    4. nut-monitor.service entfernen
      Rushmed Most Active last edited by
      in meine iob diag finde ich Folgendes:
      *** FAILED SERVICES ***
        UNIT                LOAD   ACTIVE SUB    DESCRIPTION
      * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
      1 loaded units listed.
      Wenn ich versuche zu deinstallieren kommt:
      pi@Smartazamba:~ $ sudo apt-get remove nut-monitor
      Reading package lists... Done
      Building dependency tree... Done
      Package 'nut-monitor' is not installed, so not removed
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Wie kann ich den nut-monitor.service, bzw. die Meldung loswerden?
        Thomas Braun Most Active @Rushmed last edited by
        @rushmed sagte in nut-monitor.service entfernen:
        nut-monitor
        sudo systemctl hide nut-monitor.service
          Rushmed Most Active @Thomas Braun last edited by Rushmed
          @thomas-braun Das hat leider nicht geklappt:
          pi@Smartazamba:~ $ sudo systemctl hide nut-monitor.service
          Unknown command verb hide.
          und
          pi@Smartazamba:~ $ systemctl status nut-monitor.service
          × nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
               Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; preset: enabled)
               Active: failed (Result: exit-code) since Fri 2024-03-01 19:29:19 CET; 1h 15min ago
             Duration: 97ms
              Process: 660 ExecStart=/sbin/upsmon -F (code=exited, status=1/FAILURE)
             Main PID: 660 (code=exited, status=1/FAILURE)
                  CPU: 36ms
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: fopen /run/nut/upsmon.pid: No such file or directory
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Could not find PID file to see if previous upsmon instance is already run>
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Using power down flag file /etc/killpower
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Network UPS Tools upsmon 2.8.0
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Fatal error: insufficient power configured!
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Sum of power values........: 0
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Minimum value (MINSUPPLIES): 1
          Mar 01 19:29:19 Smartazamba nut-monitor[660]: Edit your upsmon.conf and change the values.
          Mar 01 19:29:19 Smartazamba systemd[1]: nut-monitor.service: Main process exited, code=exited, status=1/FAILURE
          Mar 01 19:29:19 Smartazamba systemd[1]: nut-monitor.service: Failed with result 'exit-code'.
          lines 1-18/18 (END)
            @rushmed
            Sorry, mein Fehler.
            sudo systemctl mask nut-monitor.service
              @thomas-braun Danke, das hat geklappt.
              81.0k
              linux nut service
