    4. Nach Update auf Jarvis 3.1.8 keine Lebenszeichen mehr
    • Tom Arnold
      Tom Arnold last edited by
      Ich hatte die letzten 3 Jahre sehr viel Spaß mit Jarvis und auch Ruhe, nach einigen Updates (auf die aktuelle node.js Version geupdatet etc) zeigt jarvis stets rot. Hat jemand vielleicht eine Idee? Viele Grüße Tom
      Hier der Auszug aus dem Log:
      host.ioBroker
      2024-01-26 20:39:20.073 error instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.ioBroker
      2024-01-26 20:39:20.072 error Caught by controller[0]: Node.js v18.19.0
      host.ioBroker
      2024-01-26 20:39:20.072 error Caught by controller[0]: }
      host.ioBroker
      2024-01-26 20:39:20.071 error Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.discovery/main.js' ]
      host.ioBroker
      2024-01-26 20:39:20.071 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.ioBroker
      2024-01-26 20:39:20.070 error Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      host.ioBroker
      2024-01-26 20:39:20.069 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.ioBroker
      2024-01-26 20:39:20.069 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.ioBroker
      2024-01-26 20:39:20.068 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.ioBroker
      2024-01-26 20:39:20.068 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.ioBroker
      2024-01-26 20:39:20.068 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.discovery/main.js:17:21)
      host.ioBroker
      2024-01-26 20:39:20.067 error Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.ioBroker
      2024-01-26 20:39:20.067 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
      host.ioBroker
      2024-01-26 20:39:20.061 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
      host.ioBroker
      2024-01-26 20:39:20.060 error Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
      host.ioBroker
      2024-01-26 20:39:20.060 error Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.discovery/main.js
      host.ioBroker
      2024-01-26 20:39:20.059 error Caught by controller[0]: Require stack:
      host.ioBroker
      2024-01-26 20:39:20.059 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools'
      host.ioBroker
      2024-01-26 20:39:20.058 error Caught by controller[0]: ^
      host.ioBroker
      2024-01-26 20:39:20.058 error Caught by controller[0]: throw err;
      host.ioBroker
      2024-01-26 20:39:20.057 error Caught by controller[0]: node:internal/modules/cjs/loader:1137
        Thomas Braun Most Active @Tom Arnold last edited by
        @tom-arnold
        Wie bist du da insgesamt unterwegs?
        iob diag
        anschauen.
        • Tom Arnold
          Vielen Dank für die schnelle Antwort, meintest du das?
          v.2023-10-10
          Static hostname: ioBroker
          Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
          Kernel: Linux 5.10.103-v7l+
          Architecture: arm
          Installation: native
          Kernel: armv7l
          Userland: armhf
          Timezone: Europe/Berlin (CET, +0100)
          User-ID: 1000
          X-Server: false
          Boot Target: graphical.target
          Pending OS-Updates: 0
          Pending iob updates: 17
          Nodejs-Installation: /usr/bin/nodejs v18.19.0
          /usr/bin/node v18.19.0
          /usr/bin/npm 10.2.3
          /usr/bin/npx 10.2.3
          /usr/bin/corepack 0.22.0
          Recommended versions are nodejs 18.19.0 and npm 10.2.3
          MEMORY:
          total used free shared buff/cache available
          Mem: 3.8G 1.1G 1.3G 4.0M 1.4G 2.5G
          Swap: 99M 6.0M 93M
          Total: 3.9G 1.2G 1.4G
          Active iob-Instances: 15
          Active repo(s): stable
          ioBroker Core: js-controller 5.0.17
          admin 6.12.0
          ioBroker Status: iobroker is running on this host.
          Objects type: jsonl
          States type: jsonl
          • system.adapter.admin.0 : admin : ioBroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.web.0 : web : ioBroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects: 5054
          States: 3992
          Size of iob-Database:
          10M /opt/iobroker/iobroker-data/objects.jsonl
          5.5M /opt/iobroker/iobroker-data/objects.json.migrated
          5.5M /opt/iobroker/iobroker-data/objects.json.bak.migrated
          4.2M /opt/iobroker/iobroker-data/states.jsonl
          980K /opt/iobroker/iobroker-data/states.json.migrated
          980K /opt/iobroker/iobroker-data/states.json.bak.migrated
          === Mark text until here for copying ===
            @tom-arnold sagte in Nach Update auf Jarvis 3.1.8 keine Lebenszeichen mehr:
            Die Langfassung. In CodeTags belassen.
            ist aber tot und muss ersetzt werden. Am besten durch die 64Bit-Version.
            Und bring deinen ioBroker vollständig auf aktuellen Stand.
            1.0k
            81.0k
