Installation Docker Image auf Synology 920+
ich habe mir das "latest-v9" Image runter geladen und den Container gestartet. Danach habe ich im Web-Portal Port 8081 auf Port 8081 von diesem Container gemapped. Wenn ich Port 8081 auf dem NAS aufrufe bekomme ich allerdings nur das ioBroker Logo in dem ein Virtel blau rotiert.
In der Browser Konsole sehe ich jede Menge Websocket Verbindungsfehler.socket.io.js:67 [2024-01-09T07:00:18.133Z] No READY flag received in 3 seconds. Re-init (anonym) @ instrument.ts:144 warn @ socket.io.js:67 (anonym) @ socket.io.js:148 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 socket.onerror @ socket.io.js:189 error (async) SocketClient.connect @ socket.io.js:182 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 12 weitere Frames anzeigen Weniger anzeigen socket.io.js:396 WebSocket connection to 'ws://192.168.101.6:8081/?sid=1704783615128&name=admin' failed: WebSocket is closed before the connection is established. SocketClient.close @ socket.io.js:396 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 socket.onerror @ socket.io.js:189 error (async) SocketClient.connect @ socket.io.js:182 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient.connect @ socket.io.js:146 (anonym) @ socket.io.js:428 o @ helpers.ts:98 setTimeout (async) (anonym) @ trycatch.ts:122 SocketClient._reconnect @ socket.io.js:423 SocketClient.close @ socket.io.js:410 (anonym) @ socket.io.js:149 o @ helpers.ts:98 11 weitere Frames anzeigen Weniger anzeigen socket.io.js:66 [2024-01-09T07:00:18.142Z] Start reconnect 5 socket.io.js:66 [2024-01-09T07:00:18.142Z] Reconnect is already running 5 socket.io.js:68 [2024-01-09T07:00:18.142Z] ws connection error: CLOSE_ABNORMAL (anonym) @ instrument.ts:144 error @ socket.io.js:68 socket.onclose @ socket.io.js:177 1 weiteren Frame anzeigen Weniger anzeigen socket.io.js:66 [2024-01-09T07:00:18.142Z] Reconnect is already running 5 socket.io.js:66 [2024-01-09T07:00:23.145Z] Try to connectHat jemand einen Tip für mich?
Viele Grüße
Michael
Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
Hier gehts zur Hilfe. -
@leahcim
Ich frag' mal ganz blöd:
Du betreibst den Container im Bridge-Mode? Die benötigten Ports hast Du in den Container weitergereicht? -
@leahcim sagte in Installation Docker Image auf Synology 920+:
Wenn du das Web-Portal aktivierst, dann schaltet die Synology einen Reverse-Proxy vor den ioBroker, der mit Websockets im Standard nicht klar kommt.
Also Web-Portal deaktivieren, diese Einstellungen wieder löschen, und nur das Port-Mapping (unter Port-Einstellungen) machen. -
@marc-berg super, danke.
