    2. English
    3. Visualization
    4. Variable resistant to shutdown iobroker ?
      mguc last edited by
      My problem looks like this:
      I want to create two variables whose values ​​I will set from e.g. vis. This means, for example, setting the time "from - to".
      I can create variables in the iobroker tree. It's not a problem.
      But how to ensure that the values ​​entered there do not reset to zero after restarting the computer?
        Homoran Global Moderator Administrators @mguc last edited by
        @mguc sagte in Variable resistant to shutdown iobroker ?:
        sure that you mean variables? and not states?
        variables in scripts will forget their values if the script is stopped.
        Values of states will be kept "forever"
          mguc @Homoran last edited by
          It actually works. After restarting the server (tests), all manually set values ​​are the same.
          Thank you.
