    4. [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle
    • I
      Ianig Iro last edited by Ianig Iro
      • Adaptername: Javascript
      • Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.javascript
      • Adapterversion: 7.1.6
      • js-controller Version: 5.0.17
      • Admin Version: 6.12.0
      • Hardwaresystem: Pi4
      • Arbeitsspeicher: 4GB
      • Festplattenart: SSD
      • Betriebssystem: Rasp Pi OS
      • Nodejs-Version: 18.19.0
      • NPM-Version: 10.2.3
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      • Ort, Name der Imagedatei: ...
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       10:15:27 up 12 days, 15:04,  3 users,  load average: 0.37, 0.45, 0.39
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-01-26 10:15:27 CET
                 Universal time: Fri 2024-01-26 09:15:27 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.6G        998M        1.4M        1.5G        2.4G
      Total:          4.1G        1.6G        1.1G
               3792 M total memory
               1526 M used memory
               1986 M active memory
                657 M inactive memory
                951 M free memory
                139 M buffer memory
               1251 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  379M   1% /run
      /dev/sda2      ext4      110G  7.0G   97G   7% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
      [Sat Jan 13 19:11:13 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2A:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=def89f0e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB
      [Sat Jan 13 19:11:17 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 13 19:11:18 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      725M	/var/
      246M	/var/log/journal/be2ab101d79b4303b4dc531310d8bc39
      246M	/var/log
      191M	/var/lib
      Archived and active journals take up 245.3M in the file system.
      /opt/iobroker/backups:
      73M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      343M	/opt/iobroker/iobroker-data/
      292M	/opt/iobroker/iobroker-data/files
      89M	/opt/iobroker/iobroker-data/files/echarts.admin
      67M	/opt/iobroker/iobroker-data/files/javascript.admin
      57M	/opt/iobroker/iobroker-data/files/echarts
      24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      17M	/opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2255680-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.19.0
      /usr/bin/node 		v18.19.0
      /usr/bin/npm 		10.2.3
      /usr/bin/npx 		10.2.3
      /usr/bin/corepack 	0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 600
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: typescript@5.2.2 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! invalid: form-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/form-data
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-26T09_15_34_808Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.17
      admin: 		6.12.0
      javascript: 	7.1.6
      Adapters from github: 	0
      Adapter State
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
        system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled, port: 80
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 192.168.178.21
      + system.adapter.sureflap.0               : sureflap              : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
      + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sureflap"     : 1.2.3    , installed 1.2.1  [Updatable]
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
      Objects and States
      Objects: 	3416
      States: 	2681
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 34
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:45127         0.0.0.0:*               LISTEN      1001       3524116    2590/io.yahka.1
      tcp        0      0 127.0.0.1:39037         0.0.0.0:*               LISTEN      1001       1987251    2590/io.yahka.1
      tcp        0      0 127.0.0.1:34867         0.0.0.0:*               LISTEN      1001       2011832    2590/io.yahka.1
      tcp        0      0 127.0.0.1:32813         0.0.0.0:*               LISTEN      1001       4995153    2590/io.yahka.1
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6428985    320870/cupsd
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          13972      767/vncserver-x11-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25428      2423/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22407      2423/iobroker.js-co
      tcp        0      0 127.0.0.1:39725         0.0.0.0:*               LISTEN      1001       4090455    2590/io.yahka.1
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17419      772/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:38591         0.0.0.0:*               LISTEN      1001       6656388    2590/io.yahka.1
      tcp        0      0 127.0.0.1:44885         0.0.0.0:*               LISTEN      1001       4718584    2590/io.yahka.1
      tcp        0      0 127.0.0.1:36733         0.0.0.0:*               LISTEN      1001       3118844    2590/io.yahka.1
      tcp        0      0 127.0.0.1:40705         0.0.0.0:*               LISTEN      1001       6655452    2590/io.yahka.1
      tcp        0      0 127.0.0.1:45021         0.0.0.0:*               LISTEN      1001       964360     2590/io.yahka.1
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          13971      767/vncserver-x11-c
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        17528      869/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23450      2441/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17421      772/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6428984    320870/cupsd
      tcp6       0      0 :::46001                :::*                    LISTEN      1001       26737      2590/io.yahka.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15817      573/avahi-daemon: r
      udp        0      0 0.0.0.0:56777           0.0.0.0:*                           104        15819      573/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       26109      2759/io.shelly.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          6429833    320872/cups-browsed
      udp6       0      0 :::5353                 :::*                                104        15818      573/avahi-daemon: r
      udp6       0      0 fe80::44e4:421c:c1e:546 :::*                                0          14130      711/NetworkManager
      udp6       0      0 fe80::d890:c26c:38f:546 :::*                                0          16841      711/NetworkManager
      udp6       0      0 :::46009                :::*                                104        15820      573/avahi-daemon: r
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-26 10:16:29.963  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1225:19)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-26 10:16:29.964  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:45:23)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-01-26 10:16:29.965  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2024-01-26 10:16:29.966  - error: host.raspberrypi Caught by controller[0]: Node.js v18.19.0
      2024-01-26 10:16:29.966  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-26 10:16:29.966  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      Moin zusammen,
      ich habe vor kurzem meinen Pi neu aufgesetzt. Soweit hat alles funktioniert. Der Js-Controller auch. Ich habe ein Backup reingezogen, es hat immernoch alles funktioniert.
      Nun habe ich mich an ein paar Skripten versucht (nagut, eher C&P), jetzt ist der Adapter rot und steigt auch sofort wieder aus.
      Was ich vergeblich probiert habe:
      • neue Skripte löschen
      • Adapter neu installiert
      Es scheint ein Problem mit dem JS-Controller zu geben? Kann es daran liegen, dass ich ein veraltetes Backup in den IOB geladen habe? Oder kann ich mir mit dem Skript was zerschossen haben?
      Besten Dank für euren Input und viele Grüße
        Thomas Braun Most Active @Ianig Iro last edited by
        @ianig-iro sagte in Javascript Adapter funktioniert nicht /JS-Controller stopped:
        Pending Updates: 34
        Updaten, die iob-Adapter auch.
        Hast du im javaskript-Adapter zusätzliche Module eingetragen? Trag die nochmal ein.
        I 1 Reply Last reply Reply Quote 1
        • I
          Ianig Iro @Thomas Braun last edited by
          @thomas-braun Oh man, es lag wirklich am Update. Mea Culpa
            Da liegt es erstaunlich oft dran...
            Ich weiß... 'Näwah tatsch äh runnink süstäm'...
            iob diag
            sagt nun?
            • I
              Ianig Iro @Thomas Braun last edited by Ianig Iro
              @thomas-braun said in [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle:
              Damit habe ich mir eigtl schon die Finger verbrannt und wollte jetzt alles (halbwegs) aktuell halten.
              Das ganze ist zwei Tage nachdem ich mein System komplett neu aufgezogen habe passiert, deswegen hatte ich das garnicht auf dem Schirm.
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               16:14:10 up  4:14,  3 users,  load average: 0.70, 0.56, 0.45
              CPU threads: 4
              Current issues:
                             Local time: Fri 2024-01-26 16:14:10 CET
                         Universal time: Fri 2024-01-26 15:14:10 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server: 	false
              Desktop:
              Terminal: 	tty
              *** MEMORY ***
              Mem:            4.0G        1.2G        2.2G        1.4M        714M        2.8G
              Total:          4.1G        1.2G        2.3G
                       3792 M total memory
                       1101 M used memory
                       1437 M active memory
                        163 M inactive memory
                       2082 M free memory
                         60 M buffer memory
                        620 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/sda2      ext4      110G  6.9G   98G   7% /
              [Fri Jan 26 11:59:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:61:2A:FD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=def89f0e-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=GB
              [Fri Jan 26 11:59:48 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
              [Fri Jan 26 11:59:49 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
              /var:
              733M	/var/
              254M	/var/log/journal/be2ab101d79b4303b4dc531310d8bc39
              254M	/var/log
              191M	/var/lib
              Archived and active journals take up 253.3M in the file system.
              341M	/opt/iobroker/iobroker-data/
              USB-Devices by-id:
              /usr/bin/npm 		10.2.3
              /usr/bin/npx 		10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              npm ERR! invalid: color-convert@1.9.3 /opt/iobroker/node_modules/color-convert
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-26T15_14_18_362Z-debug-0.log
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin: 		6.12.0
              javascript: 	7.1.6
              Adapter State
              + instance is alive
              Adapter    "sureflap"     : 1.2.3    , installed 1.2.3
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              Objects and States
              Objects: 	3450
              States: 	2720
              Pending Updates: 0
              tcp        0      0 127.0.0.1:38299         0.0.0.0:*               LISTEN      1001       114757     1208/io.yahka.1
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13009      746/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14961      733/vncserver-x11-c
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12992      719/cupsd
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17121      908/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15187      908/iobroker.js-con
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13011      746/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12991      719/cupsd
              tcp6       0      0 :::39177                :::*                    LISTEN      1001       18058      1208/io.yahka.1
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          14960      733/vncserver-x11-c
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13278      1009/io.admin.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        13118      842/influxd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13112      823/cups-browsed
              udp        0      0 0.0.0.0:40066           0.0.0.0:*                           104        12850      558/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12848      558/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18451      1063/io.shelly.0
              udp6       0      0 fe80::44e4:421c:c1e:546 :::*                                0          13169      684/NetworkManager
              udp6       0      0 fe80::d890:c26c:38f:546 :::*                                0          14997      684/NetworkManager
              udp6       0      0 :::5353                 :::*                                104        12849      558/avahi-daemon: r
              udp6       0      0 :::57318                :::*                                104        12851      558/avahi-daemon: r
              2024-01-26 16:13:00.531  - info: wolf-smartset.0 (5282) terminating
              2024-01-26 16:13:00.704  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
              2024-01-26 16:13:00.705  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
              2024-01-26 16:13:01.766  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5298
              2024-01-26 16:13:04.274  - info: wolf-smartset.0 (5298) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
              2024-01-26 16:13:05.255  - info: wolf-smartset.0 (5298) Initialization with Login and new Session done!
              2024-01-26 16:14:00.018  - info: wolf-smartset.0 (5298) Scheduled restart.
              2024-01-26 16:14:00.065  - info: wolf-smartset.0 (5298) terminating
              2024-01-26 16:14:00.067  - info: wolf-smartset.0 (5298) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2024-01-26 16:14:00.525  - info: wolf-smartset.0 (5298) terminating
              2024-01-26 16:14:00.641  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
              2024-01-26 16:14:00.642  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
              2024-01-26 16:14:01.757  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5315
              2024-01-26 16:14:04.201  - info: wolf-smartset.0 (5315) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
              2024-01-26 16:14:05.200  - info: wolf-smartset.0 (5315) Initialization with Login and new Session done!
              2024-01-26 16:15:00.024  - info: wolf-smartset.0 (5315) Scheduled restart.
              2024-01-26 16:15:00.073  - info: wolf-smartset.0 (5315) terminating
              2024-01-26 16:15:00.076  - info: wolf-smartset.0 (5315) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2024-01-26 16:15:00.644  - warn: wolf-smartset.0 (5315) get state error: Connection is closed.
              2024-01-26 16:15:00.646  - info: wolf-smartset.0 (5315) terminating
              2024-01-26 16:15:00.734  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 scheduled normal terminated and will be restarted on schedule.
              2024-01-26 16:15:00.736  - info: host.raspberrypi Restart adapter system.adapter.wolf-smartset.0 because enabled
              2024-01-26 16:15:01.790  - info: host.raspberrypi instance system.adapter.wolf-smartset.0 started with pid 5586
              2024-01-26 16:15:04.720  - info: wolf-smartset.0 (5586) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.wolf-smartset, node: v18.19.0, js-controller: 5.0.17
              2024-01-26 16:15:05.895  - info: wolf-smartset.0 (5586) Initialization with Login and new Session done!
              Habe ich mir jetzt ein npm Problem eingefangen?
              Edit: Hatte beim Javascript Adapter Color-Convert drin, bei der Neuinstallation habe ich vergessen, es nachzutragen. Der Fehler ist jetzt auch weg.
                @ianig-iro sagte in [gelöst] Javascript Adapter funktioniert nicht /JS-Controlle:
                Soweit schaut das gut aus. Ich würde aber im Zigbee-Adapter als COM-Port statt
                • system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/ttyACM0
                besser das eintragen:
