    4. Installation
    5. Backup IOBroker but cannot find admin.js
      A Former User last edited by
      Hello i restored an old version of my IOBroker installation but the webinterface wont start 😞
        Homoran Global Moderator Administrators @Guest last edited by
        @marvin diese schwarze Briefmarke ist nur sehr schwer zu entziffern,.
        Bitte als Text in code-tags posten!
          @marvin please provide the full output of iob diag
            A Former User @Homoran last edited by
              system.adapter.admin.2                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
            + system.adapter.broadlink2.1             : broadlink2            : raspberrypi                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
            + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
            + system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
              system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
            + system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
              system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
            + system.adapter.tvprogram.0              : tvprogram             : raspberrypi                              -  enabled
              system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
              system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
              system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
              system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
              system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
              system.adapter.web.1                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
              system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
            + instance is alive
            pi@raspberrypi:~ $ node node_modules/iobroker.admin/admin.js --logs
            node:internal/modules/cjs/loader:1137
              throw err;
            Error: Cannot find module '/home/pi/node_modules/iobroker.admin/admin.js'
                at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                at Module._load (node:internal/modules/cjs/loader:975:27)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                at node:internal/main/run_main_module:28:49 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            Node.js v18.19.0
            ? Homoran 2 Replies Last reply Reply Quote 0
              A Former User @Guest last edited by A Former User
              i tried following but i didnt help:
              cd /opt/iobroker
              npm i iobroker.admin --production
              iobroker upload admin
              iobroker restart admin.2
                @marvin thanks!
                don't use the iobroker commands with sudo! never!
                please try iob start admin.2 --debug
                but the full output of iob diag should reveal more infos
                  @homoran said in Backup IOBroker but cannot find admin.js:
                  this is my iob diag output:
                  			v.2023-10-10
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.1.0-rpi7-rpi-v8
                      Architecture: arm64
                  Installation: 		native
                  Kernel: 		aarch64
                  Userland: 		arm64
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  X-Server: 		true
                  Boot Target: 		graphical.target
                  Pending OS-Updates: 	73
                  Pending iob updates: 	28
                  Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                  			/usr/bin/node 		v18.19.0
                  			/usr/bin/npm 		10.2.3
                  			/usr/bin/npx 		10.2.3
                  			/usr/bin/corepack 	0.22.0
                  MEMORY:
                  Mem:            4.0G        2.2G        691M        161M        1.3G        1.8G
                  Swap:           104M        4.2M        100M
                  Total:          4.1G        2.2G        792M
                  Active iob-Instances: 	19
                  Active repo(s): stable
                  ioBroker Core: 		js-controller 		5.0.17
                  			admin 			6.2.20
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		7891
                  States: 		6317
                  Size of iob-Database:
                  16M	/opt/iobroker/iobroker-data/objects.jsonl
                  8.8M	/opt/iobroker/iobroker-data/objects.json.migrated
                  8.8M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                  12M	/opt/iobroker/iobroker-data/states.jsonl
                  5.1M	/opt/iobroker/iobroker-data/states.json.migrated
                  5.1M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                  Homoran DJMarc75 3 Replies Last reply Reply Quote 0
                    @marvin sagte in Backup IOBroker but cannot find admin.js:
                    unfortunately just the summary
                      A Former User @Homoran last edited by A Former User
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                        in combination with
                        leads me to me guess that you restored an old version with controller v4.
                        did you?
                          @homoran i dont know the exact version but not the newest for sure...
                          • DJMarc75
                            DJMarc75 last edited by
                            @Homoran please postpone to english category 😉
                              Homoran Global Moderator Administrators @DJMarc75 last edited by
                              @djmarc75 sagte in Backup IOBroker but cannot find admin.js:
                              there is no beginners forum
                                you cannot restore a backup of v4 in a new installation with controller v5.
                                @thomas-braun tried this at another user
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                iob update
                                iob upgrade all -y
                                I recommend to stop iob first iob stop
                                Good luck!
                                • DJMarc75
                                  DJMarc75 @Guest last edited by
                                  Really ?
                                  X-Server: true
                                  Desktop: LXDE-pi
                                  Terminal: x11
                                  Pending Updates: 73
                                    @homoran thank you so much for your help and time. fixed it 🙂
                                      glad to hear!
                                      but fix also all old stuff!
                                      And what already was said by @DJMarc75 :
                                      a Server will not have an graphical interface!
                                      and do you really live in German time-zone?
                                      • Samson71
                                        Samson71 Global Moderator last edited by Samson71
                                        @Marvin
                                        Deutscher Forumsteil, deutsche IP (bei mir um die Ecke im Norden), warum dann nicht auf Deutsch?
                                        EDIT
                                        So kann man es natürlich auch machen. Anstatt zu reagieren einfach abmelden und wieder verschwinden.
                                        509
