    4. gelöst: node.js macht Probleme
      Karacho last edited by Karacho
      beim Update von node.js ist was schief gelaufen...
      instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Caught by controller[1]: Node.js v18.19.0
      Caught by controller[1]: at node:internal/main/run_main_module:28:49
      Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      Caught by controller[1]: ^
      Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
      Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      Caught by controller[0]: /bin/sh: 1: npm: not found
      iob diag
      sagt:
                              v.2023-10-10
       Static hostname: iobroker20
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Userland:               arm64
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
      /home/iobroker/.diag.sh: line 488: npm: command not found
      /home/iobroker/.diag.sh: line 489: npx: command not found
      /home/iobroker/.diag.sh: line 490: corepack: command not found
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            4.0G        2.5G        993M         16K        511M        1.4G
      Swap:           104M         33M         71M
      Total:          4.1G        2.6G        1.1G
      Active iob-Instances:   32
      ioBroker Core:          js-controller           5.0.16
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker20                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : iobroker20                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                16191
      States:                 14127
      Size of iob-Database:
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      11M     /opt/iobroker/iobroker-data/states.jsonl
      Eduard77 1 Reply Last reply Reply Quote 0
      • Eduard77
        Eduard77 @Karacho last edited by
        @karacho sagte in node.js macht Probleme:
        Guten Morgen,
        https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
