    4. Broadlink RM 4 Pro geht nicht
      lustig29 last edited by
      ich habe einen Rm4 Pro und möchte ihn gerne unter Iobroker nutzen. Auftauchen tut er in den Objekten, aber leider fehlt mir den Button zum anlernen der Signale.
      broadlink2.0
      2024-01-28 09:51:42.890	warn	Unknown UN:BroadLink-WiFi-Device-54-29-c1 with { address: '192.168.0.62', port: 80, devtype: 25755, oname: '智能遥控', cloud: 0, maco: <Buffer c1 29 54 b0 43 a0>, mac: 'a0:43:b0:54:29:c1', type: 'unknown', name: 'UN:BroadLink-WiFi-Device-54-29-c1', devname: 'UKN', devhex: '0x649b', names: [ 'BroadLink-WiFi-Device-54-29-c1' ], iname: 'UN:BroadLink-WiFi-Device-54-29-c1'}
      broadlink2.0
      2024-01-28 09:51:42.885	info	Device UN:BroadLink-WiFi-Device-54-29-c1 detected: address=192.168.0.62, mac=a0:43:b0:54:29:c1, typ=unknown, id=0x649b devtype=UKN
      broadlink2.0
      2024-01-28 09:51:42.816	info	discover [ '192.168.0.255', '255.255.255.255', '224.0.0.251' ] from 192.168.0.1:32870
      broadlink2.0
      2024-01-28 09:51:42.815	info	interface to be used: { netmaskBits: 24, address: '192.168.0.80/24', addrs: [ 192, 168, 0, 80 ], cidr: '192.168.0.80/24', bcaddr: '192.168.0.255'}:
      broadlink2.0
      2024-01-28 09:51:42.761	info	Discover Broadlink devices for 10sec on broadlink2.0
      broadlink2.0
      2024-01-28 09:51:42.760	info	macObjects: []
      broadlink2.0
      2024-01-28 09:51:42.760	info	interface to be used: { netmaskBits: 24, address: '192.168.0.80/24', addrs: [ 192, 168, 0, 80 ], cidr: '192.168.0.80/24', bcaddr: '192.168.0.255'}:
      broadlink2.0
      2024-01-28 09:51:42.758	info	broadlink2 has 0 old devices!
      broadlink2.0
      2024-01-28 09:51:42.758	info	Devices to rename: LB:hostName-aa-bb-cc=LB:SmartBulb
      broadlink2.0
      2024-01-28 09:51:42.757	info	Devices to add:
      broadlink2.0
      2024-01-28 09:51:42.757	info	Scanning additional IP's: 192.168.0.62
      broadlink2.0
      2024-01-28 09:51:42.756	info	broadlink2 initialization started...
      broadlink2.0
      2024-01-28 09:51:42.714	info	starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.19.0, js-controller: 5.0.17
      host.IobrokerHauptinstallation
      2024-01-28 09:51:42.036	info	instance system.adapter.broadlink2.0 started with pid 21139
      2024-01-28 09:51:39.504	info	instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      broadlink2.0
      2024-01-28 09:51:39.469	info	terminating
      MalleRalle P 2 Replies Last reply Reply Quote 0
      • MalleRalle
        MalleRalle @lustig29 last edited by
        @lustig29
        Bei mir sieht die Config so aus:
          lustig29 @MalleRalle last edited by
          @malleralle Funktioniert leider so auch nicht.
            lustig29 @lustig29 last edited by
            Jetzt hat es funktioniert. Leider kann ich meine Fernbedienung nicht anlernen. Es ist eine Fernbedienung von einer elektrischen Tv Deckenhalterung. Hinten ist ein Aufkleber mit der Aufschrift RF Remote control drauf. Wenn ich jetzt _LearnRf drücke passiert aber nichts.
            H I 2 Replies Last reply Reply Quote 0
              hansmeier @lustig29 last edited by
              @lustig29 Ist immer etwas tricky und langwierig, das Anlernen.
              Bei mir klappt es so:
              _LearnRf drücken. Gewünschte Taste an der Remote lange drücken bis im Log "found Frequenzy .... " erscheint. Dann Taste loslassen und kurz noch einmal drücken.
                lustig29 @hansmeier last edited by
                @hansmeier Bei mir leider nicht.
                  @lustig29 Ich musste auch oft den Broadlink ein/ausschalten, damit er wieder in den Lernmodus geht.
                  Könnte auch noch ein Signal sein, dass sich selbst verändert. Als Sicherheitsfeature. Ist aber meist nur bei Garagen-Remotes eingesetzt. Damit kann der Broadlink nichts anfangen.
                  • I
                    Infinity 0 @lustig29 last edited by Infinity 0
                    @lustig29 hi, wie hat es denn letztendlich bei dir funktioniert? Ich habe auch keinen Learnrf Button. Jetzt frage ich hier um Rat und eben klappt alles. 😂
                      Pixelsolution @lustig29 last edited by
                      @lustig29 Hi Lustig, darf man fragen mit welcher App du den Broadlink in die Cloud gebracht hast?
                        Bernd 3 @Pixelsolution last edited by
                        @pixelsolution
                        @Infinity-0
                        @hansmeier
                        @lustig29
                        @MalleRalle
                        ich hänge mich mal hier mit rein da ich das gleiche Problem habe. Leider fehlt mir nach wie vor die Lösung.
                        Ich habe zunächst mit der Android-App "Broadlink" den RM Pro eingerichtet. Die Einbindung in das WLAN der FritzBox hat funktioniert. Habe auch in der APP versuchsweise zwei IR-Geräte eingerichtet. Funktioniert, aber im iOBroker tut sich nichts, siehe Screenshots. Mir fehlen die eingetragenen IR-Geräte und der Learn-Button. Ich hoffe dass ich die Eintragungen in der Instanzeneinstellung richtig sind (Nur die IP-Adresse eingetragen, alles andere unverändert.)
                        Bin gespannt auf Eure Tipps.
                        • E
                          Einstein2002 last edited by
                          Gude,
                          ich habe das selbe Problem, keinen LERN Taster!
                          Bei meinem Brodlink RM mini 3 funktioniert alles super.
                          Hat keiner ne Idee an was das liegen könnte.
                          Ich benötige den RM4 Pro zum Steuern einer Markise und diese hat eine Funk Fernbedienung.
                          Dankeschön im vorab
                          grüße
                            tklein last edited by
                            hohoho euch allen,
                            gibt es neuigkeiten zu dem rm4 pro?
                            zuerst hatte ich folgendes im log:
                            warn	Warning: Device discovered which operates in cloud mode and could not be authenticated!Delete device from mobile app, reset device and bring it into WiFi network again but do not assign it any name, room or function, close app immediately!Device: { address: '192.168.0.232', port: 80, devtype: 21003, oname: '智能遥控', cloud: 1, maco: <Buffer fe 65 7d 56 16 e8>, mac: 'e8:16:56:7d:65:fe', type: 'unknown', name: '0x520b_e8:16:56:7d:65:fe', devname: 'UKN', devhex: '0x520b'}
                            Failed to authenticate device Unknown, undefined, e8:16:56:7d:65:fe, 192.168.0.232, 智能遥控cloud=true with err [object Object]
                            das könnte ich ändern zu:
                            warn	Unknown UN:BroadLink-Remote-7d-65-fe with { address: '192.168.0.232', port: 80, devtype: 21003, oname: '智能遥控', cloud: 0, maco: <Buffer fe 65 7d 56 16 e8>, mac: 'e8:16:56:7d:65:fe', type: 'unknown',
                            name: 'UN:BroadLink-Remote-7d-65-fe', devname: 'UKN', devhex: '0x520b', names: [ 'BroadLink-rm4-pro', 'Twinkly-2B4871-vorhang-treppe', 'BroadLink-Remote-7d-65-fe' ], iname: 'UN:BroadLink-Remote-7d-65-fe' }
                            btw: keine Ahnung wie/warum meine Twinkly Gruppe dort gelistet ist.
                            habe jetzt folgende dp:
                            vielleicht konnte jemand diese Problem lösen und mir so ein schöneres X-mas ermöglichen 🙂
                            • E
                              Einstein2002 @tklein last edited by
                              @tklein
                              Hier ist anscheinend keiner mehr, ich bekomme dieses Blöde Ding nicht zum laufen. Auch habe ich keinerlei Beschreibung gefunden die Funktioniert. Schade, dass es hier keinen gibt der einen Broadlink RM4Pro mit 433Mhz Funk am laufen hat und die Einstellungen verrät. Es ist sehr stark anzunehmen das dieser RM4Pro nicht IOB läuft.
                              Sascha Schmieder 1 Reply Last reply Reply Quote 0
                              • Sascha Schmieder
                                Sascha Schmieder @Einstein2002 last edited by
                                @einstein2002
                                Hey, weiß jetzt zwar nicht ob es dir jetzt noch was bringt, beziehungsweise ob es dir überhaupt was bringt.
                                Ist schon über ein Jahr her, daher sind die Erinnerungen auch etwas Schwammig.
                                Ich habe meinen RM4Pro irgendwie damit zum laufen bekommen.
                                Bei "IP Adresse" nichts eintragen.
                                Bei "Definieren Sie neue Geräte" habe ich "0x653c=RM4P" Eingetragen. Erst dann sind auch die Objekte fürs anlernen gekommen.
                                Bei "Zusätzliche IPs zum Scannen" IP des RM4Pro.
                                Ich weiß noch grob, das man ihn nicht komplett mit der App verbinden durfte. Man musste den RM4Pro in einen Art Kopplungszustand bringen und dann wurde er vom Adapter gefunden.
                                Kann aber nicht mehr sagen, ob ich den Adapter nochmal neu installiert habe und evtl. auch die Datenpunkte in dem zusammenhang gelöscht habe. Evtl. auch Iobroker neu Starten.
                                Sorry für den ungenauen Vorgang.
                                Sollten weitere Daten aus meinem System was bringen, stehe ich gerne zur Verfügung.
                                Hoffe es hilft. Viel Glück.
                                Gruß Hannibal
                                1.0k
                                1747
