    4. [gelöst] Logitech Harmony-Adapter
      Kueppert last edited by
      Hallo in die Runde der Wissenden,
      wollte jetzt mal den Harmony-Adapter ausprobieren, da bei mir der Samsung-Adapter nicht funktioniert (TV wird nicht unterstützt), um eine Fernbedienung in VIS zu basteln…aber scheitere leider bei der Installation vom Harmony-Adapter:
      iobroker	2017-08-09 18:10:19.452	info	exit 13
      iobroker	2017-08-09 18:10:19.421	error	host.raspberrypi3 Cannot install harmony
      iobroker	2017-08-09 18:10:19.419	info	host.raspberrypi3 install adapter harmony
      iobroker	2017-08-09 18:10:19.400	info	npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
      iobroker	2017-08-09 18:10:19.398	info
      iobroker	2017-08-09 18:10:19.206	info	Please check if you have git installed and in your PATH.
      iobroker	2017-08-09 18:10:19.204	info	npm ERR!
      iobroker	2017-08-09 18:10:19.204	info	npm ERR! This is most likely not a problem with npm itself.
      iobroker	2017-08-09 18:10:19.204	info	npm ERR! Failed using git.
      iobroker	2017-08-09 18:10:19.204	info	ERR! not found: gitnpm ERR!
      iobroker	2017-08-09 18:10:19.201	info	npm
      iobroker	2017-08-09 18:10:19.199	info
      iobroker	2017-08-09 18:10:19.193	info	npm ERR! code ENOGIT
      iobroker	2017-08-09 18:10:19.191	info	npm ERR! npm v2.15.11
      iobroker	2017-08-09 18:10:19.191	info	npm ERR! node v4.8.3
      iobroker	2017-08-09 18:10:19.191	info	ERR! Linux 4.9.30-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
      iobroker	2017-08-09 18:10:19.189	info	npm
      iobroker	2017-08-09 18:10:18.832	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
      iobroker	2017-08-09 18:10:18.728	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
      iobroker	2017-08-09 18:10:18.700	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
      iobroker	2017-08-09 18:10:18.700	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      iobroker	2017-08-09 18:10:18.700	info	addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.j
      iobroker	2017-08-09 18:10:18.696	info	WARN
      iobroker	2017-08-09 18:10:18.694	info	npm
      iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
      iobroker	2017-08-09 18:10:18.694	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      iobroker	2017-08-09 18:10:18.688	info	npm WARN addRemoteGit Error: not found: git
      iobroker	2017-08-09 18:10:17.818	info	WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
      iobroker	2017-08-09 18:10:17.815	info	npm
      iobroker	2017-08-09 18:10:13.945	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-08-09 18:10:13.517	info	host.raspberrypi3 install adapter harmony
      iobroker	2017-08-09 18:10:13.501	info	npm ERR! /opt/npm-debug.log
      iobroker	2017-08-09 18:10:13.501	info	npm ERR! Please include the following file with any support request:
      iobroker	2017-08-09 18:10:13.336	info	Please check if you have git installed and in your PATH.
      iobroker	2017-08-09 18:10:13.328	info	ERR! This is most likely not a problem with npm itself.npm ERR!
      iobroker	2017-08-09 18:10:13.325	info	npm
      iobroker	2017-08-09 18:10:13.325	info	npm ERR! Failed using git.
      iobroker	2017-08-09 18:10:13.325	info	not found: gitnpm ERR!
      iobroker	2017-08-09 18:10:13.323	info	npm ERR!
      iobroker	2017-08-09 18:10:13.318	info	npm ERR! code ENOGIT
      iobroker	2017-08-09 18:10:13.318	info	npm ERR! npm v2.15.11
      iobroker	2017-08-09 18:10:13.318	info	npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.3
      iobroker	2017-08-09 18:10:13.314	info	ERR! Linux 4.9.30-v7+
      iobroker	2017-08-09 18:10:13.312	info	npm
      iobroker	2017-08-09 18:10:13.059	info	ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! git
      iobroker	2017-08-09 18:10:13.057	info	npm
      iobroker	2017-08-09 18:10:13.028	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
      iobroker	2017-08-09 18:10:13.028	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      iobroker	2017-08-09 18:10:13.028	info	WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/acc
      iobroker	2017-08-09 18:10:13.023	info	npm
      iobroker	2017-08-09 18:10:13.023	info	WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      iobroker	2017-08-09 18:10:13.018	info	at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm
      iobroker	2017-08-09 18:10:13.016	info	npm WARN addRemoteGit
      iobroker	2017-08-09 18:10:13.016	info	WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
      iobroker	2017-08-09 18:10:13.012	info	npm
      iobroker	2017-08-09 18:10:12.812	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
      iobroker	2017-08-09 18:10:12.081	info	WARN engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
      iobroker	2017-08-09 18:10:12.078	info	npm
      iobroker	2017-08-09 18:10:08.971	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-08-09 18:10:08.503	info	host.raspberrypi3 install adapter harmony
      iobroker	2017-08-09 18:10:08.442	info	npm ERR! /opt/npm-debug.log
      iobroker	2017-08-09 18:10:08.437	info	ERR! Please include the following file with any support request:
      iobroker	2017-08-09 18:10:08.435	info	npm
      iobroker	2017-08-09 18:10:08.434	info
      iobroker	2017-08-09 18:10:08.255	info	npm ERR! Please check if you have git installed and in your PATH.
      iobroker	2017-08-09 18:10:08.255	info	npm ERR! This is most likely not a problem with npm itself.
      iobroker	2017-08-09 18:10:08.255	info	npm ERR! Failed using git.
      iobroker	2017-08-09 18:10:08.255	info	npm ERR! not found: git
      iobroker	2017-08-09 18:10:08.242	info	npm ERR! npm v2.15.11npm ERR! code ENOGIT
      iobroker	2017-08-09 18:10:08.239	info	npm ERR! node v4.8.3
      iobroker	2017-08-09 18:10:08.239	info	npm ERR! Linux 4.9.30-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
      iobroker	2017-08-09 18:10:07.810	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128: undefinednpm ERR! g
      iobroker	2017-08-09 18:10:07.721	info	npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
      iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/https-github-com-swissmanu-ltx-git-634cc128 because of error: { [Error: no
      iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
      iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      iobroker	2017-08-09 18:10:07.684	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      iobroker	2017-08-09 18:10:07.684	info	WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
      iobroker	2017-08-09 18:10:07.673	info	npm
      iobroker	2017-08-09 18:10:07.673	info	npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
      iobroker	2017-08-09 18:10:07.670	info	npm WARN addRemoteGit Error: not found: git
      iobroker	2017-08-09 18:10:06.808	info	engine harmonyhubjs-client@1.1.10: wanted: {"npm":">=3.0.0"} (current: {"node":"4.8.3","npm":"2.15.11"})
      iobroker	2017-08-09 18:10:06.804	info	WARN
      iobroker	2017-08-09 18:10:06.800	info	npm
      iobroker	2017-08-09 18:10:02.694	info	npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
      iobroker	2017-08-09 18:10:00.530	info	add harmony
      Sehr schade…habe js-controller 1.1.2 installiert.
      Hat jemand eine Idee, ob und wenn ja, wie ich den Adapter installiert bekomme?
      Alternative wäre: Adapter geht halt nicht dann baue deine Fernbedienung für TV, Verstärker usw. mit...???
      Danke euch und Grüße, Thorsten
      • eric2905
        eric2905 last edited by
        In der 7. oder 8. Zeile von unten steht „Not found: git“.
        Installiere das mal in der Konsole mit „apt-get install git“ nach (sofern Du einen Pi oder Linux-Maschine als Basis hast) - falls Du Dich nicht als Root anmeldest, setze noch ein „sudo“ davor.
        Gruß,
        Eric
        Von unterwegs getippert
          Hey Eric,
          hab einen Pi3 mit Jessy Lite. Mit deinem Befehl hat es geklappt, danke 🙂
          PS: bin immer als root unterwegs 😉
          Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
          81.0k
