    4. Fehler bei ..............&& sudo apt upgrade [gelöst]
    • Duffy
      Duffy last edited by Duffy
      Schönen guten Morgen,
      mein Testpi hat gestern einen Fehler bei:
      sudo apt update && sudo apt full-upgrade
      ausgegeben.
      testpi@Testpi:~ $ sudo apt update && sudo apt full-upgrade
      Get:2 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
      Get:3 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB]
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Get:5 https://apt.grafana.com stable InRelease [5,983 B]
      Get:6 http://archive.raspberrypi.org/debian bookworm InRelease [23.6 kB]
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Get:8 http://security.debian.org/debian-security bookworm-security/main Sources [79.6 kB]
      Get:9 http://security.debian.org/debian-security bookworm-security/main armhf Packages [132 kB]
      Get:10 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [134 kB]
      Get:11 https://apt.grafana.com stable/main arm64 Packages [157 kB]
      Get:12 https://apt.grafana.com stable/main armhf Packages [123 kB]
      Get:13 http://archive.raspberrypi.org/debian bookworm/main armhf Packages [362 kB]
      Get:14 http://archive.raspberrypi.org/debian bookworm/main arm64 Packages [353 kB]
      Fetched 1,470 kB in 2s (752 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      Calculating upgrade... Done
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      1 not fully installed or removed.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n]
      Setting up raspi-firmware (1:1.20231024+ds-1+rpt5) ...
      stat: cannot read file system information for '/boot/firmware': No such file or directory
      Error: missing /boot/firmware, did you forget to mount it?
      dpkg: error processing package raspi-firmware (--configure):
       installed raspi-firmware package post-installation script subprocess returned error exit status 1
      Processing triggers for initramfs-tools (0.142) ...
      Errors were encountered while processing:
       raspi-firmware
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      testpi@Testpi:~ $
      Ich muss bestimmt nicht erwähnen das ich wieder mal auf dem Schlauch stehe, ist zum Glück nur der Testpi 🙂
      Bekommt man den Fehler wieder los ohne Neuinstallation?
      VG Duffy
        Thomas Braun Most Active @Duffy last edited by
        @duffy
        Kann es sein, dass du das System nicht neuaufgesetzt hast sondern von Debian 11 'Bullseye' kommend ein Dist-Upgrade gemacht hast?
        • Duffy
          Duffy @Thomas Braun last edited by
          Puhh, ich glaube nicht. Ich glaube es neu installiert zu haben. Ich nehme den Testpi nur sehr wenig und kann es nicht zu 100% sagen.
          Ich meine aber auch zum testen direkt Bookworm installiert zu haben.
          Wenn sich das nicht lösen lässt würde ich es halt noch mal neu installieren.
          VG Duffy
            @duffy
            Gib mal die Langfassung von
            iob diag
            bekannt. Da kann man das sehen.
            • Duffy
              Sehr gerne.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: Testpi
                     Icon name: computer
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.5
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : arm64
              Systemuptime and Load:
               11:12:38 up 1 day, 11 min,  2 users,  load average: 0.21, 0.15, 0.14
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Fri 2024-02-09 11:12:38 CET
                         Universal time: Fri 2024-02-09 10:12:38 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              testpi
              /home/testpi
              testpi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.0G        1.2G        773M        1.2M        2.1G        2.7G
              Total:          4.1G        1.2G        878M
                       3793 M total memory
                       1172 M used memory
                       1445 M active memory
                       1422 M inactive memory
                        737 M free memory
                        111 M buffer memory
                       1848 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       30G  7.2G   21G  26% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  1.2M  758M   1% /run
              /dev/sda1      vfat      255M   31M  225M  13% /boot
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Thu Feb  8 11:01:16 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:B3:1A:9B vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4ef48f9-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Thu Feb  8 11:01:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
              [Thu Feb  8 11:01:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
              [Thu Feb  8 11:01:21 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
              TARGET  SOURCE    FSTYPE OPTIONS
              /       /dev/sda2 ext4   rw,noatime
              `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              1.9G    /var/
              1006M   /var/cache
              1000M   /var/cache/apt
              887M    /var/cache/apt/archives
              529M    /var/log
              Archived and active journals take up 524.1M in the file system.
              /opt/iobroker/backups:
              501M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              658M    /opt/iobroker/iobroker-data/
              554M    /opt/iobroker/iobroker-data/files
              138M    /opt/iobroker/iobroker-data/files/vis-2
              89M     /opt/iobroker/iobroker-data/files/echarts.admin
              78M     /opt/iobroker/iobroker-data/files/vis-2/static
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
               *** 18.19.0-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.17
              admin:          6.13.16
              javascript:     7.1.6
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : Testpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : Testpi                                   -  enabled
                system.adapter.device-reminder.0        : device-reminder       : Testpi                                   - disabled
              + system.adapter.discovery.0              : discovery             : Testpi                                   -  enabled
              + system.adapter.influxdb.0               : influxdb              : Testpi                                   -  enabled, port: 8086
              + system.adapter.influxdb.1               : influxdb              : Testpi                                   -  enabled, port: 8086
                system.adapter.iot.0                    : iot                   : Testpi                                   - disabled
                system.adapter.javascript.0             : javascript            : Testpi                                   - disabled
              + system.adapter.rpi2.0                   : rpi2                  : Testpi                                   -  enabled
                system.adapter.sonoff.0                 : sonoff                : Testpi                                   - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.vis-2.0                  : vis-2                 : Testpi                                   - disabled
                system.adapter.vis.0                    : vis                   : Testpi                                   - disabled
                system.adapter.web.0                    : web                   : Testpi                                   - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                 : zigbee                : Testpi                                   - disabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "device-reminder": 3.1.2  , installed 3.1.2
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
              Adapter    "web"          : 6.2.3    , installed 6.2.3
              Adapter    "ws"           : 2.5.10   , installed 2.5.10
              Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
              Objects and States
              Objects:        729
              States:         435
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12229      629/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       50512      1828/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       49760      1828/iobroker.js-co
              tcp6       0      0 :::22                   :::*                    LISTEN      0          12231      629/sshd: /usr/sbin
              tcp6       0      0 :::3000                 :::*                    LISTEN      110        15464      806/grafana
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        1978       746/influxd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       57821      4045/io.admin.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1790       474/avahi-daemon: r
              udp        0      0 0.0.0.0:34813           0.0.0.0:*                           108        1792       474/avahi-daemon: r
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1898       740/dhcpcd
              udp6       0      0 :::33934                :::*                                108        1793       474/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        1791       474/avahi-daemon: r
              2024-02-09 03:57:06.846  - info: host.Testpi stopInstance system.adapter.backitup.0 (force=false, process=true)
              2024-02-09 03:57:06.866  - info: backitup.0 (4742) Got terminate signal TERMINATE_YOURSELF
              2024-02-09 03:57:06.878  - info: backitup.0 (4742) cleaned everything up...
              2024-02-09 03:57:06.879  - info: backitup.0 (4742) terminating
              2024-02-09 03:57:06.880  - info: backitup.0 (4742) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-02-09 03:57:06.908  - info: host.Testpi stopInstance system.adapter.backitup.0 send kill signal
              2024-02-09 03:57:07.382  - info: backitup.0 (4742) terminating
              2024-02-09 03:57:07.442  - info: host.Testpi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-02-09 03:57:09.971  - info: host.Testpi instance system.adapter.backitup.0 started with pid 33498
              2024-02-09 03:57:12.070  - info: backitup.0 (33498) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
              2024-02-09 03:57:12.141  - info: backitup.0 (33498) [iobroker] backup will be activated at 03:55 every 1 day(s)
                @duffy
                Das ist das alte Boot-Layout.
                Die Boot-Partition wird auf /boot eingehängt, aktuell wird aber /boot/firmware erwartet. Das führt dann auch zu der Meldung beim apt upgrade.
                Und diese Änderungen sind auch der Grund warum diesmal bei Raspberry OS die Empfehlung ganz klar eine Neuinstallation von 'Bookworm' war.
                Duffy 1 Reply Last reply Reply Quote 1
                • Duffy
                  Duffy @Thomas Braun last edited by Duffy
                  Ok danke für deine Expertiese. Dann werde ich den Testpi neu installieren.
                  Danke dir vielmals.
                  Das Aktivsystem habe ich aber sicher neu installiert 🙂
                  Gruß Duffy
