    4. Start aus Backup *gelöst*
    • G
      gluecksmann last edited by gluecksmann
      Hallo, nachdem ich heute Vomittag ein Backup über den Backitup Adapter eingespielt habe, läuft IObroker nicht mehr...bzw. ist es nicht über VIS oder Backend erreichbar. Über Putty komme ich noch dran...
        Thomas Braun Most Active @gluecksmann last edited by
        @gluecksmann
        Wie immer.
        iob diag
        G Thomas Braun 2 Replies Last reply Reply Quote 0
        • G
          gluecksmann @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           16:40:22 up  1:46,  1 user,  load average: 2.58, 1.95, 1.55
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-01-14 16:40:25 CET
                     Universal time: Sun 2024-01-14 15:40:25 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           7.9G        353M        6.7G        8.0M        812M        7.3G
          Swap:           99M          0B         99M
          Total:         8.0G        353M        6.8G
                   7898 M total memory
                    352 M used memory
                    517 M active memory
                    445 M inactive memory
                   6732 M free memory
                    239 M buffer memory
                    573 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       29G   14G   14G  50% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Sun Jan 14 14:53:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun Jan 14 14:53:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Sun Jan 14 14:53:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun Jan 14 14:53:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          404M    /var/
          118M    /var/lib
          102M    /var/cache
          90M     /var/cache/apt
          82M     /var/log
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          68M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          595M    /opt/iobroker/iobroker-data/
          313M    /opt/iobroker/iobroker-data/files
          144M    /opt/iobroker/iobroker-data/backup-objects
          94M     /opt/iobroker/iobroker-data/sonosCache
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          12M     /opt/iobroker/iobroker-data/objects.json.migrated
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          npm ERR! code ELSPROBLEMS
          npm ERR! extraneous: @iobroker/socket-classes@1.4.6 /opt/iobroker/node_modules/@iobroker/socket-classes
          npm ERR! extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
          npm ERR! extraneous: @iobroker/ws-server@2.1.2 /opt/iobroker/node_modules/@iobroker/ws-server
          npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
          npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
          npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
          npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
          npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
          npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
          npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
          npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
          npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
          npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
          npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
          npm ERR! extraneous: ajv@8.12.0 /opt/iobroker/node_modules/ajv
          npm ERR! extraneous: archiver-utils@4.0.1 /opt/iobroker/node_modules/archiver-utils
          npm ERR! extraneous: archiver@6.0.1 /opt/iobroker/node_modules/archiver
          npm ERR! extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
          npm ERR! extraneous: compress-commons@5.0.1 /opt/iobroker/node_modules/compress-commons
          npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
          npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
          npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
          npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
          npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
          npm ERR! extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
          npm ERR! extraneous: crc32-stream@5.0.0 /opt/iobroker/node_modules/crc32-stream
          npm ERR! extraneous: express-fileupload@1.4.3 /opt/iobroker/node_modules/express-fileupload
          npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
          npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
          npm ERR! extraneous: iobroker.sonoff@3.0.3 /opt/iobroker/node_modules/iobroker.sonoff
          npm ERR! extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
          npm ERR! extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
          npm ERR! extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
          npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
          npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
          npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
          npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
          npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
          npm ERR! extraneous: passport@0.6.0 /opt/iobroker/node_modules/passport
          npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
          npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
          npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
          npm ERR! extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
          npm ERR! extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
          npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
          npm ERR! extraneous: zip-stream@5.0.1 /opt/iobroker/node_modules/zip-stream
          npm ERR! extraneous: bytes@3.0.0 /opt/iobroker/node_modules/compression/node_modules/bytes
          npm ERR! extraneous: cookie@0.4.2 /opt/iobroker/node_modules/express-session/node_modules/cookie
          npm ERR! extraneous: safe-buffer@5.2.1 /opt/iobroker/node_modules/express-session/node_modules/safe-buffer
          npm ERR! extraneous: semver@7.5.4 /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
          npm ERR! extraneous: readable-stream@2.3.8 /opt/iobroker/node_modules/lazystream/node_modules/readable-stream
          npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/lazystream/node_modules/string_decoder
          npm ERR! invalid: string_decoder@1.3.0 /opt/iobroker/node_modules/string_decoder
          npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
          npm ERR! invalid: ms@2.0.0 /opt/iobroker/node_modules/ms
          npm ERR! invalid: protobufjs@ /opt/iobroker/node_modules/protobufjs
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_34_077Z-debug-0.log
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          "admin" not found
          javascript:     7.1.6
          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-14T15_40_54_148Z-debug-0.log
          Adapters from github:   0
          Adapter State
            system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
            system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
            system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
            system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
            system.adapter.govee.0                  : govee                 : raspberrypi                              - disabled
            system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              - disabled
            system.adapter.history.0                : history               : raspberrypi                              - disabled
            system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            system.adapter.info.0                   : info                  : raspberrypi                              - disabled
            system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
            system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
            system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              - disabled
            system.adapter.musiccast.0              : musiccast             : raspberrypi                              - disabled
            system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
            system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
            system.adapter.philips-air.0            : philips-air           : raspberrypi                              - disabled
            system.adapter.philips-air.1            : philips-air           : raspberrypi                              - disabled
            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
            system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
            system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
            system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
            system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
            system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
            system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
            system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpected end of JSON input
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "hue"          : 3.10.1   , installed 3.10.1
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
          Adapter    "icons-mfd-svg": 1.2.0    , installed 1.1.0  [Updatable]
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "meross"       : 1.17.0   , installed 1.16.1 [Updatable]
          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.0.0  [Updatable]
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "zigbee"       : 1.9.7    , installed 1.8.24 [Updatable]
          Objects and States
          Objects:        11186
          States:         8901
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16886      641/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14852      365/cupsd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       45899      9623/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45892      9623/iobroker.js-co
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16888      641/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14851      365/cupsd
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17522      631/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16544      484/cups-browsed
          udp        0      0 0.0.0.0:42683           0.0.0.0:*                           108        16161      372/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16159      372/avahi-daemon: r
          udp6       0      0 :::41952                :::*                                108        16162      372/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          16570      631/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        16160      372/avahi-daemon: r
          2024-01-14 16:40:45.597  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24)
          2024-01-14 16:40:45.597  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
          2024-01-14 16:40:45.598  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.admin/package.json'
          2024-01-14 16:40:45.598  - error: host.raspberrypi Caught by controller[0]: }
          2024-01-14 16:40:45.599  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
          2024-01-14 16:40:45.599  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-14 16:40:45.600  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
          2024-01-14 16:41:15.734  - error: host.raspberrypi startInstance admin.0: Cannot read and parse "/opt/iobroker/node_modules/iobroker.admin/package.json"
          2024-01-14 16:41:15.749  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 10027
          2024-01-14 16:41:16.203  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/package_json_reader:92
          2024-01-14 16:41:16.204  - error: host.raspberrypi Caught by controller[0]:         throw error;
          2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]:         ^
          2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
          2024-01-14 16:41:16.205  - error: host.raspberrypi Caught by controller[0]:     at parse (<anonymous>)
          2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at read (node:internal/modules/package_json_reader:79:16)
          2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at readPackage (node:internal/modules/package_json_reader:140:10)
          2024-01-14 16:41:16.206  - error: host.raspberrypi Caught by controller[0]:     at readPackageScope (node:internal/modules/package_json_reader:157:19)
          2024-01-14 16:41:16.207  - error: host.raspberrypi Caught by controller[0]:     at shouldUseESMLoader (node:internal/modules/run_main:77:15)
          2024-01-14 16:41:16.207  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:122:24)
          2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
          2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.admin/package.json'
          2024-01-14 16:41:16.208  - error: host.raspberrypi Caught by controller[0]: }
          2024-01-14 16:41:16.209  - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0
          2024-01-14 16:41:16.209  - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-01-14 16:41:16.209  - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
            Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
            @gluecksmann
            Buster ist tot. Muss ersetzt werden.
            Installier da NEU ein 64Bit Bookworm.
            • G
              Mhhhh... werde das dann wohl mal machen müssen...wobei es ja vorher lief...
                Homoran Global Moderator Administrators @gluecksmann last edited by
                @gluecksmann sagte in Start aus Backup:
                das heisst nichts.
                jetzt ist jetzt.
                wie alt?
                welche Grundkonfiguration in dem Backup?
                welche jetzt?
                  @gluecksmann
                  Es läuft immer vorher, bis es eben nicht mehr läuft.
                  Ich vermute du hast den Back-up-Prozess unterbrochen. Das kann geraume Zeit dauern.
                  • G
                    na da hoffe ich das das Backup nachts "gut" ist.... Suche jetzt mal eine neue Speicherkarte...
                    • G
                      gluecksmann @gluecksmann last edited by
                      @gluecksmann
                      Hat jetzt scheinbar geklappt...bin aber das Problem mit Zigbee nicht losgeworden...
                      2024-01-14 20:12:42.572  - error: zigbee.0 (14059) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                      was denn nun schon wieder? Ist doch alles neu und frisch...
                        Vielleicht gerade deswegen.
                        wie ist die Konfiguration von der Instanz?
                        • G
                          gluecksmann @Homoran last edited by
                          wenn ich in die Instanz gehe, begrüßt mich diese Fehlermeldung...
                            @gluecksmann
                            Schau in das LogFile rein und guck was der Adapter da zu melden hat.
                            Ein CC2531 ist allerdings auch mittlerweile veraltet. Würde ich eh austauschen.
                            G 2 Replies Last reply Reply Quote 0
                            • G
                                @gluecksmann
                                Keine Screenshots.
                                Schau in die Datei.
                                iob logs --watch
                                Beobachte da einen Neustart.
                                • G
                                  was austauschen? Geht es um den Zigbee Stick? Da hatte ich nach Empfehlungen gefragt..bekam aber keine für mich als DAU User verwertbaren Antworten..
                                    Homoran Global Moderator Administrators @gluecksmann last edited by Homoran
                                    @gluecksmann dein /dev/by-id in der Konfiguration scheint bei der list of ports nicht dabei zu sein.
                                    Du solltest aber doch inzwischen wissen dass logs als Text in code-tags gepostet werden
                                      Ja.
                                      Nimm einen aus dieser Liste:
                                      https://www.zigbee2mqtt.io/guide/adapters/#recommended
                                      • G
                                        @thomas-braun sagte in Start aus Backup:
                                        iob logs --watch
                                        2024-01-14 20:21:59.992  - error: zigbee.0 (14059) getGroups: caught error: Type        Error: Cannot read properties of undefined (reading 'getGroups')
                                          @gluecksmann
                                          Den ganzen Neustart des Adapters anschauen. Da steht deutlich mehr drin.
                                          • crunchip
                                            Einstellungen sind
                                            irgendwelche bindings/Gruppen angelegt?
                                            1617
