    4. [gelöst] js-adapter startet immer wieder neu
    • fhainz
      fhainz last edited by fhainz
      Hallo!
      Ich habe seit heute morgen ein Problem, mein js Adapter startet immer wieder neu. Im Protokoll finden sich diese Meldungen.
      Kann mir jemand weiterhelfen?
      LG
      host.iobroker
      2024-01-15 10:20:30.021	info	Restart adapter system.adapter.javascript.0 because enabled
      host.iobroker
      2024-01-15 10:20:30.021	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[1]: Node.js v18.19.0
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: }
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
      host.iobroker
      2024-01-15 10:20:30.021	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
      host.iobroker
      host.iobroker
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
      host.iobroker
      2024-01-15 10:20:30.020	error	Caught by controller[0]: at parse (<anonymous>)
      host.iobroker
      2024-01-15 10:20:30.019	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
      host.iobroker
      2024-01-15 10:20:30.019	error	Caught by controller[0]: ^
      host.iobroker
      2024-01-15 10:20:30.019	error	Caught by controller[0]: throw error;
      host.iobroker
      2024-01-15 10:20:30.019	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
      Homoran Thomas Braun Codierknecht 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @fhainz last edited by Homoran
        @fhainz sagte in js-controller startet immer wieder neu:
        nicht wenn du die wichtigsten Zeilen abschneidest.
        Die Fehlermeldung muss noch etwas früher stehen
          Thomas Braun Most Active @fhainz last edited by
          @fhainz
          iob diag
          sagt?
          • fhainz
            Ab und an kommt die Meldung
            host.iobroker
            2024-01-15 09:34:43.496	error	cannot call visUtils: Not exists
            vis ist auch schon deaktiviert.
            Hab das System jetzt komplett neugestartet und davor das Protokoll gelöscht. Sieht so aus:
            2024-01-15 09:34:06.726 - info: socketio.0 (1274) terminating http server on port 8084
            2024-01-15 09:34:06.750 - info: admin.0 (953) terminating http server on port 8081
            2024-01-15 09:34:06.759 - info: statistics.0 (1244) cleaned everything up...
            2024-01-15 09:34:06.699 - info: backitup.0 (1192) cleaned everything up...
            2024-01-15 09:34:06.788 - info: host.iobroker received SIGTERM
            2024-01-15 09:34:06.800 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
            2024-01-15 09:34:06.800 - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
            2024-01-15 09:34:06.800 - info: host.iobroker stopInstance system.adapter.history.0 (force=false, process=false)
            2024-01-15 09:34:06.800 - info: host.iobroker stopInstance system.adapter.influxdb.0 (force=false, process=true)
            2024-01-15 09:34:06.800 - info: host.iobroker stopInstance system.adapter.telegram.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.owfs.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.mqtt.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.mqtt-client.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.modbus.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.s7.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.ping.0 (force=false, process=false)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.shelly.0 (force=false, process=true)
            2024-01-15 09:34:06.801 - info: host.iobroker stopInstance system.adapter.modbus.1 (force=false, process=true)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.modbus.2 (force=false, process=true)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.sonoff.0 (force=false, process=false)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=false)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.notification-manager.0 (force=false, process=true)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.modbus.3 (force=false, process=true)
            2024-01-15 09:34:06.802 - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2024-01-15 09:34:06.831 - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=false)
            2024-01-15 09:34:06.831 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
            2024-01-15 09:34:06.832 - info: host.iobroker stopInstance system.adapter.fronius-solarweb.0 (force=false, process=false)
            2024-01-15 09:34:06.832 - info: host.iobroker stopInstance system.adapter.fronius.0 (force=false, process=true)
            2024-01-15 09:34:06.832 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
            2024-01-15 09:34:06.833 - info: host.iobroker stopInstance system.adapter.mobile.0 (force=false, process=false)
            2024-01-15 09:34:06.833 - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=false)
            2024-01-15 09:34:06.833 - info: host.iobroker stopInstance system.adapter.statistics.0 (force=false, process=true)
            2024-01-15 09:34:06.833 - info: host.iobroker stopInstance system.adapter.linkeddevices.0 (force=false, process=false)
            2024-01-15 09:34:06.836 - info: host.iobroker stopInstance system.adapter.jarvis.0 (force=false, process=false)
            2024-01-15 09:34:06.836 - info: host.iobroker stopInstance system.adapter.pvforecast.0 (force=false, process=false)
            2024-01-15 09:34:06.837 - info: host.iobroker stopInstance system.adapter.govee-local.0 (force=false, process=true)
            2024-01-15 09:34:06.837 - info: host.iobroker stopInstance system.adapter.govee.0 (force=false, process=false)
            2024-01-15 09:34:06.837 - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=false)
            2024-01-15 09:34:06.837 - info: host.iobroker stopInstance system.adapter.awattar.0 (force=false, process=false)
            2024-01-15 09:34:06.842 - info: host.iobroker stopInstance canceled schedule system.adapter.awattar.0
            2024-01-15 09:34:06.842 - info: host.iobroker stopInstance system.adapter.lovelace.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.socketio.0 (force=false, process=true)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-2.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-material-advanced.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-2-widgets-material.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-2-widgets-energy.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-2-widgets-jaeger-design.0 (force=false, process=false)
            2024-01-15 09:34:06.843 - info: host.iobroker stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
            2024-01-15 09:34:06.914 - info: mqtt.0 (1032) Disconnected from 10.0.2.2: undefined
            2024-01-15 09:34:06.963 - info: statistics.0 (1244) terminating
            2024-01-15 09:34:06.964 - info: statistics.0 (1244) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.966 - info: admin.0 (953) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.967 - info: telegram.0 (1002) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.968 - info: mqtt.0 (1032) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.969 - info: modbus.0 (1062) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.971 - info: s7.0 (1079) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.972 - info: shelly.0 (1101) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.974 - info: modbus.1 (1116) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.976 - info: notification-manager.0 (1146) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.976 - info: modbus.3 (1161) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.977 - info: modbus.2 (1131) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.978 - info: backitup.0 (1192) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.979 - info: statistics.0 (1244) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.980 - info: socketio.0 (1274) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.982 - info: socketio.0 (1274) terminating
            2024-01-15 09:34:06.983 - info: socketio.0 (1274) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.983 - info: govee-local.0 (1259) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.984 - info: admin.0 (953) terminating
            2024-01-15 09:34:06.984 - info: admin.0 (953) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.985 - info: notification-manager.0 (1146) terminating
            2024-01-15 09:34:06.985 - info: notification-manager.0 (1146) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.986 - info: govee-local.0 (1259) terminating
            2024-01-15 09:34:06.986 - info: govee-local.0 (1259) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.984 - info: web.0 (1229) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.988 - info: modbus.0 (1062) terminating
            2024-01-15 09:34:06.988 - info: modbus.0 (1062) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.981 - info: fronius.0 (1207) Got terminate signal TERMINATE_YOURSELF
            2024-01-15 09:34:06.990 - info: s7.0 (1079) terminating
            2024-01-15 09:34:06.990 - info: s7.0 (1079) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.994 - info: mqtt.0 (1032) terminating
            2024-01-15 09:34:06.994 - info: modbus.2 (1131) terminating
            2024-01-15 09:34:06.995 - info: mqtt.0 (1032) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:06.995 - info: modbus.2 (1131) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.001 - info: backitup.0 (1192) terminating
            2024-01-15 09:34:07.002 - info: backitup.0 (1192) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.003 - info: modbus.1 (1116) terminating
            2024-01-15 09:34:07.004 - info: shelly.0 (1101) terminating
            2024-01-15 09:34:07.004 - info: shelly.0 (1101) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.004 - info: modbus.3 (1161) terminating
            2024-01-15 09:34:07.003 - info: modbus.1 (1116) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.005 - info: modbus.3 (1161) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.038 - info: influxdb.0 (987) terminating
            2024-01-15 09:34:07.039 - info: influxdb.0 (987) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.041 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
            2024-01-15 09:34:07.042 - info: mqtt-client.0 (1047) terminating
            2024-01-15 09:34:07.043 - info: mqtt-client.0 (1047) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.telegram.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.owfs.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.mqtt.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.modbus.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.s7.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.shelly.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.modbus.1 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.modbus.2 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.notification-manager.0 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.modbus.3 send kill signal
            2024-01-15 09:34:07.045 - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.fronius.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.statistics.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.govee-local.0 send kill signal
            2024-01-15 09:34:07.046 - info: host.iobroker stopInstance system.adapter.socketio.0 send kill signal
            2024-01-15 09:34:07.122 - info: web.0 (1229) terminated http server on port 8082
            2024-01-15 09:34:07.156 - info: telegram.0 (1002) terminating
            2024-01-15 09:34:07.157 - info: telegram.0 (1002) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.165 - info: web.0 (1229) terminating
            2024-01-15 09:34:07.166 - info: web.0 (1229) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.194 - info: notification-manager.0 (1146) terminating
            2024-01-15 09:34:07.227 - info: fronius.0 (1207) terminating
            2024-01-15 09:34:07.227 - info: fronius.0 (1207) Terminated (NO_ERROR): Without reason
            2024-01-15 09:34:07.251 - info: govee-local.0 (1259) terminating
            2024-01-15 09:34:07.253 - info: modbus.0 (1062) terminating
            2024-01-15 09:34:07.255 - info: admin.0 (953) terminating
            2024-01-15 09:34:07.258 - info: s7.0 (1079) terminating
            2024-01-15 09:34:07.260 - info: mqtt-client.0 (1047) terminating
            2024-01-15 09:34:07.264 - info: statistics.0 (1244) terminating
            2024-01-15 09:34:07.266 - info: web.0 (1229) terminating
            2024-01-15 09:34:07.270 - info: modbus.2 (1131) terminating
            2024-01-15 09:34:07.271 - info: modbus.1 (1116) terminating
            2024-01-15 09:34:07.272 - info: backitup.0 (1192) terminating
            2024-01-15 09:34:07.273 - info: modbus.3 (1161) terminating
            2024-01-15 09:34:07.276 - info: mqtt.0 (1032) terminating
            2024-01-15 09:34:07.326 - info: shelly.0 (1101) terminating
            2024-01-15 09:34:07.679 - info: host.iobroker instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.002 - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.002 - info: host.iobroker instance system.adapter.owfs.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.002 - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.002 - info: host.iobroker instance system.adapter.mqtt-client.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.096 - info: host.iobroker instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.096 - info: host.iobroker instance system.adapter.s7.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.096 - info: host.iobroker instance system.adapter.modbus.1 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.096 - info: host.iobroker instance system.adapter.modbus.2 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.096 - info: host.iobroker instance system.adapter.notification-manager.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.097 - info: host.iobroker stopInstance system.adapter.telegram.0 killing pid 1002
            2024-01-15 09:34:08.097 - info: host.iobroker stopInstance system.adapter.zigbee.0 killing pid 1176
            2024-01-15 09:34:08.097 - info: host.iobroker stopInstance system.adapter.fronius.0 killing pid 1207
            2024-01-15 09:34:08.097 - info: host.iobroker stopInstance system.adapter.web.0 killing pid 1229
            2024-01-15 09:34:08.191 - info: host.iobroker instance system.adapter.modbus.3 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.191 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.191 - info: host.iobroker instance system.adapter.govee-local.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.191 - info: host.iobroker instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.206 - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.206 - info: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
            2024-01-15 09:34:08.206 - info: host.iobroker All instances are stopped.
            2024-01-15 09:34:08.321 - warn: host.iobroker instance system.adapter.telegram.0 terminated due to SIGTERM
            2024-01-15 09:34:08.321 - info: host.iobroker instance system.adapter.telegram.0 terminated with code null ()
            2024-01-15 09:34:08.321 - info: host.iobroker All instances are stopped.
            2024-01-15 09:34:08.321 - warn: host.iobroker instance system.adapter.zigbee.0 terminated due to SIGTERM
            2024-01-15 09:34:08.322 - info: host.iobroker instance system.adapter.zigbee.0 terminated with code null ()
            2024-01-15 09:34:08.322 - info: host.iobroker All instances are stopped.
            2024-01-15 09:34:08.322 - warn: host.iobroker instance system.adapter.fronius.0 terminated due to SIGTERM
            2024-01-15 09:34:08.322 - info: host.iobroker instance system.adapter.fronius.0 terminated with code null ()
            2024-01-15 09:34:08.322 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGTERM
            2024-01-15 09:34:08.322 - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
            2024-01-15 09:34:08.356 - info: host.iobroker terminated
            2024-01-15 09:34:30.879 - info: host.iobroker iobroker.js-controller version 5.0.17 js-controller starting
            2024-01-15 09:34:30.882 - info: host.iobroker Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
            2024-01-15 09:34:30.882 - info: host.iobroker hostname: iobroker, node: v18.19.0
            2024-01-15 09:34:30.882 - info: host.iobroker ip addresses: 10.0.100.233 fe80::a00:27ff:fe05:7e90
            2024-01-15 09:34:31.729 - info: host.iobroker connected to Objects and States
            2024-01-15 09:34:31.748 - info: host.iobroker added notifications configuration of host
            2024-01-15 09:34:32.199 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
            2024-01-15 09:34:32.200 - info: host.iobroker 46 instances found
            2024-01-15 09:34:32.235 - info: host.iobroker starting 27 instances
            2024-01-15 09:34:32.307 - info: host.iobroker instance system.adapter.admin.0 started with pid 953
            2024-01-15 09:34:32.341 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
            2024-01-15 09:34:32.343 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
            2024-01-15 09:34:32.345 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
            2024-01-15 09:34:32.347 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
            2024-01-15 09:34:32.348 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
            2024-01-15 09:34:32.350 - info: host.iobroker Some obsolete host states deleted.
            2024-01-15 09:34:33.578 - info: admin.0 (953) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:34:33.592 - info: admin.0 (953) requesting all objects
            2024-01-15 09:34:34.286 - info: admin.0 (953) received all objects
            2024-01-15 09:34:34.345 - warn: admin.0 (953) No repository source configured. Possible values: none. Active repo(s): "stable"
            2024-01-15 09:34:34.394 - info: admin.0 (953) socket.io server listening on port 8081
            2024-01-15 09:34:34.396 - info: admin.0 (953) http server listening on port 8081
            2024-01-15 09:34:34.396 - info: admin.0 (953) Use link "http://127.0.0.1:8081" to configure.
            2024-01-15 09:34:36.305 - info: host.iobroker instance system.adapter.javascript.0 started with pid 980
            2024-01-15 09:34:36.526 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:92
            2024-01-15 09:34:36.526 - error: host.iobroker Caught by controller[0]: throw error;
            2024-01-15 09:34:36.526 - error: host.iobroker Caught by controller[0]: ^
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at parse ()
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:34:36.527 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            2024-01-15 09:34:36.528 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            2024-01-15 09:34:36.529 - error: host.iobroker Caught by controller[0]: }
            2024-01-15 09:34:36.529 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
            2024-01-15 09:34:36.529 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-15 09:34:36.529 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            2024-01-15 09:34:38.926 - info: admin.0 (953) failed connection to socket.io from ::ffff:10.0.0.134: Passport was not initialized
            2024-01-15 09:34:38.928 - info: admin.0 (953) failed connection to socket.io from ::ffff:10.0.0.134: Passport was not initialized
            2024-01-15 09:34:40.279 - info: host.iobroker instance system.adapter.influxdb.0 started with pid 987
            2024-01-15 09:34:41.401 - info: influxdb.0 (987) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:34:41.410 - info: influxdb.0 (987) No stored data from last exit found
            2024-01-15 09:34:41.411 - info: influxdb.0 (987) Connecting http://localhost:8086/ ...
            2024-01-15 09:34:41.411 - info: influxdb.0 (987) Influx DB Version used: 2.x
            2024-01-15 09:34:41.439 - info: influxdb.0 (987) Applying retention policy for iobroker to 31536000 seconds. Shard Group Duration (calculated): 604800 seconds
            2024-01-15 09:34:41.495 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_PUFFER_UNTEN, Alias=false, 1 points now activated
            2024-01-15 09:34:41.495 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.StromAllgemein.E02_Power_Sum__W, Alias=false, 2 points now activated
            2024-01-15 09:34:41.496 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.StromAllgemein.E02_PowerFactor, Alias=false, 3 points now activated
            2024-01-15 09:34:41.496 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.StromAllgemein.E02_Energy_import__kWh, Alias=false, 4 points now activated
            2024-01-15 09:34:41.496 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.StromAllgemein.E02_Energy_export__kWh, Alias=false, 5 points now activated
            2024-01-15 09:34:41.496 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_AU, Alias=false, 6 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_SW_RAUM, Alias=false, 7 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_SW_PUFFER_KONSTANT, Alias=false, 8 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_SW_PUFFER_SPAR, Alias=false, 9 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_SW_PUFFER, Alias=false, 10 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_PUFFER_OBEN, Alias=false, 11 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_WP_STATUS, Alias=false, 12 points now activated
            2024-01-15 09:34:41.497 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_VL, Alias=false, 13 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_WP, Alias=false, 14 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_SW_WP, Alias=false, 15 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-vt.Modbus.Waermepumpe.H01_MT_RL, Alias=false, 16 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of 0_userdata.0.Z00.power, Alias=false, 17 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of 0_userdata.0.Z00.consExport, Alias=false, 18 points now activated
            2024-01-15 09:34:41.498 - info: influxdb.0 (987) enabled logging of 0_userdata.0.Z00.consImport, Alias=false, 19 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of fronius.0.inverter.1.PAC, Alias=false, 20 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of fronius.0.inverter.1.UDC, Alias=false, 21 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of fronius.0.inverter.1.PDC, Alias=false, 22 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of fronius.0.inverter.1.TOTAL_ENERGY, Alias=false, 23 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R02_MT_EDV_OBEN, Alias=false, 24 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R03_MT_RAUM, Alias=false, 25 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of 0_userdata.0.R03_MF_RAUM, Alias=false, 26 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R02_MT_RAUM, Alias=false, 27 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R04_MT_RAUM, Alias=false, 28 points now activated
            2024-01-15 09:34:41.499 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R08_MT_RAUM, Alias=false, 29 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R11_MT_RAUM, Alias=false, 30 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R14_MT_RAUM, Alias=false, 31 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R15_MT_RAUM, Alias=false, 32 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R16_MT_RAUM, Alias=false, 33 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of owfs.0.wires.R17_MT_RAUM, Alias=false, 34 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of 0_userdata.0.R14_MF_RAUM, Alias=false, 35 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R03.humidity, Alias=false, 36 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R14.humidity, Alias=false, 37 points now activated
            2024-01-15 09:34:41.500 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.evu.power, Alias=false, 38 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.evu.consExport, Alias=false, 39 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.evu.consImport, Alias=false, 40 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.edv.temperatureOben, Alias=false, 41 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R03.temperature, Alias=false, 42 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R04.temperature, Alias=false, 43 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R08.temperature, Alias=false, 44 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R11.temperature, Alias=false, 45 points now activated
            2024-01-15 09:34:41.501 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R14.temperature, Alias=false, 46 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R15.temperature, Alias=false, 47 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R16.temperature, Alias=false, 48 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R17.temperature, Alias=false, 49 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.geschirrsp.power, Alias=false, 50 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.geschirrsp.energy, Alias=false, 51 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R90.temperature, Alias=false, 52 points now activated
            2024-01-15 09:34:41.502 - info: influxdb.0 (987) enabled logging of linkeddevices.0.ww.temperaturePufferOben, Alias=false, 53 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.ww.temperaturePufferUnten, Alias=false, 54 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.temperatureRl, Alias=false, 55 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.temperatureVl, Alias=false, 56 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.temperatureWp, Alias=false, 57 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.plc.s7-1500.cycleTime, Alias=false, 58 points now activated
            2024-01-15 09:34:41.503 - info: influxdb.0 (987) enabled logging of linkeddevices.0.R01.temperature, Alias=false, 59 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.status, Alias=false, 60 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.cons.heizen, Alias=false, 61 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.sw.puffer, Alias=false, 62 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.sw.pufferKonstant, Alias=false, 63 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.sw.pufferSpar, Alias=false, 64 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.sw.raum, Alias=false, 65 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.sw.wp, Alias=false, 66 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-main.H01_CONS_WWB.value, Alias=false, 67 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.cons.wwb, Alias=false, 68 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of mqtt.0.fhem-main.H01_CONS_ABTAUEN.value, Alias=false, 69 points now activated
            2024-01-15 09:34:41.504 - info: influxdb.0 (987) enabled logging of linkeddevices.0.hzg.cons.abtauen, Alias=false, 70 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.lftg.power, Alias=false, 71 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.lftg.energy, Alias=false, 72 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.speedABL, Alias=false, 73 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.speedZUL, Alias=false, 74 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.temperatureABL, Alias=false, 75 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.temperatureFOL, Alias=false, 76 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.temperatureVHR, Alias=false, 77 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.temperatureZUL, Alias=false, 78 points now activated
            2024-01-15 09:34:41.505 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.volumeABL, Alias=false, 79 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.volumeZUL, Alias=false, 80 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.stufe, Alias=false, 81 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.switch.summerWinter, Alias=false, 82 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.desired.volumeS4, Alias=false, 83 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.meter.pcBuero.power, Alias=false, 84 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of linkeddevices.0.lftg.sensors.temperatureFRL, Alias=false, 85 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.speedZUL, Alias=false, 86 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureZUL, Alias=false, 87 points now activated
            2024-01-15 09:34:41.506 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureVHR, Alias=false, 88 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureRaum, Alias=false, 89 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureFRL, Alias=false, 90 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureFOL, Alias=false, 91 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureABL, Alias=false, 92 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.volumeZUL, Alias=false, 93 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.volumeABL, Alias=false, 94 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.speedABL, Alias=false, 95 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.desired.volumeLevel4, Alias=false, 96 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.switch.level, Alias=false, 97 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.lftg.switch.season, Alias=false, 98 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.hzg.sensor.temperaturePufferDown, Alias=false, 99 points now activated
            2024-01-15 09:34:41.507 - info: influxdb.0 (987) enabled logging of alias.0.hzg.sensor.temperaturePufferUp, Alias=false, 100 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.hzg.sensor.temperatureOutside, Alias=false, 101 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.powerAC, Alias=false, 102 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.powerMPP1, Alias=false, 103 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.r04.sensor.temperature, Alias=false, 104 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.r01.sensor.temperature, Alias=false, 105 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.r90.sensor.temperature, Alias=false, 106 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.r90.sensor.humidity, Alias=false, 107 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.r90.sensor.temperature2, Alias=false, 108 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.voltageMPP2, Alias=false, 109 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.voltageMPP1, Alias=false, 110 points now activated
            2024-01-15 09:34:41.508 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.temperature, Alias=false, 111 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.pv.fronius10k.energyAC, Alias=false, 112 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.lftg.meter.power, Alias=false, 113 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.lftg.meter.energy, Alias=false, 114 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.hzg.meter.power, Alias=false, 115 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.hzg.meter.energy, Alias=false, 116 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.meter.evu.consExport, Alias=false, 117 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.meter.evu.consImport, Alias=false, 118 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.meter.evu.power, Alias=false, 119 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.hzg.meter.energyWaterheating, Alias=false, 120 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.hzg.meter.energyDefrosting, Alias=false, 121 points now activated
            2024-01-15 09:34:41.509 - info: influxdb.0 (987) enabled logging of alias.0.r09.sensor.temperature, Alias=false, 122 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r09.sensor.co2, Alias=false, 123 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r11.sensor.temperature, Alias=false, 124 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.controller.s7-1500.cycleTime, Alias=false, 125 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.hvt.sensor.temperatureOben, Alias=false, 126 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.edv.sensor.temperatureOben, Alias=false, 127 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.hvt.sensor.temperatureKKOben, Alias=false, 128 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r04.plug.pc.power, Alias=false, 129 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r04.plug.hzg.power, Alias=false, 130 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r04.plug.hzg.energy, Alias=false, 131 points now activated
            2024-01-15 09:34:41.510 - info: influxdb.0 (987) enabled logging of alias.0.r06.sensor.temperature, Alias=false, 132 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.meter.haus.power, Alias=false, 133 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.r11.plug.geschirrsp.energy, Alias=false, 134 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.r11.plug.geschirrsp.power, Alias=false, 135 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.humidityABLBox, Alias=false, 136 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureABLBox, Alias=false, 137 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.temperatureZULBox, Alias=false, 138 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.lftg.sensor.humidityZULBox, Alias=false, 139 points now activated
            2024-01-15 09:34:41.511 - info: influxdb.0 (987) enabled logging of alias.0.r14.sensor.temperature, Alias=false, 140 points now activated
            2024-01-15 09:34:41.514 - info: influxdb.0 (987) Connected!
            2024-01-15 09:34:43.210 - info: admin.0 (953) ==> Connected system.user.admin from ::ffff:10.0.0.134
            2024-01-15 09:34:43.496 - error: host.iobroker cannot call visUtils: Not exists
            2024-01-15 09:34:44.272 - info: host.iobroker instance system.adapter.telegram.0 started with pid 1002
            2024-01-15 09:34:45.504 - info: telegram.0 (1002) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:34:48.297 - info: host.iobroker instance system.adapter.owfs.0 started with pid 1017
            2024-01-15 09:34:48.921 - error: host.iobroker cannot call visUtils: Not exists
            2024-01-15 09:34:52.296 - info: host.iobroker instance system.adapter.mqtt.0 started with pid 1032
            2024-01-15 09:34:53.183 - info: mqtt.0 (1032) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:34:53.354 - info: mqtt.0 (1032) Try to connect to mqtt://10.0.2.2:1884 with clientId=iobroker.mqtt.0
            2024-01-15 09:34:53.402 - info: mqtt.0 (1032) Connected to 10.0.2.2
            2024-01-15 09:34:53.403 - info: mqtt.0 (1032) Subscribe on "#"
            2024-01-15 09:34:53.683 - info: mqtt.0 (1032) All states published
            2024-01-15 09:34:56.283 - info: host.iobroker instance system.adapter.mqtt-client.0 started with pid 1047
            2024-01-15 09:34:57.249 - info: mqtt-client.0 (1047) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:34:57.347 - info: mqtt-client.0 (1047) Try to connect to mqtt://10.0.2.2:1884?clientId=iobroker
            2024-01-15 09:34:58.087 - info: mqtt-client.0 (1047) connected to broker
            2024-01-15 09:35:00.269 - info: host.iobroker instance system.adapter.modbus.0 started with pid 1062
            2024-01-15 09:35:01.235 - info: modbus.0 (1062) starting. Version 6.0.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:01.659 - info: modbus.0 (1062) Connected to slave 10.0.1.27
            2024-01-15 09:35:04.283 - info: host.iobroker instance system.adapter.s7.0 started with pid 1079
            2024-01-15 09:35:05.240 - info: s7.0 (1079) starting. Version 1.3.15 in /opt/iobroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:06.562 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1094
            2024-01-15 09:35:06.725 - info: s7.0 (1079) Connect in S7 mode to 0 / 1
            2024-01-15 09:35:06.734 - info: s7.0 (1079) Successfully connected in S7 mode
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:92
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: throw error;
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: ^
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: at parse ()
            2024-01-15 09:35:06.817 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            2024-01-15 09:35:06.818 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: }
            2024-01-15 09:35:06.821 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
            2024-01-15 09:35:06.821 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-15 09:35:06.821 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            2024-01-15 09:35:08.281 - info: host.iobroker instance system.adapter.shelly.0 started with pid 1101
            2024-01-15 09:35:09.412 - info: shelly.0 (1101) starting. Version 6.6.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:09.872 - info: shelly.0 (1101) Starting in CoAP mode. Listening on 0.0.0.0:5683
            2024-01-15 09:35:09.923 - info: shelly.0 (1101) [CoAP Server] Listening for packets in the network
            2024-01-15 09:35:10.906 - info: shelly.0 (1101) [CoAP] Device 10.0.50.31 (shellyrgbw2 / shellyrgbw2-25A357 / SHRGBW2#25A357#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:10.908 - info: shelly.0 (1101) [CoAP] Device 10.0.50.25 (shellyrgbw2 / shellyrgbw2-25BDAA / SHRGBW2#25BDAA#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:11.293 - info: shelly.0 (1101) [CoAP] Device 10.0.50.36 (shellyrgbw2 / shellyrgbw2-E752A6 / SHRGBW2#E752A6#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:11.422 - info: shelly.0 (1101) [CoAP] Device 10.0.50.37 (shellyrgbw2 / shellyrgbw2-81E0BF / SHRGBW2#81E0BF#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:11.445 - info: shelly.0 (1101) [CoAP] Device 10.0.50.26 (shellyrgbw2 / shellyrgbw2-259CF8 / SHRGBW2#259CF8#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:11.721 - info: shelly.0 (1101) [CoAP] Device 10.0.50.24 (shellyrgbw2 / shellyrgbw2-25A725 / SHRGBW2#25A725#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:12.303 - info: host.iobroker instance system.adapter.modbus.1 started with pid 1116
            2024-01-15 09:35:12.792 - info: shelly.0 (1101) [CoAP] Device 10.0.50.22 (shellyrgbw2 / shellyrgbw2-D940AC / SHRGBW2#D940AC#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:13.319 - info: shelly.0 (1101) [CoAP] Device 10.0.50.35 (shellyrgbw2 / shellyrgbw2-25A78F / SHRGBW2#25A78F#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:13.765 - info: shelly.0 (1101) [CoAP] Device 10.0.50.23 (shellyrgbw2 / shellyrgbw2-D96999 / SHRGBW2#D96999#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:13.827 - info: modbus.1 (1116) starting. Version 6.0.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:14.198 - info: shelly.0 (1101) [CoAP] Device 10.0.50.20 (shellyrgbw2 / shellyrgbw2-D8FC06 / SHRGBW2#D8FC06#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:14.430 - info: shelly.0 (1101) [CoAP] Device 10.0.100.143 (shellyrgbw2 / shellyrgbw2-D8AEF4 / SHRGBW2#D8AEF4#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:14.460 - info: modbus.1 (1116) Connected to slave 10.0.0.80
            2024-01-15 09:35:15.564 - info: shelly.0 (1101) [CoAP] Device 10.0.50.34 (shellyrgbw2 / shellyrgbw2-25A7EA / SHRGBW2#25A7EA#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:16.325 - info: host.iobroker instance system.adapter.modbus.2 started with pid 1131
            2024-01-15 09:35:17.379 - info: modbus.2 (1131) starting. Version 6.0.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:17.830 - info: modbus.2 (1131) Connected to slave 10.0.0.81
            2024-01-15 09:35:19.197 - info: shelly.0 (1101) [CoAP] Device 10.0.50.32 (shellyrgbw2 / shellyrgbw2-25A53A / SHRGBW2#25A53A#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:20.280 - info: host.iobroker instance system.adapter.notification-manager.0 started with pid 1146
            2024-01-15 09:35:21.183 - info: notification-manager.0 (1146) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.notification-manager, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:21.194 - info: notification-manager.0 (1146) Starting notification manager ...
            2024-01-15 09:35:21.559 - info: shelly.0 (1101) [CoAP] Device 10.0.50.33 (shellyrgbw2 / shellyrgbw2-25B32C / SHRGBW2#25B32C#1) connected! Polltime set to 5 sec.
            2024-01-15 09:35:24.300 - info: host.iobroker instance system.adapter.modbus.3 started with pid 1161
            2024-01-15 09:35:25.416 - info: modbus.3 (1161) starting. Version 6.0.1 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:26.071 - info: modbus.3 (1161) Connected to slave
            2024-01-15 09:35:28.285 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 1176
            2024-01-15 09:35:32.297 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1192
            2024-01-15 09:35:33.317 - info: backitup.0 (1192) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:33.355 - info: backitup.0 (1192) [iobroker] backup will be activated at 02:40 every 1 day(s)
            2024-01-15 09:35:36.247 - info: host.iobroker instance system.adapter.fronius.0 started with pid 1207
            2024-01-15 09:35:36.907 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1218
            2024-01-15 09:35:37.137 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:92
            2024-01-15 09:35:37.137 - error: host.iobroker Caught by controller[0]: throw error;
            2024-01-15 09:35:37.137 - error: host.iobroker Caught by controller[0]: ^
            2024-01-15 09:35:37.137 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at parse ()
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-01-15 09:35:37.138 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            2024-01-15 09:35:37.139 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            2024-01-15 09:35:37.139 - error: host.iobroker Caught by controller[0]: }
            2024-01-15 09:35:37.139 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
            2024-01-15 09:35:37.139 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-15 09:35:37.139 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            2024-01-15 09:35:37.219 - info: fronius.0 (1207) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.fronius, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:40.297 - info: host.iobroker instance system.adapter.web.0 started with pid 1229
            2024-01-15 09:35:41.367 - info: web.0 (1229) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:41.534 - info: web.0 (1229) socket.io server listening on port 8082
            2024-01-15 09:35:41.536 - info: web.0 (1229) http server listening on port 8082
            2024-01-15 09:35:44.276 - info: host.iobroker instance system.adapter.statistics.0 started with pid 1244
            2024-01-15 09:35:45.273 - info: statistics.0 (1244) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.statistics, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:45.335 - info: statistics.0 (1244) [SETUP] enabled statistics for linkeddevices.0.meter.evu.power
            2024-01-15 09:35:45.335 - info: statistics.0 (1244) [SETUP] enabled statistics for linkeddevices.0.R04.temperature
            2024-01-15 09:35:45.335 - info: statistics.0 (1244) [SETUP] enabled statistics for linkeddevices.0.R90.temperature
            2024-01-15 09:35:45.336 - info: statistics.0 (1244) [SETUP] enabled statistics for linkeddevices.0.R09.sensors.temperature
            2024-01-15 09:35:45.336 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.pv.fronius10k.powerAC
            2024-01-15 09:35:45.336 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r04.sensor.temperature
            2024-01-15 09:35:45.336 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r01.sensor.temperature
            2024-01-15 09:35:45.336 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r90.sensor.temperature
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r90.sensor.humidity
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r90.sensor.temperature2
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r90.sensor.absHum
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.pv.fronius10k.energyAC
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.meter.power
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.meter.energy
            2024-01-15 09:35:45.337 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hzg.meter.power
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hzg.meter.energy
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.evu.consExport
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.evu.consImport
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.evu.power
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hzg.meter.energyWaterheating
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hzg.meter.energyHeating
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hzg.meter.energyDefrosting
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r09.sensor.temperature
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.evu.statistics.consImport.dayLast
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hvt.sensor.temperatureOben
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.hvt.sensor.temperatureKKOben
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r04.plug.hzg.power
            2024-01-15 09:35:45.338 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r04.plug.hzg.energy
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r04.plug.hzg.statistics.energy.dayLast
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r06.sensor.temperature
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.haus.energy
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.haus.power
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.haus.selfConsumptionRate
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.haus.energyFromGrid
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.meter.haus.energyFromPV
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r08.sensor.temperature
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.r11.plug.geschirrsp.energy
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.sensor.humidityABLBox
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.sensor.temperatureABLBox
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.sensor.temperatureZULBox
            2024-01-15 09:35:45.339 - info: statistics.0 (1244) [SETUP] enabled statistics for alias.0.lftg.sensor.humidityZULBox
            2024-01-15 09:35:48.341 - info: host.iobroker instance system.adapter.govee-local.0 started with pid 1259
            2024-01-15 09:35:49.552 - info: govee-local.0 (1259) starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.govee-local, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:51.921 - info: statistics.0 (1244) [SETUP] observing 41 values after startup
            2024-01-15 09:35:52.348 - info: host.iobroker instance scheduled system.adapter.awattar.0 18,19 9 * * *
            2024-01-15 09:35:56.287 - info: host.iobroker instance system.adapter.socketio.0 started with pid 1274
            2024-01-15 09:35:57.475 - info: socketio.0 (1274) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.19.0, js-controller: 5.0.17
            2024-01-15 09:35:57.496 - warn: socketio.0 (1274) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
            2024-01-15 09:35:57.519 - info: socketio.0 (1274) socket.io server listening on port 8084
            2024-01-15 09:36:07.188 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1289
            2024-01-15 09:36:07.404 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:92
            2024-01-15 09:36:07.404 - error: host.iobroker Caught by controller[0]: throw error;
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: ^
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at parse ()
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            2024-01-15 09:36:07.405 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: }
            2024-01-15 09:36:07.406 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
            2024-01-15 09:36:07.406 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-15 09:36:07.406 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            2024-01-15 09:36:37.454 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1296
            2024-01-15 09:36:37.697 - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:92
            2024-01-15 09:36:37.697 - error: host.iobroker Caught by controller[0]: throw error;
            2024-01-15 09:36:37.697 - error: host.iobroker Caught by controller[0]: ^
            2024-01-15 09:36:37.697 - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
            2024-01-15 09:36:37.697 - error: host.iobroker Caught by controller[0]: at parse ()
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
            2024-01-15 09:36:37.698 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: }
            2024-01-15 09:36:37.699 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
            2024-01-15 09:36:37.699 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            2024-01-15 09:36:37.699 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            • Codierknecht
              Codierknecht Developer Most Active @fhainz last edited by
              @fhainz sagte in js-controller startet immer wieder neu:
              seit heute morgen
              Was hast Du geändert?
              Sowas kommt in der Regel nicht aus heiterem Himmel.
              fhainz 1 Reply Last reply Reply Quote 0
              • fhainz
                fhainz @Codierknecht last edited by
                @codierknecht
                Nein, nichts geändert. Bis 05:15 lief alles normal.
                Als ich heute morgen aufgestanden bin, ging schon nichts mehr.
                iob diag
                			v.2023-10-10
                 Static hostname: iobroker
                       Icon name: computer-vm
                         Chassis: vm
                  Virtualization: oracle
                Operating System: Ubuntu 22.04.3 LTS
                          Kernel: Linux 5.15.0-91-generic
                    Architecture: x86-64
                 Hardware Vendor: innotek GmbH
                  Hardware Model: VirtualBox
                Installation: 		oracle
                Kernel: 		x86_64
                Userland: 		amd64
                Timezone: 		Etc/UTC (UTC, +0000)
                User-ID: 		1000
                X-Server: 		false
                Boot Target: 		graphical.target
                Pending OS-Updates: 	0
                Error: Object "system.repositories" not found
                Pending iob updates: 	0
                Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
                			/usr/bin/node 		v18.19.0
                			/usr/bin/npm 		10.2.3
                			/usr/bin/npx 		10.2.3
                			/usr/bin/corepack 	0.22.0
                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                MEMORY:
                Mem:            7.9G        1.7G        5.3G        1.0M        991M        6.0G
                Swap:             0B          0B          0B
                Total:          7.9G        1.7G        5.3G
                Active iob-Instances: 	21
                List is empty
                ioBroker Core: 		js-controller 		5.0.17
                			admin 			6.12.0
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects: 		11044
                States: 		8689
                Size of iob-Database:
                13M	/opt/iobroker/iobroker-data/objects.jsonl
                24M	/opt/iobroker/iobroker-data/states.jsonl
                Anscheinend wird system.repositories nicht gefunden?
                  Homoran Global Moderator Administrators @fhainz last edited by
                  SUMMARY
                  bitte full Ausgabe
                    Thomas Braun Most Active @fhainz last edited by
                    Die Langfassung.
                    Aber die Zeitzone und das Boot-Target kannste schon direkt korrigieren.
                    • fhainz
                      Ich hänge iob diag an, ist leider zu lange für das Forum.
                      iob.txt
                      Wie kann ich die Zeitzone und Boot-Target korrigieren?
                        dann bitte teilen!
                        • fhainz
                          fhainz @Homoran last edited by
                          Ist ja im Beitrag dabei? Klick mal auf iob.txt
                          Homoran 1 Reply Last reply Reply Quote -1
                            ach was!
                            und wie bekomme ich das am Handy auf?
                            • fhainz
                              @homoran Ok, dann versuche ich es in mehreren Beiträgen aufzuteilen.
                              Teil 1
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Chassis: vm
                              model name	: Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
                              Docker          : false
                              Virtualization  : oracle
                              Kernel          : x86_64
                              Userland        : amd64
                              Systemuptime and Load:
                               09:54:08 up 19 min,  2 users,  load average: 0.65, 0.59, 0.42
                              CPU threads: 2
                              *** Time and Time Zones ***
                                             Local time: Mon 2024-01-15 09:54:08 UTC
                                         Universal time: Mon 2024-01-15 09:54:08 UTC
                                               RTC time: Mon 2024-01-15 09:54:09
                                              Time zone: Etc/UTC (UTC, +0000)
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              fabian
                              /home/fabian
                              fabian adm cdrom sudo dip plugdev lxd iobroker
                              *** X-Server-Setup ***
                              X-Server: 	false
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Mem:            7.9G        1.8G        5.2G        1.0M        1.0G        5.9G
                              Swap:             0B          0B          0B
                              Total:          7.9G        1.8G        5.2G
                                       7938 M total memory
                                       1755 M used memory
                                        482 M active memory
                                       2008 M inactive memory
                                       5150 M free memory
                                        118 M buffer memory
                                        914 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              Filesystem                        Type   Size  Used Avail Use% Mounted on
                              tmpfs                             tmpfs  794M  1.2M  793M   1% /run
                              /dev/mapper/ubuntu--vg-ubuntu--lv ext4    18G   16G  1.4G  93% /
                              tmpfs                             tmpfs  3.9G     0  3.9G   0% /dev/shm
                              tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                              /dev/sda2                         ext4   1.8G  252M  1.4G  16% /boot
                              tmpfs                             tmpfs  794M  4.0K  794M   1% /run/user/1000
                              [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              [Mon Jan 15 09:34:19 2024] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
                              [Mon Jan 15 09:34:20 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                              TARGET              SOURCE                            FSTYPE   OPTIONS
                              /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                              |-/snap/snapd/20671 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
                              |-/snap/snapd/20290 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
                              |-/snap/core20/2015 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
                              |-/snap/lxd/24322   /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
                              |-/snap/core20/2105 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
                              `-/boot             /dev/sda2                         ext4     rw,relatime
                              /var:
                              8.6G	/var/
                              7.2G	/var/lib
                              6.5G	/var/lib/influxdb/engine/data
                              Archived and active journals take up 808.3M in the file system.
                              /opt/iobroker/backups:
                              4.0K	/opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              1.1G	/opt/iobroker/iobroker-data/
                              650M	/opt/iobroker/iobroker-data/files
                              200M	/opt/iobroker/iobroker-data/history
                              190M	/opt/iobroker/iobroker-data/backup-objects
                              166M	/opt/iobroker/iobroker-data/files/vis-2
                              27M	/opt/iobroker/iobroker-data/states.jsonl
                              24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                              24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                              23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                              22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03188557-if00-port0
                              /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A907AG4V-if00-port0
                              *** NodeJS-Installation ***
                              /usr/bin/npm 		10.2.3
                              /usr/bin/npx 		10.2.3
                              nodejs:
                                Installed: 18.19.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                               *** 18.19.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   18.18.2-1nodesource1 500
                                   18.18.1-1nodesource1 500
                                   18.18.0-1nodesource1 500
                                   18.17.1-1nodesource1 500
                                   18.17.0-1nodesource1 500
                                   18.16.1-1nodesource1 500
                                   18.16.0-1nodesource1 500
                                   18.15.0-1nodesource1 500
                                   18.14.2-1nodesource1 500
                                   18.14.1-1nodesource1 500
                                   18.14.0-1nodesource1 500
                                   18.13.0-1nodesource1 500
                                   18.12.0-1nodesource1 500
                                   18.11.0-1nodesource1 500
                                   18.10.0-1nodesource1 500
                                   18.9.1-1nodesource1 500
                                   18.9.0-1nodesource1 500
                                   18.8.0-1nodesource1 500
                                   18.7.0-1nodesource1 500
                                   18.6.0-1nodesource1 500
                                   18.5.0-1nodesource1 500
                                   18.4.0-1nodesource1 500
                                   18.3.0-1nodesource1 500
                                   18.2.0-1nodesource1 500
                                   18.1.0-1nodesource1 500
                                   18.0.0-1nodesource1 500
                                   12.22.9~dfsg-1ubuntu3.3 500
                                      500 http://at.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                      500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                   12.22.9~dfsg-1ubuntu3 500
                                      500 http://at.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                              No problems detected
                              Errors in npm tree:
                              npm ERR! code ELSPROBLEMS
                              npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
                              npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
                              npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
                              npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
                              npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                              npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                              npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                              npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
                              npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                              npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                              npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                              npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
                              npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
                              npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
                              npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
                              npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
                              npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
                              npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
                              npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
                              npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
                              npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
                              npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                              npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                              npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                              npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
                              npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                              npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                              npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                              npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                              npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
                              npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
                              npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                              npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
                              npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
                              npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
                              npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
                              npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
                              npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
                              npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
                              npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
                              npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
                              npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                              npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
                              npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
                              npm ERR! invalid: @types/node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                              npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                              npm ERR! extraneous: @ungap/structured-clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                              npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
                              npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
                              npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
                              npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                              npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                              npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv
                              npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
                              npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
                              npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                              npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                              npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                              npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                              npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                              npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                              npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                              npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                              npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                              npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                              npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                              npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                              npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                              npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                              npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                              npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
                              npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                              npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                              npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                              npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                              npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                              npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/asn1
                              npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assert-plus
                              npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                              npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                              npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
                              npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                              npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
                              npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                              npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                              npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                              npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                              npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws-sign2
                              npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/aws4
                              npm ERR! invalid: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/axios
                              npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                              npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                              npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                              npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
                              npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
                              npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bcrypt-pbkdf
                              npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                              npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
                              npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
                              npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
                              npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
                              npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                              npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                              npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
                              npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                              npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
                              npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
                              npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
                              npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
                              npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
                              npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                              npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                              npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
                              npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                              npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                              npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                              npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                              npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/caseless
                              npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
                              npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                              npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                              npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                              npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                              npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                              npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
                              npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                              npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                              npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                              npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                              npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                              npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                              npm ERR! invalid: coffeescript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript
                              npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                              npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
                              npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                              npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                              npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                              npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                              npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
                              npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                              npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                              npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                              npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
                              npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
                              npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
                              npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
                              npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                              npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
                              npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
                              npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                              npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                              npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/core-util-is
                              npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
                              npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser
                              npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                              npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
                              npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
                              npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                              npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dashdash
                              npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/debug
                              npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                              npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                              npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                              npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                              npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                              npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                              npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
                              npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                              npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                              npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
                              npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
                              npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                              npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
                              npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                              npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                              npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
                              npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
                              npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
                              npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
                              npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
                              npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                              npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                              npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                              npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
                              npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
                              npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ecc-jsbn
                              npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
                              npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                              npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
                              npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                              npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
                              npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
                              npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
                              npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                              npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
                              npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                              npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                              npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                              npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                              npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                              npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                              npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
                              npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                              npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
                              npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                              npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                              npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                              npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                              npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
                              npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                              npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                              npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                              npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                              npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
                              npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
                              npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
                              npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                              npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                              npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                              npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
                              npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                              npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                              npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend
                              npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                              npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extsprintf
                              npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                              npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-deep-equal
                              npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                              npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-json-stable-stringify
                              npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
                              npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                              npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
                              npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path
                              npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                              npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
                              npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                              npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
                              npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
                              npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
                              npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
                              npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
                              npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
                              npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
                              npm ERR! extraneous: follow-redirects@1.15.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/follow-redirects
                              npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
                              npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
                              npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/forever-agent
                              npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
                              npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
                              npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
                              npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
                              npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
                              npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
                              npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
                              npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents
                              npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
                              npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
                              npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
                              npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
                              npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
                              npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
                              npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/getpass
                              npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
                              npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
                              npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
                              npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
                              npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
                              npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
                              npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
                              npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
                              npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
                              npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
                              npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd
                              npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
                              npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
                              npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
                              npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
                              npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                              npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
                              npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
                              npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-schema
                              npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator
                              npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
                              npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors
                              npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto
                              npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
                              npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
                              npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
                              npm ERR! extraneous: hasown@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hasown
                              npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
                              npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
                              npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
                              npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
                              npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
                              npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
                              npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
                              npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-signature
                              npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                              npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
                              npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
                              npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                              npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/immediate
                              npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
                              npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                              npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                              npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                              npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
                              npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                              npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                              npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                              npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
                              npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                              npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                              npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                              npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                              npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                              npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                              npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                              npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                              npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                              npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                              npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                              npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                              npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                              npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
                              npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                              npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                              npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                              npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                              npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                              npm ERR! extraneous: is-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-stream
                              npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-typedarray
                              npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                              npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                              npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                              npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                              npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                              npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
                              npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/isarray
                              npm ERR! extraneous: isexe@
                              npm ERR! A complete log of this run can be found in: /home/fabian/.npm/_logs/2024-01-15T09_54_11_756Z-debug-0.log
                              so geht es noch einige zeilen weiter...
                              • fhainz
                                fhainz @fhainz last edited by
                                nach dem npm ERR! ... kommt noch das:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Core adapters versions
                                admin: 		6.12.0
                                javascript: 	7.1.6
                                Adapters from github: 	2
                                Adapter State
                                  system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
                                  system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                  system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                  system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                  system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
                                + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                                + system.adapter.govee-local.0            : govee-local           : iobroker                                 -  enabled
                                  system.adapter.govee.0                  : govee                 : iobroker                                 - disabled
                                  system.adapter.history.0                : history               : iobroker                                 - disabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                  system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 - disabled
                                  system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                                  system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                                + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                                + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                                + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
                                + system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 -  enabled, port: 1884
                                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                  system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
                                + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                                + system.adapter.owfs.0                   : owfs                  : iobroker                                 -  enabled, port: 4304
                                  system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                  system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
                                  system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                  system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1887, bind: 0.0.0.0
                                + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                                  system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
                                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                                  system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                                  system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB1
                                + instance is alive
                                ioBroker-Repositories
                                List is empty
                                Installed ioBroker-Instances
                                Objects and States
                                Objects: 	11044
                                States: 	8689
                                Hit:1 http://at.archive.ubuntu.com/ubuntu jammy InRelease
                                Hit:2 http://at.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                Hit:3 http://at.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                Hit:4 https://repos.influxdata.com/debian stable InRelease
                                Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        21829      660/systemd-resolve
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20100      734/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15796      1/init
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22586      799/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22433      799/iobroker.js-con
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22666      953/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24575      1229/io.web.0
                                tcp6       0      0 :::8084                 :::*                    LISTEN      1001       25139      1274/io.socketio.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      998        22198      702/influxd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          20114      734/sshd: /usr/sbin
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          15798      1/init
                                udp        0      0 0.0.0.0:45390           0.0.0.0:*                           1001       25163      1259/io.govee-local
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24122      1101/io.shelly.0
                                udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       25009      1259/io.govee-local
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        21828      660/systemd-resolve
                                udp        0      0 10.0.100.233:68         0.0.0.0:*                           101        19831      658/systemd-network
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15797      1/init
                                udp6       0      0 :::111                  :::*                                0          15799      1/init
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:     at node:internal/main/run_main_module:28:49 {
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]: }
                                2024-01-15 09:54:18.186  - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
                                2024-01-15 09:54:18.187  - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2024-01-15 09:54:18.187  - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                iob diag has finished.
                                Press any key for a summary
                                  @fhainz hast du an den Skripten etwas verändert?
                                  der Adapter wird beendet, und ein modul cron-parser angemeckert.
                                  Hast du das zusätzlich installiert?
                                  startet wirklich der controller neu?
                                    javascript
                                    Installier den Adapter javascript nochmal.
                                    • fhainz
                                      Nein, wie gsagt, bin heute morgen auf und nichts ging mehr. Hab gestern nur an der vis-2 gebastelt. Hab auch alle Skripte, sowie den vis und den vis-2 adapter deaktiviert.
                                      Nein, cron-parser hab ich nicht (bewusst) installiert.
                                      Ja, der Javascript Adapter startet immer wieder, mit den unterstehenden Meldungen, neu.
                                      host.iobroker
                                      2024-01-15 11:26:36.598	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:26:36.598	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:26:36.597	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:26:36.354	info	instance system.adapter.javascript.0 started with pid 6146
                                      host.iobroker
                                      2024-01-15 11:26:06.287	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:26:06.287	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:26:06.286	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:26:06.078	info	instance system.adapter.javascript.0 started with pid 6139
                                      host.iobroker
                                      2024-01-15 11:25:35.947	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:25:35.947	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:25:35.947	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:25:35.946	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:25:35.945	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:25:35.945	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:25:35.945	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:25:35.945	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:25:35.749	info	instance system.adapter.javascript.0 started with pid 6132
                                      host.iobroker
                                      2024-01-15 11:25:05.702	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:25:05.702	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:05.701	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:25:05.699	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:25:05.698	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:25:05.698	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:25:05.698	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:25:05.466	info	instance system.adapter.javascript.0 started with pid 6125
                                      host.iobroker
                                      2024-01-15 11:24:35.396	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:24:35.396	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:24:35.395	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:24:35.161	info	instance system.adapter.javascript.0 started with pid 6115
                                      host.iobroker
                                      2024-01-15 11:24:05.122	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:24:05.122	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:24:05.121	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:24:04.869	info	instance system.adapter.javascript.0 started with pid 6107
                                      host.iobroker
                                      2024-01-15 11:23:34.777	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:23:34.777	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:23:34.776	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:23:34.567	info	instance system.adapter.javascript.0 started with pid 6100
                                      host.iobroker
                                      2024-01-15 11:23:04.513	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:23:04.513	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:23:04.512	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:23:04.268	info	instance system.adapter.javascript.0 started with pid 6086
                                      host.iobroker
                                      2024-01-15 11:22:34.229	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:22:34.229	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:22:34.229	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:22:34.229	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:22:34.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:22:34.227	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:22:34.022	info	instance system.adapter.javascript.0 started with pid 5942
                                      host.iobroker
                                      2024-01-15 11:22:03.982	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:22:03.982	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:22:03.982	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:22:03.981	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:22:03.980	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:22:03.711	info	instance system.adapter.javascript.0 started with pid 5935
                                      host.iobroker
                                      2024-01-15 11:21:33.652	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:21:33.652	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:21:33.651	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:21:33.650	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:21:33.650	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:21:33.431	info	instance system.adapter.javascript.0 started with pid 5928
                                      host.iobroker
                                      2024-01-15 11:21:03.380	info	Restart adapter system.adapter.javascript.0 because enabled
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[1]: Node.js v18.19.0
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: }
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      2024-01-15 11:21:03.380	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: at parse (<anonymous>)
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: ^
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: throw error;
                                      host.iobroker
                                      2024-01-15 11:21:03.379	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                      host.iobroker
                                      2024-01-15 11:21:03.174	info	instance system.adapter.javascript.0 started with pid 5921
                                      Die Uhrzeit passt nun plötzlich wieder.
                                      In den Repository-Einstellungen verschwinden nach dem Speichern beide Einträge wieder.
                                      • fhainz
                                        fhainz @Thomas Braun last edited by
                                        Hab ich getan. Leider keine Änderung.
                                        host.iobroker
                                        2024-01-15 11:30:38.294	info	Restart adapter system.adapter.javascript.0 because enabled
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: Node.js v18.19.0
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: }
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json'
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49 {
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:47:23)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/index.js:4:46)
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:4:18)
                                        host.iobroker
                                        host.iobroker
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1120:27)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:658:31)
                                        host.iobroker
                                        2024-01-15 11:30:38.294	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:580:15)
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: at readPackage (node:internal/modules/package_json_reader:140:10)
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: at read (node:internal/modules/package_json_reader:79:16)
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: at parse (<anonymous>)
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/iobroker.javascript/node_modules/cron-parser/package.json: Unexpected end of JSON input
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: ^
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: throw error;
                                        host.iobroker
                                        2024-01-15 11:30:38.293	error	Caught by controller[0]: node:internal/modules/package_json_reader:92
                                        host.iobroker
                                        2024-01-15 11:30:38.058	info	instance system.adapter.javascript.0 started with pid 6221
                                        host.iobroker
                                        2024-01-15 11:30:36.470	error	cannot call visUtils: Not exists
                                          Homoran Global Moderator Administrators @fhainz last edited by
                                          @fhainz sagte in js-controller startet immer wieder neu:
                                          aber laut Threadtitel der js-controller!!
                                          und danach suche ich die ganze Zeit
                                          fhainz 1 Reply Last reply Reply Quote 0
                                            auch den Javascript Adapter?
                                            2312
