    3. Tester
    4. Test Adapter vbus-gw v0.3.x Latest
      pdbjjens last edited by pdbjjens
      Aktuelle Test Version 0.3.0
      Veröffentlichungsdatum 29.08.2025
      Github Link https://github.com/pdbjjens/ioBroker.vbus-gw.git
      npm Link https://www.npmjs.com/package/iobroker.vbus-gw
      vbus-gw adapter for ioBroker
      Allows TCP access to serial port based VBus devices
      This ioBroker Adapter is based on work by Daniel Wippermann.
      https://github.com/danielwippermann/resol-vbus/tree/master/examples/serial-to-tcp
      Overview
      There are two types of VBus hardware adapters:
      TCP based: DL2, DL3, KM2, VBus/LAN
      Serial port based: VBus/USB, USB port of DeltaSol SLT and other controllers
      This ioBroker adapter connects to one or more serial port based hardware adapters and exposes them over TCP. This allows:
      • transmitting VBus data over longer distances than USB or serial ports would normally permit
      • accessing serial port based adapters from applications that only support TCP based ones
      Configuration
      See README on GitHub
      Changelog
        pdbjjens @pdbjjens last edited by
        v0.0.7 was released on 2024-02-24.
        Changes:
        (pdbjjens) Fix: VBus write fixed
        (pdbjjens) Fix: Password logging removed
        Note: This adapter version has been released to ioBroker latest repository and can be installed from there from now on.
        I hope you may find this adapter useful and I am looking forward to your testing feedback.
          The 2024H2 maintenance release v0.1.0 was released on 2024-08-13.
          Changelog:
          (pdbjjens) Change: node>=18, js-contoller>=5 and admin>=6 required
          (pdbjjens) New: Updated dependencies
          (pdbjjens) New: Ensure that vbus-gw is started before myvbus or resol
            0.2.0 (2025-01-29) - 2025H1 maintenance release
            (pdbjjens) Change: Migration to ESLint 9
            (pdbjjens) New: Accept serial port paths /dev/serial/by-id/usb-xxxxxxxxxxxxxxxxxxx or /dev/serial/by-path/platform-xxxxxxxxxxxxxxxxxxx
            (pdbjjens) Change: Responsive Design optimizations
              @pdbjjens
              0.3.0 (2025-08-29) - 2025H1 maintenance release
              (pdbjjens) Change: node>=20, js-controller>=7.0.7 and admin>=7.6.17 required
              (pdbjjens) Change: Cleanup devDependencies
              resol vbus serial-to-tcp
