    4. Zigbee macht immer mal wieder schlapp - findet Adapter nicht
      brokeling last edited by brokeling
      zigbee.0
      2024-02-07 21:37:03.669	info	cleaned everything up...
      zigbee.0
      2024-02-07 21:37:03.653	error	SRSP - SYS - version after 6000ms
      zigbee.0
      2024-02-07 21:37:03.653	error	Error: SRSP - SYS - version after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:312:45 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:26) at Znp.request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:300:27) at AdapterBackup.getAdapterVersion (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:403:48) at AdapterBackup.createBackup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/adapter-backup.ts:63:48) at ZStackAdapter.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:860:43) at Controller.backup (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:330:47)
      zigbee.0
      2024-02-07 21:37:03.490	error	unhandled promise rejection: SRSP - SYS - version after 6000ms
      zigbee.0
      2024-02-07 21:37:03.489	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      und dann:
      zigbee.0
      Zeit
      info
      Nachricht
      zigbee.0
      2024-02-07 22:04:08.662	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"L1100GB8","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyACM1","manufacturer":"Texas Instruments","serialNumber":"L1100GB8","pnpId":"usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03","vendorId":"0451","productId":"bef3"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      zigbee.0
      2024-02-07 22:04:08.425	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      zigbee.0
      zigbee.0
      2024-02-07 21:38:15.516	error	Error herdsman start
      zigbee.0
      2024-02-07 21:38:15.515	error	Failed to start Zigbee
      zigbee.0
      2024-02-07 21:38:15.509	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2024-02-07 21:38:15.188	info	Installed Version: iobroker.zigbee@1.10.1
      zigbee.0
      2024-02-07 21:38:13.150	info	Starting Zigbee npm ...
      zigbee.0
      2024-02-07 21:38:13.149	info	Try to reconnect. 1 attempts left
      zigbee.0
      2024-02-07 21:38:03.142	error	Error herdsman start
      zigbee.0
      2024-02-07 21:38:03.142	error	Failed to start Zigbee
      zigbee.0
      2024-02-07 21:38:03.140	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.0
      2024-02-07 21:37:42.696	info	Installed Version: iobroker.zigbee@1.10.1
      zigbee
      Ich verwende den usb Adpater: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
      Zigbee will in dem Zustand auch nicht wieder starten. Dazu muss ich USB ein/ausstecken bzw. den raspberry mal wieder ganz aus/anschalten. Dann läuft es wieder - ggf. auch viele Tage wieder durch. Aber so ab und an kommt dann wieder der Fehler!
      Was kann da denn sein?
      Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @brokeling last edited by
        @brokeling
        Zeig mal die Langfassung von
        iob diag
          brokeling @Thomas Braun last edited by brokeling
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspi
                   Icon name: computer
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           22:30:26 up 6 days, 54 min,  1 user,  load average: 2.77, 1.76, 1.26
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2024-02-07 22:30:26 CET
                     Universal time: Wed 2024-02-07 21:30:26 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        2.2G        298M        0.0K        1.2G        1.4G
          Swap:            99M         99M          0B
          Total:          3.9G        2.3G        298M
                   3786 M total memory
                   2238 M used memory
                    758 M active memory
                   2588 M inactive memory
                    297 M free memory
                    201 M buffer memory
                   1049 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
          * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
          1 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      117G   20G   92G  18% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     758M  864K  757M   1% /run
          /dev/sdb1      ext4      113G   79G   29G  74% /backup
          /dev/sda1      vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     379M   16K  379M   1% /run/user/1000
          [Thu Feb  1 21:36:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:40:0F:7D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Thu Feb  1 21:36:07 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Feb  1 21:36:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Thu Feb  1 21:36:08 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
          [Thu Feb  1 21:36:10 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
          TARGET    SOURCE    FSTYPE OPTIONS
          /         /dev/sda2 ext4   rw,noatime,stripe=8191
          |-/backup /dev/sdb1 ext4   ro,noatime
          `-/boot   /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          7.0G    /var/
          3.4G    /var/cache/apt
          3.4G    /var/cache
          3.3G    /var/cache/apt/archives
          3.0G    /var/lib
          Archived and active journals take up 528.1M in the file system.
          /opt/iobroker/backups:
          3.7G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          553M    /opt/iobroker/iobroker-data/backup-objects
          354M    /opt/iobroker/iobroker-data/files
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          41M     /opt/iobroker/iobroker-data/states.json.old
          41M     /opt/iobroker/iobroker-data/states.json.bak
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if03
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.15
          javascript:     7.1.6
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.1                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : raspi                                    -  enabled
          + system.adapter.backitup.0               : backitup              : raspi                                    -  enabled
          + system.adapter.chromecast.0             : chromecast            : raspi                                    -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspi                                    -  enabled
            system.adapter.deconz.0                 : deconz                : raspi                                    - disabled, port: 80
          + system.adapter.discovery.0              : discovery             : raspi                                    -  enabled
            system.adapter.feiertage.0              : feiertage             : raspi                                    -  enabled
            system.adapter.flot.0                   : flot                  : raspi                                    -  enabled
            system.adapter.fritzdect.0              : fritzdect             : raspi                                    - disabled
            system.adapter.hue-extended.0           : hue-extended          : raspi                                    - disabled
            system.adapter.hue.0                    : hue                   : raspi                                    - disabled, port: 443
            system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspi                                    -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi                                    -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi                                    -  enabled
            system.adapter.iqontrol.0               : iqontrol              : raspi                                    - disabled
          + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
            system.adapter.luftdaten.0              : luftdaten             : raspi                                    -  enabled
            system.adapter.luftdaten.1              : luftdaten             : raspi                                    -  enabled
            system.adapter.mqtt.0                   : mqtt                  : raspi                                    - disabled, port: 1884, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : raspi                                    -  enabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspi                                    -  enabled
          + system.adapter.nuki.0                   : nuki                  : raspi                                    -  enabled
          + system.adapter.ping.0                   : ping                  : raspi                                    -  enabled
          + system.adapter.pushover.0               : pushover              : raspi                                    -  enabled
          + system.adapter.reolink.0                : reolink               : raspi                                    -  enabled
          + system.adapter.reolink.1                : reolink               : raspi                                    -  enabled
          + system.adapter.reolink.2                : reolink               : raspi                                    -  enabled
          + system.adapter.reolink.3                : reolink               : raspi                                    -  enabled
            system.adapter.reolink.4                : reolink               : raspi                                    - disabled
          + system.adapter.samsung_tizen.0          : samsung_tizen         : raspi                                    -  enabled, port: 8002
          + system.adapter.sayit.0                  : sayit                 : raspi                                    -  enabled
          + system.adapter.sayit.1                  : sayit                 : raspi                                    -  enabled
          + system.adapter.sayit.2                  : sayit                 : raspi                                    -  enabled
          + system.adapter.sayit.3                  : sayit                 : raspi                                    -  enabled
          + system.adapter.sayit.4                  : sayit                 : raspi                                    -  enabled
          + system.adapter.sayit.5                  : sayit                 : raspi                                    -  enabled
          + system.adapter.shelly.0                 : shelly                : raspi                                    -  enabled, port: 1885, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : raspi                                    - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.signal-cmb.0             : signal-cmb            : raspi                                    -  enabled
          + system.adapter.simple-api.0             : simple-api            : raspi                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.smartcontrol.0           : smartcontrol          : raspi                                    - disabled
          + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.2         : sourceanalytix        : raspi                                    -  enabled
            system.adapter.spotify-premium.0        : spotify-premium       : raspi                                    - disabled
          + system.adapter.sql.0                    : sql                   : raspi                                    -  enabled, port: 0
            system.adapter.statistics.0             : statistics            : raspi                                    - disabled
          + system.adapter.telegram.0               : telegram              : raspi                                    -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : raspi                                    - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi                                    -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspi                                    -  enabled
            system.adapter.vis-history.0            : vis-history           : raspi                                    -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi                                    -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi                                    -  enabled
            system.adapter.vis-metro.0              : vis-metro             : raspi                                    -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : raspi                                    -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    -  enabled
            system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
          + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    - disabled
          + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.26__Embed_with_CMSIS-DAP_L1100GB8-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.13.15 [Updatable]
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
          Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
          Adapter    "hue"          : 3.10.2   , installed 3.10.1 [Updatable]
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
          Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
          Adapter    "paw"          : 0.3.2    , installed 0.3.2
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "reolink"      : 1.0.3    , installed 1.0.3
          Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
          Adapter    "sayit"        : 3.0.5    , installed 3.0.0  [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects:        10127
          States:         7782
          Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Reading package lists...
          Pending Updates: 2
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11784      350/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13876      508/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          30611392   20791/cupsd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19029      2034/io.sonoff.0
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14038      350/deCONZ
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       21677      2409/io.shelly.0
          tcp        0      0 192.168.178.53:9092     0.0.0.0:*               LISTEN      1001       20456      2699/io.nuki.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14121      586/iobroker.js-con
          tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        11801      588/mariadbd
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        13901      498/redis-server 12
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15655      1018/io.admin.1
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20060      2483/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13878      508/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          30611391   20791/cupsd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       25459      3468/io.simple-api.
          tcp6       0      0 ::1:6379                :::*                    LISTEN      118        13902      498/redis-server 12
          udp        0      0 0.0.0.0:50173           0.0.0.0:*                           108        14434      343/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13967      816/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          30613852   20799/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       21341      2223/io.chromecast.
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14432      343/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15422      350/deCONZ
          udp6       0      0 :::546                  :::*                                0          15138      816/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        14433      343/avahi-daemon: r
          udp6       0      0 :::42734                :::*                                108        14435      343/avahi-daemon: r
          2024-02-07 22:30:23.183  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-02-07 22:30:32.880  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:30:32.880  - info: sql.0 (1947) No Data
          2024-02-07 22:30:33.403  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.0015bc0031015219.temperature
          2024-02-07 22:30:33.414  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.54ef4410000345bd.illuminance
          2024-02-07 22:30:42.959  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:30:42.959  - info: sql.0 (1947) No Data
          2024-02-07 22:30:52.884  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:30:52.885  - info: sql.0 (1947) No Data
          2024-02-07 22:31:02.890  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:02.891  - info: sql.0 (1947) No Data
          2024-02-07 22:31:12.919  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:12.919  - info: sql.0 (1947) No Data
          2024-02-07 22:31:22.898  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:22.899  - info: sql.0 (1947) No Data
          2024-02-07 22:31:32.887  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:32.888  - info: sql.0 (1947) No Data
          2024-02-07 22:31:33.393  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.0015bc0031015219.temperature
          2024-02-07 22:31:33.402  - warn: sql.0 (1947) getOneCachedData: got null states 1 times for zigbee.0.54ef4410000345bd.illuminance
          2024-02-07 22:31:42.726  - info: sql.0 (1947) Do not store value "NULL" for PM10 Outdoor because no number
          2024-02-07 22:31:42.728  - info: sql.0 (1947) Do not store value "NULL" for PM25 Outdoor because no number
          2024-02-07 22:31:42.890  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:42.890  - info: sql.0 (1947) No Data
          2024-02-07 22:31:52.885  - warn: sql.0 (1947) Cannot get index of "zigbee.0.00158d0005422cc0.contact": id not found
          2024-02-07 22:31:52.885  - info: sql.0 (1947) No Data
          • Asgothian
            Asgothian Developer @brokeling last edited by
            @brokeling sagte in [Zigbee macht immer mal wieder schlapp - findet Adapter nicht]
            Da stürzt die Firmware auf dem Stick ab.
            1. Versuch: Neu Flashen
            2. Versuch: Andere Hardware benutzen
            Vorsicht - es gibt in der ZStack Firmware aktuell Probleme - (zumindest hatte @arteck das zuletzt im Forum erwähnt - find das gerade nicht)
            A.
              @asgothian
              Danke für deine Einschätzung.
              Wie sicher ist die Diagnose?
              Ich nehme an bei beiden Varianten (1. und 2.) muss ich alle Geräte neu anlernen???
              Was natürlich sehr schlecht wäre.
              Aber wie gesagt, es läuft z. T. auch Tage bzw. Wochen-lang unauffällig durch ...
              • Asgothian
                Asgothian Developer @brokeling last edited by Asgothian
                @brokeling sagte in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
                @asgothian
                99.9%
                Variante 1; sicher nicht. Variante 2; wahrscheinlich nicht
                Es gibt noch eine Variante 3:
                • eine WLan schaltbare Steckdose
                • ein usb-hub mit eigener Stromversorgung
                • ein Skript den Stick darüber neu zu booten wenn der Zigbee-adapter nicht will.
                Auch ein um positionieren vom Koordinator relativ zu anderen 2.4gHz Quellen kann helfen (wlan, dect, aber auch 2.4gHz Tastaturen, Kopfhörern und so weiter sowie USB3 Festplatten am Pi.)
                A.
                • Codierknecht
                  Codierknecht Developer Most Active @brokeling last edited by Codierknecht
                  @brokeling
                  Ganz schön viel installiert auf der kleinen Kiste.
                  Könnte auch einfach sein, dass ihr der Speicher ausgeht.
                  Die teils mehrfachen Instanzen (luftdaten, reolink, sayit) sind notwendig?
                  Discovery-Adapter kann man in der Regel schon mal rauswerfen. Braucht man nach der Ersteinrichtung eigentlich nicht.
                  Telegram und Signal parallel?
                  Iqontrol und vis parallel?
                    brokeling @Asgothian last edited by
                    @asgothian
                    Dann könnte ich auf alle Fälle Variante 1 mal probieren.
                    Die ZSTack Firmware muss ich dann noch schauen, welche Probleme da gerade bestehen.
                    Und für Variante 2 - welche Hardware ist empfehlenswert(er)?
                    Variante 3 könnte ich natürlich auch noch probieren, ist als Dauerlösung halt nicht so befriedigend.
                    Abstand zu potenziellen Störgeräten hab ich schon über 1m. Ich könnte das auch mal drehen oder anders kippen, wenn du meinst das könnte auch was bringen.
                      brokeling @Codierknecht last edited by
                      @codierknecht
                      Alle Adapter laufen nicht drauf.
                      Aber da miste ich jetzt auch etwas aus...
                      Die mehrfachen Adapter sind leider in Benutzung. Da muss man für jedes Gerät leider einen eigenen Adapter installieren!
                      Aber danke für den Hinweis.
                      • Codierknecht
                        Ja - wenn man richtig hinguckt, sieht man's auch
                        Ist meistens 'ne gute Idee.
                        MariaDB läuft da ja auch noch still und heimlich auf der Kiste.
                        Und Redis auch.
                        Mit nur noch < 300 MB freiem Speicher könnte es schon ganz schön eng werden, wenn nachts das Backup läuft.
                        Schmakus B 2 Replies Last reply Reply Quote 0
                        • Schmakus
                          Schmakus Developer @Codierknecht last edited by Schmakus
                          Ich habe das auch sporadisch mit meinem TI-Board und TCP Anbindung.
                          Hier hilft ein kurzer PowerCycle des POE-Ports, an welchem das TI-Board hängt.
                          Ich vermute, es liegt an einer buggy ZStack Firmware. Dazu gibt es auch eine Diskussion: https://github.com/Koenkk/Z-Stack-firmware/discussions/483.
                          Ich muss es jetzt auch mal die Version 20231112 testen.
                            @codierknecht said in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
                            Und Redis auch.
                            Der Speicher ist aber nicht immer so belegt, jetzt z. B.
                            *** MEMORY ***
                            Mem:            3.8G        1.8G        1.0G        0.0K        924M        1.8G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.8G        1.1G
                                     3786 M total memory
                                     1813 M used memory
                                      217 M active memory
                                     2415 M inactive memory
                                     1048 M free memory
                                      104 M buffer memory
                                      819 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Und am Handy kann ich die Daten auch kontrollieren, auch die CPU ist immer relativ gering belastet, meistens im 1-stelligen Bereich, und springt manchmal auf max. 60-70% hoch um dann wieder gleich runter zu gehen:
                              brokeling @Schmakus last edited by brokeling
                              @schmakus said in Zigbee macht immer mal wieder schlapp - findet Adapter nicht:
                              Bei mir zickt zigbee (bzw. das TI-Board) allerdings länger rum.
                              Zunächst, wenn das problem auftritt USB ein/ausstecken, Adapter neu starten.
                              Dann geht er auf grün, funktioniert aber nicht richtig.
                              Bei mir muss ich wie ich das sehe tatsächlich den ganzen raspi rebooten, dass ich da richtig Erfolg kriege. Und jetzt hält er derzeit nicht so lange durch...er stieg schon wieder aus!?!
                              Vielleicht doch den Adapter wechseln. Wenn das nicht mit Neu-Anlernen verbunden wäre, dann hätte ich kein Problem damit.
                              Welcher Adapter ist der beste?
                                brokeling @brokeling last edited by
                                Habe das device jetzt von
                                CC2652R_coordinator_20230507
                                auf
                                CC2652R_coordinator_20231112
                                upgedated.
                                Es läuft jetzt. Mal sehen wie lange!
                                  brokeling @brokeling last edited by brokeling
                                  ...nicht sehr lange!
                                  Leider stürzte er immer wieder ab.
                                  Gestern hab ich dann einen nagelneuen USB Adapter installiert:
                                  es ist der Sonoff ZIGBEE 3.0 USB-STICK CC2652P.
                                  Doch nach fast 24 Stunden perfektem Lauf - ich habe mich schon gefreut - habe ich jetzt wieder diese Aussetzer.
                                  Oh nein!
                                  Also wahrscheinlich lag es jetzt doch nicht an einer abgestürzten Firmware.
                                  Kann mir da jemand helfen und der Sache endgültig auf den Grund gehen?
                                  Es ist wirklich sehr übel dass Zigbee bei mir immer wieder ausfällt 😞
                                  Eigentlich sind es meine wichtigsten Geräte.
                                  Cluni Asgothian 2 Replies Last reply Reply Quote 0
                                  • Cluni
                                    Cluni @brokeling last edited by
                                    @brokeling Hast du den Stick denn auch über eine USB-Verlängerung eingesteckt? Die Dinger sind sehr empfindlich. Ich hatte anfangs nur eine sehr kurze Verlängerung und auch damit hatte ich dann schon Probleme. Du solltest den Stick mindestens so 50-100cm vom Raspi weg positionieren und auch schauen, dass nicht unmittelbar daneben ein Router oder sonstige Störquellen sind.
                                    Ich bin kein Experte, ob dies zu genau deinen Problemen führen könnte. Soll nur ein Hinweis am Rande sein.
                                    • Asgothian
                                      @brokeling
                                      Du musst nach störquellen im 2.4 GHz Band schauen
                                      • wifi
                                      • dect
                                      • proprietäre funkstrecken für Tastaturen, Mäuse und Kopfhörer
                                      • usb3 Störungen durch Festplatten / ssd / Hubs
                                      Auch: USB Verlängerungskabel auf Qualität prüfen
                                      Koordinator an USB 2 anschließen, nicht USB3
                                      A.
                                        @asgothian
                                        Danke für die Hinweise!
                                        Ich habe die Verlängerung gleich im Bundle mitbestellt, müsste also passen.
                                        Mit den Abständen zu Wlan usw. hab ich jetzt weiter optimiert.
                                        Und von USB 3.0 in USB 2.0 umgesteckt.
                                        Mal sehen wie es weitergeht.
                                        • Asgothian
                                          @asgothian
                                          Es geht nicht nur um passen, sondern um Qualität - USb3 streut gerne in 2.4 ghz band - da kann eine schlechte Abschirmung schon zu Problemen führen.
                                            @asgothian
                                            Ich gehe davon aus, dass das mitgelieferte Kabel den optimalen Betrieb gewährleistet.
                                            Aber wie kann man das Kabel prüfen?
                                            1260
