    4. Node-Red
    5. Node Red ?Telegram adapter oder ?
    • Fred Freund
      Fred Freund last edited by
      Hi, leider bekam ich nach dem Umzug von Raspi auf Proxmox Node Red Probleme , habe es jetzt mal deinstalliert und wieder installiert.
      Bekomme diesen Fehler leider:
      node-red.0
      	2024-01-02 21:03:12.407	warn	2 Jan 21:03:12 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      	2024-01-02 21:03:10.015	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      	2024-01-02 21:03:09.801	warn	Cannot enable the dynamic object read as admin has authentication
      Ich hoffe diese Fehler die ich vorher bekam sind jetzt weg..hab auch ein altes Backup von vor 14tagen eingespielt.
      node-red.0
      	2024-01-02 18:12:15.105	warn	2 Jan 18:12:15 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      	2024-01-02 18:12:12.366	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      	2024-01-02 18:12:07.366	info	node-red exited with 6
      node-red.0
      	2024-01-02 18:12:06.843	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      node-red.0
      	2024-01-02 18:12:06.843	info	terminating
      node-red.0
      	2024-01-02 18:12:06.339	error	Exception-Code: EFATAL: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      node-red.0
      	2024-01-02 18:12:06.339	error	RequestError: Error: getaddrinfo EAI_AGAIN api.telegram.org at new RequestError (/opt/iobroker/iobroker-data/node-red/node_modules/request-promise-core/lib/errors.js:14:15) at plumbing.callback (/opt/iobroker/iobroker-data/node-red/node_modules/request-promise-core/lib/plumbing.js:87:29) at Request.RP$callback [as _callback] (/opt/iobroker/iobroker-data/node-red/node_modules/request-promise-core/lib/plumbing.js:46:31) at self.callback (/opt/iobroker/iobroker-data/node-red/node_modules/request/request.js:185:22) at Request.emit (node:events:517:28) at Request.onRequestError (/opt/iobroker/iobroker-data/node-red/node_modules/request/request.js:877:8) at ClientRequest.emit (node:events:517:28) at TLSSocket.socketErrorListener (node:_http_client:501:9) at TLSSocket.emit (node:events:517:28) at emitErrorNT (node:internal/streams/destroy:151:8) at emitErrorCloseNT (node:internal/streams/destroy:116:3) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      node-red.0
      	2024-01-02 18:12:06.339	error	unhandled promise rejection: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      node-red.0
      	2024-01-02 18:12:06.338	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      node-red.0
      	2024-01-02 18:11:46.197	warn	2 Jan 18:11:46 - [warn] Projects disabled : editorTheme.projects.enabled=false
      node-red.0
      	2024-01-02 18:11:43.420	info	Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0
      	2024-01-02 18:11:38.418	info	node-red exited with 6
      node-red.0
      	2024-01-02 18:11:37.898	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      node-red.0
      	2024-01-02 18:11:37.898	info	terminating
      node-red.0
      	2024-01-02 18:11:37.394	error	Exception-Code: EFATAL: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
      auch geht das Fenster nicht auf wenn ich links auf Node Red klicke.
      ![0_1704227040614_f7f13574-d897-4388-9214-3fafe2a2bbf4-image.png](Uploading 100%)
      Fred Freund 1 Reply Last reply Reply Quote 0
      • Fred Freund
        Fred Freund @Fred Freund last edited by Fred Freund
        Duerfte sich erledigt haben ...glaube mein DNS war ueberlasted , bitte loeschen das Topic
