    4. Frage: JSON Inhalt als BarWidget Visualisieren
      Maas-Meister last edited by
      Moin,
      ich bekomme von dem Tibber Adapter ein JSON-DP mit meinen Energiedaten.
      Einen Teil dieser Werte würde ich gerne mit einem Bar Widget Visualisieren.
      Mit dem E-Charts Adapter hatte ich bisher keinen Erfolg.
      Außerdem müsste noch die Uhrzeit konvertiert werden?
      Kann mir jemand aufzeigen wie das geht?
      Beispiel DP:
      [{"from":"2023-03-01T00:00:00.000+01:00","to":"2023-04-01T00:00:00.000+02:00","cost":137.372376561,"unitPrice":0.25357,"unitPriceVAT":0.040486,"consumption":541.754,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-04-01T00:00:00.000+02:00","to":"2023-05-01T00:00:00.000+02:00","cost":90.7700860794,"unitPrice":0.243949,"unitPriceVAT":0.03895,"consumption":372.087,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-05-01T00:00:00.000+02:00","to":"2023-06-01T00:00:00.000+02:00","cost":45.3044254425,"unitPrice":0.219539,"unitPriceVAT":0.035052,"consumption":206.362,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-06-01T00:00:00.000+02:00","to":"2023-07-01T00:00:00.000+02:00","cost":41.3673965509,"unitPrice":0.234526,"unitPriceVAT":0.037445,"consumption":176.387,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-07-01T00:00:00.000+02:00","to":"2023-08-01T00:00:00.000+02:00","cost":44.7069721861,"unitPrice":0.225864,"unitPriceVAT":0.036062,"consumption":197.938,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-08-01T00:00:00.000+02:00","to":"2023-09-01T00:00:00.000+02:00","cost":58.4057955355,"unitPrice":0.247937,"unitPriceVAT":0.039587,"consumption":235.567,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-09-01T00:00:00.000+02:00","to":"2023-10-01T00:00:00.000+02:00","cost":62.7189878063,"unitPrice":0.257247,"unitPriceVAT":0.041073,"consumption":243.808,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-10-01T00:00:00.000+02:00","to":"2023-11-01T00:00:00.000+01:00","cost":113.0440595319,"unitPrice":0.243011,"unitPriceVAT":0.0388,"consumption":465.18,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-11-01T00:00:00.000+01:00","to":"2023-12-01T00:00:00.000+01:00","cost":165.1500357416,"unitPrice":0.24995,"unitPriceVAT":0.039908,"consumption":660.731,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-12-01T00:00:00.000+01:00","to":"2024-01-01T00:00:00.000+01:00","cost":218.4211066317,"unitPrice":0.21144,"unitPriceVAT":0.033759,"consumption":1033.019,"consumptionUnit":"kWh","currency":"EUR"}]
        "type": "state",
        "common": {
          "name": "jsonMonthly",
          "type": "string",
          "role": "text",
          "read": true,
          "write": false
      liv-in-sky mickym 2 Replies Last reply Reply Quote 0
      • liv-in-sky
        liv-in-sky @Maas-Meister last edited by liv-in-sky
        @maas-meister
        evtl mit dem materialdesign chart json widget
        anleitung https://github.com/Scrounger/ioBroker.vis-materialdesign#json-chart
        • mickym
          mickym Most Active @Maas-Meister last edited by mickym
          @maas-meister Ich habe zwar den eCharts Adapter nicht im Einsatz - aber entweder Du schreibst einzelne Datenpunkte in eine Datenbank oder Du kannst doch auch aus JSON das rausziehen.
          und ich würde ggf halt wieder die geniale JSONATA Bibliothek nutzen - nutzt man NodeRed - dann wächst man damit quasi auf.
          • mickym
            Also um Dein oben gezeigtes Array entsprechend in die vom eCharts erwarteten JSON umzuwandeln, nimmst Du JSONATA: https://try.jsonata.org/r0MUIUBX3
            • mickym
              Das neue Array kannst dann in einen Datenpunkt schreiben und musst halt dieses eChart Adapter Teil mal befragen, wie Du den JSON dann in den Adapter bekommst.
               <variables>
                 <variable id=";po#/$v(8.UbHdHNkx[6">Objekt</variable>
               </variables>
               <block type="variables_set" id=":=#[V+q{~-1q78b_H^FF" x="-1137" y="-687">
                 <field name="VAR" id=";po#/$v(8.UbHdHNkx[6">Objekt</field>
                   <block type="convert_json2object" id="?vV.vvxZ^NQN^_lWU1f}">
                       <block type="text" id="+fF--6Ew-2u1R;P~2mBq">
                         <field name="TEXT">[{"from":"2023-03-01T00:00:00.000+01:00","to":"2023-04-01T00:00:00.000+02:00","cost":137.372376561,"unitPrice":0.25357,"unitPriceVAT":0.040486,"consumption":541.754,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-04-01T00:00:00.000+02:00","to":"2023-05-01T00:00:00.000+02:00","cost":90.7700860794,"unitPrice":0.243949,"unitPriceVAT":0.03895,"consumption":372.087,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-05-01T00:00:00.000+02:00","to":"2023-06-01T00:00:00.000+02:00","cost":45.3044254425,"unitPrice":0.219539,"unitPriceVAT":0.035052,"consumption":206.362,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-06-01T00:00:00.000+02:00","to":"2023-07-01T00:00:00.000+02:00","cost":41.3673965509,"unitPrice":0.234526,"unitPriceVAT":0.037445,"consumption":176.387,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-07-01T00:00:00.000+02:00","to":"2023-08-01T00:00:00.000+02:00","cost":44.7069721861,"unitPrice":0.225864,"unitPriceVAT":0.036062,"consumption":197.938,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-08-01T00:00:00.000+02:00","to":"2023-09-01T00:00:00.000+02:00","cost":58.4057955355,"unitPrice":0.247937,"unitPriceVAT":0.039587,"consumption":235.567,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-09-01T00:00:00.000+02:00","to":"2023-10-01T00:00:00.000+02:00","cost":62.7189878063,"unitPrice":0.257247,"unitPriceVAT":0.041073,"consumption":243.808,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-10-01T00:00:00.000+02:00","to":"2023-11-01T00:00:00.000+01:00","cost":113.0440595319,"unitPrice":0.243011,"unitPriceVAT":0.0388,"consumption":465.18,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-11-01T00:00:00.000+01:00","to":"2023-12-01T00:00:00.000+01:00","cost":165.1500357416,"unitPrice":0.24995,"unitPriceVAT":0.039908,"consumption":660.731,"consumptionUnit":"kWh","currency":"EUR"},{"from":"2023-12-01T00:00:00.000+01:00","to":"2024-01-01T00:00:00.000+01:00","cost":218.4211066317,"unitPrice":0.21144,"unitPriceVAT":0.033759,"consumption":1033.019,"consumptionUnit":"kWh","currency":"EUR"}]</field>
                   <block type="update" id="?MX[5({c^a)[E=lykv#7">
                     <field name="OID">0_userdata.0.Test.JSON</field>
                       <block type="convert_object2json" id=":]vcnitNlb(q[piw1dKL">
                         <field name="PRETTIFY">TRUE</field>
                           <block type="convert_jsonata" id="K^,R%C%:kuMI]a)P0lTr">
                             <value name="EXPRESSION">
                               <shadow type="text" id="Q,$o4b`D}XpbeQ1?~$Z+">
                                 <field name="TEXT">$.{"ts":$toMillis(from),"val":consumption}</field>
                             <value name="TARGET">
                               <block type="variables_get" id="zxc9Y^(TcdSMquQab8o^">
                Maas-Meister @mickym last edited by
                @mickym
                Vielen Dank für deine Antwort!
                Geht nur bedingt, da sich der Datenpunkt stetig ändert.
                Daher müsste ich das ja in Blockly/Java Triggern und umwandeln.
                • mickym
                  @maas-meister sagte in Frage: JSON Inhalt als BarWidget Visualisieren:
                  Das ist doch egal in welchen Datenpunkt Du das schreibst - es wird doch im Blockly gewandelt?
                    @mickym
                    Oh, da habe ich dich wohl falsch verstanden.
                    Ich dachte ich müsste das auf der Seite "https://try.jsonata.org/r0MUIUBX3" umwandeln und das Ergebnis weiterverarbeiten.
                    Aber die Seite dient wohl nur als Info wie die Daten aussehen müssen.
                    Ich muss mich da mal rein fuchsen.
                    Besten dank, ich probiere mal ob echarts die neuen Werte annimmt.
                    • mickym
                      @maas-meister Ich wollte Dir nur zeigen, wie man es lernt.
                      Ausserdem habe ich Dir doch das Blockly hier zum Import angeboten: https://forum.iobroker.net/post/1105940
                      Du musst doch nur den Spoiler aufmachen. Du brauchst doch nur Deine Daten in die Variable Objekt einlesen und dann in den gewünschten Datenpunkt schreiben. Mehr kann ich nun wirklich nicht tun.
                      • jogibear9988
                        jogibear9988 last edited by
                        Hab dir mal ein Beispiel in meiner Live webui (http://129.159.205.3:8082/webui/index.html) gemacht wie es dort gehen würde.
                        Screen "chart sample".
                        Das Binding sähe dort so aus:
                        Datum umformatieren ginge z.B. mit diesem String:
                         JSON.parse(__0).map(x => [x.consumption, new Date(Date.parse(x.from) + 60*60+1000).toLocaleDateString()])
                        81.0k
                        708
