    4. Fehlermeldungen beim Biobroker Update
    • V
      Volleyhomer last edited by Volleyhomer
      mir wurde in der Facebook "iobroker SmartHome und IoT" Gruppe schon ein wenig geholfen und ich wurde darum geben hier mein Diagnose Log rein zu stellen.
      Vielen Dank schon mal dafür. Ich hoffe das funktioniert mit dem angehängten log File.
      *** iob diag is starting up, please wait ***
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2023-10-25
      *** BASE SYSTEM ***
         Static hostname: rock64
               Icon name: computer
        Operating System: Debian GNU/Linux 9 (stretch)
                  Kernel: Linux 4.4.192-rockchip64
            Architecture: arm64
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       11:59:39 up 20:43,  1 user,  load average: 1.35, 1.38, 0.98
      CPU threads: 4
      *** Time and Time Zones ***
            Local time: Sat 2024-01-20 11:59:39 CET
        Universal time: Sat 2024-01-20 10:59:39 UTC
              RTC time: Sat 2024-01-20 10:59:39
       Network time on: yes
      NTP synchronized: yes
       RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal:
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:           4.1G        1.4G        2.1G        9.2M        651M        2.6G
      Swap:          1.0G          0B        1.0G
      Total:         5.1G        1.4G        3.1G
               3988 M total memory
               1347 M used memory
               1556 M active memory
                280 M inactive memory
               2004 M free memory
                 77 M buffer memory
                559 M swap cache
               1023 M total swap
                  0 M used swap
               1023 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      udev           devtmpfs  2.0G     0  2.0G   0% /dev
      tmpfs          tmpfs     399M  5.4M  394M   2% /run
      /dev/mmcblk0p1 ext4       15G  4.8G  9.2G  34% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
      tmpfs          tmpfs     2.0G  636K  2.0G   1% /tmp
      /dev/zram0     ext4       49M  3.9M   42M   9% /var/log
      tmpfs          tmpfs     399M     0  399M   0% /run/user/1000
      [Fri Jan 19 15:16:20 2024] Kernel command line: earlycon=uart8250,mmio32,0xff130000 swiotlb=1 kpti=0 no_console_suspend=1 usbcore.autosuspend=-1 root=UUID=aadb45fc-8b8b-4b5b-ad50-7e6416a4e1c5 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=9dd9d2a5-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
      [Fri Jan 19 15:16:30 2024] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
      [Fri Jan 19 15:16:30 2024] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
      [Fri Jan 19 15:16:31 2024] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
      [Sat Jan 20 11:55:20 2024] EXT4-fs warning (device zram0): ext4_dirent_csum_verify:353: inode #11: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 4096
      [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 8192
      [Sat Jan 20 11:55:20 2024] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm du: path /var/log/lost+found: directory fails checksum at offset 12288
      Show mounted filesystems:
      TARGET                                SOURCE                   FSTYPE     OPTIONS
      /                                     /dev/mmcblk0p1           ext4       rw,noatime,nodiratime,errors=remount-ro,commit=600
      |-/sys                                sysfs                    sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs               securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs                    tmpfs      ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/systemd          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/memory           cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,memory
      | | |-/sys/fs/cgroup/blkio            cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/freezer          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/hugetlb          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,hugetlb
      | | |-/sys/fs/cgroup/pids             cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/perf_event       cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/devices          cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,devices
      | | `-/sys/fs/cgroup/cpuset           cgroup                   cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
      | |-/sys/fs/pstore                    pstore                   pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug                 debugfs                  debugfs    rw,relatime
      | | `-/sys/kernel/debug/tracing       tracefs                  tracefs    rw,relatime
      | |-/sys/kernel/config                configfs                 configfs   rw,relatime
      | `-/sys/fs/fuse/connections          fusectl                  fusectl    rw,relatime
      |-/proc                               proc                     proc       rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1                autofs     rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/dev                                udev                     devtmpfs   rw,nosuid,relatime,size=2039432k,nr_inodes=509858,mode=755
      | |-/dev/pts                          devpts                   devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                          tmpfs                    tmpfs      rw,nosuid,nodev
      | |-/dev/mqueue                       mqueue                   mqueue     rw,relatime
      | `-/dev/hugepages                    hugetlbfs                hugetlbfs  rw,relatime
      |-/run                                tmpfs                    tmpfs      rw,nosuid,noexec,relatime,size=408448k,mode=755
      | |-/run/lock                         tmpfs                    tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc                   rpc_pipefs rw,relatime
      | `-/run/user/1000                    tmpfs                    tmpfs      rw,nosuid,nodev,relatime,size=408444k,mode=700,uid=1000,gid=1000
      |-/tmp                                tmpfs                    tmpfs      rw,nosuid,relatime
      |-/var/log.hdd                        /dev/mmcblk0p1[/var/log] ext4       rw,noatime,nodiratime,errors=remount-ro,commit=600
      `-/var/log                            /dev/zram0               ext4       rw,relatime,discard
      /var:
      569M	/var/
      286M	/var/lib
      274M	/var/cache
      269M	/var/cache/apt
      266M	/var/lib/apt/lists
      Archived and active journals take up 4.9M in the file system.
      /opt/iobroker/backups:
      71M	/opt/iobroker/backups/
      43M	/opt/iobroker/backups/Alt
      /opt/iobroker/iobroker-data:
      357M	/opt/iobroker/iobroker-data/
      234M	/opt/iobroker/iobroker-data/files
      83M	/opt/iobroker/iobroker-data/backup-objects
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      51M	/opt/iobroker/iobroker-data/files/javascript.admin
      23M	/opt/iobroker/iobroker-data/objects.jsonl
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      18M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      8.2M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v14.21.3
      /usr/bin/node 		v14.21.3
      /usr/bin/npm 		6.14.18
      /usr/bin/npx 		6.14.18
      /usr/bin/corepack 	0.15.1
      nodejs:
        Installed: 14.21.3-1nodesource1
        Candidate: 14.21.3-1nodesource1
        Version table:
       *** 14.21.3-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x stretch/main arm64 Packages
              100 /var/lib/dpkg/status
           8.11.1~dfsg-2~bpo9+1 100
              100 http://httpredir.debian.org/debian stretch-backports/main arm64 Packages
           4.8.2~dfsg-1 500
              500 http://httpredir.debian.org/debian stretch/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapters from github: 	3
      Adapter State
      + system.adapter.admin.0                  : admin                 : rock64                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : rock64                                   - disabled
      + system.adapter.bluelink.0               : bluelink              : rock64                                   -  enabled
      + system.adapter.discovery.0              : discovery             : rock64                                   -  enabled
        system.adapter.fronius.0                : fronius               : rock64                                   - disabled
      + system.adapter.fronius.1                : fronius               : rock64                                   -  enabled
      + system.adapter.history.0                : history               : rock64                                   -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : rock64                                   -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : rock64                                   -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : rock64                                   -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : rock64                                   -  enabled, port: 443
      + system.adapter.info.0                   : info                  : rock64                                   -  enabled
      + system.adapter.iot.0                    : iot                   : rock64                                   -  enabled
      + system.adapter.javascript.0             : javascript            : rock64                                   -  enabled
        system.adapter.midea.0                  : midea                 : rock64                                   - disabled
      + system.adapter.mihome.0                 : mihome                : rock64                                   -  enabled, port: 9898, bind: 192.168.0.176
      + system.adapter.pushover.0               : pushover              : rock64                                   -  enabled
      + system.adapter.shelly.0                 : shelly                : rock64                                   -  enabled, port: 1882, bind: 192.168.0.176
      + system.adapter.telegram.0               : telegram              : rock64                                   -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : rock64                                   -  enabled
      + system.adapter.tr-064.0                 : tr-064                : rock64                                   -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rock64                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rock64                                   -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : rock64                                   -  enabled
        system.adapter.vis.0                    : vis                   : rock64                                   -  enabled
      + system.adapter.web.0                    : web                   : rock64                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : rock64                                   -  enabled
      + system.adapter.yahka.1                  : yahka                 : rock64                                   -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.3.5  [Updatable]
      Adapter    "backitup"     : 2.9.8    , installed 2.8.1  [Updatable]
      Adapter    "bluelink"     : 2.3.6    , installed 2.3.2  [Updatable]
      Adapter    "discovery"    : 4.2.0    , installed 3.1.0  [Updatable]
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
      Adapter    "hm-rega"      : 4.0.0    , installed 3.0.46 [Updatable]
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.16 [Updatable]
      Adapter    "hue"          : 3.10.1   , installed 3.7.1  [Updatable]
      Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
      Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
      Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
      Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
      Adapter    "shelly"       : 6.6.1    , installed 6.4.1  [Updatable]
      Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
      Adapter    "telegram"     : 3.0.1    , installed 1.15.6 [Updatable]
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
      Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
      Adapter    "worx"         : 2.3.4    , installed 2.3.2  [Updatable]
      Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Objects and States
      Objects: 	5463
      States: 	3094
      Pending Updates: 136
      *** Listening Ports ***
      Netid  State      Recv-Q Send-Q Local Address:Port               Peer Address:Port
      udp    UNCONN     0      0         *:9898                  *:*                   users:(("io.mihome.0",pid=1750,fd=27))
      udp    UNCONN     0      0         *:68                    *:*                   users:(("dhclient",pid=906,fd=6))
      udp    UNCONN     0      0         *:111                   *:*                   users:(("rpcbind",pid=443,fd=6))
      udp    UNCONN     0      0      192.168.0.176:123                   *:*                   users:(("ntpd",pid=1481,fd=19))
      udp    UNCONN     0      0      127.0.0.1:123                   *:*                   users:(("ntpd",pid=1481,fd=18))
      udp    UNCONN     0      0         *:123                   *:*                   users:(("ntpd",pid=1481,fd=17))
      udp    UNCONN     0      0         *:619                   *:*                   users:(("rpcbind",pid=443,fd=7))
      udp    UNCONN     0      0         *:5353                  *:*                   users:(("io.yahka.1",pid=2294,fd=27))
      udp    UNCONN     0      0        :::111                  :::*                   users:(("rpcbind",pid=443,fd=9))
      udp    UNCONN     0      0       fdad:a636:5c1e:ff4d:8907:c27d:dc5a:3529:123                  :::*                   users:(("ntpd",pid=1481,fd=25))
      udp    UNCONN     0      0      fe80::f777:1c02:d801:d955%eth0:123                  :::*                   users:(("ntpd",pid=1481,fd=21))
      udp    UNCONN     0      0       ::1:123                  :::*                   users:(("ntpd",pid=1481,fd=20))
      udp    UNCONN     0      0        :::123                  :::*                   users:(("ntpd",pid=1481,fd=16))
      udp    UNCONN     0      0        :::619                  :::*                   users:(("rpcbind",pid=443,fd=10))
      tcp    LISTEN     0      128    127.0.0.1:9000                  *:*                   users:(("iobroker.js-con",pid=838,fd=26))
      tcp    LISTEN     0      128    127.0.0.1:9001                  *:*                   users:(("iobroker.js-con",pid=838,fd=20))
      tcp    LISTEN     0      128       *:111                   *:*                   users:(("rpcbind",pid=443,fd=8))
      tcp    LISTEN     0      128    192.168.0.176:2001                  *:*                   users:(("io.hm-rpc.0",pid=1684,fd=27))
      tcp    LISTEN     0      128    127.0.0.1:42836                 *:*                   users:(("io.yahka.1",pid=2294,fd=30))
      tcp    LISTEN     0      128       *:22                    *:*                   users:(("sshd",pid=857,fd=3))
      tcp    LISTEN     0      128    192.168.0.176:1882                  *:*                   users:(("io.shelly.0",pid=1781,fd=27))
      tcp    LISTEN     0      128    192.168.0.176:2010                  *:*                   users:(("io.hm-rpc.1",pid=1712,fd=27))
      tcp    LISTEN     0      128      :::40972                :::*                   users:(("io.yahka.1",pid=2294,fd=26))
      tcp    LISTEN     0      128      :::111                  :::*                   users:(("rpcbind",pid=443,fd=11))
      tcp    LISTEN     0      128      :::8081                 :::*                   users:(("io.admin.0",pid=1489,fd=27))
      tcp    LISTEN     0      128      :::8082                 :::*                   users:(("io.web.0",pid=1856,fd=27))
      tcp    LISTEN     0      128      :::22                   :::*                   users:(("sshd",pid=857,fd=4))
      2024-01-20 12:00:44.991  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.58" greater than max "100"
      2024-01-20 12:00:47.513  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:00:47.845  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:00:51.499  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:00:57.801  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:00:58.422  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:02.168  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:08.258  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:08.972  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:13.540  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:14.954  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.47" greater than max "100"
      2024-01-20 12:01:18.555  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:19.303  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:20.258  - info: admin.0 (1489) <== Disconnect system.user.admin from ::ffff:192.168.0.100 admin
      2024-01-20 12:01:25.247  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:29.139  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:29.794  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:35.888  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:38.567  - error: shelly.0 (1781) [MQTT] (Shelly?) device unknown, configuration for client with id "shellypmmini-543204a97f50" does not exist!
      2024-01-20 12:01:38.568  - error: shelly.0 (1781) [MQTT] DO NOT CHANGE THE CLIENT-ID OF YOUR SHELLY DEVICES (see adapter documentation for details)
      2024-01-20 12:01:38.605  - info: shelly.0 (1781) [MQTT] Client Close:  (shellypmmini / shellypmmini-543204a97f50 / undefined) (false)
      2024-01-20 12:01:39.697  - warn: shelly.0 (1781) [authEnabled] 192.168.0.188 (shellydimmer / shellydimmer-D464FD / SHDM-1#D464FD#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:40.202  - warn: shelly.0 (1781) [authEnabled] 192.168.0.142 (shellydimmer / shellydimmer-D177F6 / SHDM-1#D177F6#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-20 12:01:44.922  - warn: shelly.0 (1781) State value to set for "shelly.0.SHDM-1#D177F6#1.temperatureF" has value "102.12" greater than max "100"
      2024-01-20 12:01:46.455  - warn: shelly.0 (1781) [authEnabled] 192.168.0.116 (shelly1 / shelly1-B8F6B3 / SHSW-1#B8F6B3#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
      			v.2023-10-25
               Icon name: computer
            Architecture: arm64
      Installation: 		native
      Kernel: 		aarch64
      Userland: 		arm64
      Timezone: 		rlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		false
      Pending OS-Updates: 	136
      Pending iob updates: 	20
      Nodejs-Installation: 	/usr/bin/nodejs 	v14.21.3
      Recommended versions are nodejs 16.20.2 and npm 8.19.4
      MEMORY:
      Mem:           4.1G        1.4G        2.1G        9.2M        653M        2.6G
      Swap:          1.0G          0B        1.0G
      Active iob-Instances: 	22
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			6.3.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		5463
      States: 		3094
      Size of iob-Database:
      6.3M	/opt/iobroker/iobroker-data/objects.json.migrated
      6.3M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      3.8M	/opt/iobroker/iobroker-data/states.jsonl
      1000K	/opt/iobroker/iobroker-data/states.json.migrated
      1000K	/opt/iobroker/iobroker-data/states.json.bak.migrated
      === Mark text until here for copying ===
      Mein Versionen:
      pi@rock64:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v14.21.3
      v14.21.3
      6.14.18
      6.14.18
      Mein iobroker läuft sehr gut und stabil (backitup Adapter ausgenommen) ich kann nur einige wichtige Adapter nicht mehr updaten (u.a. Shelly) weil meine Versionen zu alt sind. Beim Updaten kommen dann diverse npm Fehlermeldungen.
      Meine Idee war jetzt erstmal ein backup zu ziehen, ein neues System auf dem neuesten Stand aufzusetzen und das Backup wieder einzuspielen.
      Achso, das ganze läuft auf einem ROCK64.
      Danke an Thomas Braun. Das Diagnose Tool ist mega gut!!
      Gruß Andy
      Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Volleyhomer last edited by Thomas Braun
        @volleyhomer
        Da ist aber auch alles hoffnungslos veraltet...
        Debian 9 'Stretch'...
        Mittlerweile sind wir bei 12 und 10 ist auch bereits tot, 11 ist im Auslauf...
        Versuch mal:
        iob stop
        iob fix
        iob nodejs-update 16
          @volleyhomer
          Die Kiste über Jahre versumpfen zu lassen funktioniert nachgewiesener Maßen nicht.
            Homoran Global Moderator Administrators @Volleyhomer last edited by
            @volleyhomer sagte in Fehlermeldungen beim Biobroker Update:
            bitte als Text in code-tags posten.
            • V
              Volleyhomer @Homoran last edited by
              @homoran said in Fehlermeldungen beim Biobroker Update:
              Hab ich gemacht.
              • V
                Volleyhomer @Thomas Braun last edited by
                @thomas-braun said in Fehlermeldungen beim Biobroker Update:
                @volleyhomer
                Versuch mal:
                iob stop
                iob fix
                Mir fehlte die Zeit und die Muße mich damit weiter zu beschäftigen. Seit dem Umstieg auf den Rock64 lief das System zu fehlerfrei... Das wird dann aber jetzt so langsam mal Zeit.
                Der Befehl "iob nodejs-update 16" brachte folgende Ausgabe:
                pi@rock64:~$ iob nodejs-update 16
                iobroker [command]
                Commands:
                 iobroker setup                                               Setup ioBroker
                 iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                 iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                 iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                 iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                 iobroker info                                                Shows the host info
                 iobroker logs [<adapter>]                                    Monitor log
                 iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                 iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                 iobroker rebuild [<module>]                                  Rebuild all native modules or path
                 iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                 iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                 iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                 iobroker update [<repositoryUrl>]                            Update repository and list adapters
                 iobroker upgrade                                             Upgrade management
                 iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                 iobroker object                                              Object management  [aliases: o]
                 iobroker state                                               State management  [aliases: s]
                 iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                 iobroker list <type> [<filter>]                              List all entries, like objects
                 iobroker chmod <mode> <file>                                 Change file rights
                 iobroker chown <user> <group> <file>                         Change file ownership
                 iobroker touch <file>                                        Touch file
                 iobroker rm <file>                                           Remove file
                 iobroker file                                                File management
                 iobroker user                                                User commands
                 iobroker group                                               group management
                 iobroker host <hostname>                                     Set host to given hostname
                 iobroker set <adapter>.<instance>                            Change settings of adapter config
                 iobroker license <license.file or license.text>              Update license by given file
                 iobroker cert                                                Certificate management
                 iobroker clean <yes>                                         Clears all objects and states
                 iobroker backup                                              Create backup
                 iobroker restore <backup name or path>                       Restore a specified backup
                 iobroker validate <backup name or path>                      Validate a specified backup
                 iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                 iobroker repo [<name>]                                       Show repo information
                 iobroker uuid                                                Show uuid of the installation  [aliases: id]
                 iobroker unsetup                                             Reset license, installation secret and language
                 iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                 iobroker multihost                                           Multihost management
                 iobroker compact                                             compact group management
                 iobroker plugin                                              Plugin management
                 iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                Options:
                 --help  Show help  [boolean]
                Erscheint den Befehl also nicht zu kennen.
                Vielleicht ist es doch mal Zeit alles frisch und sauber aufzusetzen.
                  iob stop
                  iob fix
                  iob start
                  ...warten...
                  oder
                    Du musst auch den fix zuvor ausführen... Wie ich geschrieben hatte...
                    • V
                      Habe ich exakt in der Reihenfolge gemacht. Bei dem fix kommt nach einer Sekunde der Eingabe-Prompt.
                      pi@rock64:~$ iob stop
                      pi@rock64:~$ iob fix
                      iobroker [command]
                      • V
                        iob stop
                        iob fix
                        iob start
                        ...warten...
                        oder
                        Es bleibt bei der gleichen Reaktion. iobroker listet mir möglich Optionen auf.
                        pi@rock64:~$ iob start
                        pi@rock64:~$ iobroker stop
                        iobroker [command]
                        Commands:
                          @volleyhomer
                          Dann anders:
                          curl -fsL https://iobroker.net/fix.sh | bash -
                          • V
                            Soll iobroker dabei laufen? Also mit oder ohne
                            iob stop
                            Danke nochmal!
                            • V
                              Volleyhomer @Volleyhomer last edited by
                              @volleyhomer said in Fehlermeldungen beim Biobroker Update:
                              iob stop
                              Danke nochmal!
                              Hab gerade getestet. Result ist so oder so gleich. Seltsam
                                Und wie lautet das gleiche Resultat?
                                • V
                                  @thomas-braun bei dem fix passiert gar nichts und der Eingabeprompt erscheint nach 1 Sekunde und wenn ich danach nodejs-16 Updaten will, listet er mir alle Optionen auf. Exakt gleich wie weiter oben beschrieben.
                                    Du sollst es auch nicht nacherzählen oder beschreiben sondern immer den Output im Terminal zeigen. Dann sehe ich was da passiert.
                                    curl -L https://iobroker.net/fix.sh | bash -
                                    • V
                                      pi@rock64:~$ curl -L https://iobroker.net/fix.sh | bash -
                                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                        0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                                      curl: (60) SSL certificate problem: certificate has expired
                                      More details here: https://curl.haxx.se/docs/sslcerts.html
                                      curl performs SSL certificate verification by default, using a "bundle"
                                       of Certificate Authority (CA) public keys (CA certs). If the default
                                       bundle file isn't adequate, you can specify an alternate file
                                       using the --cacert option.
                                      If this HTTPS server uses a certificate signed by a CA represented in
                                       the bundle, the certificate verification probably failed due to a
                                       problem with the certificate (it might be expired, or the name might
                                       not match the domain name in the URL).
                                      If you'd like to turn off curl's verification of the certificate, use
                                       the -k (or --insecure) option.
                                        @volleyhomer
                                        Auch das ist eine Folge von deiner Update-Faulheit...
                                        sudo apt update
                                        V 1 Reply Last reply Reply Quote 1
                                        • V
                                          @volleyhomer
                                          sudo apt update
                                          pi@rock64:~$ sudo apt update
                                          [sudo] password for pi:
                                          Ign:1 http://httpredir.debian.org/debian stretch InRelease
                                          Ign:2 http://security.debian.org stretch/updates InRelease
                                          Err:3 http://security.debian.org stretch/updates Release
                                            404  Not Found [IP: 146.75.122.132 80]
                                          Ign:4 http://httpredir.debian.org/debian stretch-updates InRelease
                                          Ign:5 http://httpredir.debian.org/debian stretch-backports InRelease
                                          Err:6 http://httpredir.debian.org/debian stretch Release
                                          Err:7 http://httpredir.debian.org/debian stretch-updates Release
                                          Err:8 http://httpredir.debian.org/debian stretch-backports Release
                                          Ign:9 http://apt.armbian.com stretch InRelease
                                          Hit:10 https://deb.nodesource.com/node_14.x stretch InRelease
                                          Err:11 http://apt.armbian.com stretch Release
                                            502  Bad Gateway [IP: 130.185.239.78 80]
                                          Reading package lists... Done
                                          E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
                                          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                          N: See apt-secure(8) manpage for repository creation and user configuration details.
                                          E: The repository 'http://httpredir.debian.org/debian stretch Release' does no longer have a Release file.
                                          E: The repository 'http://httpredir.debian.org/debian stretch-updates Release' does no longer have a Release file.
                                          E: The repository 'http://httpredir.debian.org/debian stretch-backports Release' does no longer have a Release file.
                                          E: The repository 'http://apt.armbian.com stretch Release' does no longer have a Release file.
                                            curl -kL https://iobroker.net/fix.sh | bash -
                                            1695
