    5. javascript - Error install "basic-ftp"
    • bahnuhr
      wenn ich in der Instanz "basic-ftp" hinzufüge
      kommt im log:
      javascript.0
      2024-01-08 17:25:23.790	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.0
      2024-01-08 17:25:23.789	error	npm WARN
      javascript.0
      2024-01-08 17:25:23.714	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.0
      2024-01-08 17:25:23.713	error	npm
      javascript.0
      2024-01-08 17:25:23.640	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      javascript.0
      2024-01-08 17:25:23.640	error	npm
      javascript.0
      2024-01-08 17:25:23.537	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
      javascript.0
      2024-01-08 17:25:23.536	error	npm
      Ich lese das so, dass dieses modul Teil von node.js ist und nicht extra installiert werden muss.
      Nehme ich dies wieder raus, kam eben im log:
      javascript.0
      2024-01-08 17:18:44.078	error	at script.js.Scripte.System.Sicherung_iob_Dateien_loeschen:53:3
      javascript.0
      2024-01-08 17:18:44.078	error	at script.js.Scripte.System.Sicherung_iob_Dateien_loeschen:3:17
      javascript.0
      2024-01-08 17:18:44.078	error	at require (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:528:32)
      javascript.0
      2024-01-08 17:18:44.078	error	at require (node:internal/modules/cjs/helpers:119:18)
      javascript.0
      2024-01-08 17:18:44.078	error	at Module.require (node:internal/modules/cjs/loader:1143:19)
      javascript.0
      2024-01-08 17:18:44.078	error	script.js.Scripte.System.Sicherung_iob_Dateien_loeschen: Error: Cannot find module 'basic-ftp'
      javascript.0
      2024-01-08 17:18:44.069	error	at Script.runInContext (node:vm:135:12)
      Dies habe ich nun nochmal probiert.
      Jetzt kam der Fehler "cannot find module "basic-ftp" nicht mehr.
      Komisch.
      Warum kam der Fehler "cannot find" und dann kommt kein Fehler mehr.
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      • bahnuhr
        Und warum wird mir jetzt dieses request issue angehängt ?
          @bahnuhr sagte in javascript - Error install "basic-ftp":
          steht halt im code
          • bahnuhr
            bahnuhr Forum Testing Most Active @Homoran last edited by
            @homoran sagte in javascript - Error install "basic-ftp":
            steht halt im code
            ok, verstehe
            • bahnuhr
              Nachtrag:
              Wenn ich das Script ausführe, wo dies enthalten ist:
              rot unterstrichen; wenn man drüber fährt dann kommt auch "cannot find module"
              Aber !
              Es läuft einwandfrei.
              • Glasfaser
                Glasfaser @bahnuhr last edited by
                @bahnuhr
                die obere Meldung ist Werbung 🙂 im Sinne ...
                zb. har-validator usw ....
                https://forum.iobroker.net/post/1108222
                javascript
