2.0
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "parser"       : 2.0.7    , installed 2.0.7
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vesync"       : 0.0.3    , installed 0.0.3
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vr200"        : 1.0.0    , installed 1.1.0
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.9.5    , installed 1.9.6
          Objects and States
          Objects:        20956
          States:         17674
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       18971      1091/io.shelly.0
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       778        619/iobroker.js-con
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14296      619/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          339        1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14211      532/sshd: /usr/sbin
          tcp        0      0 192.168.178.111:8087    0.0.0.0:*               LISTEN      1001       19340      1316/io.simple-api.
          tcp        0      0 192.168.178.111:1883    0.0.0.0:*               LISTEN      1001       18839      998/io.mqtt.0
          tcp        0      0 192.168.178.111:1884    0.0.0.0:*               LISTEN      1001       18840      998/io.mqtt.0
          tcp        0      0 192.168.178.111:1887    0.0.0.0:*               LISTEN      1001       21637      1067/io.sainlogic.0
          tcp        0      0 192.168.178.111:9092    0.0.0.0:*               LISTEN      1001       20327      765/io.nuki.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          13798      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14213      532/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      102        773        618/grafana
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       21183      1239/io.harmony.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16146      650/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21889      1189/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       22347      1443/io.ws.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        14270      524/influxd
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21184      1239/io.harmony.0
          udp        0      0 0.0.0.0:38878           0.0.0.0:*                           1001       21460      1369/io.upnp.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13264      1/init
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       23106      1369/io.upnp.0
          udp6       0      0 :::111                  :::*                                0          13265      1/init
          2024-01-02 19:12:35.827  - error: host.SmartHome Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-02 19:12:35.827  - error: host.SmartHome Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          2024-01-02 19:12:35.827  - error: host.SmartHome Caught by controller[1]:     at node:internal/main/run_main_module:28:49
          2024-01-02 19:12:35.827  - error: host.SmartHome Caught by controller[1]: Node.js v18.19.0
          2024-01-02 19:12:35.827  - error: host.SmartHome instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-02 19:12:35.827  - info: host.SmartHome Restart adapter system.adapter.info.0 because enabled
          2024-01-02 19:12:45.260  - info: host.SmartHome "system.adapter.info.0" disabled
          2024-01-02 19:12:49.703  - info: host.SmartHome "system.adapter.info.0" enabled
          2024-01-02 19:12:49.941  - info: host.SmartHome instance system.adapter.info.0 started with pid 1752
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[0]: /bin/sh: 1: npm: not found
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]:               adapter.log.error("Could not check npm version: " + e);
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]:                       ^
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
          2024-01-02 19:12:51.728  - error: host.SmartHome Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]:     at node:internal/main/run_main_module:28:49
          2024-01-02 19:12:51.729  - error: host.SmartHome Caught by controller[1]: Node.js v18.19.0
          2024-01-02 19:12:51.729  - error: host.SmartHome instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-02 19:12:51.729  - info: host.SmartHome Restart adapter system.adapter.info.0 because enabled
            Thomas Braun Most Active @stenmic last edited by Thomas Braun
            Dann Versuch die zweite Alternative.
            Die dritte Zeile davon reicht.
              stenmic @Thomas Braun last edited by
              @thomas-braun sagte in Could not check npm version:
              Danke, das hat jetzt den Fehler behoben.
