    4. Logfile läuft voll mit TimeoutoverflowWarning etc.
      JoergH last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4.
      Arbeitsspeicher: 32GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Nodejs-Version: 18.19.0
      NPM-Version: 10.2.3
      Bei mir läuft das Logfile zu mit folgenden Meldungen:
      Jan 07 17:41:30 raspberrypi bash[1652]: (node:2009) TimeoutOverflowWarning: 3600000000 does not fit into a 32-bit signed integer.
      Jan 07 17:41:30 raspberrypi bash[1652]: Timeout duration was set to 1.
      Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2d99b-ad7b-11ee-9b10-dca632f1625f 112496
      Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd3090e-ad7b-11ee-9b16-dca632f1625f 111350
      Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd30d89-ad7b-11ee-9b17-dca632f1625f 111299
      Jan 07 17:41:30 raspberrypi influxd-systemd-start.sh[861]: [httpd] 192.168.178.55 - admin [07/Jan/2024:17:41:30 +0100] "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=admin HTTP/1.1 " 204 0 "-" "-" 9bd2e778-ad7b-11ee-9b12-dca632f1625f 112315
      Woran kann das liegen?
      Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @JoergH last edited by Thomas Braun
        @joergh
        Zeig uns mal wie du da unterwegs bist:
        iob diag
        in der Langfassung bitte.
        Und
        sudo apt update
        apt policy influxdb*
          JoergH @Thomas Braun last edited by
          Hi Thomas. Wie gewünscht...
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           18:03:35 up  1:46,  1 user,  load average: 4.97, 5.04, 5.26
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-01-07 18:03:36 CET
                     Universal time: Sun 2024-01-07 17:03:36 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        3.3G        211M        1.0M        4.3G        4.5G
          Swap:            99M          0B         99M
          Total:          7.9G        3.3G        311M
                   7811 M total memory
                   3316 M used memory
                   6908 M active memory
                    403 M inactive memory
                    211 M free memory
                     42 M buffer memory
                   4240 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      118G   15G   99G  13% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Sun Jan  7 16:16:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:F1:62:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  usb-storage.quirk=152d:0579:u console=ttyS0,115200 console=tty1 root=PARTUUID=622a00f4-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Jan  7 16:16:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Jan  7 16:16:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sun Jan  7 16:16:59 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
          9.5G    /var/
          5.7G    /var/log
          4.2G    /var/log/journal/ebf43f1ac9ac40f88ddf4138fee55e47
          1.9G    /var/lib
          Archived and active journals take up 4.1G in the file system.
          /opt/iobroker/backups:
          333M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          441M    /opt/iobroker/iobroker-data/
          301M    /opt/iobroker/iobroker-data/files
          102M    /opt/iobroker/iobroker-data/backup-objects
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          19M     /opt/iobroker/iobroker-data/states.jsonl
          18M     /opt/iobroker/iobroker-data/objects.jsonl
          8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
          npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
          npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
          npm ERR! extraneous: homebridge-plugin-wrapper@3.2.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
          npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
          npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
          npm ERR! extraneous: q@1.1.2 /opt/iobroker/node_modules/q
          npm ERR! extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
          npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
          npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/debug
          npm ERR! extraneous: fs-extra@10.1.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/fs-extra
          npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/ms
          npm ERR! extraneous: tslib@2.5.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper/node_modules/tslib
          npm ERR! missing: cheerio@^1.0.0-rc.12, required by iobroker.javascript@7.1.6
          npm ERR! missing: puppeteer@^21.6.1, required by iobroker.javascript@7.1.6
          npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/mock-require/node_modules/get-caller-file
          npm ERR! extraneous: normalize-path@2.1.1 /opt/iobroker/node_modules/mock-require/node_modules/normalize-path
          npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/node-persist/node_modules/mkdirp
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-07T17_04_20_177Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   4
          Adapter State
            system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
          + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
          + system.adapter.ham.0                    : ham                   : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
          + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
          + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
            system.adapter.odl.0                    : odl                   : raspberrypi                              -  enabled
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
            system.adapter.powerfox2.0              : powerfox2             : raspberrypi                              -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
          + system.adapter.renault.0                : renault               : raspberrypi                              -  enabled
          + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
            system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              -  enabled
            system.adapter.solarmanpv.0             : solarmanpv            : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          List is empty
          Installed ioBroker-Instances
          Error: Object "system.repositories" not found
          Objects and States
          Objects:        27182
          States:         22818
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1906       967/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       40806      2549/io.sonoff.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       37985      2426/io.mqtt.0
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      111        15567      861/influxd
          tcp        0      0 192.168.178.55:2010     0.0.0.0:*               LISTEN      1001       42033      2510/io.hm-rpc.1
          tcp        0      0 192.168.178.55:2001     0.0.0.0:*               LISTEN      1001       32118      2221/io.hm-rpc.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15946      1652/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15029      1652/iobroker.js-co
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15521      952/dnsmasq
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1908       967/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        16893      1651/grafana
          tcp6       0      0 :::8086                 :::*                    LISTEN      111        14917      861/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       93089      3023/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16064      1862/io.admin.0
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15520      952/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15517      952/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15378      630/dhclient
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       47467      2568/io.mihome-vacu
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       46609      2581/io.mihome-vacu
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       34486      2132/io.ham.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3671       425/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       54901      2502/io.shelly.0
          udp        0      0 0.0.0.0:51826           0.0.0.0:*                           0          14535      -
          udp        0      0 0.0.0.0:44435           0.0.0.0:*                           108        3673       425/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        3672       425/avahi-daemon: r
          udp6       0      0 :::38694                :::*                                108        3674       425/avahi-daemon: r
          udp6       0      0 :::51826                :::*                                0          14536      -
          2024-01-07 18:07:28.195  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Speichertemperatur: 46.7 - Temperaturdifferenz Speicher - RL ( >25 Grad ? ): 16.500000000000004
          2024-01-07 18:07:28.196  - info: javascript.0 (2077) script.js.Heizung.Zirkulationspumpe_Bedarf: Zirkulation ist AUS - Temperaturdifferenz Vorlauf - Vorlauf ALT ( >0.1 Grad ?): 0 Zeit seit Ausschalten ( >900000 ) in ms: 2728664
          2024-01-07 18:07:28.230  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.4911666666667
          2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
          2024-01-07 18:07:28.232  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
          2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
          2024-01-07 18:07:28.233  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
          2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
          2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
          2024-01-07 18:07:28.234  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
          2024-01-07 18:07:30.006  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Zeit seit Anstecken an go-e charger: 1408.5207666666668
          2024-01-07 18:07:30.011  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom GO-E: 0 A
          2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA: 0 A
          2024-01-07 18:07:30.012  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Ladestrom TESLA FINAL: 0 A
          2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Überschuss brutto / netto: -12 / -12
          2024-01-07 18:07:30.013  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt go-e: 0 - Restzeit go-e: 00:00
          2024-01-07 18:07:30.014  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Gemittelt TESLA: 0
          2024-01-07 18:07:30.016  - info: javascript.0 (2077) script.js.Energiemanagement.PV_Laden_neu: Restzeit TESLA: 11:04
          2024-01-07 18:07:33.878  - info: host.raspberrypi instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
          2024-01-07 18:07:34.591  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
          2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
          2024-01-07 18:07:34.593  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
          2024-01-07 18:07:34.651  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_go-e" has to be stringified but received type "object"
          2024-01-07 18:07:34.652  - info: javascript.0 (2077) State value to set for "0_userdata.0.Energiedaten.Stromwerte_Tesla" has to be stringified but received type "object"
          und
          pi@raspberrypi://var/log $ sudo apt update
          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
          OK:2 http://deb.debian.org/debian bullseye InRelease
          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
          OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
          OK:5 https://apt.grafana.com stable InRelease
          OK:6 https://apt.pivccu.de/piVCCU stable InRelease
          OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut… Fertig
          Statusinformationen werden eingelesen… Fertig
          Alle Pakete sind aktuell.
          pi@raspberrypi://var/log $ apt policy influxdb
          influxdb:
            Installiert:           1.8.10-1
            Installationskandidat: 1.8.10-1
            Versionstabelle:
           *** 1.8.10-1 100
               1.6.7~rc0-1+b5 500
          Thomas Braun 4 Replies Last reply Reply Quote 0
            @joergh sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
            Ist verdammt hoch und dein influxdb hängt da irgendwie ohne Anbindung an ein Repo herum. Wie hast du das installiert?
              Was ist da los? LXC auf einem Raspberry?
                Was ist da kaputt?
                  Ich meine, dass ich das so installiert habe:
                  wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                  source /etc/os-release
                  echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                  sudo apt-get update
                  sudo apt-get install influxdb
                  Ist lange her....
                    List is empty
                    Hier stimmt auch was nicht. Keine Repos angelegt?
                      Da sollte eigentlich nichts kaputt sein. Ich habe mal probiert eine Webseite zu parsen mit einem Javascript...funktionierte aber nicht wie gewünscht und ich habe das dann aufgegeben. Die Skripte sind nicht aktiv, die das genutzt haben.
                        Verstehe nicht von was Du redest, tut mir leid. Was muss ich denn für Repos anlegen?
                          @thomas-braun Was ist LXC?
                            @joergh
                            Ein Containerformat. Könnte aber vom pivCCU kommen.
                            Aber warum ist dein LoginPrompt so merkwürdig?
                            Das sollte ohne // da stehen. So wie hier:
                            echad@chet:~ $ cd /var/log/
                            echad@chet:/var/log $
                              @joergh
                              Da sind so viele Ungereimheiten auf dem System... Keine Ahnung was du da wie und warum wann gemacht hast...
                              Wird das LogFile z. B. dauerhaft im Millisekundentakt zugekleistert?
                                @thomas-braun sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                                @joergh
                                Gute Frage. Wissentlich habe ich nichts geändert, wüsste auch nicht wie...
                                  @joergh
                                  Ja, das geht ständig weiter...
                                  Nach einem cd /var/log ist der zweite Backslash nun weg....
                                    Auf dem System ist eigentlich sogar ziemlich viel 'kaputt'.
                                    • Marc Berg
                                      Marc Berg Most Active @JoergH last edited by Marc Berg
                                      Du hast mit ziemlicher Sicherheit einen zu großen Zeitwert in den InfluxDB Adapter Einstellungen eingetragen. Das wird da nicht verhindert. Zeig mal die Instanzeinstellungen (DB).
                                        Tja, Linux halt. Durch normales Installieren geht anscheinend irgendwann alles kaputt....
                                          JoergH @Marc Berg last edited by
                                          @marc-berg sagte in Logfile läuft voll mit TimeoutoverflowWarning etc.:
                                          Welchen Wert meinst Du? Schreibintervall?
                                            @joergh
                                            Tja, Ahnungslosigkeit halt... Es ist ja eben nicht vom Admin (dir?) ordentlich installiert.
                                            4667
