    4. error Caught by controller[1] nach apt full-upgrade [gelöst]
      reutli last edited by reutli
      Hallo Leute,
      habe soeben meine Systeme (Master und zwei Slaves) per apt update und apt full-upgrade auf Vordermann gebracht und habe jetzt unangenehme Fehler im Log:
      host.iobroker-master
      	2024-01-07 10:10:09.396	info	Restart adapter system.adapter.info.0 because enabled
      	2024-01-07 10:10:09.396	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: Node.js v18.19.0
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: ^
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
      	2024-01-07 10:10:09.396	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      	2024-01-07 10:10:09.396	error	Caught by controller[0]: /bin/sh: 1: npm: not foun
      Hier mal die Daten des Masters aus diag Sicht. Wenn ich das korrekt verstehe, hat's mir bei NodeJS was verhagelt???
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker-master
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-17-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name	: QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       10:11:35 up 17 min,  2 users,  load average: 0.36, 0.52, 0.54
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2024-01-07 10:11:35 CET
                 Universal time: Sun 2024-01-07 09:11:35 UTC
                       RTC time: Sun 2024-01-07 09:11:36
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      admin
      /home/admin
      admin sudo users iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            6.2G        3.5G        2.4G        524K        632M        2.7G
      Swap:           1.0G          0B        1.0G
      Total:          7.2G        3.5G        3.4G
               5924 M total memory
               3315 M used memory
                265 M active memory
               3045 M inactive memory
               2264 M free memory
                 70 M buffer memory
                532 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  2.9G     0  2.9G   0% /dev
      tmpfs          tmpfs     593M  512K  592M   1% /run
      /dev/sda1      ext4       97G  4.7G   88G   6% /
      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     593M     0  593M   0% /run/user/1001
      [Sun Jan  7 09:53:38 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Jan  7 09:53:38 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      576M	/var/
      268M	/var/cache
      260M	/var/cache/apt
      184M	/var/cache/apt/archives
      171M	/var/lib
      Archived and active journals take up 33.9M in the file system.
      /opt/iobroker/backups:
      1.3M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      403M	/opt/iobroker/iobroker-data/
      254M	/opt/iobroker/iobroker-data/files
      97M	/opt/iobroker/iobroker-data/backup-objects
      67M	/opt/iobroker/iobroker-data/files/javascript.admin
      48M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      33M	/opt/iobroker/iobroker-data/objects.jsonl
      33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      20M	/opt/iobroker/iobroker-data/states.jsonl
      18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.0
      /usr/bin/node 		v18.19.0
      /home/iobroker/.diag.sh: line 279: npm: command not found
      /home/iobroker/.diag.sh: line 280: npx: command not found
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      /home/iobroker/.diag.sh: line 290: npm: command not found
      /home/iobroker/.diag.sh: line 291: npx: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      /home/iobroker/.diag.sh: line 360: npm: command not found
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.17
      admin: 		6.12.0
      javascript: 	7.1.6
      /home/iobroker/.diag.sh: line 375: npm: command not found
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                  : admin                 : iobroker-master                          -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker-master                          -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker-master                          -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker-master                          -  enabled
        system.adapter.backitup.2               : backitup              : iobroker2                                - disabled
        system.adapter.backitup.3               : backitup              : iobroker                                 - disabled
      + system.adapter.cloud.0                  : cloud                 : iobroker-master                          -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker-master                          -  enabled
        system.adapter.devices.0                : devices               : iobroker-master                          -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-master                          -  enabled
      + system.adapter.ds18b20.1                : ds18b20               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker-master                          -  enabled
      + system.adapter.email.1                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
        system.adapter.flot.0                   : flot                  : iobroker-master                          -  enabled
      + system.adapter.followthesun.0           : followthesun          : iobroker-master                          -  enabled
      + system.adapter.fronius.0                : fronius               : iobroker-master                          -  enabled
      + system.adapter.history.0                : history               : iobroker-master                          -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker-master                          -  enabled
        system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-master                          -  enabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker-master                          -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker-master                          -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker-master                          -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : iobroker-master                          -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-master                          -  enabled, port: 1887, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker-master                          -  enabled
      + system.adapter.panasonic-viera.0        : panasonic-viera       : iobroker-master                          -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker-master                          -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker-master                          -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker-master                          -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker-master                          -  enabled, port: 8087, bind: 192.168.200.5, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : iobroker-master                          -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker-master                          -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : iobroker-master                          -  enabled, port: 5001
      + system.adapter.telegram.0               : telegram              : iobroker-master                          -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker-master                          -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
      + system.adapter.text2command.0           : text2command          : iobroker-master                          -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-master                          -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker-master                          -  enabled
      + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : iobroker-master                          -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker2                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_74290f152e86ec11b5c6641719c2d21c-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "email"        : 1.2.1    , installed 1.2.1
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "scenes"       : 2.3.9    , installed 2.3.3  [Updatable]
      Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects: 	15902
      States: 	13503
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       29438      2266/iobroker.js-co
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       30836      2266/iobroker.js-co
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1002       32405      2798/io.jarvis.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15082      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17090      542/sshd: /usr/sbin
      tcp        0      0 192.168.200.5:2001      0.0.0.0:*               LISTEN      1002       31086      2451/io.hm-rpc.0
      tcp        0      0 192.168.200.5:2010      0.0.0.0:*               LISTEN      1002       29688      2466/io.hm-rpc.1
      tcp        0      0 192.168.200.5:8701      0.0.0.0:*               LISTEN      1002       28530      2481/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       31205      2571/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       28625      2556/io.shelly.1
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1002       31825      2511/io.mqtt.0
      tcp        0      0 0.0.0.0:59169           0.0.0.0:*               LISTEN      103        21431      955/rpc.statd
      tcp        0      0 192.168.200.5:8087      0.0.0.0:*               LISTEN      1002       33386      2859/io.simple-api.
      tcp6       0      0 :::53341                :::*                    LISTEN      103        21435      955/rpc.statd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15083      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17092      542/sshd: /usr/sbin
      tcp6       0      0 :::8090                 :::*                    LISTEN      1002       34847      2897/io.terminal.0
      tcp6       0      0 :::8089                 :::*                    LISTEN      1002       30911      2300/io.admin.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       32666      2942/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       30879      2284/io.admin.0
      tcp6       0      0 :::36691                :::*                    LISTEN      1002       34928      2957/io.yahka.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15359      388/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          461        1/init
      udp        0      0 0.0.0.0:49713           0.0.0.0:*                           103        21429      955/rpc.statd
      udp        0      0 127.0.0.1:707           0.0.0.0:*                           0          21425      955/rpc.statd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       34929      2957/io.yahka.0
      udp        0      0 192.168.200.5:5353      0.0.0.0:*                           1002       33816      2601/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1002       31866      2541/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1002       32978      2616/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1002       32979      2616/io.tuya.0
      udp6       0      0 :::44779                :::*                                103        21433      955/rpc.statd
      udp6       0      0 :::111                  :::*                                0          12720      1/init
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2024-01-07 10:11:10.439  - error: host.iobroker-master Caught by controller[0]: Node.js v18.19.0
      2024-01-07 10:11:10.439  - error: host.iobroker-master instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-07 10:11:10.439  - info: host.iobroker-master Restart adapter system.adapter.info.0 because enabled
      2024-01-07 10:11:40.510  - info: host.iobroker-master instance system.adapter.info.0 started with pid 3251
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[0]: /bin/sh: 1: npm: not found
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: 		adapter.log.error("Could not check npm version: " + e);
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: 		        ^
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-07 10:11:40.929  - error: host.iobroker-master Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-07 10:11:40.930  - error: host.iobroker-master Caught by controller[1]:     at node:internal/main/run_main_module:28:49
      2024-01-07 10:11:40.930  - error: host.iobroker-master Caught by controller[1]: Node.js v18.19.0
      2024-01-07 10:11:40.930  - error: host.iobroker-master instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-07 10:11:40.930  - info: host.iobroker-master Restart adapter system.adapter.info.0 because enabled
      Thomas Braun R Homoran 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @reutli last edited by
        @reutli
        Schau in die Ankündigungen. Dein Problem ist da festgetackert. Du hast die dfsg-Version am Wickel.
          reutli @reutli last edited by
          Im debug gibt's leider auch nicht mehr:
          	2024-01-07 10:34:03.709	error	instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: Node.js v18.19.0
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at node:internal/main/run_main_module:28:49
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._load (node:internal/modules/cjs/loader:1013:12)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1197:32)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: ^
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
          	2024-01-07 10:34:03.709	error	Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
          	2024-01-07 10:34:03.709	error	Caught by controller[0]: /bin/sh: 1: npm: not found
          @Thomas-Braun : Habe mal im Forum gesucht aber nichts gefunden, was darauf hinweist.
          passt nicht zu
          admin@iobroker-master:~$ nodejs -v
          v18.19.0
            reutli @Thomas Braun last edited by
            Mist, danke. Ich schau.
              @reutli
              https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                Homoran Global Moderator Administrators @reutli last edited by
                @reutli sagte in error Caught by controller[1] nach apt full-upgrade:
                @Thomas-Braun war schneller
                  reutli @Homoran last edited by
                  @homoran & @Thomas-Braun
                  Danke, hat geklappt!
