    4. [gelöst] Fehler bei Upgrade js-controller 0.7.1 -> 0.7.2
    • I
      iben last edited by
      Erhalte folgende Fehler beim Versuch Upzugraden:
      ben@ubuntu2:~$ cd /opt/iobroker/
      ben@ubuntu2:/opt/iobroker$ sudo -i
      [sudo] password for ben:
      root@ubuntu2:~# cd /opt/iobroker/
      root@ubuntu2:/opt/iobroker# ./iobroker start
      Starting ioBroker controller daemon...
      ioBroker controller daemon started. PID: 1074
      root@ubuntu2:/opt/iobroker# ./iobroker update
      update done
      Adapter    "zwave"         : 0.1.0
      Adapter    "yr"            : 0.1.6
      Adapter    "web"           : 0.4.2    , installed 0.4.1 [Updateable]
      Adapter    "vis-metro"     : 0.1.0
      Adapter    "vis"           : 0.6.2    , installed 0.6.1 [Updateable]
      Adapter    "sonos"         : 0.1.6    , installed 0.1.6
      Adapter    "rickshaw"      : 0.2.2    , installed 0.2.2
      Adapter    "pushover"      : 0.1.1
      Adapter    "owfs"          : 0.0.2
      Adapter    "onkyo"         : 0.1.8
      Adapter    "socketio"      : 0.4.1
      Adapter    "simple-api"    : 0.1.1
      Adapter    "sayit"         : 0.3.8    , installed 0.3.8
      Adapter    "s7"            : 0.1.2
      Adapter    "ping"          : 0.1.4    , installed 0.1.4
      Adapter    "node-red"      : 0.3.2
      Adapter    "mqtt"          : 0.2.9
      Adapter    "megad"         : 0.1.1
      Adapter    "legacy"        : 0.1.12
      Adapter    "knx"           : 0.0.1
      Controller "js-controller" : 0.7.2    , installed 0.7.1 [Updateable]
      Adapter    "javascript"    : 0.4.8    , installed 0.4.7 [Updateable]
      Adapter    "icons-ultimate-png": 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.1
      Adapter    "icons-mfd-svg" : 0.1.0
      Adapter    "icons-mfd-png" : 0.1.0
      Adapter    "icons-material-svg": 0.1.0
      Adapter    "icons-material-png": 0.1.0
      Adapter    "icons-addictive-flavour-png": 0.1.0
      Adapter    "ical"          : 0.1.1    , installed 0.1.1
      Adapter    "hmm"           : 0.1.1
      Adapter    "hue"           : 0.2.0    , installed 0.2.0
      Adapter    "hm-rpc"        : 0.5.1    , installed 0.5.1
      Adapter    "hm-rega"       : 0.2.2    , installed 0.2.2
      Adapter    "history"       : 0.1.3    , installed 0.1.3
      Adapter    "example"       : 0.1.1    , installed 0.1.1
      Adapter    "email"         : 0.1.2    , installed 0.1.2
      Adapter    "dwd"           : 0.1.9
      Adapter    "cul"           : 0.0.4
      Adapter    "b-control-em"  : 0.1.1
      Adapter    "artnet"        : 0.0.3
      Adapter    "admin"         : 0.5.4    , installed 0.5.2 [Updateable]
      root@ubuntu2:/opt/iobroker# ./iobroker upgrade
      /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:426
                          if ((!toRead || sources._failCounter.length > 10) && timeo
      TypeError: Cannot read property 'length' of undefined
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:426:57
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:376:39
          at getJson (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:162:31)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:346:13
          at getJson (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:131:31)
          at getIoPack (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:339:5)
          at Object.getRepositoryFile (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:424:17)
          at yes (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:788:27)
          at Object.States.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2006:70)
          at Socket.StatesInMemClient.client.on.i (/opt/iobroker/node_modules/iobroker.js-controller/lib/statesInMemClient.js:80:68)
        Habe schon Fehler gefixt: https://github.com/ioBroker/ioBroker.js … 9d1aec1488
        Das sollte auf jeden Fall gehen:
        cd /opt/iobroker
        ./iobroker stop
        npm install iobroker.js-controller --production
        ./iobroker start
        • I
          iben last edited by
          Super, danke!!!
