    4. Error: Cannot find module 'tar' - iobroker nicht erreichbar
      ThoHilde last edited by
      ich habe heute Morgen verschiedene updates eingespilet über die Weboberfläche (u.a. admin, nodered, modbus) und seitdem funktioniert mein iobroker nicht mehr.
      iob fix habe ich laufen lassen, jedoch ohne Erfolg.
      Wenn ich über ssh z.b. die logs bei einem restart ansehen will kommt folgendes:
      pi@raspberrypi:~ $ iob logs --watch
      node:internal/modules/cjs/loader:1137
       throw err;
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
         at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
         at Module._load (node:internal/modules/cjs/loader:975:27)
         at Module.require (node:internal/modules/cjs/loader:1225:19)
         at require (node:internal/modules/helpers:177:18)
         at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
         at Module._compile (node:internal/modules/cjs/loader:1356:14)
         at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
         at Module.load (node:internal/modules/cjs/loader:1197:32)
         at Module._load (node:internal/modules/cjs/loader:1013:12)
         at Module.require (node:internal/modules/cjs/loader:1225:19) {
       code: 'MODULE_NOT_FOUND',
       requireStack: [
         '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
         '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
         '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Node.js v18.19.0
      iob diag sagt folgendes:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.21-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       10:34:36 up  1:15,  1 user,  load average: 0.97, 0.95, 0.87
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-02-01 10:34:36 CET
                 Universal time: Thu 2024-02-01 09:34:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            1.9G        573M        804M        0.0K        492M        1.3G
      Swap:            99M        1.0M         98M
      Total:          2.0G        574M        903M
               1870 M total memory
                573 M used memory
                208 M active memory
                734 M inactive memory
                804 M free memory
                100 M buffer memory
                392 M swap cache
                 99 M total swap
                  1 M used swap
                 98 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      110G   11G   95G  11% /
      devtmpfs       devtmpfs  679M     0  679M   0% /dev
      tmpfs          tmpfs     936M     0  936M   0% /dev/shm
      tmpfs          tmpfs     375M  864K  374M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     188M     0  188M   0% /run/user/1000
      [Thu Feb  1 09:18:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:1F:BE:D6 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=16b6bb5a-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Feb  1 09:18:48 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Thu Feb  1 09:18:48 2024] EXT4-fs (sda2): write access will be enabled during recovery
      [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): 5 orphan inodes deleted
      [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): recovery complete
      [Thu Feb  1 09:18:49 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Feb  1 09:18:49 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Feb  1 09:18:52 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      4.3G    /var/
      3.1G    /var/log
      3.0G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
      852M    /var/lib
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      /opt/iobroker/iobroker-data:
      478M    /opt/iobroker/iobroker-data/
      392M    /opt/iobroker/iobroker-data/files
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      67M     /opt/iobroker/iobroker-data/backup-objects
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_66b57112301aec11875774e5f01c6278-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @emnapi/core@ /opt/iobroker/node_modules/@emnapi/core
      npm ERR! extraneous: @emnapi/runtime@ /opt/iobroker/node_modules/@emnapi/runtime
      npm ERR! extraneous: @mongodb-js/saslprep@ /opt/iobroker/node_modules/@mongodb-js/saslprep
      npm ERR! extraneous: @napi-rs/wasm-runtime@ /opt/iobroker/node_modules/@napi-rs/wasm-runtime
      npm ERR! extraneous: @node-red/editor-api@ /opt/iobroker/node_modules/@node-red/editor-api
      npm ERR! extraneous: @node-red/editor-client@ /opt/iobroker/node_modules/@node-red/editor-client
      npm ERR! extraneous: @node-red/nodes@ /opt/iobroker/node_modules/@node-red/nodes
      npm ERR! extraneous: @node-red/registry@ /opt/iobroker/node_modules/@node-red/registry
      npm ERR! extraneous: @node-red/runtime@ /opt/iobroker/node_modules/@node-red/runtime
      npm ERR! extraneous: @node-red/util@ /opt/iobroker/node_modules/@node-red/util
      npm ERR! extraneous: @tybys/wasm-util@ /opt/iobroker/node_modules/@tybys/wasm-util
      npm ERR! extraneous: @types/webidl-conversions@7.0.3 /opt/iobroker/node_modules/@types/webidl-conversions
      npm ERR! extraneous: @types/whatwg-url@11.0.4 /opt/iobroker/node_modules/@types/whatwg-url
      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
      npm ERR! extraneous: acorn-walk@8.2.0 /opt/iobroker/node_modules/acorn-walk
      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
      npm ERR! extraneous: addressparser@1.0.1 /opt/iobroker/node_modules/addressparser
      npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
      npm ERR! extraneous: aproba@1.2.0 /opt/iobroker/node_modules/aproba
      npm ERR! extraneous: array-indexofobject@0.0.1 /opt/iobroker/node_modules/array-indexofobject
      npm ERR! extraneous: async-mutex@ /opt/iobroker/node_modules/async-mutex
      npm ERR! extraneous: basic-auth@2.0.1 /opt/iobroker/node_modules/basic-auth
      npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/bcrypt
      npm ERR! extraneous: bcryptjs@2.4.3 /opt/iobroker/node_modules/bcryptjs
      npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
      npm ERR! extraneous: bson@ /opt/iobroker/node_modules/bson
      npm ERR! extraneous: cli-table@0.3.11 /opt/iobroker/node_modules/cli-table
      npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/clone
      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
      npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
      npm ERR! extraneous: cronosjs@1.7.1 /opt/iobroker/node_modules/cronosjs
      npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
      npm ERR! extraneous: detect-libc@ /opt/iobroker/node_modules/detect-libc
      npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/enquirer
      npm ERR! extraneous: feedparser@2.2.10 /opt/iobroker/node_modules/feedparser
      npm ERR! extraneous: fs.notify@0.0.4 /opt/iobroker/node_modules/fs.notify
      npm ERR! extraneous: gridstack@0.6.4 /opt/iobroker/node_modules/gridstack
      npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
      npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
      npm ERR! extraneous: hash-sum@2.0.0 /opt/iobroker/node_modules/hash-sum
      npm ERR! extraneous: hpagent@ /opt/iobroker/node_modules/hpagent
      npm ERR! extraneous: i18next@ /opt/iobroker/node_modules/i18next
      npm ERR! invalid: iobroker.node-red@ /opt/iobroker/node_modules/iobroker.node-red
      npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
      npm ERR! invalid: jquery@ /opt/iobroker/node_modules/jquery
      npm ERR! extraneous: jquery@ /opt/iobroker/node_modules/jquery
      npm ERR! extraneous: js2xmlparser@5.0.0 /opt/iobroker/node_modules/js2xmlparser
      npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
      npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: lodash.assign@4.2.0 /opt/iobroker/node_modules/lodash.assign
      npm ERR! extraneous: lodash.clonedeep@4.5.0 /opt/iobroker/node_modules/lodash.clonedeep
      npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
      npm ERR! extraneous: lodash.has@4.5.2 /opt/iobroker/node_modules/lodash.has
      npm ERR! extraneous: lodash.uniq@4.5.0 /opt/iobroker/node_modules/lodash.uniq
      npm ERR! extraneous: memory-pager@1.5.0 /opt/iobroker/node_modules/memory-pager
      npm ERR! extraneous: memorystore@1.6.7 /opt/iobroker/node_modules/memorystore
      npm ERR! extraneous: mongodb-connection-string-url@ /opt/iobroker/node_modules/mongodb-connection-string-url
      npm ERR! extraneous: mri@1.2.0 /opt/iobroker/node_modules/mri
      npm ERR! extraneous: mustache@4.2.0 /opt/iobroker/node_modules/mustache
      npm ERR! extraneous: node-disk-info@1.3.0 /opt/iobroker/node_modules/node-disk-info
      npm ERR! extraneous: node-red-admin@ /opt/iobroker/node_modules/node-red-admin
      npm ERR! extraneous: node-red-contrib-aggregator@2.0.0 /opt/iobroker/node_modules/node-red-contrib-aggregator
      npm ERR! extraneous: node-red-contrib-os@0.2.1 /opt/iobroker/node_modules/node-red-contrib-os
      npm ERR! extraneous: node-red-contrib-polymer@0.0.22 /opt/iobroker/node_modules/node-red-contrib-polymer
      npm ERR! extraneous: node-red-dashboard@ /opt/iobroker/node_modules/node-red-dashboard
      npm ERR! extraneous: node-red-node-email@2.1.0 /opt/iobroker/node_modules/node-red-node-email
      npm ERR! extraneous: node-red-node-feedparser@0.3.0 /opt/iobroker/node_modules/node-red-node-feedparser
      npm ERR! extraneous: node-red-node-sentiment@0.1.6 /opt/iobroker/node_modules/node-red-node-sentiment
      npm ERR! extraneous: node-red-node-twitter@1.2.0 /opt/iobroker/node_modules/node-red-node-twitter
      npm ERR! extraneous: node-red@ /opt/iobroker/node_modules/node-red
      npm ERR! extraneous: node-watch@ /opt/iobroker/node_modules/node-watch
      npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
      npm ERR! extraneous: oauth@0.10.0 /opt/iobroker/node_modules/oauth
      npm ERR! extraneous: oauth2orize@1.11.1 /opt/iobroker/node_modules/oauth2orize
      npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
      npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
      npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
      npm ERR! extraneous: passport-http-bearer@1.0.1 /opt/iobroker/node_modules/passport-http-bearer
      npm ERR! extraneous: passport-oauth2-client-password@0.1.2 /opt/iobroker/node_modules/passport-oauth2-client-password
      npm ERR! extraneous: pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
      npm ERR! extraneous: sentiment@2.1.0 /opt/iobroker/node_modules/sentiment
      npm ERR! extraneous: simple-statistics@2.5.0 /opt/iobroker/node_modules/simple-statistics
      npm ERR! extraneous: sparse-bitfield@3.0.3 /opt/iobroker/node_modules/sparse-bitfield
      npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
      npm ERR! extraneous: twitter-ng@0.6.2 /opt/iobroker/node_modules/twitter-ng
      npm ERR! extraneous: uglify-js@ /opt/iobroker/node_modules/uglify-js
      npm ERR! extraneous: uid2@0.0.4 /opt/iobroker/node_modules/uid2
      npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
      npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
      npm ERR! extraneous: xmlcreate@2.0.4 /opt/iobroker/node_modules/xmlcreate
      npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@emnapi/core/node_modules/tslib
      npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@emnapi/runtime/node_modules/tslib
      npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/bcrypt
      npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/body-parser
      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/mime
      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/@node-red/editor-api/node_modules/node-addon-api
      npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/@node-red/editor-api/node_modules/raw-body
      npm ERR! extraneous: @sindresorhus/is@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/@sindresorhus/is
      npm ERR! extraneous: @szmarczak/http-timer@5.0.1 /opt/iobroker/node_modules/@node-red/nodes/node_modules/@szmarczak/http-timer
      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/ajv
      npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/body-parser
      npm ERR! extraneous: cacheable-lookup@7.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/cacheable-lookup
      npm ERR! extraneous: cacheable-request@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/cacheable-request
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/fs-extra
      npm ERR! extraneous: get-stream@6.0.1 /opt/iobroker/node_modules/@node-red/nodes/node_modules/get-stream
      npm ERR! extraneous: got@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/got
      npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/http2-wrapper
      npm ERR! extraneous: lowercase-keys@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/lowercase-keys
      npm ERR! extraneous: mimic-response@4.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/mimic-response
      npm ERR! extraneous: normalize-url@8.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/normalize-url
      npm ERR! extraneous: p-cancelable@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/p-cancelable
      npm ERR! extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/@node-red/nodes/node_modules/raw-body
      npm ERR! extraneous: responselike@3.0.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/responselike
      npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/tough-cookie
      npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/@node-red/nodes/node_modules/uuid
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/registry/node_modules/fs-extra
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/runtime/node_modules/fs-extra
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/@node-red/util/node_modules/fs-extra
      npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/@tybys/wasm-util/node_modules/tslib
      npm ERR! extraneous: tslib@ /opt/iobroker/node_modules/async-mutex/node_modules/tslib
      npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/basic-auth/node_modules/safe-buffer
      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/bcrypt/node_modules/node-addon-api
      npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/feedparser/node_modules/isarray
      npm ERR! extraneous: readable-stream@2.3.7 /opt/iobroker/node_modules/feedparser/node_modules/readable-stream
      npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/feedparser/node_modules/safe-buffer
      npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/feedparser/node_modules/string_decoder
      npm ERR! extraneous: async@0.1.22 /opt/iobroker/node_modules/fs.notify/node_modules/async
      npm ERR! extraneous: retry@0.6.1 /opt/iobroker/node_modules/fs.notify/node_modules/retry
      npm ERR! invalid: xml2js@ /opt/iobroker/node_modules/xml2js
      npm ERR! extraneous: @iobroker/adapter-core@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
      npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/gaxios
      npm ERR! extraneous: gcp-metadata@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/gcp-metadata
      npm ERR! extraneous: mongodb@ /opt/iobroker/node_modules/iobroker.node-red/node_modules/mongodb
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/memorystore/node_modules/debug
      npm ERR! extraneous: lru-cache@4.1.5 /opt/iobroker/node_modules/memorystore/node_modules/lru-cache
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/memorystore/node_modules/ms
      npm ERR! extraneous: yallist@2.1.2 /opt/iobroker/node_modules/memorystore/node_modules/yallist
      npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/mongodb-connection-string-url/node_modules/tr46
      npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/mongodb-connection-string-url/node_modules/whatwg-url
      npm ERR! extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/node-disk-info/node_modules/iconv-lite
      npm ERR! extraneous: accepts@1.3.3 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/accepts
      npm ERR! extraneous: arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/arraybuffer.slice
      npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/base64-arraybuffer
      npm ERR! extraneous: base64id@1.0.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/base64id
      npm ERR! extraneous: blob@0.0.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/blob
      npm ERR! extraneous: component-emitter@1.1.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/component-emitter
      npm ERR! extraneous: cookie@0.3.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/cookie
      npm ERR! extraneous: debug@2.3.3 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/debug
      npm ERR! extraneous: engine.io-client@1.8.6 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-client
      npm ERR! extraneous: engine.io-parser@1.3.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-parser
      npm ERR! extraneous: engine.io@1.8.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io
      npm ERR! extraneous: ms@0.7.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ms
      npm ERR! extraneous: negotiator@0.6.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/negotiator
      npm ERR! extraneous: object-assign@4.1.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/object-assign
      npm ERR! extraneous: parseqs@0.0.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/parseqs
      npm ERR! extraneous: parseuri@0.0.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/parseuri
      npm ERR! extraneous: socket.io-adapter@0.5.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-adapter
      npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-client
      npm ERR! extraneous: socket.io-parser@2.3.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser
      npm ERR! extraneous: socket.io@1.7.4 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io
      npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ultron
      npm ERR! extraneous: ws@1.1.5 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/ws
      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/debug
      npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/engine.io-parser
      npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/engine.io
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/node-red-dashboard/node_modules/ms
      npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/node-red-dashboard/node_modules/socket.io
      npm ERR! extraneous: @selderee/plugin-htmlparser2@0.11.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/@selderee/plugin-htmlparser2
      npm ERR! extraneous: base32.js@0.1.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/base32.js
      npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/core-util-is
      npm ERR! extraneous: deepmerge@4.3.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/deepmerge
      npm ERR! extraneous: dom-serializer@2.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/dom-serializer
      npm ERR! extraneous: domelementtype@2.3.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/domelementtype
      npm ERR! extraneous: domhandler@5.0.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/domhandler
      npm ERR! extraneous: domutils@3.1.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/domutils
      npm ERR! extraneous: encoding-japanese@2.0.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/encoding-japanese
      npm ERR! extraneous: entities@4.5.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/entities
      npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/he
      npm ERR! extraneous: html-to-text@9.0.5 /opt/iobroker/node_modules/node-red-node-email/node_modules/html-to-text
      npm ERR! extraneous: htmlparser2@8.0.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/htmlparser2
      npm ERR! extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/iconv-lite
      npm ERR! extraneous: imap@0.8.19 /opt/iobroker/node_modules/node-red-node-email/node_modules/imap
      npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/node-red-node-email/node_modules/inherits
      npm ERR! extraneous: ipv6-normalize@1.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/ipv6-normalize
      npm ERR! extraneous: isarray@0.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/isarray
      npm ERR! extraneous: leac@0.6.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/leac
      npm ERR! extraneous: libbase64@1.2.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libbase64
      npm ERR! extraneous: libmime@5.2.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libmime
      npm ERR! extraneous: libqp@2.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/libqp
      npm ERR! extraneous: linkify-it@4.0.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/linkify-it
      npm ERR! extraneous: mailparser@3.6.5 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailparser
      npm ERR! extraneous: mailsplit@5.4.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailsplit
      npm ERR! extraneous: node-pop3@0.9.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/node-pop3
      npm ERR! extraneous: nodemailer@6.9.7 /opt/iobroker/node_modules/node-red-node-email/node_modules/nodemailer
      npm ERR! extraneous: parseley@0.12.1 /opt/iobroker/node_modules/node-red-node-email/node_modules/parseley
      npm ERR! extraneous: peberminta@0.9.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/peberminta
      npm ERR! extraneous: readable-stream@1.1.14 /opt/iobroker/node_modules/node-red-node-email/node_modules/readable-stream
      npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/safer-buffer
      npm ERR! extraneous: selderee@0.11.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/selderee
      npm ERR! extraneous: semver@5.3.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/semver
      npm ERR! extraneous: smtp-server@3.13.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/smtp-server
      npm ERR! extraneous: string_decoder@0.10.31 /opt/iobroker/node_modules/node-red-node-email/node_modules/string_decoder
      npm ERR! extraneous: tlds@1.240.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/tlds
      npm ERR! extraneous: uc.micro@1.0.6 /opt/iobroker/node_modules/node-red-node-email/node_modules/uc.micro
      npm ERR! extraneous: utf7@1.0.2 /opt/iobroker/node_modules/node-red-node-email/node_modules/utf7
      npm ERR! extraneous: bcrypt@ /opt/iobroker/node_modules/node-red/node_modules/bcrypt
      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/node-red/node_modules/fs-extra
      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-red/node_modules/node-addon-api
      npm ERR! extraneous: minipass@ /opt/iobroker/node_modules/tar/node_modules/minipass
      npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/@node-red/nodes/node_modules/raw-body/node_modules/iconv-lite
      npm ERR! extraneous: universalify@0.2.0 /opt/iobroker/node_modules/@node-red/nodes/node_modules/tough-cookie/node_modules/universalify
      npm ERR! invalid: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
      npm ERR! invalid: moment-timezone@ /opt/iobroker/node_modules/moment-timezone
      npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/engine.io-client/node_modules/component-emitter
      npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-client/node_modules/component-emitter
      npm ERR! extraneous: debug@2.2.0 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser/node_modules/debug
      npm ERR! extraneous: ms@0.7.1 /opt/iobroker/node_modules/node-red-contrib-polymer/node_modules/socket.io-parser/node_modules/ms
      npm ERR! extraneous: nodemailer@6.9.3 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailparser/node_modules/nodemailer
      npm ERR! extraneous: libmime@5.2.0 /opt/iobroker/node_modules/node-red-node-email/node_modules/mailsplit/node_modules/libmime
      npm ERR! extraneous: nodemailer@6.9.4 /opt/iobroker/node_modules/node-red-node-email/node_modules/smtp-server/node_modules/nodemailer
      npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
      npm ERR! invalid: @node-rs/jieba-android-arm-eabi@ /opt/iobroker/node_modules/@node-rs/jieba-android-arm-eabi
      npm ERR! invalid: @node-rs/jieba-android-arm64@ /opt/iobroker/node_modules/@node-rs/jieba-android-arm64
      npm ERR! invalid: @node-rs/jieba-darwin-arm64@ /opt/iobroker/node_modules/@node-rs/jieba-darwin-arm64
      npm ERR! invalid: @node-rs/jieba-darwin-x64@ /opt/iobroker/node_modules/@node-rs/jieba-darwin-x64
      npm ERR! invalid: @node-rs/jieba-freebsd-x64@ /opt/iobroker/node_modules/@node-rs/jieba-freebsd-x64
      npm ERR! invalid: @node-rs/jieba-linux-arm64-gnu@ /opt/iobroker/node_modules/@node-rs/jieba-linux-arm64-gnu
      npm ERR! invalid: @node-rs/jieba-linux-arm64-musl@ /opt/iobroker/node_modules/@node-rs/jieba-linux-arm64-musl
      npm ERR! invalid: @node-rs/jieba-linux-x64-gnu@ /opt/iobroker/node_modules/@node-rs/jieba-linux-x64-gnu
      npm ERR! invalid: @node-rs/jieba-linux-x64-musl@ /opt/iobroker/node_modules/@node-rs/jieba-linux-x64-musl
      npm ERR! invalid: @node-rs/jieba-wasm32-wasi@ /opt/iobroker/node_modules/@node-rs/jieba-wasm32-wasi
      npm ERR! invalid: @node-rs/jieba-win32-arm64-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-arm64-msvc
      npm ERR! invalid: @node-rs/jieba-win32-ia32-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-ia32-msvc
      npm ERR! invalid: @node-rs/jieba-win32-x64-msvc@ /opt/iobroker/node_modules/@node-rs/jieba-win32-x64-msvc
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T09_34_50_992Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Core adapters versions
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      js-controller:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      admin:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      javascript:
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-01T09_35_04_737Z-debug-0.log
      Adapters from github:   0
      Adapter State
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      ioBroker-Repositories
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Installed ioBroker-Instances
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
      Hit:4 http://deb.debian.org/debian bullseye-proposed-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://repos.influxdata.com/debian bullseye InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:8 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15401      926/dnsmasq
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          43890      7048/sshd: /usr/sbi
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        13284      845/influxd
      tcp6       0      0 :::51216                :::*                    LISTEN      999        16741      1759/homebridge
      tcp6       0      0 :::22                   :::*                    LISTEN      0          43892      7048/sshd: /usr/sbi
      tcp6       0      0 :::8581                 :::*                    LISTEN      999        15845      1564/hb-service
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        16514      845/influxd
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15400      926/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15397      926/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          772        724/dhclient
      udp        0      0 0.0.0.0:41549           0.0.0.0:*                           108        12903      463/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           999        16742      1759/homebridge
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           999        15842      1564/hb-service
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12901      463/avahi-daemon: r
      udp6       0      0 :::33747                :::*                                108        12904      463/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12902      463/avahi-daemon: r
      2024-02-01 08:59:03.012  - info: host.raspberrypi instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2024-02-01 08:59:03.012  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]: Error: DB closed
      2024-02-01 08:59:03.365  - error: host.raspberrypi Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
      2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
      2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Object.onceWrapper (node:events:629:26)
      2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:events:514:28)
      2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at Socket.emit (node:domain:489:12)
      2024-02-01 08:59:03.366  - error: host.raspberrypi Caught by controller[0]:     at TCP.<anonymous> (node:net:323:12)
      2024-02-01 08:59:03.366  - info: host.raspberrypi instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
      2024-02-01 08:59:03.368  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
      2024-02-01 08:59:03.369  - warn: host.raspberrypi instance system.adapter.hm-rega.0 terminated due to SIGTERM
      2024-02-01 08:59:03.369  - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code null ()
      2024-02-01 08:59:03.369  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
      2024-02-01 08:59:03.369  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
      2024-02-01 08:59:03.442  - warn: host.raspberrypi instance system.adapter.psa.0 terminated due to SIGTERM
      2024-02-01 08:59:03.442  - info: host.raspberrypi instance system.adapter.psa.0 terminated with code null ()
      2024-02-01 08:59:03.443  - warn: host.raspberrypi instance system.adapter.telegram.0 terminated due to SIGTERM
      2024-02-01 08:59:03.443  - info: host.raspberrypi instance system.adapter.telegram.0 terminated with code null ()
      2024-02-01 08:59:03.443  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
      2024-02-01 08:59:03.443  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
      2024-02-01 08:59:03.511  - info: host.raspberrypi instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
      2024-02-01 08:59:03.511  - info: host.raspberrypi All instances are stopped.
      2024-02-01 08:59:03.725  - info: host.raspberrypi terminated
                              v.2023-10-10
               Icon name: computer
            Architecture: arm
      Kernel:                 armv7l
      Userland:               armhf
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      MEMORY:
      Mem:            1.9G        571M        628M        0.0K        670M        1.3G
      Swap:            99M        1.0M         98M
      Total:          2.0G        572M        727M
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Active iob-Instances:   0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      ioBroker Core:          js-controller
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
                              admin
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      ioBroker Status:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.19.0
      Objects:                0
      States:                 0
      Size of iob-Database:
      7.3M    /opt/iobroker/iobroker-data/objects.jsonl
      4.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      4.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      912K    /opt/iobroker/iobroker-data/states.jsonl
      540K    /opt/iobroker/iobroker-data/states.json.migrated
      540K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      Auf dem RaspberryPi läuft zusätzlich noch eine pivccu, diese funktioniert ohne Probleme. Backups vom Zustand vor den Updates sind vorhanden. Ich habe diese testweise in einer iobroker proxmoxx Installation eingespielt, hierbei kam es zu keinen Fehlern.
      Kann ich die aktuelle Installation retten oder komme ich um eine (komplette) Neuinstalltion nicht herum?
        machmal
        iob fix
          Thomas Braun Most Active @ThoHilde last edited by Thomas Braun
          @thohilde sagte in Error: Cannot find module 'tar' - iobroker nicht erreichbar:
          Strom-weg-Exekution? Dein Dateisystem hat jetzt Lücken.
          Wenn der fixer nicht zum Erfolg führt versuch:
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          Und dann installier den
          node-red-Adapter nochmal neu.
            ThoHilde @Thomas Braun last edited by
            @thomas-braun Danke! Funktioniert wieder. Ich komme auf die weboberfläche und konnte nodered darüber installieren. Update wurde mir dort angezeigt.
            Bezüglich Strom-weg: am Pi ist eine SSD angeschlossen. Dies lief bisher ohne Probleme, aber werde ich beobachten, ob der Hardwareadapter oder die SSD vielleicht einen Fehler haben.
            @arteck iob fix hatte ich als erstes versucht. Leider ohne Erfolg.
              Wenn die inodes bei einem sauberen Reboot / nach einem ordentlichen ShutDown gelöscht werden mussten, dann ist die SD-Karte definitiv fällig...
              iob diag
              sagt?
                Homoran Global Moderator Administrators @ThoHilde last edited by
                ist das Netzteil dafür stark genug?
                  Ja, scheint stark genug zu sein:
                  Current issues:
