    4. [gelöst] Javascript Adapter stürzt ab
    • blue231181
      blue231181 last edited by blue231181
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Mitac PC
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu
      Node-Version: 19.9.0
      Nodejs-Version: command not found
      NPM-Version: 9.6.3
      Installationsart: Skript
      ich habe seit 3 Tagen das Problem das mein Javascript Adapter in unregelmäßigen Abständen abstürzt.
      Hier der Log dazu:
      2024-01-15 21:07:00.119 - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 253355
      2024-01-15 21:07:05.103 - info: openweathermap.0 (253355) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v19.9.0, js-controller: 5.0.17
      2024-01-15 21:07:24.977 - info: openweathermap.0 (253355) Terminated (NO_ERROR): Without reason
      2024-01-15 21:07:25.513 - info: host.iobroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2024-01-15 21:09:17.519 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
      2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052324 ms: Scavenge 2042.5 (2081.4) -> 2042.0 (2081.9) MB, 15.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
      2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052350 ms: Scavenge 2043.1 (2081.9) -> 2042.7 (2082.9) MB, 18.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
      2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: [241690:0x6791ae0] 8052376 ms: Scavenge 2043.9 (2082.9) -> 2043.4 (2087.4) MB, 16.4 / 0.0 ms (average mu = 0.182, current mu = 0.201) allocation failure;
      2024-01-15 21:09:17.520 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[1]: 1: 0xbf9890 node::Abort() [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[2]: 2: 0xaf6859 [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[3]: 3: 0xddaf80 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[4]: 4: 0xddb336 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[5]: 5: 0xfd9db5 [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[6]: 6: 0xfda366 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0]
      2024-01-15 21:09:17.521 - error: host.iobroker Caught by controller[7]: 7: 0xfec656 [io.javascript.0]
      2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[8]: 8: 0xfed295 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
      2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[9]: 9: 0xfef978 v8::internal::Heap::HandleGCRequest() [io.javascript.0]
      2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[10]: 10: 0xf69be7 v8::internal::StackGuard::HandleInterrupts() [io.javascript.0]
      2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[11]: 11: 0x13bd365 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
      2024-01-15 21:09:17.522 - error: host.iobroker Caught by controller[12]: 12: 0x18443f9 [io.javascript.0]
      2024-01-15 21:09:17.522 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
      2024-01-15 21:09:17.522 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
      2024-01-15 21:09:17.523 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
      2024-01-15 21:09:47.865 - info: host.iobroker instance system.adapter.javascript.0 started with pid 253608
      2024-01-15 21:09:52.402 - info: javascript.0 (253608) starting. Version 7.1.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v19.9.0, js-controller: 5.0.17
      2024-01-15 21:09:55.489 - info: javascript.0 (253608) requesting all states
      2024-01-15 21:09:55.492 - info: javascript.0 (253608) requesting all objects
      2024-01-15 21:10:01.666 - info: javascript.0 (253608) received all objects
      2024-01-15 21:10:03.022 - info: javascript.0 (253608) received all states
      2024-01-15 21:10:03.796 - info: javascript.0 (253608) Start javascript script.js.2021-04-09-scripts.Abfragen.Garagentor_Auf_Fährt_Zu
      es wurden keine neuen Scripte erstellt oder geändert.
      System läuft auf einem Proxmox Container unter Ubuntu.
      @iobroker:~# npm -v
      9.6.3
      @iobroker:~# node -v
      v19.9.0
      @iobroker:~# nodejs -v
      -bash: nodejs: command not found
      @iobroker:~# iob status
      Objects type: jsonl
      States  type: jsonl
      Danke im voraus und viele Grüße
      Codierknecht haus-automatisierung Homoran Thomas Braun 4 Replies Last reply Reply Quote 0
      • Codierknecht
        Codierknecht Developer Most Active @blue231181 last edited by
        @blue231181 sagte in Javascript Adapter stürzt ab:
        Was sagt
        iob diag
        • haus-automatisierung
          haus-automatisierung Developer Most Active @blue231181 last edited by
          Für die nodejs und npm version wirst du gleich auf die Finger bekommen 🙂 Zieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!
          Codierknecht 1 Reply Last reply Reply Quote 3
            Homoran Global Moderator Administrators @blue231181 last edited by
            v19.9.0
            wie kommst du denn an das krumme Ding?
            • Codierknecht
              Codierknecht Developer Most Active @haus-automatisierung last edited by
              @haus-automatisierung sagte in Javascript Adapter stürzt ab:
              3 ... 2 ... 1 😁
                Thomas Braun Most Active @blue231181 last edited by
                @blue231181
                NICHT als root herumhampeln. (Auch wenn du den verschämt löschst sieht man das noch...)
                Als USER!:
                iob nodejs-update 18
                • blue231181
                  @Codierknecht
                  @haus-automatisierung (wow ich glaubs nicht mein persönlicher youtube Held 💓 😳 , danke für all die genialen Videos und super Erklärungen)
                  @Homoran
                  euch allen Danke erstmal das ihr hier im Forum so aktiv seid und es zu dem macht was ioBroker ausmacht
                  @Codierknecht ich habe einen neuen Benutzer angelegt. @Thomas-Braun hat recht ich habe es zu meiner Schande schön verstecken wollen. Nun mit dem neuen Benutzer kommt folgende Meldung:
                  Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on iobroker.local.
                  Also habe ich das folgende durchgelesen: ioBroker Forum diag-skript was ich feststellen musste, von @Thomas-Braun entwickelt wurde. Hier hat Thomas wohl auch die LXC Container (Proxmox) mit auslesen können.
                  Nun habe ich mal meine Version überprüft und folgendes ist heraus gekommen:
                  blue2311@iobroker:~$ cat /etc/*release
                  PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                  NAME="Debian GNU/Linux"
                  VERSION_ID="11"
                  VERSION="11 (bullseye)"
                  VERSION_CODENAME=bullseye
                  ID=debian
                  HOME_URL="https://www.debian.org/"
                  SUPPORT_URL="https://www.debian.org/support"
                  BUG_REPORT_URL="https://bugs.debian.org/"
                  Also muss ich zu meiner weiteren Schande gestehen das es kein Ubuntu System ist, sondern ein Bullseye 11 Debian.
                  @haus-automatisierung "Für die nodejs und npm version wirst du gleich auf die Finger bekommen 🙂 Zieh das erstmal gerade. Wie ist das nodejs auf das System gekommen? Wahrscheinlich nicht über apt?!" mit "apt-get" konnte ich diverse updates fahren..
                  "Für die nodejs und npm version wirst du gleich auf die Finger bekommen" bitte nicht. Ich bin kein entwickler, hab auch niemals Informatiker gelernt aber mir macht es als Hobby Spass und ich bin unendlich dankbar hier im Forum immer wieder auf so nette und hilfsbereite Menschen zu treffen. Also nicht hauen 😖
                  und zu guter letzt @Thomas-Braun:
                  blue2311@iobroker:~$ iob nodejs-update 18
                  [sudo] password for blue2311:
                  Sorry, user blue2311 is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/node-update.sh --output /home/iobroker/.nodejs-update.sh' as iobroker on iobroker.local.
                  Thomas Braun Homoran haus-automatisierung 4 Replies Last reply Reply Quote 0
                    blue2311
                    Dann ist der user nicht in den rudimentärsten Gruppen drin.
                    Als dieser User:
                    groups
                      das gilt hier für >90% der User.
                      aber node v19 kommt dann üblicherweise nicht bei raus
                      das ist das Problem wenn nicht von Anfang an mit dem User gearbeitet wird, dann hat er nicht automatisch die notwendigen Rechte und/oder die Nutzung von Root hat gewisse Rechte verbogen, dass der Systemuser iobroker und dein neuer User da nicht dran dürfen.
                      Erschwerend kommt dein Konstrukt mit Container dazu, wo wiederum zusätzlich Dinge richtig eingestellt sein müssen
                        @blue231181
                        In der Doku steht auch drin, wie man im Container einen user anlegt:
                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                        blue231181 1 Reply Last reply Reply Quote 1
                        • blue231181
                          blue231181 @Thomas Braun last edited by
                          @thomas-braun @Homoran also wäre eine Neuinstallation mit einspielen des Backups am sinnvollsten wenn so viel schief liegt?
                            Das musst du selber entscheiden.
                            • blue231181
                              @thomas-braun ja ich versuchs mit Neuinstallation bevor ich das krumme System anpasse
                              Danke an alle
                                @blue231181 sagte in [gelöst] Javascript Adapter stürzt ab:
                                Gern, dort habe ich übrigens auch gezeigt wie man einen neuen Benutzer im LXC anlegt usw.
                                https://youtu.be/p6XmgzhH0Ow?si=ybEmskSEjmE_c6vc&t=1113
                                • blue231181
                                  blue231181 @haus-automatisierung last edited by blue231181
                                  muss hier leider wieder öffnen.
                                  Habe nach bestem Wissen und gewissen mein System gerade gezogen
                                  Leider stürzt der Javascript Adapter weiterhin ab.
                                  Hier der Auszug vom Iob Diag
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer-container
                                             Chassis: container
                                      Virtualization: lxc
                                    Operating System: Debian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 5.15.131-2-pve
                                        Architecture: x86-64
                                  model name      : Intel(R) Celeron(R) CPU  J1900  @ 1.99GHz
                                  Docker          : false
                                  Virtualization  : lxc
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   05:45:53 up 21:39,  1 user,  load average: 1.82, 1.66, 1.35
                                  CPU threads: 4
                                  *** Time and Time Zones ***
                                                 Local time: Thu 2024-01-18 05:45:53 CET
                                             Universal time: Thu 2024-01-18 04:45:53 UTC
                                                   RTC time: n/a
                                                NTP service: inactive
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  blue2311
                                  /home/blue2311
                                  blue2311 sudo
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:
                                  *** MEMORY ***
                                  Mem:            7.8G        3.7G        3.5G        0.0K        592M        4.1G
                                  Swap:             0B          0B          0B
                                  Total:          7.8G        3.7G        3.5G
                                           7822 M total memory
                                           3689 M used memory
                                            167 M active memory
                                           3918 M inactive memory
                                           3541 M free memory
                                              0 M buffer memory
                                            592 M swap cache
                                              0 M total swap
                                              0 M used swap
                                              0 M free swap
                                  *** FAILED SERVICES ***
                                    UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                                  * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
                                  * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
                                  * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
                                  3 loaded units listed.
                                  *** FILESYSTEM ***
                                  Filesystem                       Type      Size  Used Avail Use% Mounted on
                                  /dev/mapper/pve-vm--100--disk--0 ext4       42G   11G   29G  27% /
                                  none                             tmpfs     492K  4.0K  488K   1% /dev
                                  /dev/mapper/pve-root             ext4       29G   20G  7.7G  73% /dev/ttyACM0
                                  udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                                  tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                                  tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
                                  tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                  dmesg: read kernel buffer failed: Operation not permitted
                                  TARGET         SOURCE                                                 FSTYPE OPTIONS
                                  /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
                                  `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/189/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                                  /var:
                                  3.2G    /var/
                                  2.6G    /var/log/journal/4b4c08ea54a04d2e89ddb21f3e8976ed
                                  2.6G    /var/log
                                  466M    /var/cache
                                  Archived and active journals take up 8.0M in the file system.
                                  /opt/iobroker/backups:
                                  521M    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  2.3G    /opt/iobroker/iobroker-data/
                                  1.1G    /opt/iobroker/iobroker-data/history
                                  706M    /opt/iobroker/iobroker-data/files
                                  299M    /opt/iobroker/iobroker-data/backup-objects
                                  142M    /opt/iobroker/iobroker-data/files/vis.0
                                  70M     /opt/iobroker/iobroker-data/objects.jsonl
                                  65M     /opt/iobroker/iobroker-data/states.jsonl
                                  41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                  40M     /opt/iobroker/iobroker-data/objects.json.migrated
                                  40M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2410075-if00
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v18.19.0
                                  /usr/bin/node           v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Installed: 18.19.0-1nodesource1
                                    Candidate: 18.19.0-1nodesource1
                                    Version table:
                                   *** 18.19.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                          100 /var/lib/dpkg/status
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                          500 http://security.debian.org bullseye-security/main amd64 Packages
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapters from github:   4
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8083, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                    system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
                                  + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                  + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
                                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                    system.adapter.email.0                  : email                 : iobroker                                 - disabled
                                    system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                                  + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                    system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                                    system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
                                    system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                                    system.adapter.heizoel.0                : heizoel               : iobroker                                 - disabled
                                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                    system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                                  + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                  + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    system.adapter.kodi.0                   : kodi                  : iobroker                                 - disabled, port: 8080
                                    system.adapter.lgtv.0                   : lgtv                  : iobroker                                 - disabled
                                    system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                                  + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                  + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                  + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                  + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
                                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                  + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                                  + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                  + system.adapter.proxmox.1                : proxmox               : iobroker                                 -  enabled, port: 8006
                                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                    system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                                  + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 7770, bind: 0.0.0.0, run as: admin
                                    system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
                                  + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 7769, bind: 0.0.0.0, run as: admin
                                    system.adapter.solarmanpv.0             : solarmanpv            : iobroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                    system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
                                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 - disabled
                                  + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
                                    system.adapter.windows-control.0        : windows-control       : iobroker                                 - disabled
                                  + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                                    system.adapter.worx.0                   : worx                  : iobroker                                 - disabled
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                                  + instance is alive
                                  ioBroker-Repositories
                                  New           : http://iobroker.live/repo/sources-dist.json
                                  Active repo(s): stable
                                  Installed ioBroker-Instances
                                  Used repository: stable
                                  Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                  Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                  Adapter    "coronavirus-statistics": 0.9.0, installed 0.8.8-0 [Updatable]
                                  Adapter    "countdown"    : 2.2.0    , installed 2.2.0
                                  Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
                                  Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                                  Adapter    "email"        : 1.2.1    , installed 1.2.1
                                  Adapter    "eusec"        : 1.2.1    , installed 1.2.1
                                  Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                  Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                                  Adapter    "fullybrowser" : 3.0.9    , installed 2.0.4  [Updatable]
                                  Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                                  Adapter    "hmip"         : 1.21.0   , installed 1.21.0
                                  Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                                  Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                  Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                  Controller "js-controller": 5.0.17   , installed 5.0.17
                                  Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                                  Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "logparser"    : 2.2.1    , installed 2.2.1
                                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                  Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                  Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                                  Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                                  Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
                                  Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                  Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                  Adapter    "snmp"         : 3.1.0    , installed 2.4.11 [Updatable]
                                  Adapter    "solarmanpv"   : 0.5.1    , installed 0.5.1
                                  Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                                  Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                                  Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                  Adapter    "tuya"         : 3.15.0   , installed 3.6.5  [Updatable]
                                  Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.4  [Updatable]
                                  Adapter    "unifi"        : 0.6.7    , installed 0.6.6  [Updatable]
                                  Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                  Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                                  Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                  Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                  Adapter    "worx"         : 2.3.4    , installed 2.1.3  [Updatable]
                                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                  Adapter    "zigbee"       : 1.9.7    , installed 1.8.24 [Updatable]
                                  Objects and States
                                  Objects:        32363
                                  States:         26941
                                  Hit:1 http://security.debian.org bullseye-security InRelease
                                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       46666067   120/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       46666075   120/iobroker.js-con
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          46667947   289/master
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        46666916   108/systemd-resolve
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          46665812   1/init
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       47647964   30207/io.sonoff.0
                                  tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        46666910   108/systemd-resolve
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          46667948   289/master
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       46677868   1462/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46666242   307/io.admin.0
                                  tcp6       0      0 :::8000                 :::*                    LISTEN      1000       46683978   1398/io.upnp.0
                                  tcp6       0      0 :::7770                 :::*                    LISTEN      1000       46676821   1261/io.simple-api.
                                  tcp6       0      0 :::7769                 :::*                    LISTEN      1000       46676885   1284/io.socketio.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          46665611   1/init
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          46665814   1/init
                                  tcp6       0      0 :::5355                 :::*                    LISTEN      104        46666913   108/systemd-resolve
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       46678967   1473/io.wled.0
                                  udp        0      0 192.168.178.100:5353    0.0.0.0:*                           1000       46671958   548/io.tr-064.0
                                  udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        46666909   108/systemd-resolve
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       46972090   8939/io.shelly.0
                                  udp        0      0 0.0.0.0:54955           0.0.0.0:*                           1000       46678822   1398/io.upnp.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       46677926   1398/io.upnp.0
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       46670144   565/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       46670145   565/io.tuya.0
                                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        46666915   108/systemd-resolve
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          46665813   1/init
                                  udp6       0      0 :::5355                 :::*                                104        46666912   108/systemd-resolve
                                  udp6       0      0 :::111                  :::*                                0          46665815   1/init
                                  2024-01-18 05:42:06.483  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                  2024-01-18 05:42:06.851  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                  2024-01-18 05:42:08.285  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                  2024-01-18 05:42:08.365  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                  2024-01-18 05:42:08.419  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                  2024-01-18 05:42:08.856  - info: solarmanpv.0 (120094) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                  2024-01-18 05:42:10.733  - error: zigbee.0 (583) Send command to 0xc4988600000060aa failed with no error code (no response received (161)
                                  2024-01-18 05:42:10.808  - info: solarmanpv.0 (120094) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                  2024-01-18 05:42:11.349  - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-01-18 05:45:00.070  - info: host.iobroker instance system.adapter.ical.1 started with pid 120404
                                  2024-01-18 05:45:00.202  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 10
                                  2024-01-18 05:45:00.202  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0
                                  2024-01-18 05:45:00.204  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0
                                  2024-01-18 05:45:00.205  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Zahlen aufsteigend sortiert: 0,0,0,0,0,0,0,0,0,0
                                  2024-01-18 05:45:00.206  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Auswahl der Liste 7-9 : 0,0,0,0,0,0
                                  2024-01-18 05:45:00.206  - info: javascript.0 (79290) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: errechneter Mittelwert: 0
                                  2024-01-18 05:45:03.942  - info: ical.1 (120404) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                                  2024-01-18 05:45:12.852  - info: ical.1 (120404) Terminated (NO_ERROR): Without reason
                                  2024-01-18 05:45:13.399  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                                  iob diag has finished.
                                  Press any key for a summary
                                                          v.2023-10-10
                                             Chassis: container
                                      Virtualization: lxc
                                  Installation:           lxc
                                  Userland:               amd64
                                  User-ID:                1001
                                  X-Server:               false
                                  Pending OS-Updates:     0
                                  Pending iob updates:    10
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                  MEMORY:
                                  Mem:            7.8G        3.8G        3.3G        0.0K        703M        4.0G
                                  Swap:             0B          0B          0B
                                  Total:          7.8G        3.8G        3.3G
                                  Active iob-Instances:   40
                                  ioBroker Core:          js-controller           5.0.17
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                32363
                                  States:                 26941
                                  Size of iob-Database:
                                  81M     /opt/iobroker/iobroker-data/objects.jsonl
                                  9.5M    /opt/iobroker/iobroker-data/states.json.migrated
                                  9.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  9.4M    /opt/iobroker/iobroker-data/states.jsonl
                                  Hier der Auszug aus den Logs:
                                  2024-01-17 22:12:07.737 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string"
                                  2024-01-17 22:12:07.819 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number"
                                  2024-01-17 22:12:07.873 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                  2024-01-17 22:12:08.290 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                  2024-01-17 22:12:09.634 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                  2024-01-17 22:12:09.721 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                  2024-01-17 22:12:09.774 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                  2024-01-17 22:12:10.226 - info: solarmanpv.0 (79070) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                  2024-01-17 22:12:11.201 - info: solarmanpv.0 (79070) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                  2024-01-17 22:12:11.740 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                                  2024-01-17 22:14:19.619 - error: host.iobroker Caught by controller[0]: [64004:0x6cde870] 9870984 ms: Scavenge 2044.5 (2084.6) -> 2044.0 (2085.4) MB, 14.7 / 0.0 ms (average mu = 0.183, current mu = 0.193) allocation failure;
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: <--- JS stacktrace --->
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 1: 0xb95b60 node::Abort() [io.javascript.0]
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 2: 0xa9a7f8 [io.javascript.0]
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                  2024-01-17 22:14:19.620 - error: host.iobroker Caught by controller[0]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 5: 0xf4cba5 [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[0]: 6: 0xf4daa8 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 7: 0xf5dfb3 [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 8: 0xf5ee28 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[1]: 9: 0xf3978e v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                                  2024-01-17 22:14:19.621 - error: host.iobroker Caught by controller[2]: 10: 0xf3ab57 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.javascript.0]
                                  2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 11: 0xf1bd2a v8::internal::Factory::NewFillerObject(int, v8::internal::AllocationAlignment, v8::internal::AllocationType, v8::internal::AllocationOrigin) [io.javascript.0]
                                  2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[2]: 12: 0x12e114f v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                                  2024-01-17 22:14:19.622 - error: host.iobroker Caught by controller[3]: 13: 0x170deb9 [io.javascript.0]
                                  2024-01-17 22:14:19.622 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                  2024-01-17 22:14:19.623 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                                  2024-01-17 22:14:19.623 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                  2024-01-17 19:24:00.046 - info: host.iobroker instance system.adapter.solarmanpv.0 started with pid 63515
                                  2024-01-17 19:24:03.269 - info: solarmanpv.0 (63515) starting. Version 0.5.1 (non-npm: raschy/ioBroker.solarmanpv) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.0, js-controller: 5.0.17
                                  2024-01-17 19:24:08.390 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.DEV_TYP1" has to be type "number" but received type "string"
                                  2024-01-17 19:24:08.475 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.COMM_PTC_v1" has to be type "string" but received type "number"
                                  2024-01-17 19:24:08.531 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.HWv1" has to be type "string" but received type "number"
                                  2024-01-17 19:24:08.934 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634911.225508433.NOP" has to be type "number" but received type "string"
                                  2024-01-17 19:24:10.435 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.DEV_TYP1" has to be type "number" but received type "string"
                                  2024-01-17 19:24:10.507 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.COMM_PTC_v1" has to be type "string" but received type "number"
                                  2024-01-17 19:24:10.562 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.HWv1" has to be type "string" but received type "number"
                                  2024-01-17 19:24:10.973 - info: solarmanpv.0 (63515) State value to set for "solarmanpv.0.60634926.225510526.NOP" has to be type "number" but received type "string"
                                  2024-01-17 19:24:12.062 - info: solarmanpv.0 (63515) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                  2024-01-17 19:24:12.644 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2024-01-17 19:25:00.192 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Durchgang Zähler LUX : 7
                                  2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aktuelle LUX = 0
                                  2024-01-17 19:25:00.194 - info: javascript.0 (51920) script.js.2021-04-09-scripts.Abfragen.Helligkeit_Aussen: Aussenlichtstaerke Mittelwert = 0
                                  2024-01-17 19:29:07.194 - error: host.iobroker Caught by controller[0]: <--- Last few GCs --->
                                  2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8062565 ms: Scavenge 2044.2 (2084.9) -> 2043.7 (2089.4) MB, 16.4 / 0.0 ms (average mu = 0.179, current mu = 0.167) allocation failure;
                                  2024-01-17 19:29:07.195 - error: host.iobroker Caught by controller[0]: [51920:0x717f870] 8068108 ms: Mark-sweep (reduce) 2045.7 (2089.4) -> 2044.7 (2084.1) MB, 4609.8 / 0.0 ms (+ 97.8 ms in 31 steps since start of marking, biggest step 5.9 ms, walltime since start of marking 4746 ms) (average mu = 0.172, current mu = 0.164
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[1]: <--- JS stacktrace --->
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[2]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[3]: 1: 0xb95b60 node::Abort() [io.javascript.0]
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[4]: 2: 0xa9a7f8 [io.javascript.0]
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[5]: 3: 0xd6f2f0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                  2024-01-17 19:29:07.196 - error: host.iobroker Caught by controller[6]: 4: 0xd6f697 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[7]: 5: 0xf4cba5 [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[8]: 6: 0xf5f08d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[9]: 7: 0xf61ff5 v8::internal::Heap::HandleGCRequest() [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[10]: 8: 0xee014f v8::internal::StackGuard::HandleInterrupts() [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[11]: 9: 0x12e0bcf v8::internal::Runtime_StackGuardWithGap(int, unsigned long*, v8::internal::Isolate*) [io.javascript.0]
                                  2024-01-17 19:29:07.197 - error: host.iobroker Caught by controller[12]: 10: 0x170deb9 [io.javascript.0]
                                  2024-01-17 19:29:07.197 - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGABRT
                                  2024-01-17 19:29:07.198 - info: host.iobroker instance system.adapter.javascript.0 terminated with code null ()
                                  2024-01-17 19:29:07.198 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                  2024-01-17 19:29:37.457 - info: host.iobroker instance system.adapter.javascript.0 started with pid 64004
                                  • Codierknecht
                                    @blue231181
                                    1.) Entferne die privaten Daten aus dem Log!
                                    2.) Was passiert, wenn Du alle Scripte mal stoppst? Bleibt der Adapter am Leben?
                                    • blue231181
                                      blue231181 @Codierknecht last edited by
                                      @codierknecht private daten...? meine IP Adresse?
                                      Stimmt das könnte ich versuchen. Alle Skripte beenden, und nach und nach wieder starten. Das wird ein längerer Akt weil der Fehler nur alle 3 Stunden auftritt, aber ich versuche es
                                      • Codierknecht
                                        Codierknecht Developer Most Active @blue231181 last edited by Codierknecht
                                        Nein - Die Kalender-ID's 😉
                                        In der Langfassung von diag.
                                        Und was passiert alle 3 Stunden?
                                        Läuft der vielleicht in genau diesem Intervall?
                                        mcm1957 blue231181 2 Replies Last reply Reply Quote 1
                                        • mcm1957
                                          mcm1957 @Codierknecht last edited by
                                          Keine Ahnung ob das auch hier zutreffen könnte - einen Zusammenhang mit 3h Intervall sehe ich da nicht - aber hier ging es um einen Crash des Javascript Adapters bei eine zu größen Anzahl von States (70.000 Alarmstates des unifi Adapters)
                                          https://github.com/ioBroker/ioBroker.javascript/issues/1467
                                          schmupu created this issue in ioBroker/ioBroker.javascript
                                          closed JavaScript instance crash with $ - Selector #1467
                                          • blue231181
                                            @codierknecht Danke für den Hinweis
                                            Was euch alles auffällt 🤦‍♂️
                                            Also der Solarmanpv läuft alle 8 Min.
                                            3 stunden Intervall ist mir nichts bekannt. Ich habe alle Scripte nun mal deaktiviert und teste mich durch.
                                            @mcm57 den Adapter habe ich schon deaktiviert und die zugehörigen States gelöscht, ja damit hatte ich auch Probleme und massiv viele States die er mir angelegt hat
                                            Codierknecht mcm1957 2 Replies Last reply Reply Quote 0
                                            855
