    4. Backup einspielen
    Backup einspielen
    • O
      Oebler last edited by Homoran
      ich habe über backitup ein Backup meiner ioBroker Installation gemacht.
      Nun habe ich mit Portainer einen Container mit der aktuellen Version (buanet) erstellt.
      Leider kann ich darin nicht mein Backup installieren (weder über Google Drive noch durch hochladen.
      Die Fehlermeldung sieht folgendermaßen aus:
      2024-01-13 21:11:01.619 - error: backitup.0 (62738) uncaught exception: listen EADDRINUSE: address already in use :::9081
      2024-01-13 21:11:01.631 - error: backitup.0 (62738) Error: listen EADDRINUSE: address already in use :::9081
      at Server.setupListenHandle [as _listen2] (node:net:1817:16)
      at listenInCluster (node:net:1865:12)
      at Server.listen (node:net:1953:7)
      at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24)
      at dlFileServer (/opt/iobroker/node_modules/iobroker.backitup/main.js:1703:39)
      at AdapterClass. (/opt/iobroker/node_modules/iobroker.backitup/main.js:311:29)
      at AdapterClass.emit (node:events:517:28)
      at AdapterClass.emit (node:domain:489:12)
      at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11143:34)
      at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37)
      2024-01-13 21:11:01.632 - error: backitup.0 (62738) Exception-Code: EADDRINUSE: listen EADDRINUSE: address already in use :::9081
      2024-01-13 21:11:01.709 - info: backitup.0 (62738) cleaned everything up...
      2024-01-13 21:11:01.711 - info: backitup.0 (62738) terminating
      2024-01-13 21:11:01.717 - warn: backitup.0 (62738) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-13 21:11:02.221 - error: host.427605deb40c Caught by controller[0]: Error: listen EADDRINUSE: address already in use :::9081
      2024-01-13 21:11:02.224 - error: host.427605deb40c Caught by controller[0]: at Server.setupListenHandle [as _listen2] (node:net:1817:16)
      2024-01-13 21:11:02.225 - error: host.427605deb40c Caught by controller[0]: at listenInCluster (node:net:1865:12)
      2024-01-13 21:11:02.225 - error: host.427605deb40c Caught by controller[0]: at Server.listen (node:net:1953:7)
      2024-01-13 21:11:02.226 - error: host.427605deb40c Caught by controller[0]: at Function.listen (/opt/iobroker/node_modules/express/lib/application.js:635:24)
      2024-01-13 21:11:02.226 - error: host.427605deb40c Caught by controller[0]: at dlFileServer (/opt/iobroker/node_modules/iobroker.backitup/main.js:1703:39)
      2024-01-13 21:11:02.227 - error: host.427605deb40c Caught by controller[0]: at AdapterClass. (/opt/iobroker/node_modules/iobroker.backitup/main.js:311:29)
      2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at AdapterClass.emit (node:events:517:28)
      2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at AdapterClass.emit (node:domain:489:12)
      2024-01-13 21:11:02.228 - error: host.427605deb40c Caught by controller[0]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11143:34)
      2024-01-13 21:11:02.229 - error: host.427605deb40c Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:379:37) {
      2024-01-13 21:11:02.229 - error: host.427605deb40c Caught by controller[0]: code: 'EADDRINUSE',
      2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: errno: -98,
      2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: syscall: 'listen',
      2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: address: '::',
      2024-01-13 21:11:02.230 - error: host.427605deb40c Caught by controller[0]: port: 9081
      2024-01-13 21:11:02.231 - error: host.427605deb40c Caught by controller[0]: }
      2024-01-13 21:11:02.231 - error: host.427605deb40c instance system.adapter.backitup.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Kann man hieraus erkennen, worin das Problem liegt?
      Vielenn Dank für eure Hilfe!
      Oebler
      • crunchip
        crunchip Forum Testing Most Active @Oebler last edited by crunchip
        @oebler sagte in Backup einspielen:
        ansonsten
        https://github.com/simatec/ioBroker.backitup/wiki/ioBroker.backitup-Wiki-Deutsch
        • O
          Oebler @crunchip last edited by
          @crunchip
          Super, danke dir - habe einen neuen Container erstellt, wo ich diesen Port 1:1 weiterleite, damit läuft das Backup aktuell erst mal los 🙂
          • simatec
            simatec Developer Most Active @Oebler last edited by
            @oebler Installiere die neuste Version von Backitup aus der latest Repo. Aktuell die v2.10.1
            Bitte in deinem Docker die Ports laut Doku mappen.
            Dann läuft der Restore auch... Leider ist das mappen bei Docker nötig... oder du baust dir für den iobroker ein Macvlan. Damit entfallen die Mapping Ports.
