    4. ESPHome frage zu Logs
      tourer4778 last edited by
      Hallo, ich habe vor kurzem mein Iobroker neu aufgesetzt und habe ein update von Esphome gemacht. Vermutlich seit dem, finde ich in den Log´s meiner ESP´s neue Zeilen, mit denen ich nichts anfangen kann.
      Bei einem zum Beispiel :
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:96.50.1 [0x454d48]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:96.1.0 [0x0a01454d480000bed575]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:1.8.0 [0x000000000448b783]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:2.8.0 [0x0000000000145b04]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:36.7.0 [0x0000005d]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:56.7.0 [0x00000540]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:76.7.0 [0x000000f1]
      [05:59:00][D][sml:084]:   (0a01454d480000bed575) 1-0:16.7.0 [0x0000068e]
      [05:59:00][W][component:214]: Component sml took a long time for an operation (0.09 s).
      [05:59:00][W][component:215]: Components should block for at most 20-30ms.
      [05:59:01][D][sensor:093]: 'evu_import_180': Sending state 7187.44385 kWh with 4 decimals of accuracy
      [05:59:01][D][sensor:093]: 'evu_export_280': Sending state 133.40199 kWh with 4 decimals of accuracy
      [05:59:01][D][sensor:093]: 'emh_leistung': Sending state 1681.00000 W with 0 decimals of accuracy
      [05:59:01][D][sml:078]: OBIS info:
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:96.50.1 [0x454d48]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:96.1.0 [0x0a01454d480000bed575]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:1.8.0 [0x000000000448b788]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:2.8.0 [0x0000000000145b04]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:36.7.0 [0x0000005d]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:56.7.0 [0x00000544]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:76.7.0 [0x000000f0]
      [05:59:01][D][sml:084]:   (0a01454d480000bed575) 1-0:16.7.0 [0x00000691]
      [05:59:01][W][component:214]: Component sml took a long time for an operation (0.09 s).
      [05:59:01][W][component:215]: Components should block for at most 20-30ms.
      [05:59:02][D][sensor:093]: 'evu_import_180': Sending state 7187.44482 kWh with 4 decimals of accuracy
      [05:59:02][D][sensor:093]: 'evu_export_280': Sending state 133.40199 kWh with 4 decimals of accuracy
      [05:59:02][D][sensor:093]: 'emh_leistung': Sending state 1704.00000 W with 0 decimals of accuracy
      [05:59:02][D][sml:078]: OBIS info:
      esphome:
      esp8266:
       board: d1_mini
      wifi:
       ssid: !secret wifi_ssid
       password: !secret wifi_password
      logger:
      api:
      ota:
      web_server:
       port: 80
      status_led:
       pin:
         number: D4
         inverted: true
      uart:
       - id: uart_bus
         tx_pin: D2  # Gelb
         rx_pin: D1  # Weiß
         baud_rate: 9600
         rx_buffer_size: 2048
         data_bits: 8
         stop_bits: 1
         parity: NONE
      sml:
      - id: sml_emh
        uart_id: uart_bus
      sensor:
       - platform: wifi_signal
         name: "WiFi Signal Sensor"
         update_interval: 30s
       - platform: uptime
         update_interval: 10s
       - platform: sml
         sml_id: sml_emh
         obis_code: "1-0:16.7.0"
         filters:
          - multiply: 1
         unit_of_measurement: W
         state_class: measurement
         device_class: power
       - platform: sml
         sml_id: sml_emh
         obis_code: "1-0:1.8.0"
         unit_of_measurement: kWh
         state_class: total_increasing
         device_class: energy
         filters:
          - multiply: 0.0001
         accuracy_decimals: 4
         force_update: true
       - platform: sml
         sml_id: sml_emh
         obis_code: "1-0:2.8.0"
         filters:
          - multiply: 0.0001
         force_update: true
      switch:
      # Restart
       - platform: restart
      Weiß jemand, woran das liegen könnte ?
        MCU @tourer4778 last edited by MCU
        @tourer4778 Man muss den logger level angeben?
        logger:
          level: WARNING
        DEBUG: Detaillierte Debug-Informationen
        INFO: Allgemeine Informationen
        WARNING: Warnungen
        ERROR: Fehler
        logger: -> Standard -> INFO
          tourer4778 last edited by tourer4778
          @mcu
          Danke und du bist sicher, diese beiden Zeilen kommen deswegen? Die waren füher nicht da.
            @tourer4778 Ich dachte es geht um das ganze LOG. Welche 2 Zeilen sind denn neu?
              tourer4778 @MCU last edited by
              @mcu
              [20:28:08][W][component:214]: Component sml took a long time for an operation (0.10 s).
              [20:28:08][W][component:215]: Components should block for at most 20-30ms.
              Die ander sind für mich in Ordnung
                @tourer4778 Kommunikationsproblem?
                sml Komponente brauchte länger als normal vorgesehen (20-30ms) -> 0.1s
                Hängt also mit dem Energiemesser emh zusammen? Warum? -> keine Ahnung.
                Kommen diese Meldungen denn öfter?
                  @mcu
                  Ja, alle 1 - 2 Sekunden ...
                  Wie gesagt, vor dem update war noch alle in Ornung, zumindest ist es mir nicht aufgefallen.
                    @tourer4778 Kann Dir da leider nicht weiter helfen.
                    Du kannst ja einmal zurückgehen und es überprüfen. Ansonsten in github zum Adapter selbst mal das Anliegen schildern.
                    https://github.com/DrozmotiX/ioBroker.esphome/issues
                      @mcu
                      Okay, danke für die Hilfe
