    4. Unifi Controller HTTP Status 404 – Not Found
      Snopy_16 last edited by
      Hallo ich betreibe den Unificontroller zusammen mit iobroker nativ auf einen Raspberry PI4.
      Habe immer wieder mal apt-update && apt full-upgrade gemacht.
      Nun fiel mir auf dass der Unifi Controller nicht mehr erreichbar ist
      "HTTP Status 404 – Not Found"
      Hier die Meldung beim Abfragen des Status
      pi@raspberrypi:~ $ systemctl status unifi.service
      ● unifi.service - unifi
           Loaded: loaded (/lib/systemd/system/unifi.service; enabled; vendor preset: enabled)
           Active: activating (start-post) since Tue 2024-02-20 11:45:00 CET; 4min 3s ago
          Process: 7044 ExecStartPre=/usr/sbin/unifi-network-service-helper init (code=exited, status=0/SUCCESS)
          Process: 7088 ExecStartPre=/usr/sbin/unifi-network-service-helper init-uos (code=exited, status=0/SUCCESS)
         Main PID: 7097 (java); Control PID: 7098 (unifi-network-s)
            Tasks: 39 (limit: 8755)
              CPU: 1min 24.887s
           CGroup: /system.slice/unifi.service
                   ├─7097 /usr/bin/java -Dfile.encoding=UTF-8 -Djava.awt.headless=true -Dapple.awt.UIElement=true -Dunifi.core.enabled=false -Dunifi.mongodb.service.enabled=false -Xmx1024M -XX:+UseParallelGC -XX:>
                   ├─7098 /bin/bash /usr/sbin/unifi-network-service-helper healthcheck
                   └─8920 sleep 3
      Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7087]: <13>Feb 20 11:45:00 unifi: init complete...
      Feb 20 11:45:00 raspberrypi unifi[7096]: Skipping init-uos...
      Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7096]: <13>Feb 20 11:45:00 unifi: Skipping init-uos...
      Feb 20 11:45:00 raspberrypi unifi[7108]: health-check max retry count: 100
      Feb 20 11:45:00 raspberrypi unifi-network-service-helper[7108]: <13>Feb 20 11:45:00 unifi: health-check max retry count: 100
      Feb 20 11:45:13 raspberrypi java[7097]: WARNING: An illegal reflective access operation has occurred
      Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Illegal reflective access by org.apache.catalina.loader.WebappClassLoaderBase (file:/usr/lib/unifi/lib/tomcat-embed-core-9.0.65.jar) to field java.io.ObjectS>
      Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Please consider reporting this to the maintainers of org.apache.catalina.loader.WebappClassLoaderBase
      Feb 20 11:45:13 raspberrypi java[7097]: WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
      Feb 20 11:45:13 raspberrypi java[7097]: WARNING: All illegal access operations will be denied in a future release
      Ich bin nicht sehr fit in Sachen Linux und die Ausgabe sagt mir eigentlich gar nichts und ich weiss nicht wo ich das reparieren kann.
        Thomas Braun Most Active @Snopy_16 last edited by Thomas Braun
        @snopy_16 sagte in Unifi Controller HTTP Status 404 – Not Found:
        Wenn man danach sucht findet man einiges.
        Auf welchem Stand ist denn dein 'immer mal' upgedatetes System?
        iob diag
        sagt dir das.
          Snopy_16 @Thomas Braun last edited by
          @thomas-braun sagte in Unifi Controller HTTP Status 404 – Not Found:
          Ja, aber leider ist mein englisch fast nicht zu verwenden
          iob diag
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           12:50:22 up  1:20,  3 users,  load average: 0.60, 0.86, 1.13
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Tue 2024-02-20 12:50:22 CET
                     Universal time: Tue 2024-02-20 11:50:22 UTC
                           RTC time: n/a
                          Time zone: Europe/Vienna (CET, +0100)
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        3.0G        3.5G         29M        1.3G        4.6G
          Swap:            99M          0B         99M
          Total:          7.9G        3.0G        3.6G
                   7812 M total memory
                   3023 M used memory
                   3414 M active memory
                    708 M inactive memory
                   3495 M free memory
                     87 M buffer memory
                   1206 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G   13G   14G  49% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
          /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
          tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
          [Tue Feb 20 11:29:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:59:9B:B3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=96bb02d6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Tue Feb 20 11:29:34 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Feb 20 11:29:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Feb 20 11:29:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          2.9G    /var/
          1.5G    /var/lib
          1.1G    /var/cache/apt
          1.1G    /var/cache
          936M    /var/cache/apt/archives
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          124M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.8G    /opt/iobroker/iobroker-data/
          1.3G    /opt/iobroker/iobroker-data/history
          397M    /opt/iobroker/iobroker-data/files
          99M     /opt/iobroker/iobroker-data/backup-objects
          89M     /opt/iobroker/iobroker-data/files/echarts.admin
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          22M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.1
          /usr/bin/node           v18.19.1
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Installed: 18.19.1-1nodesource1
            Candidate: 18.19.1-1nodesource1
            Version table:
           *** 18.19.1-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   2
          Adapter State
          + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
          + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
          + system.adapter.eventlist.1              : eventlist             : raspberrypi                              -  enabled
          + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.octoprint.0              : octoprint             : raspberrypi                              -  enabled
          + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
            system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 9090, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
          + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b4cc327b0745ec11aff094fd6f14af06-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.9.6   , installed 2.9.6
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "eventlist"    : 2.0.0    , installed 2.0.0
          Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.2  [Updatable]
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
          Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "snmp"         : 3.1.0    , installed 3.1.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects:        10959
          States:         9320
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 http://giteduberger.fr rpimonitor/ InRelease
          Hit:6 https://packages.grafana.com/oss/deb stable InRelease
          Hit:7 https://repos.influxdata.com/debian stable InRelease
          Hit:8 https://repos.influxdata.com/debian bullseye InRelease
          Hit:9 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:10 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      117        16549      577/mongod
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12970      681/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          13102      802/perl
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17401      1557/iobroker.js-co
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       18360      1557/iobroker.js-co
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16414      567/cupsd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        2044       631/mosquitto
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21342      2899/io.sonoff.0
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15571      630/vncserver-x11-c
          tcp6       0      0 :::3000                 :::*                    LISTEN      120        17172      1553/grafana
          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       446767     3550/io.upnp.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      119        16973      597/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       19281      2573/io.admin.0
          tcp6       0      0 :::8080                 :::*                    LISTEN      118        480432     26071/java
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31658      3636/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12973      681/sshd: /usr/sbin
          tcp6       0      0 :::8443                 :::*                    LISTEN      118        480443     26071/java
          tcp6       0      0 :::8843                 :::*                    LISTEN      118        478174     26071/java
          tcp6       0      0 :::8880                 :::*                    LISTEN      118        480433     26071/java
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16413      567/cupsd
          tcp6       0      0 :::1883                 :::*                    LISTEN      116        2045       631/mosquitto
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          15570      630/vncserver-x11-c
          udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13008      -
          udp        0      0 0.0.0.0:48878           0.0.0.0:*                           1001       31344      3425/io.snmp.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14904      526/dhcpcd
          udp        0      0 0.0.0.0:49453           0.0.0.0:*                           1001       32178      3550/io.upnp.0
          udp        0      0 0.0.0.0:41326           0.0.0.0:*                           1001       31343      3425/io.snmp.0
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14890      770/cups-browsed
          udp        0      0 0.0.0.0:54019           0.0.0.0:*                           1001       32179      3550/io.upnp.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1855       424/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21320      2823/io.shelly.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32466      3550/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32465      3550/io.upnp.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       32464      3550/io.upnp.0
          udp        0      0 0.0.0.0:47126           0.0.0.0:*                           108        1857       424/avahi-daemon: r
          udp        0      0 0.0.0.0:59784           0.0.0.0:*                           1001       32177      3550/io.upnp.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21404      2924/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21405      2924/io.tuya.0
          udp6       0      0 :::51820                :::*                                0          13009      -
          udp6       0      0 :::546                  :::*                                0          16538      526/dhcpcd
          udp6       0      0 :::46104                :::*                                108        1858       424/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        1856       424/avahi-daemon: r
          2024-02-20 11:33:07.070  - info: tuya.0 (2924) 67334207807d3a73076a: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.24:6668
          2024-02-20 11:33:15.889  - info: tuya.0 (2924) bfce629f8925be1b3avd8x: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.21:6668
          2024-02-20 11:33:21.815  - info: tuya.0 (2924) bf2a002143d1aaa3d6pxdo: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.80:6668
          2024-02-20 11:33:22.681  - info: tuya.0 (2924) bf6cb789979a05727fivhw: Error on Reconnect (7): connect ECONNREFUSED 192.168.178.51:6668
          2024-02-20 11:33:24.375  - info: tuya.0 (2924) 703548358cce4ecf54fb: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
          2024-02-20 11:33:28.695  - info: tuya.0 (2924) bfd24a3dcc000234f1fdsz: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.50:6668
          2024-02-20 11:33:30.423  - info: tuya.0 (2924) 10801581f4cfa202a51c: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.45:6668
          2024-02-20 11:33:32.119  - info: tuya.0 (2924) 10801581f4cfa202a6a2: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.78:6668
          2024-02-20 11:33:33.495  - info: tuya.0 (2924) 27051506b4e62d57b7e7: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.60:6668
          2024-02-20 11:33:36.471  - info: tuya.0 (2924) 70354835e09806164458: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.79:6668
          2024-02-20 11:33:38.040  - info: tuya.0 (2924) 703384143c6105ebb2c8: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.55:6668
          2024-02-20 11:49:34.513  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
          2024-02-20 11:49:50.081  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
          2024-02-20 11:49:53.101  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          2024-02-20 12:02:00.240  - info: javascript.0 (2693) script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
          2024-02-20 12:03:00.162  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1387a9c41346d TS011F after 4 ping attempts
          2024-02-20 12:03:00.710  - warn: zigbee.0 (2958) DeviceAvailability:Stopping to ping 0xa4c1382e5d9115bd TS011F after 4 ping attempts
          2024-02-20 12:21:33.640  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
          2024-02-20 12:21:33.653  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36 admin
          2024-02-20 12:21:33.656  - info: admin.0 (2573) <== Disconnect system.user.admin from ::ffff:192.168.178.36
          2024-02-20 12:30:01.890  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
          2024-02-20 12:34:21.995  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl.Liter, feature disabled processing normally)
          2024-02-20 12:34:22.134  - info: sourceanalytix.0 (3464) Device reset detected for mqtt.0.EASY-ESP32-02.Heizöl_MW.Liter_MW, feature disabled processing normally)
          2024-02-20 12:49:09.157  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
          2024-02-20 12:49:09.173  - info: admin.0 (2573) ==> Connected system.user.admin from ::ffff:192.168.178.36
            630/vncserver-x11-c
            Schalt den Desktop-Mumpitz und damit auch den vnc-Mist aus.
            Zum Problem: Könnte sein, dass die verwendete Datenbank zu alt ist.
            Ich hab aber keine Ahnung, ob eine Neuinstallation von Raspberry OS 'Bookworm' da aktuelleres mit bringt.
            Und die Quelle
            würde ich auch rauskicken, wenn du nicht weißt warum die drin ist.
            influxdb hast du doppelt drin.
              wie kann ich das rauskicken und kann ich auch die 2. influx kicken (Welche?)
                @snopy_16
                sudo systemctl set-default multi-user.target
                ls -lAh /etc/apt/sources.list.d/
                zeigen.
                  pi@raspberrypi:~ $ sudo systemctl set-default multi-user.target
                  Removed /etc/systemd/system/default.target.
                  Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
                  pi@raspberrypi:~ $ ls -lAh /etc/apt/sources.list.d/
                  insgesamt 28K
                  -rw-r--r-- 1 root root 137 22. Sep 17:19 100-ubnt-unifi.list
                  -rw-r--r-- 1 root root  53 29. Okt 17:30 grafana.list
                  -rw-r--r-- 1 root root 117 24. Okt 17:24 influxdata.list
                  -rw-r--r-- 1 root root  56 24. Okt 17:07 influxdb.list
                  -rw-r--r-- 1 root root 100 24. Okt 15:37 nodesource.list
                  -rw-r--r-- 1 root root 191  3. Mai 2023  raspi.list
                  -rw-r--r-- 1 root root  73 24. Okt 10:47 rpimonitor.list
                    sudo rm /etc/apt/sources.list.d/rpimonitor.list
                    sudo rm /etc/apt/sources.list.d/influxdb.list
                    sudo apt update
                      Snopy_16 @Thomas Braun last edited by Snopy_16
                      so ok ?
                      insgesamt 20K
                      Unifi - Problem hab ich noch nicht gelöst😕
                      Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                        @snopy_16
                        sudo apt update
                        sagt?
                        Zum unifi-Problem kann ich dir nichts sagen.
                          sudo apt update
                          pi@raspberrypi:~ $ sudo apt update
                          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                          OK:2 http://deb.debian.org/debian bullseye InRelease
                          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                          OK:4 https://repos.influxdata.com/debian stable InRelease
                          OK:5 https://packages.grafana.com/oss/deb stable InRelease
                          OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          OK:7 https://dl.ui.com/unifi/debian unifi-7.4 InRelease
                          OK:8 http://archive.raspberrypi.org/debian bullseye InRelease
                          Paketlisten werden gelesen… Fertig
                          Abhängigkeitsbaum wird aufgebaut… Fertig
                          Statusinformationen werden eingelesen… Fertig
                          Alle Pakete sind aktuell.
                          Ich glaub das ist so in Ordnung?
                            @snopy_16
                            Ja, passt.
                              @thomas-braun Danke
                              • Meister Mopper
                                Meister Mopper @Snopy_16 last edited by
                                Hier wirst du doch bestimmt fündig für die Fälle des Installierens und Update.
                                1081
