    4. Problem nach update Admin V6.13.16 kein zugriff mehr auf Gui
      keineAhnungvonProgrmieren last edited by
      nach dem Update des Admin adapters auf 6.13.16 kann ich nichtmehr auf die Weboberfläche mittels Browser zugreifen (Firefox+Edge)
      nach einer Diagnose scheinen aber alle adapter zu laufen
      • Adaptername: ...admin
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: ...6.13.16
      • js-controller Version: ...5.0.19
      • Admin Version: ...6.13.16
      • Hardwaresystem: Pi4 ...
      • Arbeitsspeicher: ...xGB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: ...Debian GNU/Linux 11 (bullseye)
      • Nodejs-Version: ...v18.18.2
      • NPM-Version: ...9.8.1
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      • Ort, Name der Imagedatei: ...
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: SmartHomeRohlik
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:14:49 up  5:17,  1 user,  load average: 0.08, 0.11, 0.16
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2024-03-01 19:14:49 CET
                 Universal time: Fri 2024-03-01 18:14:49 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      SmartHomeRohlik
      /home/SmartHomeRohlik
      SmartHomeRohlik adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        854M        5.9G        1.0M        1.0G        6.8G
      Swap:            99M          0B         99M
      Total:          7.9G        854M        6.0G
               7812 M total memory
                854 M used memory
                937 M active memory
                805 M inactive memory
               5918 M free memory
                 81 M buffer memory
                958 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G  4.4G   52G   8% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Fri Mar  1 13:57:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:26:C6:E7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f99eefee-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Mar  1 13:57:32 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Mar  1 13:57:32 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Mar  1 13:57:33 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Mar  1 13:57:33 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Mar  1 13:57:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Mar  1 13:57:35 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      883M    /var/log
      881M    /var/log/journal/9ab67524321c46fcbcc935773dd5bf51
      270M    /var/cache
      Archived and active journals take up 880.1M in the file system.
      /opt/iobroker/backups:
      71M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      234M    /opt/iobroker/iobroker-data/
      112M    /opt/iobroker/iobroker-data/files
      75M     /opt/iobroker/iobroker-data/backup-objects
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/344.2eef1017.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Candidate: 18.19.1-1nodesource1
        Version table:
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
       *** 18.18.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
        system.adapter.admin.0                  : admin                 : SmartHomeRohlik                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : SmartHomeRohlik                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.2                  : admin                 : SmartHomeRohlik                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.3                  : admin                 : SmartHomeRohlik                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.4                  : admin                 : SmartHomeRohlik                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : SmartHomeRohlik                          -  enabled
        system.adapter.bshb.0                   : bshb                  : SmartHomeRohlik                          - disabled
      + system.adapter.discovery.0              : discovery             : SmartHomeRohlik                          -  enabled
      + system.adapter.javascript.0             : javascript            : SmartHomeRohlik                          -  enabled
        system.adapter.mclighting.0             : mclighting            : SmartHomeRohlik                          - disabled, port: 81
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : SmartHomeRohlik                          -  enabled, port: 54321
      + system.adapter.rpi2.0                   : rpi2                  : SmartHomeRohlik                          -  enabled
      + system.adapter.shelly.0                 : shelly                : SmartHomeRohlik                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : SmartHomeRohlik                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.2                 : shelly                : SmartHomeRohlik                          -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.3                 : shelly                : SmartHomeRohlik                          -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : SmartHomeRohlik                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.vis-inventwo.0           : vis-inventwo          : SmartHomeRohlik                          -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomeRohlik                          -  enabled
        system.adapter.vis.0                    : vis                   : SmartHomeRohlik                          -  enabled
      + system.adapter.web.0                    : web                   : SmartHomeRohlik                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "bshb"         : 0.2.7    , installed 0.2.7
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mclighting"   : 0.1.2    , installed 0.1.2
      Adapter    "mihome-cloud" : 0.1.0    , installed 0.1.0
      Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
      Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        1233
      States:         898
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Reading package lists...
      Pending Updates: 56
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       135178     19133/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       133834     19250/io.shelly.3
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1590       533/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       132939     19068/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       132932     19068/iobroker.js-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1592       533/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       135279     19280/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       136365     19325/io.simple-api
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13544      391/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       133801     19234/io.shelly.2
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       132070     19117/io.shelly.0
      udp        0      0 0.0.0.0:60301           0.0.0.0:*                           108        13547      391/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13587      715/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       136260     19210/io.mihome-vac
      udp6       0      0 :::5353                 :::*                                108        13546      391/avahi-daemon: r
      udp6       0      0 :::55612                :::*                                108        13548      391/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13597      715/dhcpcd
      2024-03-01 19:15:00.003  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: --- Neuer Zyklus ---
      2024-03-01 19:15:00.003  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: Tank Level:
      2024-03-01 19:15:01.174  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:04.158  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:07.159  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:10.161  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:13.162  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:15.004  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: --- Neuer Zyklus ---
      2024-03-01 19:15:15.005  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: Tank Level:
      2024-03-01 19:15:16.164  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:19.163  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:22.166  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:25.164  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:28.166  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:30.006  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: --- Neuer Zyklus ---
      2024-03-01 19:15:30.007  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: Tank Level:
      2024-03-01 19:15:31.164  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:34.166  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 57.6
      2024-03-01 19:15:37.164  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:40.165  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:43.168  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:45.003  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: --- Neuer Zyklus ---
      2024-03-01 19:15:45.003  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Nachbefüllung_Hauptzisterne: Tank Level:
      2024-03-01 19:15:46.168  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      2024-03-01 19:15:49.170  - info: javascript.0 (19086) script.js.Wassertechnik.Hauptzisterne.Füllstand_Hauptzisterne: Datenpunkt erfolgreich aktualisiert mit Wert: 56.7
      iob diag has finished.
        paul53 @keineAhnungvonProgrmieren last edited by paul53
        @keineahnungvonprogrmieren sagte: scheinen aber alle adapter zu laufen
        Alle 5! Admin-Instanzen sind deaktiviert.
        iob start admin.0
          Homoran Global Moderator Administrators @keineAhnungvonProgrmieren last edited by Homoran
          @keineahnungvonprogrmieren sagte in Problem nach update Admin V6.13.16 kein zugriff mehr auf Gui:
          Updatestau!
          warum 5x admin und keiner läuft?
            keineAhnungvonProgrmieren @paul53 last edited by
            geht jetzt wieder Danke
            wird der nicht automatisch nach dem update neu gestartet?
              doch!
              aber vielleicht gab's einen Fehler, deswegen die Frage
              @homoran sagte in Problem nach update Admin V6.13.16 kein zugriff mehr auf Gui:
              warum 5x admin
              und alle auf port 8081.
              Kein Wunder dass es da zu einem (oder 5) Fehler kommt
                keineAhnungvonProgrmieren @Homoran last edited by
                Hatte eigentlich nur einen Admin adapter, habe den Adapter über die Gui aktualisert, danach ging nix mehr, habe dann etwas herum probiert. evtl da was zusätzlich installiert.
                Bin aber noch Anfänger evtl habe ich da auch was flasch gemacht
                  @keineahnungvonprogrmieren dann lösch jetzt admin.1-4.
                  sonst knallt's bald wieder
                    @homoran done
                    vielen Dank für die schnelle Hilfe
                      Thomas Braun Most Active @keineAhnungvonProgrmieren last edited by
                      Bring die Kiste auf Stand...
                      iob stop
                      sudo apt update
                      sudo apt upgrade
                      sudo reboot
                      1.0k
