    4. BackitUp Problem ( Rechte? )
    • N
      nettworker last edited by nettworker
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Proxmox VM
      Arbeitsspeicher: 8GB
      Festplattenart: HDD virtuell
      Betriebssystem: Debian 12.4.0
      Node-Version:
      Nodejs-Version: 18.19.x
      NPM-Version: 10.2.3
      Installationsart: Skript
      Beim Backup gibts Fehler, hier die Debug Ausgabe ( Auszug 😞
      ...[DEBUG] [iobroker] - host.iobroker 7707 states saved
      [DEBUG] [iobroker] - host.iobroker 8864 objects saved
      [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-10_33_05_backupiobroker.tar.gz'
      [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-10_33_05_backupiobroker.tar.gz'
      [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-10_33_05_backupiobroker.tar.gz'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'open',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
      [ERROR] [iobroker] - [Error: ENOENT: no such file or directory, scandir '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'] {
        errno: -2,
        code: 'ENOENT',
        syscall: 'scandir',
        path: '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/zigbee_0'
      [DEBUG] [iobroker] - done
      [DEBUG] [zigbee] - found zigbee database: zigbee.0 ......
      iob fix hab ich drüber laufen lassen, Fehler bleibt bestehen.
      Hier mal die Übersicht falls es hilft.
      dieter@iobroker:/opt$ ls -la
      insgesamt 12
      drwxr-xr-x   3 root     root     4096  8. Jan 18:15 .
      drwxr-xr-x  18 root     root     4096  8. Jan 17:20 ..
      drwxrwxr-x+  6 iobroker iobroker 4096 10. Jan 10:31 iobroker
      dieter@iobroker:/opt$ cd iobroker/
      dieter@iobroker:/opt/iobroker$ ls -la
      insgesamt 636
      drwxrwxr-x+   6 iobroker iobroker   4096 10. Jan 10:31 .
      drwxr-xr-x    3 root     root       4096  8. Jan 18:15 ..
      drwxrwxr-x+   2 iobroker iobroker   4096  8. Jan 18:17 backups
      -rwxrwxrwx+   1 iobroker iobroker    237 10. Jan 10:31 INSTALLER_INFO.txt
      lrwxrwxrwx    1 iobroker iobroker     22 10. Jan 10:31 iob -> /opt/iobroker/iobroker
      -rwxr-xr-x+   1 iobroker iobroker    701 10. Jan 10:31 iobroker
      drwxrwxr-x+   8 iobroker iobroker   4096 10. Jan 10:31 iobroker-data
      drwxrwxr-x+   2 iobroker iobroker   4096 10. Jan 10:32 log
      drwxrwxr-x+ 826 iobroker iobroker  32768  8. Jan 21:04 node_modules
      -rw-rwxr--+   1 iobroker iobroker    155 10. Jan 10:31 .npmrc
      -rw-rwxr--+   1 iobroker iobroker    920  8. Jan 21:04 package.json
      -rw-rwxr--+   1 iobroker iobroker 574487  8. Jan 21:04 package-lock.json
      dieter@iobroker:/opt/iobroker$ cd backups/
      dieter@iobroker:/opt/iobroker/backups$ ls -la
      insgesamt 8
      drwxrwxr-x+ 2 iobroker iobroker 4096  8. Jan 18:17 .
      drwxrwxr-x+ 6 iobroker iobroker 4096 10. Jan 10:31 ..
        Thomas Braun Most Active @nettworker last edited by
        @nettworker
        Wird da eine Freigabe gemountet?
        • N
          nettworker @Thomas Braun last edited by
          Ja, es soll auf einen NFS Freigabe geschrieben werden.
          Laut Debug wird die Verbindung aber erfolgreich hergestellt.
          hier die Protokollausgabe bei den Logs:
            Homoran Global Moderator Administrators @nettworker last edited by Homoran
            @nettworker sagte in BackitUp Problem ( Rechte? ):
            Bitte als Text in code-tags posten!
            EDIT:
            da scheint auch der mountversuch zu fehlen, wenn ich das richtig entziffern kann.
            Also größeren Ausschnitt bitte
              Bitte in Textform und in richtiger zeitlicher Reihenfolge.
              • N
                Started iobroker ...
                [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false}
                [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.3.244:/mnt/share/iobroker /opt/iobroker/backups"
                [DEBUG] [mount] - mount successfully completed
                [DEBUG] [mount] - done
                [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                [DEBUG] [iobroker] - host.iobroker 7693 states saved
                [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
                [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
                [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz'
                  errno: -2,
                  code: 'ENOENT',
                  syscall: 'open',
                  errno: -2,
                  code: 'ENOENT',
                  syscall: 'scandir',
                  errno: -2,
                  code: 'ENOENT',
                  syscall: 'scandir',
                [DEBUG] [zigbee] - done
                [ERROR] [zigbee] - Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'
                [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" cannot created ... Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/tmpScripts'
                [ERROR] [javascripts] - script.json cannot be written: Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
                [DEBUG] [javascripts] - found Script: Ausschalttemperatur_aendern
                [DEBUG] [javascripts] - found Script: Einschalttemperatur_aendern
                [DEBUG] [javascripts] - found Script: Frostalarm_Huette
                [DEBUG] [javascripts] - found Script: Skript_1
                [DEBUG] [javascripts] - found Script: Aquara_Doppelschalter_WZ
                [DEBUG] [javascripts] - found Script: Bewegungssensor_Flur
                [DEBUG] [javascripts] - found Script: Rollaeden
                [DEBUG] [javascripts] - found Script: Taster_Rollaeden
                [DEBUG] [javascripts] - found Script: Energie_Verwerten
                [DEBUG] [javascripts] - found Script: Solarwerte_addieren
                [DEBUG] [javascripts] - found Script: Strom_verbrennen
                [DEBUG] [javascripts] - found Script: Tagesdaten_speichern
                [DEBUG] [javascripts] - found Script: Verbrauchsdaten_sichern
                [DEBUG] [javascripts] - found Script: Werte_addieren
                [DEBUG] [javascripts] - found Script: Abendlichter_Button
                [DEBUG] [javascripts] - found Script: Abendlichter_automatik
                [DEBUG] [javascripts] - found Script: Fernseher_aus
                [DEBUG] [javascripts] - found Script: HP-Server
                [DEBUG] [javascripts] - found Script: Kuehlschraenke_aus
                [DEBUG] [javascripts] - found Script: SystemCheck
                [DEBUG] [javascripts] - found Script: unifi_1
                [DEBUG] [javascripts] - javascript Backup not created
                [DEBUG] [javascripts] - done
                [DEBUG] [cifs] - used copy path: /mnt/share/iobroker
                [DEBUG] [cifs] - done
                [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0}
                [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                [DEBUG] [clean] - done
                [DEBUG] [historyHTML] - new history html values created
                [DEBUG] [historyHTML] - done
                [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_03_31_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:03 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [DEBUG] [historyJSON] - new history json values created
                [DEBUG] [historyJSON] - done
                [DEBUG] [umount] - mount activ, umount is started ...
                [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_03_24_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_03_31_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_03_30_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:03 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                [DEBUG] [umount] - umount successfully completed
                [DEBUG] [umount] - done
                [EXIT] 1
                  @nettworker
                  Zeig mal die Einstellungen aus dem Adapter. Da scheint mir irgendwas durcheinander zu sein.
                    smb":"vers=1.0"
                    Cifs oder nfs???
                    wenn cifs, dann könnte die smb version zu niedrig sein
                    • N
                      nettworker @Homoran last edited by
                      @homoran CFIS war mal, alles umgestellt auf NFS
                        @nettworker
                        Und die Rechte an /mnt/share/iobroker auf dem NFS-Server sehen wie aus?
                        • N
                          dieter@nfs-svr:/mnt/share$ ls -la
                          insgesamt 60
                          drwxrwxrwx 10 root   root     4096  9. Jan 13:15 .
                          drwxr-xr-x  3 root   root     4096  9. Jan 17:01 ..
                          drwxr-xr-x  4 nobody nogroup  4096  7. Jan 18:18 backup
                          drwxr-xr-x  4 nobody nogroup 12288  7. Jan 19:40 dump
                          drwxr-xr-x  2 nobody nogroup  4096  5. Jan 13:39 images
                          drwxr-xr-x  2 nobody nogroup  4096  9. Jan 13:18 iobroker
                          drwx------  2 nobody nogroup 16384  7. Jan 17:34 lost+found
                          drwxr-xr-x  2 nobody nogroup  4096 13. Sep 18:58 private
                          drwxr-xr-x  2 nobody nogroup  4096 13. Sep 18:58 snippets
                          drwxr-xr-x  4 nobody nogroup  4096  7. Jan 17:50 template
                            @nettworker
                            Falsche user/gruppe.
                            Bei NFS werden die auf den Mountpunkt weitergereicht und dann kann der user 'iobroker' da nicht reinschreiben.
                            • N
                              nettworker @Thomas Braun last edited by nettworker
                              also für das Verzeichnis share die Rechte noch ändern?
                              bzw. Eigentümer / Gruppe?
                                Ja, auf die gleiche uid/gid die iobroker:iobroker hat.
                                • N
                                  dieter@nfs-svr:/mnt$ ls -la
                                  insgesamt 12
                                  drwxr-xr-x 18 root   root    4096  9. Jan 16:47 ..
                                  drwxrwxrwx 10 nobody nogroup 4096  9. Jan 13:15 share
                                  [ERROR] [iobroker] - host.iobroker Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                                  [ERROR] [iobroker] - host.iobroker Backup not created: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                                  [DEBUG] [iobroker] - Cannot create backup: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz'
                                    errno: -2,
                                    code: 'ENOENT',
                                    syscall: 'scandir',
                                    errno: -2,
                                    code: 'ENOENT',
                                    syscall: 'open',
                                    errno: -2,
                                    code: 'ENOENT',
                                    syscall: 'scandir',
                                  [ERROR] [zigbee] - Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'
                                  [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                                  [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/iobroker_2024_01_10-11_49_14_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2024_01_10-11_49_21_backupiobroker.tar.gz"],"errors":{"iobroker":"ioBroker Backup not created","zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2024_01_10-11_49_20_backupiobroker.tar.gz'"},"done":["mount","iobroker"],"types":["iobroker"]},"adapter":null,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]},"ignoreErrors":false,"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"path":"/opt/iobroker/iobroker-data","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"signedCertificates":true,"ignoreErrors":false},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.3.244","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=1.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/mnt/share/iobroker","dirMinimal":"sharename/backupDir","user":"dieter","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"slaveSuffix":"","hostType":"Single","nameSuffix":"","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"10. Januar 2024 um 11:49 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
                                  [EXIT] 1
                                    Thomas Braun Most Active @nettworker last edited by Thomas Braun
                                    @nettworker
                                    Du sollst die uid und gid umstellen und nicht die Rechte vermurksen.
                                    • N
                                      GruppenID und UserID hab ich doch angepasst
                                        @nettworker
                                        nobody:nogroup
                                        Ist nicht iobroker:iobroker
                                        • N
                                          auf dem NFS Server gibts keinen User iobroker.
                                            und das ist das Problem
                                            1832
