    4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
    • wauzzi
      wauzzi last edited by wauzzi
      Hallo liebe IoT Gemeinde,
      ich habe mein produktives IoT System auf meinen Raspi 5 8GB umgezogen. Die Wiederherstellung hat weitestgehend geklappt. Leider habe ich gemerkt, dass mein Kater nicht mehr ins Haus kommt.
      der BLE Adapter ist zwar grün, jedoch werden keine Bluetooth Daten empfangen.
      Im Log konnte ich diesen Eintrag finden. Ich schätze hier liegt das Problem.
      Leider sagt mir diese Meldung überhaupt nichts.
      Kann mir jemand einen Tipp geben ?
      Vielen Dank 🙂
      Cannot find module '@abandonware/bluetooth-hci-socket'Require stack:- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js- /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js- /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js- /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js- /opt/iobroker/node_modules/@abandonware/noble/index.js- /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
        Thomas Braun Most Active @wauzzi last edited by
        @wauzzi
        Installier den ble Adapter nochmal, mit --debug Option.
        wauzzi 2 Replies Last reply Reply Quote 0
        • wauzzi
          wauzzi @Thomas Braun last edited by
          $ iobroker add ble --host iobroker
          NPM version: 10.2.3
          Installing iobroker.ble@0.14.0... (System call)
          145 packages are looking for funding run `npm fund` for details
          host.iobroker install adapter ble
          upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
          upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
          upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
          upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
          upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
          host.iobroker object system.adapter.ble created/updated
          host.iobroker object system.adapter.ble.0.memHeapUsed created
          host.iobroker object system.adapter.ble.0.memHeapTotal created
          host.iobroker object system.adapter.ble.0.memRss created
          host.iobroker object system.adapter.ble.0.uptime created
          host.iobroker object system.adapter.ble.0.inputCount created
          host.iobroker object system.adapter.ble.0.outputCount created
          host.iobroker object system.adapter.ble.0.eventLoopLag created
          host.iobroker object system.adapter.ble.0.sigKill created
          host.iobroker object system.adapter.ble.0.logLevel created
          host.iobroker object ble.0.info created
          host.iobroker object ble.0.info.connection created
          host.iobroker object ble.0.info.driverState created
          host.iobroker object ble.0.options created
          host.iobroker object ble.0.options.allowNewDevices created
          host.iobroker Set default value of ble.0.options.allowNewDevices: false
          host.iobroker object system.adapter.ble.0 created
          Process exited with code 0
          • wauzzi
            @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
            @wauzzi
            Hab den BLE Adapter deinstalliert und neuinstalliert.
            Jetzt bleibt er auf Gelb stehen. Fehlermeldung noch die gleiche 😞
            • Glasfaser
              Glasfaser last edited by
              @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
              gehe diesen Thread mal durch :
              https://forum.iobroker.net/post/150869
              wauzzi 1 Reply Last reply Reply Quote 1
              • wauzzi
                wauzzi @Glasfaser last edited by
                @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
                Danke für Deinen Tipp !
                Beim Versuch "npm install bluetooth-hci-socket" durchzuführen erhalte ich diese Meldungen. Ich schätze irgendwo ist der Wurm drin 😞
                admin@iobroker:~ $ sudo npm install bluetooth-hci-socket
                npm ERR! code 1
                npm ERR! path /home/admin/node_modules/bluetooth-hci-socket
                npm ERR! command failed
                npm ERR! command sh -c node-gyp rebuild
                npm ERR! make: Entering directory '/home/admin/node_modules/bluetooth-hci-socket/build'
                npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
                npm ERR! make: Leaving directory '/home/admin/node_modules/bluetooth-hci-socket/build'
                npm ERR! gyp info it worked if it ends with ok
                npm ERR! gyp info using node-gyp@10.0.1
                npm ERR! gyp info using node@18.19.0 | linux | arm64
                npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                npm ERR! gyp info spawn /usr/bin/python3
                npm ERR! gyp info spawn args [
                npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                npm ERR! gyp info spawn args 'binding.gyp',
                npm ERR! gyp info spawn args '-f',
                npm ERR! gyp info spawn args 'make',
                npm ERR! gyp info spawn args '-I',
                npm ERR! gyp info spawn args '/home/admin/node_modules/bluetooth-hci-socket/build/config.gypi',
                npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.19.0/include/node/common.gypi',
                npm ERR! gyp info spawn args '-Dlibrary=shared_library',
                npm ERR! gyp info spawn args '-Dvisibility=default',
                npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.19.0',
                npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
                npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/admin/node_modules/bluetooth-hci-socket',
                npm ERR! gyp info spawn args '-Dnode_engine=v8',
                npm ERR! gyp info spawn args '--depth=.',
                npm ERR! gyp info spawn args '--no-parallel',
                npm ERR! gyp info spawn args '--generator-output',
                npm ERR! gyp info spawn args 'build',
                npm ERR! gyp info spawn args '-Goutput_dir=.'
                npm ERR! gyp info spawn args ]
                npm ERR! gyp info spawn make
                npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
                npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
                npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
                npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
                npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
                npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:33,
                npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node.h:73,
                npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
                npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
                npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
                npm ERR!       |                                              ^~~~~~~~~~~
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
                npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
                npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
                npm ERR! ../../nan/nan.h:1053:46: note: declared here
                npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                npm ERR!       |                                              ^~~~~~~~~~~~
                npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
                npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
                npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
                npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
                npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:24:
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                npm ERR!       |                                           ^~~
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                npm ERR!       |                                           ^~~
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
                npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
                npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
                npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
                npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
                npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
                npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
                npm ERR!   395 |       devId = arg0->IntegerValue();
                npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
                npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
                npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
                npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
                npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
                npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
                npm ERR!   417 |       devId = arg0->IntegerValue();
                npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
                npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
                npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
                npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
                npm ERR! gyp ERR! build error
                npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
                npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
                npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                npm ERR! gyp ERR! cwd /home/admin/node_modules/bluetooth-hci-socket
                npm ERR! gyp ERR! node -v v18.19.0
                npm ERR! gyp ERR! node-gyp -v v10.0.1
                npm ERR! gyp ERR! not ok
                npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-02-10T22_07_22_661Z-debug-0.log
                admin@iobroker:~ $
                • Glasfaser
                  Glasfaser @wauzzi last edited by Glasfaser
                  du stehst falsch
                  cd
                  /opt/iobroker
                  • wauzzi
                    du stehst falsch
                    cd
                    /opt/iobroker
                    selbes spiel
                    admin@iobroker:~ $ cd /opt/iobroker
                    admin@iobroker:/opt/iobroker $ sudo npm install bluetooth-hci-socket
                    npm ERR! code 1
                    npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
                    npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                    npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                    npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
                    npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
                    npm ERR!       |                                           ^~~
                    npm ERR!       |                                           ^~~
                    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
                    npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-02-10T22_11_48_917Z-debug-0.log
                    • wauzzi
                      @glasfaser irgendwie kann er das Verzeichnis nicht erstellen, oder liege ich falsch mit meiner Vermutung ?
                      • Glasfaser
                        selbes spiel
                        sorry habe den Thread nicht ganz dazu gelesen .
                        nur das machen ..
                        https://forum.iobroker.net/post/151081
                        nicht die Befehle darunter !
                        wauzzi 1 Reply Last reply Reply Quote 0
                        • wauzzi
                          @glasfaser Das hatte ich vorhin auch schon versucht. Hab es eben nochmals versucht.
                          Scheint aber alles sauber zu sein:
                          admin@iobroker:/opt/iobroker $ sudo npm install --production
                          npm WARN config production Use `--omit=dev` instead.
                          up to date in 3s
                          admin@iobroker:/opt/iobroker $ npm fund
                          iobroker.inst@3.0.0
                          ├── https://github.com/sponsors/epoberezkin
                          │   └── ajv@6.12.6
                          ├── https://github.com/sponsors/jaredhanson
                          │   └── passport@0.6.0, oauth2orize@1.11.1
                          ├── https://github.com/sponsors/isaacs
                          │   └── glob@7.2.3, minimatch@7.4.6, rimraf@3.0.2
                          ├── https://github.com/sponsors/feross
                          │   └── safe-buffer@5.2.1, base64-js@1.5.1, buffer@6.0.3, simple-concat@1.0.1
                          ├── https://github.com/sponsors/RubenVerborgh
                          │   └── follow-redirects@1.15.5
                          ├── https://github.com/sponsors/ljharb
                          │   └── qs@6.10.4, minimist@1.2.8, define-properties@1.2.1, es-abstract@1.22.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.slice@1.0.3, available-typed-arrays@1.0.6, es-to-primitive@1.2.1, is-date-object@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1.2.3, get-symbol-description@1.0.2, globalthis@1.0.3, is-array-buffer@3.0.4, is-callable@1.2.7, is-negative-zero@2.0.2, is-regex@1.1.4, is-shared-array-buffer@1.0.2, is-string@1.0.7, is-typed-array@1.1.13, is-weakref@1.0.2, object.assign@4.1.5, regexp.prototype.flags@1.5.1, safe-array-concat@1.1.0, safe-regex-test@1.0.3, string.prototype.trim@1.2.8, string.prototype.trimend@1.0.7, string.prototype.trimstart@1.0.7, typed-array-byte-length@1.0.0, typed-array-byte-offset@1.0.0, typed-array-length@1.0.4, unbox-primitive@1.0.2, has-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object@1.1.2, is-number-object@1.0.7, which-typed-array@1.1.14, has-tostringtag@1.0.2, traverse@0.6.8
                          ├── https://github.com/sponsors/broofa
                          │   └── uuid@9.0.1
                          ├── https://github.com/sponsors/sindresorhus
                          │   └── is-plain-obj@3.0.0, is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, onetime@5.1.2, make-dir@3.1.0, mimic-response@2.1.0, component-emitter@1.3.1, debounce@2.0.0
                          ├── https://github.com/sponsors/jonschlinkert
                          │   └── picomatch@2.3.1
                          ├─┬ https://github.com/sindresorhus/got?sponsor=1
                          │ │ └── got@11.8.6
                          │ └── https://github.com/sindresorhus/is?sponsor=1
                          │     └── @sindresorhus/is@4.6.0
                          ├── https://github.com/sponsors/NaturalIntelligence
                          │   └── fast-xml-parser@4.3.4
                          ├─┬ https://opencollective.com/node-fetch
                          │ │ └── node-fetch@3.3.2
                          │ └── https://github.com/sponsors/jimmywarting
                          │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                          ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                          │ │ └── wrap-ansi@7.0.0
                          │ └── https://github.com/chalk/ansi-styles?sponsor=1
                          │     └── ansi-styles@4.3.0
                          ├── https://opencollective.com/serialport/donate
                          │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
                          ├─┬ https://github.com/chalk/chalk-template?sponsor=1
                          │ │ └── chalk-template@0.4.0
                          │ └── https://github.com/chalk/chalk?sponsor=1
                          │     └── chalk@4.1.2
                          ├── https://opencollective.com/date-fns
                          │   └── date-fns@2.30.0
                          ├── https://opencollective.com/ioredis
                          │   └── ioredis@4.28.5
                          ├── https://github.com/sindresorhus/execa?sponsor=1
                          │   └── execa@5.1.1
                          ├── https://paulmillr.com/funding/
                          │   └── chokidar@3.6.0
                          ├── https://github.com/sponsors/sibiraj-s
                          │   └── ci-info@3.9.0
                          ├── https://opencollective.com/js-sdsl
                          │   └── js-sdsl@4.3.0
                          ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
                          │ │ └── cheerio@1.0.0-rc.10
                          │ ├─┬ https://github.com/sponsors/fb55
                          │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.1.0, domelementtype@2.3.0
                          │ │ └── https://github.com/fb55/domutils?sponsor=1
                          │ │     └── domutils@2.8.0, domutils@3.1.0
                          │ ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
                          │ │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0
                          │ │ └── https://github.com/fb55/entities?sponsor=1
                          │ │     └── entities@2.2.0, entities@4.5.0
                          │ ├── https://github.com/fb55/domhandler?sponsor=1
                          │ │   └── domhandler@4.3.1, domhandler@5.0.3
                          │ └── https://github.com/fb55/htmlparser2?sponsor=1
                          │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
                          ├── https://locize.com
                          │   └── i18next@21.10.0
                          ├── https://ko-fi.com/killymxi
                          │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
                          ├── https://github.com/sponsors/3846masa
                          │   └── http-cookie-agent@5.0.4
                          └── https://github.com/inikulin/parse5?sponsor=1
                            └── parse5@7.1.2
                          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            @wauzzi
                            ins Verzeichniss
                            cd /opt/iobroker/node_modules/bluetooth-hci-socket
                            dann dort
                            Bitte alles in Ruhe lesen , es steht auch dort !!
                            • wauzzi
                              @glasfaser
                              Danke für Deine Geduld mit mir 😌
                              Das Verzeichnis "opt/iobroker/node_modules/bluetooth-hci-socket" existiert bei mir nicht.
                              Ich hab eben nochmals mit dem Winscp geschaut. nicht vorhanden
                                sudo npm
                                Arrrgh. Nie npm in Verbindung mit sudo verwenden.
                                • Glasfaser
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install bluetooth-hci-socket
                                    @wauzzi
                                    bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
                                    echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    └── iobroker.ble@0.14.0
                                    • wauzzi
                                      admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
                                      npm ERR! code 1
                                      npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
                                      npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
                                      npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
                                      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
                                      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
                                      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
                                      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
                                      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
                                      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                                      npm ERR!       |                                           ^~~
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                                      npm ERR!       |                                           ^~~
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
                                      npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
                                      npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                      npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                                      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
                                      • wauzzi
                                        sieht bei mir ähnlich aus:
                                        admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                                        wird dies denn zwingend für den ble Adapter benötigt ?
                                        • Glasfaser
                                          keine Ahnung was das mit python3 zu tun hat
                                            @wauzzi
                                            Grundvoraussetzungen sind da?
                                            sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                                            sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                            1877
