    4. LOG anschauen , ständige Internet ausfälle
      maik5066 last edited by
      Hallo Leute, ich bin neu im Iobroker space, ich habe ständig Adapterprobleme , die Verbindungsprobleme melden, könnt ihr bitte mal meinen LOG ansehen ?
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: ioBroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.15.83-1-pve
            Architecture: x86-64
      model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       08:56:02 up 111 days, 18:13,  1 user,  load average: 0.28, 0.47, 0.39
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Fri 2024-01-12 08:56:02 CET
                 Universal time: Fri 2024-01-12 07:56:02 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: yes
      Warning: The system is configured to read the RTC time in the local time zone.
               This mode cannot be fully supported. It will create various problems
               with time zone changes and daylight saving time adjustments. The RTC
               time is never updated, it relies on external facilities to maintain it.
               If at all possible, use RTC in UTC by calling
               'timedatectl set-local-rtc 0'.
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout audio video
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           8.1G        4.7G        2.1G        0.0K        1.2G        3.3G
      Swap:          4.1G        1.1G        3.0G
      Total:          12G        5.8G        5.2G
               8064 M total memory
               4720 M used memory
               2441 M active memory
               3219 M inactive memory
               2133 M free memory
                  0 M buffer memory
               1210 M swap cache
               4096 M total swap
               1056 M used swap
               3039 M free swap
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * apparmor.service loaded failed failed Load AppArmor profiles
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/loop1     ext4       30G   11G   18G  38% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      udev           devtmpfs   32G     0   32G   0% /dev/fuse
      tmpfs          tmpfs      32G     0   32G   0% /dev/shm
      tmpfs          tmpfs     6.3G  144K  6.3G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
      [Wed Jan 10 21:07:18 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Wed Jan 10 21:07:42 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Wed Jan 10 21:08:34 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Wed Jan 10 21:08:49 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Jan 11 21:07:17 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Jan 11 21:07:42 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Jan 11 21:08:34 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Jan 11 21:08:50 2024] EXT4-fs (loop9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      TARGET                      SOURCE                         FSTYPE     OPTIONS
      /                           /dev/loop1                     ext4       rw,relatime
      |-/proc/cpuinfo             lxcfs[/proc/cpuinfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/diskstats           lxcfs[/proc/diskstats]         fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/loadavg             lxcfs[/proc/loadavg]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/meminfo             lxcfs[/proc/meminfo]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/slabinfo            lxcfs[/proc/slabinfo]          fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/stat                lxcfs[/proc/stat]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/swaps               lxcfs[/proc/swaps]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/proc/uptime              lxcfs[/proc/uptime]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/sys/kernel/debug/tracing tracefs                        tracefs    rw,nosuid,nodev,noexec,relatime
      `-/sys/devices/system/cpu   lxcfs[/sys/devices/system/cpu] fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      2.7G    /var/
      2.1G    /var/log/journal/7caaddd5c28f42b48434096facca95f9
      2.1G    /var/log
      336M    /var/lib
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      497M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      659M    /opt/iobroker/iobroker-data/
      461M    /opt/iobroker/iobroker-data/files
      140M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      find: Failed to change directory: /root: Permission denied
      find: Failed to restore initial working directory: /root: Permission denied
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_be3ff669ce12ec119e5c23c7bd930c07-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           10.19.0~dfsg-3ubuntu1.3 500
              500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
           10.19.0~dfsg-3ubuntu1 500
              500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: simple-ssh@^1.1.1, required by iobroker.javascript@7.1.6
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-12T07_56_03_957Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   7
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
      + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 192.168.0.18, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
      + system.adapter.bydhvs.0                 : bydhvs                : ioBroker                                 -  enabled
        system.adapter.canbus.0                 : canbus                : ioBroker                                 - disabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.ebus.0                   : ebus                  : ioBroker                                 - disabled
        system.adapter.echarts.0                : echarts               : ioBroker                                 - disabled
      + system.adapter.esphome.0                : esphome               : ioBroker                                 -  enabled
      + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
        system.adapter.hass.0                   : hass                  : ioBroker                                 - disabled, port: 8123
      + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
        system.adapter.heos.0                   : heos                  : ioBroker                                 - disabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 -  enabled
        system.adapter.hyperion_ng.0            : hyperion_ng           : ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
        system.adapter.lovelace.0               : lovelace              : ioBroker                                 - disabled, port: 8091, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.omada.0                  : omada                 : ioBroker                                 -  enabled, port: 443
        system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
        system.adapter.radar2.0                 : radar2                : ioBroker                                 - disabled
      + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
      + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
      + system.adapter.roomba.0                 : roomba                : ioBroker                                 -  enabled
      + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
      + system.adapter.scheppach-roboticmower.0 : scheppach-roboticmower: ioBroker                                 -  enabled
      + system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
      + system.adapter.sma-em.0                 : sma-em                : ioBroker                                 -  enabled
        system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 - disabled
      + system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 -  enabled
      + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : ioBroker                                 -  enabled, port: 8088, bind: 192.168.0.18, run as: admin
      + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wireless-mbus.0          : wireless-mbus         : ioBroker                                 - disabled
      + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
      + system.adapter.xterm.0                  : xterm                 : ioBroker                                 -  enabled, port: 8099, bind: 0.0.0.0
        system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
      Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
      Adapter    "canbus"       : 1.3.1    , installed 1.3.1
      Adapter    "denon"        : 1.15.4   , installed 1.15.4
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "ebus"         : 3.2.4    , installed 3.2.4
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "heizungssteuerung": 1.7.0, installed 1.7.0
      Adapter    "heos"         : 2.1.0    , installed 2.1.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "modbus"       : 6.0.1    , installed 6.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "radar2"       : 2.1.0    , installed 2.1.0
      Adapter    "reolink"      : 1.0.2    , installed 1.0.2
      Adapter    "roomba"       : 1.2.2    , installed 1.2.2
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "semp"         : 1.3.13   , installed 1.3.13
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
      Adapter    "smappee"      : 0.2.6    , installed 0.2.6
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
      Adapter    "tapo"         : 0.0.8    , installed 0.2.0
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
      Adapter    "wireless-mbus": 0.9.1    , installed 0.9.1
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "xterm"        : 2.0.1    , installed 2.0.1
      Adapter    "zigbee"       : 1.9.7    , installed 1.9.7
      Objects and States
      Objects:        25545
      States:         20470
      Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 https://dl.yarnpkg.com/debian stable InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 192.168.0.18:8081       0.0.0.0:*               LISTEN      1000       1335626639 3783566/io.admin.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          601716640  332/master
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1335625579 3783548/iobroker.js
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1335628103 3783548/iobroker.js
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       1335637211 3784454/io.jarvis.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        601716336  99/systemd-resolved
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1000       1335643422 3784780/python3
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1335631018 3783803/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1335632443 3784304/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1507922602 1640561/sshd: /usr/
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          601710293  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          601716641  332/master
      tcp6       0      0 :::9765                 :::*                    LISTEN      1000       1556454454 2013116/io.semp.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       1335640408 3784560/io.terminal
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1517818547 1755329/io.web.0
      tcp6       0      0 :::8099                 :::*                    LISTEN      1000       1335632253 3784210/io.xterm.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1507922604 1640561/sshd: /usr/
      tcp6       0      0 :::111                  :::*                    LISTEN      0          601714828  1/init
      udp        0      0 0.0.0.0:52164           0.0.0.0:*                           1000       1335632544 3784349/io.broadlin
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       1335628409 3784131/io.mihome-v
      udp        0      0 0.0.0.0:60660           0.0.0.0:*                           1000       1335632542 3784349/io.broadlin
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        601716335  99/systemd-resolved
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          601710294  1/init
      udp        0      0 0.0.0.0:33222           0.0.0.0:*                           1000       1335631562 3784349/io.broadlin
      udp        0      0 0.0.0.0:33524           0.0.0.0:*                           1000       1335628769 3784349/io.broadlin
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1556454456 2013116/io.semp.0
      udp        0      0 0.0.0.0:35282           0.0.0.0:*                           1000       1335631590 3784349/io.broadlin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1429471422 707657/io.wled.0
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1000       1335645296 3784780/python3
      udp        0      0 192.168.0.18:5353       0.0.0.0:*                           1000       1335645295 3784780/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1335645290 3784780/python3
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1335643410 3784760/io.esphome.
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1475426065 1260070/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1475426066 1260070/io.tuya.0
      udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1000       1491545917 1448238/io.sma-em.0
      udp        0      0 0.0.0.0:46458           0.0.0.0:*                           1000       1335632545 3784349/io.broadlin
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       1335632520 3784349/io.broadlin
      udp        0      0 0.0.0.0:48623           0.0.0.0:*                           1000       1335632521 3784349/io.broadlin
      udp6       0      0 :::111                  :::*                                0          601710297  1/init
      iob diag has finished.
      Press any key for a summary
        Homoran Global Moderator Administrators @maik5066 last edited by
        @maik5066 sagte in LOG anschauen , ständige Internet ausfälle:
        und warum schneidest du es dann ab?
          Thomas Braun Most Active @maik5066 last edited by
          @maik5066
          Deine Echtzeituhr steht auf der lokalen Zeitzone, die sollte aber auf Z-Zeit stehen.
          Boot Target: graphical.target
          sudo systemctl set-default multi-host.target
          Du verwendest einen falschen User. Leg dir einen neuen an, der dann 'maik 5066' oder so heißt. Und den setzt du dann u. a. in die Gruppen adm und iobroker rein.
          Du stehst vermutlich in /root herum. Da hast du aber nix verloren, stell dich in das /home des neuen users.
          Da fehlt ein Modul, vermutlich manuell im javascript-Adapter einzutragen.
          Für meinen Geschmack / für ein stabiles System deutlich zu viel Zeuch von GitHub installiert.
          Kann vermutlich rausgekickt werden. Braucht man im Allgemeinen nicht.
            maik5066 @Thomas Braun last edited by maik5066
            @thomas-braun said in LOG anschauen , ständige Internet ausfälle:
            Sorry hier nochmal der Gesamte LOG:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: container
                Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 4
                             RTC time: n/a
            iobroker
            /home/iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     8064 M total memory
                     4720 M used memory
                     2133 M free memory
                        0 M buffer memory
                     1210 M swap cache
                     4096 M total swap
                     1056 M used swap
                     3039 M free swap
            *** FILESYSTEM ***
            /var:
            2.7G    /var/
            2.1G    /var/log
            336M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        25545
            States:         20470
            Pending Updates: 2
            iobroker@ioBroker:/root$ apt policy nodejs
            nodejs:
              Version table:
            Failed to set default target: Access denied
              und wo genau?
              ist abgeschnitten
              Da steht kein log
                maik5066 @Homoran last edited by maik5066
                Entschuldige wenn ich Ihn einfüge schneidet er ihn immer ab
                LOG.txt
                Codierknecht MartinP 2 Replies Last reply Reply Quote 0
                • Codierknecht
                  Codierknecht Developer Most Active @maik5066 last edited by
                  @maik5066
                  Da steht auch nix drin 😞
                  Hast Du die von @Thomas-Braun genannten Probleme gelöst?
                  • MartinP
                    MartinP @maik5066 last edited by
                    @maik5066 Schau doch mal, ob Du über die Zwischenablage des Browsers die Loggings bekommst ...
                      maik5066 @MartinP last edited by Homoran
                      @martinp
                      Ich habe den Befehl iob diag über Putty ausgeführt, er bringt auf den Fehler/Hinweis Log File - Last 25 Lines ***
                      in meiner Console, was kann ich machen das er alles anzeigt ?
                      Die Fehler habe ich leider nicht richtig verstanden, sorry aber ich bin ein Anfänger.
                      **Ich habe den befehl eingeben es kommt aber die Antwort; Failed to set default target: Unit file multi-host.target does not exist. Ich habe ein User SU angelegt mit dem Namen maik5066 , wie kann ich den den Gruppen zuweisen **
                      Da fehlt ein Modul, vermutlich manuell im javascript-Adapter einzutragen.[LOG.txt](/assets/uploads/files/
                      **Welches Modul muss ich installieren ? ich habe in den Adaptern noch nichts manuell eingetragen **
                      Homoran MartinP 4 Replies Last reply Reply Quote 0
                        @maik5066 bitte immer alles zeigen!
                        input und output als Text in code-tags!
                        logs genauso
                          Diesmal war es vollständig, aber enthielt persönliche Daten.
                          Diese bitte entfernen und nochmal senden
                          • MartinP
                            MartinP @maik5066 last edited by MartinP
                            @maik5066 said in LOG anschauen , ständige Internet ausfälle:
                            Es geht um diese Zeile im diag:
                            Weiß aber nicht, wie relevant das ist ... bei mir und auch bei Dir gibt es gar keine "RTC-Time" von der Echtzeituhr (da steht N/A), da LXC-Container...
                                           Local time: Fri 2024-01-12 10:05:26 CET
                                       Universal time: Fri 2024-01-12 09:05:26 UTC
                                             RTC time: n/a
                                      RTC in local TZ: no
                              Thomas Braun Most Active @MartinP last edited by
                              @martinp sagte in LOG anschauen , ständige Internet ausfälle:
                              da LXC-Container...
                              Ja, aber die Meldung zur RTC taucht in anderen Containern in der Form nicht auf. Da ist also irgendwas anders eingestellt.
                              Da ich aber von Containern keine Ahnung habe halte ich mich im weiteren dann hier raus.
                              • MartinP
                                MartinP @Thomas Braun last edited by
                                @thomas-braun Definitiv - bei mir steht bei RTC in local TZ: no...
                                @maik5066 steht denn da etwas in der Konsole wenn Du Dir den Abschnitt des diag outputs anschaust?
                                Die Abhilfe gegen das Problem ist ja in der diag-ausgabe zu finden...
                                • wendy2702
                                  wendy2702 last edited by
                                  Schau mal in ein iobroker log, zu finden unter
                                  /opt/iobroker/log
                                  wahrscheinlich am einfachsten wenn du es per z.B. per FTP auf deinen Arbeitsrechner kopierst, dann mit Notepad++ öffnen und nach dem "fehler" suchen den du meinst.
                                  Den vollständigen relevanten Teil dann mal hier posten.
                                    Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
                                    @wendy2702 sagte in LOG anschauen , ständige Internet ausfälle:
                                    hatte er ja zumindest aus der Diag gemacht, musste ich aber wegen privater Daten entfernen.
                                    seitdem kommt nichts mehr
                                    • MartinP
                                      @maik5066 wie hast Du es geschafft "iob diag"aus "/root" auszuführen?
                                        maik5066 @MartinP last edited by maik5066
                                        @martinp
                                        Hallo, nein aus root kann ich ihn nicht ausführen, ich gehe über den Nutzer Iobroker
                                        024-01-12 09:58:36.188 - info: homeconnect.0 (1260020) Keep Alive failed Reconnect EventStream
                                        2024-01-12 09:58:39.043 - error: iot.0 (348511) Error by device connection: "read ECONNRESET"
                                        2024-01-12 09:58:39.044 - info: iot.0 (348511) Connection changed: disconnect
                                        2024-01-12 09:58:39.044 - info: iot.0 (348511) Connection lost
                                        2024-01-12 09:58:44.293 - info: iot.0 (348511) Connection changed: connect "maik5_66_gmail_com"
                                        2024-01-12 09:59:22.166 - info: alexa2.0 (1785240) Alexa-Push-Connection Error: read ECONNRESET
                                        2024-01-12 09:59:22.166 - info: alexa2.0 (1785240) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2024-01-12 09:59:23.365 - info: alexa2.0 (1785240) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2024-01-12 10:07:19.762 - info: omada.0 (3784702) Omada cID:
                                        2024-01-12 10:07:20.263 - info: omada.0 (3784702) Login successful
                                        2024-01-12 10:14:07.517 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                        2024-01-12 11:12:59.397 - info: tuya.0 (1260070) 65302272c45bbeda2ea3: Connect locally to device
                                        2024-01-12 11:12:59.397 - info: tuya.0 (1260070) 65302272c45bbeda2ea3 Init with IP=192.168.0.8, Key=75ec761dbbb96fe3, Version=3.3
                                        2024-01-12 11:14:07.572 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                        2024-01-12 11:44:58.611 - info: homeconnect.0 (1260020) BOSCH-PXV975DV1E-68A40E7A3D63/programs/active/options: There is no program active.
                                        2024-01-12 12:04:11.331 - info: alexa2.0 (1785240) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2024-01-12 12:04:12.722 - info: alexa2.0 (1785240) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2024-01-12 12:06:58.901 - info: homeconnect.0 (1260020) BOSCH-PXV975DV1E-68A40E7A3D63/programs/active/options: There is no program active.
                                        2024-01-12 12:14:07.558 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                        2024-01-12 13:02:24.485 - info: tuya.0 (1260070) 80444028a4e57cb6dd9e: Connect locally to device
                                        2024-01-12 13:02:24.485 - info: tuya.0 (1260070) 80444028a4e57cb6dd9e Init with IP=192.168.0.25, Key=cDU:/7yogI_ss_87, Version=3.3
                                        2024-01-12 13:09:54.416 - error: alexa2.0 (1785240) G0911X03149400LD Error getting aux controller state: Error: Timeout
                                        2024-01-12 13:11:57.321 - error: spotify-premium.0 (2020970) spotify status polling stopped with error Error: connect ETIMEDOUT 35.186.224.25:443
                                        2024-01-12 13:14:07.759 - debug: scheppach-roboticmower.0 (1942696) {"code":0,"msg":null,"data":{"id":"1484463711434342402","name":"Robi ","standard":"RMA301M20V","userId":12355587,"sn":"21121680002100010386","deviceModelId":"1425621945385820162","deviceModelName":"RMA301M20V","deviceTypeId":"1356878098053763073","deviceTypeName":"market_active","bluetoothMac":null,"channelId":"1448886526661398529","channelName":null,"channelChargeId":"1646709263324803074","channelChargeName":null,"productionAt":"2022-01-21","expirationAt":null,"extendedWarrantyPeriod":null,"activeFlag":true,"activedAt":"2023-04-10 21:33:07","countryRegion":"1339017275974967297","areaRegion":null,"country":null,"area":null,"firmwareVersion":23202,"mbSv":"22905","mbHv":"22100","dbSv":"61107","dbHv":"60300","bbSv":"40801","bbHv":"210700","lbSv":"0","lbHv":"0","mbltSv":"40501","mblthV":null,"boundFlag":true,"onlineFlag":false,"livelinessAt":"2024-01-11 16:27:15","deviceSettingId":"1484463711417565185","iot":"1","lat":null,"lng":null,"addr":null,"createdAt":"2022-01-21 09:51:43","updatedAt":"2023-04-17 01:59:29","usernameList":null,"workStatusCode":"0","faultStatusCode":"normal","workStatusName":"idle","faultStatusName":"normal","electricity":91,"bluetoothFlag":null,"wifiFlag":true,"rainDelayLeft":180,"rainStatusCode":"0","rainDelayDuration":"180","rainFlag":true,"stationFlag":false,"areaSize":11053,"onMin":298032,"totalMin":298032,"collectedAt":"2024-01-11 16:27:04","otaFlag":null,"operateErrFlag":true,"otaStatusFlag":false,"workMapFlag":false,"batChange":0,"batteryName":"131793366","chargingTimes":39,"dischargeTimes":null,"synchronizeTimeZone":"2023-12-03 14:54:08","timeAutoFlag":null,"timeZoneFlag":null,"timeZoneCode":null,"daylightTimeFlag":null,"scheduleAutoFlag":null,"companyName":null,"bindAntiTheftId":null,"remark":null,"bindAntiTheftSn":null,"companyAccountId":null,"stationSn":null,"stationId":null,"stationOnlineFlag":null,"onConnect":null,"iccId":null,"infoState":0,"picUrl":null,"nowTime":null},"ok":true}
                                        DJMarc75 MartinP 2 Replies Last reply Reply Quote 0
                                        • DJMarc75
                                          DJMarc75 @maik5066 last edited by
                                          @maik5066
                                          Bitte Text in CODETAGS setzen und BITTE entferne persönliche Daten !
                                          • MartinP
                                            Doppelpost
                                            875
