    4. Node-Red
    5. [gelöst] Wert für alle Objekte in einem Order setzen
      schneidy76 last edited by schneidy76
      Würde das funktionieren, das man mit einem flow alle Objekte in einen Ordner gleichzeitig auf "false" setzen kann?
      Habe da probiert, aber es funktioniert nicht:
              "id": "2d4606a3fadff7d5",
              "type": "ioBroker in",
              "z": "db97e840ec20025f",
              "name": "Vacuum state",
              "topic": "mihome-vacuum.0.info.state",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "fireOnStart": "false",
              "outFormat": "MQTT",
              "x": 130,
              "y": 240,
              "wires": [
                      "adfe5c9e24e51537",
                      "07d90c82cc2e6a57"
              "id": "adfe5c9e24e51537",
              "type": "debug",
              "name": "State sauger",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 350,
              "y": 220,
              "wires": []
              "id": "07d90c82cc2e6a57",
              "type": "switch",
              "name": "bei Heimkehr",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "6",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 350,
              "y": 260,
              "wires": [
                      "3d8cae059fee08af"
              "id": "3d8cae059fee08af",
              "type": "change",
              "name": "setze Auswahl zurück",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 560,
              "y": 260,
              "wires": [
                      "c8877bbda4460a57"
              "id": "c8877bbda4460a57",
              "type": "ioBroker out",
              "name": "Auswahl Räume",
              "topic": "0_userdata.0.Räume",
              "ack": "true",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 760,
              "y": 260,
              "wires": []
              "id": "34ca1497fa8fe595",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "6",
              "payloadType": "str",
              "x": 110,
              "y": 320,
              "wires": [
                      "07d90c82cc2e6a57"
      so wie ich das verstanden habe, sollte das doch gehen... Oder?
      VG Torsten
      • mickym
        mickym Most Active @schneidy76 last edited by mickym
        Nein das funktioniert so nicht. Die iobroker-Out Node kann nur ein state setzen, aber du kannst die Objekte alle in einem Array sammeln und dann die payload gemeinsam setzen. Allerdings solltest Du aufpassen nicht alle Objekte in einem Adapter zu setzen - da viele ReadOnly sind.
        Zeig doch mal welche Objekte Du mit einem Flow auf false setzen möchtest, dann arbeitest Du einfach mit der List Node.
        Möchtest Du alle States unter Räume auf false setzen?
        0_userdata.0.Räume
          schneidy76 @mickym last edited by schneidy76
          @mickym schade, hätte so einfach sein können... 😁
          Es geht um die Räume die ich ausgewählt habe und mein Saugroboter gereinigt hat.
          Auf der Rücktour zur Ladestation soll diese gelöscht werden...
          diese Objekte möchte ich auf "false" setzen:
          • mickym
            @schneidy76 Ja Du musst ggf den Control Ordner da rausmachen dann geht das super easy:
            [{"id":"6ff64a0eba16662a","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":250,"y":5560,"wires":[["0f1d8009da8aaaea"]]},{"id":"0f1d8009da8aaaea","type":"ioBroker list","z":"289f539dcc33814e","name":"","topic":"0_userdata.Räume.*","objType":"state","regex":"","asArray":"false","onlyIDs":"true","withValues":"false","x":440,"y":5560,"wires":[["8b50aaf612c48cad"]]},{"id":"8b50aaf612c48cad","type":"ioBroker out","z":"289f539dcc33814e","name":"Auswahl Räume","topic":"","ack":"true","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":680,"y":5560,"wires":[]}]
            Du kannst die auch drin lassen und dann über regex ausfiltern. Ich zeigs Dir.
            S mickym 2 Replies Last reply Reply Quote 1
              @mickym said in Wert für alle Objekte in einem Order setzen:
              das habe ich mir auch schon fast gedacht -ich teste mal
              Danke!!!
              • mickym
                mickym Most Active @mickym last edited by
                @mickym Ja wie gesagt warte mal - ich probiere noch die Filterung.
                  @mickym ich warte... Du bist echt genial...
                  • mickym
                    @schneidy76 Muss noch bissi an dem Filter mit regex tüfteln. 😉
                      @mickym alles klar, kein Stress
                      • mickym
                        @schneidy76 Ja sorry - manchmal ist regEx verzwickt.
                          @mickym ich kenn die Node nich mal 😂
                          • mickym
                            @schneidy76 Ok - ich habs mal so gemacht - dass es keine Sonderzeichen für Verzeichnisse gibt.
                            Also um nur die topics auf der ersten Ebene zu haben, habe ich die list Node wie folgt angepasst:
                            Also wenn Du den Filter
                            .*Räume\.\w*$
                            nutzt - dann werden aus der List Node nur die auf der 1. Ebene verwendet.
                            Also mit dem Flow sollten alles States direkt unter Räume auf false gesetzt werden:
                            [{"id":"6ff64a0eba16662a","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":250,"y":5560,"wires":[["0f1d8009da8aaaea"]]},{"id":"0f1d8009da8aaaea","type":"ioBroker list","z":"289f539dcc33814e","name":"","topic":"0_userdata.0.Räume.*","objType":"state","regex":".*Räume\\.\\w*$","asArray":"false","onlyIDs":"true","withValues":"false","x":440,"y":5560,"wires":[["8b50aaf612c48cad"]]},{"id":"8b50aaf612c48cad","type":"ioBroker out","z":"289f539dcc33814e","name":"Auswahl Räume","topic":"","ack":"true","autoCreate":"false","stateName":"","role":"","payloadType":"","readonly":"","stateUnit":"","stateMin":"","stateMax":"","x":680,"y":5560,"wires":[]}]
                            Du setzt halt statt false über die Inject Node über eine Change Node.
                              @mickym funktioniert noch nicht ganz...
                                      "onlyack": "",
                                      "func": "all",
                                      "gap": "",
                                      "x": 130,
                                      "y": 300,
                                      "wires": [
                                              "938596741a116e5c"
                                      "type": "debug",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 510,
                                      "y": 280,
                                      "wires": []
                                      "type": "switch",
                                      "rules": [
                                              "t": "eq",
                                              "v": "6",
                                              "vt": "num"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 1,
                                      "x": 510,
                                      "y": 320,
                                      "wires": [
                                              "3d8cae059fee08af"
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 720,
                                      "y": 320,
                                      "wires": [
                                              "335221c44376c77e"
                                      "type": "inject",
                                      "name": "",
                                      "props": [
                                              "p": "payload"
                                      "repeat": "",
                                      "crontab": "",
                                      "once": false,
                                      "onceDelay": 0.1,
                                      "topic": "",
                                      "payload": "6",
                                      "x": 350,
                                      "y": 420,
                                      "wires": [
                                              "07d90c82cc2e6a57"
                                      "id": "938596741a116e5c",
                                      "type": "rbe",
                                      "name": "",
                                      "func": "rbe",
                                      "gap": "",
                                      "start": "",
                                      "inout": "out",
                                      "septopics": false,
                                      "topi": "topic",
                                      "x": 330,
                                      "y": 320,
                                      "wires": [
                                              "07d90c82cc2e6a57",
                                              "adfe5c9e24e51537"
                                      "id": "8b50aaf612c48cad",
                                      "ack": "true",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1200,
                                      "y": 320,
                                      "wires": []
                                      "id": "335221c44376c77e",
                                      "type": "ioBroker list",
                                      "name": "",
                                      "topic": "0_userdata.0.Räume.*",
                                      "objType": "state",
                                      "regex": ".*Räume\\.\\w*$",
                                      "asArray": "false",
                                      "onlyIDs": "true",
                                      "withValues": "false",
                                      "x": 960,
                                      "y": 320,
                                      "wires": [
                                              "8b50aaf612c48cad"
                              mach jetzt erst mal FA, habe morgen einen wichtigen Termin...
                              • mickym
                                @schneidy76 Was funktionier denn nicht?
                                • mickym
                                  mickym Most Active @mickym last edited by mickym
                                  @mickym sagte in Wert für alle Objekte in einem Order setzen:
                                  Ich seh shcon du hast meinen Flow nicht importiert:
                                  In deiner iobroker Out NOde steht ja ein topic - bei mir nicht!!! Also topic aus der iobroker-OUT Node löschen!!!
                                  • mickym
                                    .Räume.\w$
                                    Über folgenden Filter - kannst Du dann ein und ausschließen, wieviele Hierachieebenen die id enthalten soll:
                                    https://regex101.com/r/QVMv81/1
                                    .*Räume(?:\.\w*){1,2}$
                                    Für Ebene 1 und 2 unter Räume zum Beispiel
                                    oder {2,3} für die Ebenen 2 und 3 unter Räumen:
                                      @mickym Moin, generell scheint das zu funktionieren, es scheint ein Problem mit den Raumnamen zu geben, wenn Sonderzeichen im Spiel sind...
                                      Debug schmeißt das raus.
                                      Dagegen steht in den Objekten
                                      VG Torsten
                                      • mickym
                                        @schneidy76 Ja immer die Leute, die Sonderzeichen in Objekten verwenden. 🙄
                                        Dann ändere mal den Filter in der iobroker-List node wie folgt:
                                        .*Räume\.(?:\w|[ä,ü,ö,ß])*$
                                        Generell würde ich mir das Leben mit Sonderzeichen in Objekten nicht schwer machen, sondern den reinen ASCI Zeichensatz verwenden. In deiner UI oder Dashboard kannst Du ja soviele Sonderzeichen verwenden, wie Du willst.
                                          jaja, schon verstanden, bisher war es kein Problem... 😉
                                          Aber nun zum wesentlichen: es funktioniert tatsächlich!
                                          Dankeschön!!!
                                          node-red
                                          927
