    4. [Erledigt] zigbee läuft nicht nach Umzug auf proxmox
      lesiflo Most Active last edited by lesiflo
      Bin jetzt auch auf proxmox umgezogen und bekomme Zigbee nicht ans rennen. Jemand einen Tipp für mich. Suchfunktion brachte leider bisher keine Erfolg.
      pi@iobroker:~$ lsusb
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 004: ID 0573:1573 Zoran Co. Personal Media Division (Nogatech) USB Audio and HID
      Bus 001 Device 003: ID 0bda:c821 Realtek Semiconductor Corp. Bluetooth Radio
      Bus 001 Device 010: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      pi@iobroker:~$ ls -al /dev/tty*
      crw-rw-rw- 1 nobody nogroup   5, 0 Feb  2 06:48 /dev/tty
      crw------- 1 pi     tty     136, 1 Feb  2 08:01 /dev/tty1
      crw--w---- 1 root   tty     136, 2 Feb  2 07:50 /dev/tty2
      crw-rw-rw- 1 nobody nogroup 166, 0 Feb  2 07:53 /dev/ttyACM0
      pi@iobroker:~$ ls -l /dev/serial/by-id
      total 0
      ---------- 1 root root 0 Feb  2 07:50 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151036-if00
      pi@iobroker:~$ iob logs --watch | uniq | grep zigbee
      2024-02-02 08:12:36.096  - info: zigbee.0 (2156) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-02-02 08:12:36.201  - info: zigbee.0 (2156) delete old Backup files. keep only last 10
      2024-02-02 08:12:36.202  - info: zigbee.0 (2156) Starting Zigbee  npm ...
      2024-02-02 08:12:36.368  - info: zigbee.0 (2156) Installed Version: iobroker.zigbee@1.10.1
      2024-02-02 08:12:39.719  - info: zigbee.0 (2156) Coordinator firmware version: undefined
      2024-02-02 08:12:49.768  - error: zigbee.0 (2156) Starting zigbee-herdsman problem : "get network parameters Error:TIMEOUT"
      2024-02-02 08:12:49.768  - error: zigbee.0 (2156) Failed to start Zigbee
      2024-02-02 08:12:49.768  - error: zigbee.0 (2156) Error herdsman start
      2024-02-02 08:12:49.848  - info: zigbee.0 (2156) debug devices set to []
      2024-02-02 08:12:59.769  - info: zigbee.0 (2156) Try to reconnect. 1 attempts left
      2024-02-02 08:12:59.770  - info: zigbee.0 (2156) Starting Zigbee  npm ...
      2024-02-02 08:12:59.776  - info: zigbee.0 (2156) Installed Version: iobroker.zigbee@1.10.1
      2024-02-02 08:12:59.897  - error: zigbee.0 (2156) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2024-02-02 08:12:59.897  - error: zigbee.0 (2156) Failed to start Zigbee
      2024-02-02 08:12:59.897  - error: zigbee.0 (2156) Error herdsman start
        Thomas Braun Most Active @lesiflo last edited by
        @lesiflo
        Nach welcher Anleitung hast du es denn bislang versucht?
          lesiflo Most Active @Thomas Braun last edited by
          @thomas-braun Die hier https://www.iobroker.net/#de/documentation/install/proxmox.md
            @lesiflo
            Also danach?
            Proxmox - LXC (Linux Containers) -> USB Geräte durchreichen
            Und wo konkret hast du Probleme?
              lesiflo Most Active @Thomas Braun last edited by lesiflo
              @thomas-braun Ja danach bin ich vorgegangen. Das Problem ist, das der Adapter gelb bleibt und die Meldungen hier kommen:
              zigbee.0
              2024-02-02 09:00:30.823	error	Error herdsman start
              zigbee.0
              2024-02-02 09:00:30.823	error	Failed to start Zigbee
              zigbee.0
              2024-02-02 09:00:30.823	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              zigbee.0
              2024-02-02 09:00:30.672	info	Installed Version: iobroker.zigbee@1.10.1
              zigbee.0
              2024-02-02 09:00:30.659	info	Starting Zigbee npm ...
              zigbee.0
              2024-02-02 09:00:30.658	info	Try to reconnect. 1 attempts left
              zigbee.0
              2024-02-02 09:00:20.684	info	debug devices set to []
              zigbee.0
              2024-02-02 09:00:20.657	error	Error herdsman start
              zigbee.0
              2024-02-02 09:00:20.657	error	Failed to start Zigbee
              zigbee.0
              2024-02-02 09:00:20.657	error	Starting zigbee-herdsman problem : "get network parameters Error:TIMEOUT"
              zigbee.0
              2024-02-02 09:00:10.605	info	Coordinator firmware version: undefined
              zigbee.0
              2024-02-02 09:00:07.424	info	Installed Version: iobroker.zigbee@1.10.1
              Hier noch meine Konfigurationsdatei:
              arch: amd64
              cores: 4
              features: nesting=1
              hostname: iobroker
              memory: 4096
              net0: name=eth0,bridge=vmbr0,firewall=1,gw=192.168.2.1,hwaddr=BC:24:11:0F:06:DF,ip=192.168.2.50/24,ip6=dhcp,type=veth
              ostype: ubuntu
              rootfs: local-lvm:vm-100-disk-1,size=16G
              swap: 512
              unprivileged: 1
              lxc.cgroup2.devices.allow: c 189:* rwm
              lxc.mount.entry: usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151036-if00 dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_I>
              lxc.cgroup2.devices.allow: c 166:* rwm
              lxc.mount.entry: /var/lib/lxc/100/devices/ttyACM0 dev/ttyACM0 none bind,optional,create=file
                @lesiflo
                Und wie sah jetzt deine Lösung aus?
                Wäre für die Nachwelt interessant, die hier in den Thread stolpert.
                  @thomas-braun Ich habe den Zigbee Stick mal aus lauter Verzweifelung an einen USB-Port am proxmox Server gesteckt.
                  Danach ging es, warum auch immer.
                  Thomas Braun MartinP 2 Replies Last reply Reply Quote 0
                    @lesiflo
                    Und wo hat der zuvor gesteckt?
                    • MartinP
                      MartinP @lesiflo last edited by
                      @lesiflo Interessant wäre, was jetzt hierbei herauskommt ...
                      martin@ZigbeeStuff:~$ ls -l /dev/serial/by-id/
                      insgesamt 0
                      lrwxrwxrwx 1 root root 13 28. Dez 10:41 usb-dresden_elektronik_ConBee_III_DE03189531-if00-port0 -> ../../ttyUSB0
                      Der Hinweis "-> ../../ttyUSB0" dass es ein Symlink ist, fehlte bei Deiner Ausgabe
                        lesiflo Most Active @MartinP last edited by
                        @martinp sagte in [Erledigt] zigbee läuft nicht nach Umzug auf proxmox:
                        Auf der VM vom iobroker steht das hier:
                        pi@iobroker:~$ ls -l /dev/serial/by-id/
                        total 0
                        ---------- 1 root root 0 Feb  2 11:46 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151036-if00
                        pi@iobroker:~$
                        Auf dem proxmox das hier:
                        root@proxmox:~# ls -l /dev/serial/by-id/
                        total 0
                        lrwxrwxrwx 1 root root 13 Feb  2 11:50 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2151036-if00 -> ../../ttyACM0
                        root@proxmox:~#
                          @thomas-braun Vorher steckte er in einem USB 2.0 Port jetzt in einen 3.0 Port. Kann aber auch Zufall gewesen sein das es jetzt geht.
                            @lesiflo
                            Direkt im Port? Diese Zigbee-USB-Stöckchen hängen am liebsten an einer Verlängerung.
                              @thomas-braun Mit 1m Verlängerung.
                              539
