    4. YAKAH startet nicht nach js-controller upgrade auf 5.x.x
    • lehmann-maker
      lehmann-maker last edited by Homoran
      nach einem notwendigen upgrade des js-controllers von 4.x.x zu beliebiger Version 5.x.x funktioniert eine meiner YAKAH Instanzen nicht mehr bzw. fährt nicht mehr hoch. Ich benötige das upgrade um mit vis-2 zu arbeiten. Anbei ein Fehlerauszug aus dem Log. Habt ihr Ideen zur Lösung? Vielen Dank.
      host.NAS
      2024-01-27 10:41:31.525	warn	Do not restart adapter system.adapter.yahka.0 because restart loop detected
      host.NAS
      2024-01-27 10:41:31.525	info	Restart adapter system.adapter.yahka.0 because enabled
      host.NAS
      2024-01-27 10:41:31.524	error	instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.NAS
      2024-01-27 10:41:31.524	error	Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.524	error	Caught by controller[14]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.524	error	Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.524	error	Caught by controller[12]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.523	error	Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.523	error	Caught by controller[10]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.523	error	Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.523	error	Caught by controller[8]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.523	error	Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.522	error	Caught by controller[6]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.522	error	Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.522	error	Caught by controller[4]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
      host.NAS
      2024-01-27 10:41:31.522	error	Caught by controller[3]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
      host.NAS
      2024-01-27 10:41:31.522	error	Caught by controller[2]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
      host.NAS
      2024-01-27 10:41:31.521	error	Caught by controller[1]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
      host.NAS
      2024-01-27 10:41:31.521	error	Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
      yahka.0
      2024-01-27 10:41:30.949	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      yahka.0
      2024-01-27 10:41:30.948	info	terminating
      yahka.0
      2024-01-27 10:41:30.947	info	cleaned up ...
      yahka.0
      2024-01-27 10:41:30.947	info	cleaning up ...
      yahka.0
      2024-01-27 10:41:30.896	error	Error The pattern "[object Object]" is not a valid ID pattern
      yahka.0
      2024-01-27 10:41:30.895	error	ReplyError: Error The pattern "[object Object]" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
      yahka.0
      2024-01-27 10:41:30.893	error	unhandled promise rejection: Error The pattern "[object Object]" is not a valid ID pattern
      yahka.0
      2024-01-27 10:41:30.893	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @lehmann-maker last edited by
        @lehmann-maker
        Zeig mal wie und wo du da nun unterwegs bist.
        iob diag
        lehmann-maker 1 Reply Last reply Reply Quote 0
        • lehmann-maker
          lehmann-maker @Thomas Braun last edited by
          @thomas-braun Danke für deine Antwort. Bin gerade unterwegs, daher hier nur Screenshots vom iPhone aus.IMG_2370.png IMG_2369.png
            @lehmann-maker
            Dan poste es später richtig. Mit Screenshots kann keiner was anfangen.
            • lehmann-maker
              @thomas-braun Guten Morgen, anbei das copy/paste. Befürchte aber, dass das weniger übersichtlich ist 😞
              Skript v.2023-10-10
              107*** BASE SYSTEM
              cat:
              /sys/devices/virtual/dmi/id/sys_vendor:
              No such file or directory
              Hardware Vendor :
              Kernel	: x86 64
              Userland	: ama64
              Docker	: 18.0.1
              Virtualization	: Docker
              Kernel	: x86 64
              Userland	: amd64
              Systemuptime and Load:
              15:18:47 up
              5:47,
              o users,
              average: 1.52,
              1.61, 1.52
              CPU
              threads: 4
              load
              107*** Time and Time Zones
              Sat Jan 27 14:18:47 UTC 2024
              Sat Jan 27 15:18:47 CET
              2024
              CET
              +0100
              Etc /UTC
              107*** User and
              Groups
              iobroker
              /opt/iobroker
              iobroker tty dialout audio video
              107*** X-Server-Setup
              *火*
              X-Server:
              false
              Desktop:
              Terminal:
              107*** MEMORY ***
              total available
              Mem:
              15G
              10G
              Swap:
              24M
              Total:
              46G
              used
              5.1G
              9.7G
              30G
              5. 1G
              free
              309M
              shared
              buff/cache
              497M
              31G
              31G
              15856	M total memory
              5074	M used memory
              1491	M active memory
              12379	M inactive memory
              107***FILESYSTEM ***
              Filesystem
              Size
              Used
              Type
              • Avail Use: Mounted
              overlay
              overlay
              36G
              338G
              10% 1
              tmpfs
              64M
              0
              64M
              0%
              tmpfs
              /dev
              tmpfs
              tmpfs
              7.8G
              0
              7.8G
              0%
              /sys/fs/cgroup
              shm
              tmpfs
              64M
              0
              64M
              0% / dev/shm
              / dev/mapper/cachedev] ext
              36G
              338G
              10% / opt/iobroker
              tmpfs
              tmpfs
              7. 8G
              0
              7. 8G
              0
              /proc/asound tmpfs
              tmpfs
              7. 8G
              0
              7.8G
              0%
              /proc/acpi tmpfs
              tmpfs
              7.8G
              0
              7.8G
              0%
              /proc/scsi tmpfs
              tmpfs
              7.8G
              0
              7.8G
              0%
              /sys/firmware
              374G
              374G
              Messages concerning ext filesystem in dmesg:
                @lehmann-maker
                Vor allem Dingen ist es nicht vollständig.
                Nochmal...
                • mcm1957
                  mcm1957 @lehmann-maker last edited by
                  @lehmann-maker
                  Und bitte noch zwei Dinge:
                  Bitte gib bei Problemmeldungen IMMER die betroffenen versionen von Adapter, js-controller, admin und node an.
                  Und wenn du ein passendes Issue findest oder eh selbst eines erstellst, verlink es bitte hier:
                  https://github.com/jensweigele/ioBroker.yahka/issues/461
                  Auch in deinem Issue fehlen die wichtigen Versionsngaben. Keiner weiß ob du nicht ev. nur mit einer älteren Adapterversion die nicht js-controller 5 fähig ist unterwegs bist.
                  lehmann-maker created this issue in jensweigele/ioBroker.yahka
                  closed Some Yakah Instances not working after js-controller upgrade to 5.x.x #461
                  • lehmann-maker
                    lehmann-maker @mcm1957 last edited by
                    @mcm57 @Thomas-Braun Nächster Versuch, danke für eure Geduld mit mir. In der Diagnose erscheint, dass node.js nicht korrekt installiert sei... Details unten in summary und Komplettdiagnose. Danke nochmals für eure Hilfe. Zu den Versionen:
                    ioBroker Dockerfile buanet
                    YAKAH v. 1.0.3
                    admin v. 6.13.3
                    npm v. 10.4.0
                    Nde.js v. 18.17.1
                    js-controller v. 5.0.17
                    Summary:
                    ====================== SUMMARY =======================
                                            v.2023-10-10
                    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Installation:           Docker
                    Userland:               amd64
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                    Pending OS-Updates:     47
                    Pending iob updates:    10
                    /home/iobroker/.diag.sh: line 486: nodejs: command not found
                    Nodejs-Installation:
                                            /usr/bin/node           v18.17.1
                                            /usr/bin/npm            10.4.0
                                            /usr/bin/npx            10.4.0
                                            /usr/bin/corepack       0.24.1
                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                    *** nodejs is NOT correctly installed ***
                    Wrong installation path detected. This needs to be fixed.
                    Please check
                    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                    for more information on how to fix these errors.
                    MEMORY:
                    Mem:             15G        6.1G        525M        489M        9.3G        8.7G
                    Swap:            31G         47M         30G
                    Total:           46G        6.1G         31G
                    Active iob-Instances:   5
                    Active repo(s): beta
                    ioBroker Core:          js-controller           5.0.17
                                            admin                   6.13.3
                    Objects type: jsonl
                    States  type: jsonl
                    + system.adapter.admin.0                  : admin                 : NAS                                      -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.web.0                    : web                   : NAS                                      -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
                    Objects:                4412
                    States:                 3279
                    Size of iob-Database:
                    21M     /opt/iobroker/iobroker-data/objects.jsonl
                    3.0M    /opt/iobroker/iobroker-data/states.jsonl
                    Diagnose
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
                    Hardware Vendor :
                    Kernel          : x86_64
                    Userland        : amd64
                    Docker          : v8.0.1
                    Kernel          : x86_64
                    Userland        : amd64
                     17:48:35 up 1 day,  8:17,  0 users,  load average: 5.18, 3.47, 2.54
                    CPU threads: 4
                    *** Time and Time Zones ***
                    Sun Jan 28 16:48:35 UTC 2024
                    Sun Jan 28 17:48:35 CET 2024
                    CET +0100
                    Etc/UTC
                    *** User and Groups ***
                    root
                    /root
                    root
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Mem:             15G        6.0G        319M        487M        9.5G        8.7G
                    Swap:            31G         49M         30G
                    Total:           46G        6.1G         31G
                             6040 M used memory
                             2327 M active memory
                            11419 M inactive memory
                              318 M free memory
                             1409 M buffer memory
                             8088 M swap cache
                            31016 M total swap
                               49 M used swap
                            30967 M free swap
                    *** FILESYSTEM ***
                    Filesystem            Type     Size  Used Avail Use% Mounted on
                    overlay               overlay  374G   36G  338G  10% /
                    tmpfs                 tmpfs     64M     0   64M   0% /dev
                    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/fs/cgroup
                    shm                   tmpfs     64M     0   64M   0% /dev/shm
                    /dev/mapper/cachedev1 ext4     374G   36G  338G  10% /opt/iobroker
                    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/asound
                    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/acpi
                    tmpfs                 tmpfs    7.8G     0  7.8G   0% /proc/scsi
                    tmpfs                 tmpfs    7.8G     0  7.8G   0% /sys/firmware
                    dmesg: read kernel buffer failed: Operation not permitted
                    TARGET           SOURCE        FSTYPE OPTIONS
                    /opt/iobroker    /dev/mapper/cachedev1[/Public/Docker/iobroker-test]        ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                    /etc/resolv.conf /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/resolv.conf] ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                    /etc/hostname    /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/hostname]    ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                    /etc/hosts       /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/3306d90610d61ab1525e3fc80e70ec7520a08b9e51a3e15d97c56c97af4e6a3d/hosts]       ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                    /var:
                    33M     /var/
                    31M     /var/lib
                    18M     /var/lib/apt/lists
                    18M     /var/lib/apt
                    13M     /var/lib/dpkg
                    /opt/iobroker/backups:
                    85M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    390M    /opt/iobroker/iobroker-data/
                    298M    /opt/iobroker/iobroker-data/files
                    125M    /opt/iobroker/iobroker-data/files/vis-2
                    76M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.55ce10c1.js.map
                    17M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.a5a94c49.js.map
                    USB-Devices by-id:
                    *** NodeJS-Installation ***
                    /home/iobroker/.diag.sh: line 277: nodejs: command not found
                    /usr/bin/npm            10.4.0
                    /usr/bin/npx            10.4.0
                    /home/iobroker/.diag.sh: line 288: nodejs: command not found
                    nodejs:
                      Installed: 18.17.1-deb-1nodesource1
                      Candidate: 18.17.1-deb-1nodesource1
                      Version table:
                     *** 18.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                            100 /var/lib/dpkg/status
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                            500 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.17
                    admin:          6.13.3
                    javascript:     7.5.1
                    Adapters from github:   0
                    Adapter State
                      system.adapter.alexa2.0                 : alexa2                : NAS                                      - disabled
                    + system.adapter.backitup.0               : backitup              : NAS                                      -  enabled
                      system.adapter.boschindego.0            : boschindego           : NAS                                      - disabled
                      system.adapter.cloud.0                  : cloud                 : NAS                                      - disabled
                      system.adapter.discovery.0              : discovery             : NAS                                      - disabled
                      system.adapter.doorbird.0               : doorbird              : NAS                                      - disabled
                      system.adapter.homeconnect.0            : homeconnect           : NAS                                      - disabled
                      system.adapter.iot.0                    : iot                   : NAS                                      - disabled
                      system.adapter.javascript.0             : javascript            : NAS                                      - disabled
                      system.adapter.mihome-cloud.1           : mihome-cloud          : NAS                                      - disabled
                      system.adapter.onkyo.0                  : onkyo                 : NAS                                      - disabled
                      system.adapter.openknx.0                : openknx               : NAS                                      - disabled
                      system.adapter.sma-em.0                 : sma-em                : NAS                                      - disabled
                      system.adapter.telegram.0               : telegram              : NAS                                      - disabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.terminal.0               : terminal              : NAS                                      -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      system.adapter.tr-064.0                 : tr-064                : NAS                                      - disabled
                      system.adapter.vaillant.0               : vaillant              : NAS                                      - disabled
                      system.adapter.vis-2.0                  : vis-2                 : NAS                                      - disabled
                      system.adapter.vis.0                    : vis                   : NAS                                      -  enabled
                      system.adapter.vw-connect.0             : vw-connect            : NAS                                      - disabled
                      system.adapter.yahka.0                  : yahka                 : NAS                                      -  enabled
                      system.adapter.yahka.1                  : yahka                 : NAS                                      - disabled
                      system.adapter.yahka.2                  : yahka                 : NAS                                      - disabled
                    + instance is alive
                    ioBroker-Repositories
                    Installed ioBroker-Instances
                    Used repository: beta
                    Adapter    "admin"        : 6.13.15  , installed 6.13.3 [Updatable]
                    Adapter    "alexa2"       : 3.26.4   , installed 3.25.2 [Updatable]
                    Adapter    "backitup"     : 2.10.6   , installed 2.9.8  [Updatable]
                    Adapter    "boschindego"  : 1.1.0    , installed 1.1.0
                    Adapter    "doorbird"     : 1.3.0    , installed 1.3.0
                    Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                    Adapter    "javascript"   : 7.7.0    , installed 7.5.1  [Updatable]
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
                    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                    Adapter    "openknx"      : 0.7.2    , installed 0.7.0  [Updatable]
                    Adapter    "sma-em"       : 1.0.1    , installed 1.0.0  [Updatable]
                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                    Adapter    "vaillant"     : 0.3.1    , installed 0.2.1  [Updatable]
                    Adapter    "vis"          : 1.5.4    , installed 1.4.15 [Updatable]
                    Adapter    "vis-2"        : 2.9.24   , installed 2.9.8  [Updatable]
                    Adapter    "vw-connect"   : 0.5.1    , installed 0.0.67 [Updatable]
                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                    Objects and States
                    Objects:        4412
                    States:         3279
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian-security bullseye-security InRelease
                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Reading package lists...
                    Pending Updates: 47
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       758353     -
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       757749     -
                    tcp        0      0 127.0.0.11:34037        0.0.0.0:*               LISTEN      0          739055     -
                    tcp6       0      0 :::8090                 :::*                    LISTEN      1000       769060     -
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       765486     -
                    tcp6       0      0 :::8088                 :::*                    LISTEN      1000       763823     -
                    udp        0      0 127.0.0.11:51827        0.0.0.0:*                           0          739054     -
                    2024-01-28 09:03:18.848  - info: admin.0 (168) Request actual repository...
                    2024-01-28 09:03:19.534  - info: host.NAS Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
                    2024-01-28 09:03:23.321  - info: admin.0 (168) Repository received successfully.
                    2024-01-28 10:40:09.785  - info: admin.0 (168) Adapter rating updated
                    2024-01-28 17:05:40.753  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:06:30.752  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:07:17.557  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:08:02.568  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:09:31.104  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:09:31.115  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:09:32.278  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:10:12.283  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:10:52.765  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:11:12.765  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:20:02.869  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:20:03.061  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:20:03.160  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:20:23.166  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:20:26.858  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:20:46.860  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:26:00.615  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:26:00.710  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:26:01.756  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                    2024-01-28 17:26:31.757  - info: admin.0 (168) <== Disconnect system.user.admin from ::ffff:192.168.178.125 admin
                    2024-01-28 17:35:27.928  - info: admin.0 (168) ==> Connected system.user.admin from ::ffff:192.168.178.125
                      @lehmann-maker sagte in YAKAH startet nicht nach js-controller upgrade auf 5.x.x:
                      Das war mir so klar...
                      Neuen Docker ausrollen. Und beim Docker die Finger von individuellen Installationen non npm oder nodejs lassen. Das wird da immer in die Konservendose eingedockert.
                      • lehmann-maker
                        @thomas-braun Gesagt getan in einem neuen Docker. Fehler bleibt der gleiche. Node.js Installation scheint nun iO zu sein. Anbei die Diag.:
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                        Hardware Vendor :
                        Kernel          : x86_64
                        Userland        : amd64
                        Docker          : v9.1.1
                        Kernel          : x86_64
                        Userland        : amd64
                         18:46:26 up 1 day,  9:15,  0 user,  load average: 1.97, 2.32, 2.65
                        CPU threads: 4
                        Sun Jan 28 17:46:26 UTC 2024
                        Sun Jan 28 18:46:26 CET 2024
                        CET +0100
                        Etc/UTC
                        root
                        /root
                        root
                        X-Server:       false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:             16G        6.3G        835M        492M         10G         10G
                        Swap:            32G         81M         32G
                        Total:           49G        6.4G         33G
                                 6020 M used memory
                                 1731 M active memory
                                11515 M inactive memory
                                  796 M free memory
                                  591 M buffer memory
                                 9499 M swap cache
                                31016 M total swap
                                   77 M used swap
                                30938 M free swap
                        *** FILESYSTEM ***
                        overlay               overlay  374G   39G  335G  11% /
                        /dev/mapper/cachedev1 ext4     374G   39G  335G  11% /opt/iobroker
                        /opt/iobroker    /dev/mapper/cachedev1[/Public/Docker/iobroker-test2]        ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                        /etc/resolv.conf /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/resolv.conf] ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                        /etc/hostname    /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hostname]    ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                        /etc/hosts       /dev/mapper/cachedev1[/Public/Docker/container-station-data/lib/docker/containers/ae55d44f77a0fe709d40ccfd0f4e93bc0c129e9d83a542d767a1f71bffe9e096/hosts]       ext4   rw,relatime,noacl,stripe=128,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user
                        /var:
                        34M     /var/
                        32M     /var/lib
                        19M     /var/lib/apt/lists
                        19M     /var/lib/apt
                        13M     /var/lib/dpkg
                        87M     /opt/iobroker/backups/
                        197M    /opt/iobroker/iobroker-data/
                        172M    /opt/iobroker/iobroker-data/files
                        55M     /opt/iobroker/iobroker-data/files/javascript.admin
                        43M     /opt/iobroker/iobroker-data/files/iot.admin
                        42M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                        USB-Devices by-id:
                        /usr/bin/nodejs         v18.19.0
                        /usr/bin/node           v18.19.0
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                         *** 18.19.0-1nodesource1 1001
                               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.9
                        javascript:     7.5.1
                        Adapter State
                          system.adapter.terminal.0               : terminal              : NAS                                      - disabled, port: 8088, bind: 0.0.0.0, run as: admin
                          system.adapter.vis.0                    : vis                   : NAS                                      - disabled
                          system.adapter.web.0                    : web                   : NAS                                      - disabled, port: 8090, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        Adapter    "admin"        : 6.13.15  , installed 6.13.9 [Updatable]
                        Objects and States
                        Objects:        4382
                        States:         3399
                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                        Pending Updates: 0
                        tcp        0      0 127.0.0.11:45543        0.0.0.0:*               LISTEN      0          27210132   -
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       27227538   -
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       27225086   -
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       27229016   -
                        udp        0      0 127.0.0.11:45160        0.0.0.0:*                           0          27210131   -
                        2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaning up ...
                        2024-01-28 18:44:27.631  - info: yahka.0 (1770) cleaned up ...
                        2024-01-28 18:44:27.632  - info: yahka.0 (1770) terminating
                        2024-01-28 18:44:27.633  - warn: yahka.0 (1770) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2024-01-28 18:44:28.135  - info: yahka.0 (1770) terminating
                        2024-01-28 18:44:28.204  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
                        2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
                        2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
                        2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                        2024-01-28 18:44:28.205  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.206  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                        2024-01-28 18:44:28.207  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2024-01-28 18:44:28.208  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
                        2024-01-28 18:44:28.208  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
                          Aber deine Basis ist stabil.
                            @lehmann-maker
                            Und jetzt bringst du den ganzen ioBroker auf Stand...
                            • lehmann-maker
                              @thomas-braun Damit meinst du Adapter updaten? YAKAH ist allerdings bereits neuste Version.
                              • mcm1957
                                Schätze dann wird da wohl der Maintainer des Adapters was dazu sagen müssen.
                                  @lehmann-maker
                                  Die ganzen Adapter-Updates die da in der Pipeline hängen. Und/oder schalt das beta-Repo aus.
                                    A Former User last edited by
                                    @lehmann-maker
                                    Warum hast du 3 Yahka Instanzen, wusste garnicht, dass das geht..?
                                    Wie hast du avahi konfiguriert?
                                    • lehmann-maker
                                      Getan. Leider ohne Änderung. Es betrifft wie gesagt nur die Instanz 0. Die beiden anderen Instanzen laufen. Auf meiner Hauptinstallation mit folgendem Setup laufen alle 3 Instanzen:
                                      YAHKA 1.0.3
                                      Node.js 18.16.0
                                      NPM 9.5.1
                                      js-controller 4.0.24
                                      Hier nochmals das Log der Diagnose nach dem Adapterupdate:
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                      Hardware Vendor :
                                      Kernel          : x86_64
                                      Userland        : amd64
                                      Docker          : v9.1.1
                                      Kernel          : x86_64
                                      Userland        : amd64
                                       09:21:30 up 1 day, 23:50,  0 user,  load average: 1.60, 2.08, 2.08
                                      CPU threads: 4
                                      Mon Jan 29 08:21:30 UTC 2024
                                      Mon Jan 29 09:21:30 CET 2024
                                      CET +0100
                                      Etc/UTC
                                      root
                                      /root
                                      root
                                      X-Server:       false
                                      Desktop:
                                      Terminal:
                                      *** MEMORY ***
                                      Mem:             16G        7.5G        317M        488M        9.9G        9.1G
                                      Swap:            32G         98M         32G
                                      Total:           49G        7.6G         32G
                                               7133 M used memory
                                               2215 M active memory
                                              11436 M inactive memory
                                                302 M free memory
                                               1216 M buffer memory
                                               8253 M swap cache
                                              31016 M total swap
                                                 93 M used swap
                                              30922 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      34M     /var/
                                      32M     /var/lib
                                      19M     /var/lib/apt
                                      13M     /var/lib/dpkg
                                      215M    /opt/iobroker/iobroker-data/
                                      42M     /opt/iobroker/iobroker-data/objects.jsonl
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.13.15
                                      javascript:     7.5.1
                                      Adapter State
                                      + system.adapter.yahka.1                  : yahka                 : NAS                                      -  enabled
                                      + system.adapter.yahka.2                  : yahka                 : NAS                                      -  enabled
                                      + instance is alive
                                      Active repo(s): stable
                                      Used repository: stable
                                      Adapter    "admin"        : 6.12.0   , installed 6.13.15
                                      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                      Adapter    "backitup"     : 2.9.8    , installed 2.10.6
                                      Adapter    "javascript"   : 7.1.6    , installed 7.5.1
                                      Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.1
                                      Adapter    "openknx"      : 0.6.3    , installed 0.7.0
                                      Adapter    "sma-em"       : 1.0.0    , installed 1.0.0
                                      Adapter    "vaillant"     : 0.1.2    , installed 0.2.1
                                      Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
                                      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
                                      Adapter    "web"          : 6.1.10   , installed 6.2.3
                                      Adapter    "ws"           : 2.5.8    , installed 2.5.10
                                      Objects and States
                                      Objects:        4382
                                      States:         3403
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       38475089   -
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       38477790   -
                                      tcp        0      0 127.0.0.11:40349        0.0.0.0:*               LISTEN      0          38446094   -
                                      tcp6       0      0 :::42505                :::*                    LISTEN      1000       38899787   -
                                      tcp6       0      0 :::35019                :::*                    LISTEN      1000       38899839   -
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       38813362   -
                                      udp        0      0 127.0.0.11:45393        0.0.0.0:*                           0          38446093   -
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899840   -
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       38899788   -
                                      2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaning up ...
                                      2024-01-29 09:20:48.490  - info: yahka.0 (1911) cleaned up ...
                                      2024-01-29 09:20:48.491  - info: yahka.0 (1911) terminating
                                      2024-01-29 09:20:48.492  - warn: yahka.0 (1911) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2024-01-29 09:20:48.993  - info: yahka.0 (1911) terminating
                                      2024-01-29 09:20:49.067  - error: host.NAS Caught by controller[0]: [Yahka-0 DAC7] The selected advertiser, "avahi", isn't available on this platform. Reverting to "bonjour-hap"
                                      2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[1]: [Yahka-0 DAC7@Küche Temperatur@Temperatur@Target Temperature] characteristic was supplied illegal value: number 7 exceeded minimum of 10
                                      2024-01-29 09:20:49.068  - error: host.NAS Caught by controller[2]: [Yahka-0 DAC7@Flur Temperatur@Temperatur@Current Temperature] characteristic value expected valid finite number and received "undefined" (undefined)
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[3]: [Yahka-0 DAC7@Treppe Spots@Dimmer@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[4]: [Yahka-0 DAC7@Bad Eltern LED@LED Controller@Brightness] characteristic value expected valid finite number and received "undefined" (undefined)
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[5]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[6]: [Yahka-0 DAC7@Szene Kochen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[7]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[8]: [Yahka-0 DAC7@Szene TV@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.069  - error: host.NAS Caught by controller[9]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[10]: [Yahka-0 DAC7@Szene Gute Nacht@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[11]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[12]: [Yahka-0 DAC7@Szene Guten Morgen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[13]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[14]: [Yahka-0 DAC7@Szene Ankommen@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.070  - error: host.NAS Caught by controller[15]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.071  - error: host.NAS Caught by controller[16]: [Yahka-0 DAC7@Szene Weihnachten@Szene@On] characteristic value expected boolean and received undefined
                                      2024-01-29 09:20:49.071  - error: host.NAS instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2024-01-29 09:20:49.071  - info: host.NAS Restart adapter system.adapter.yahka.0 because enabled
                                      2024-01-29 09:20:49.071  - warn: host.NAS Do not restart adapter system.adapter.yahka.0 because restart loop detected
                                      • lehmann-maker
                                        lehmann-maker @Guest last edited by
                                        @ilovegym
                                        Wenn du in der Adapteransicht im ioBroker im Adapter auf + drückst, kannst du weitere Instanzen hinzufügen. Da ich mit YAHKA meine knx Geräte integriere habe ich mehr als 150 Geräte und muss diese daher aufteilen.
                                        • lehmann-maker
                                          lehmann-maker @lehmann-maker last edited by
                                          @Thomas-Braun Noch eine Idee? Danke im Voraus.
                                          • wendy2702
                                            wendy2702 last edited by
                                            Wie sieht denn das log vom Adapter jetzt aus?
                                            2644
