    4. [gelöst] Problem mit Javascript-Adapter
      hans_999 last edited by hans_999
      Heute ist wohl nicht mein Tag am PC.
      Der Javascript-Adater wurde mir bei den vorhandenen Aktualisierungen angezeigt (7.1.4 -> 7.8.0)
      Also habe ich "Aktualisieren gewählt.
      Das ging leider schief
      2024-02-18 21:50:01.923 - info: host.PIioBroker iobroker Update javascript from @7.1.4 to @7.8.0
      2024-02-18 21:50:02.937 - info: dwd.0 (17409) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.1, js-controller: 5.0.17
      2024-02-18 21:50:03.347 - info: host.PIioBroker iobroker NPM version: 8.19.3Installing iobroker.javascript@7.8.0... (System call)
      2024-02-18 21:50:05.632 - info: dwd.0 (17409) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-02-18 21:50:06.170 - info: host.PIioBroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-02-18 21:50:39.028 - info: host.PIioBroker iobroker npm ERR! code ETIMEDOUT
      2024-02-18 21:50:39.032 - info: host.PIioBroker iobroker npm ERR! syscall readnpm ERR! errno -110
      2024-02-18 21:50:39.039 - info: host.PIioBroker iobroker npm ERR! network read ETIMEDOUTnpm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'
      2024-02-18 21:50:39.048 - info: host.PIioBroker iobroker
      2024-02-18 21:50:39.052 - info: host.PIioBroker iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T20_50_04_520Z-debug-0.log
      2024-02-18 21:50:39.086 - error: host.PIioBroker iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall readnpm ERR! errno -110npm ERR! network read ETIMEDOUTnpm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly. See: 'npm help config'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T20_50_04_520Z-debug-0.log
      2024-02-18 21:50:39.088 - error: host.PIioBroker iobroker host.PIioBroker Cannot install iobroker.javascript@7.8.0: 146
      Etwas später habe ich festgestellt, dass keine Skripte mehr laufen 😞
      Da der Adapter noch in der Liste der Instanzen war, habe ich gestoppt und neu gestartet. Dann lief andauernd die (erfolglose) Installation los.
      Also Adapter wieder gestoppt.
      Auf die Kommandozeile gegangen und die installierten Adapter geprüft: Er war nicht in der Liste.
      Also 1. Versuch:
      iob install javascript
      Leider wieder erfolglos. Hier wohl die relevante Fehlermeldung, die mir aber nicht weiterhilft.
      Der Versuch, die alte Version
      iob install javascript@7.1.4
      wieder zu installieren, ging ebenfalls schief und bringt eine ähnliche Fehlermeldung
      2024-02-18 22:02:39.168 - error: host.PIioBroker iobroker npm-install: npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/@types/caselessnpm ERR! dest /opt/iobroker/node_modules/@types/.caseless-biP5OApGnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@types/caseless' -> '/opt/iobroker/node_modules/@types/.caseless-biP5OApG'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2024-02-18T21_02_32_356Z-debug-0.log
      2024-02-18 22:02:39.169 - error: host.PIioBroker iobroker npm-install: host.PIioBroker Cannot install iobroker.javascript@7.1.4: 217
      Was kann ich jetzt noch machen?
      Thomas Braun arteck ? H 4 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @hans_999 last edited by Thomas Braun
        @hans_999
        iob stop
        iob fix
        iob nodejs-update
        sudo reboot
        Dann weiterschauen.
        Die Ausgabe von 'iob diag' ist auch immer sinnvoll.
          arteck Developer Most Active @hans_999 last edited by arteck
          @hans_999 sagte in Problem mit Javascript-Adapter:
          da ist ein update abgebrochen...
          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          in der console.. wenn nach dem iob fix trotzdem nicht weiter geht
            A Former User @hans_999 last edited by
            Da ist beim Update dein Netzwerk zusammengebrochen oder kein Internetzugang oder DNS Fehler oder oder oder...
            Also schau am besten, noch bevor du die Commands von @Thomas-Braun eingibst, dass dein Netzwerk im iobroker funktioniert..
            • mcm1957
              mcm1957 @arteck last edited by mcm1957
              @arteck said in Problem mit Javascript-Adapter:
              Könnte dein gescheiterter Versuch einen nicht im Repo enthaltenen Adapter direkt von Github zu installieren da schuld sein?
              https://forum.iobroker.net/topic/59422/new-adapter-huawei-fusionsolar-api/92?_=1708337684217
              Da klemmt es genau beim selben Modul ....
              Und wie schon dort geschrieben: GITHUB Installatoinen immer auf eigenes Risiko und nicht auf produktiven Systemen (von Ausnahmen in Abstimmung mit dem Developer mal abgesehen)
              arteck 1 Reply Last reply Reply Quote 2
                arteck Developer Most Active @mcm1957 last edited by
                @mcm57
                .caseless-biP5OApG
                diese Ordnerstruktur ist immer dann wenn ein update läuft.. und wird nach dem Update bereinigt..
                bricht das upadate ab.. dann bleiben diese Order bestehen und blokieren alle anderen Updates..
                nur mal zur Info
                  hans_999 @hans_999 last edited by hans_999
                  @Thomas-Braun
                  Danke, die Vorgehensweise hat geholfen.
                  Es hat zwar ewig gedauert, bis das Update-Skript durch war. Aber danach konnte ich den aktuellen Javascript-Adapter problemlos (neu) installieren.
                  Danke auch für die anderen Tipps und Hinweise.
                    @hans_999
                    Das spricht dafür, dass da diverse Updates in der Pipeline hingen.
                    In einem ansonsten gepflegten System dauert das nämlich nicht besonders lange.
                    Kiste danach auch mal sauber neugestartet?
                      hans_999 @Thomas Braun last edited by
                      @thomas-braun said in [gelöst] Problem mit Javascript-Adapter:
                      Ja, das war ja der letzte Punkt in deiner Anleitung.
                        @hans_999
                        Dann kannst du dir jetzt noch die Ausgabe von
                        iob diag
                        anschauen.
                        javascript
                        562
