    4. Gelöst ESPHome (kann gelöscht werden)
    • TbsJah
      TbsJah last edited by TbsJah
      Scheinbar bin ich zu blöd oder unwissend ESPHome zu laufen zu bekommen.
      Neu aufgesetzter Rasp 5 8GB
      ESPHome wie gewohnt installiert aber bei dem Start das Dashboards erhalte ich diese Fehlermeldung
      (venv) pi@raspberrypi:~/esphome $ esphome dashboard config/
      2024-03-06 09:43:56,684 INFO Starting dashboard web server on http://0.0.0.0:6052 and configuration dir config/...
      Traceback (most recent call last):
       File "/home/pi/esphome/venv/bin/esphome", line 8, in <module>
         sys.exit(main())
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 1041, in main
         return run_esphome(sys.argv)
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 1004, in run_esphome
         return PRE_CONFIG_ACTIONS[args.command](args)
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/__main__.py", line 518, in command_dashboard
         return dashboard.start_dashboard(args)
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/dashboard.py", line 129, in start_dashboard
         asyncio.run(async_start(args))
       File "/usr/lib/python3.11/asyncio/runners.py", line 190, in run
         return runner.run(main)
       File "/usr/lib/python3.11/asyncio/runners.py", line 118, in run
         return self._loop.run_until_complete(task)
       File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
         return future.result()
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/dashboard.py", line 150, in async_start
         await dashboard.async_run()
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/core.py", line 104, in async_run
         await self.entries.async_update_entries()
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 144, in async_update_entries
         await self._async_update_entries()
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 163, in _async_update_entries
         path_to_cache_key = await self._loop.run_in_executor(
       File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
         result = self.fn(*self.args, **self.kwargs)
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/dashboard/entries.py", line 220, in _get_path_to_cache_key
         for file in util.list_yaml_files([self._config_dir]):
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/util.py", line 266, in list_yaml_files
         [os.path.join(folder, p) for folder in folders for p in os.listdir(folder)]
       File "/home/pi/esphome/venv/lib/python3.11/site-packages/esphome/util.py", line 266, in <listcomp>
      FileNotFoundError: [Errno 2] No such file or directory: 'config/'
      Ich check es nicht - vielleicht habt ihr eine Idee woran es liegen könnte
      (venv) pi@raspberrypi:~/esphome $ python3 --version
      Python 3.11.2
      (venv) pi@raspberrypi:~/esphome $ node -v
      v18.19.1
      (venv) pi@raspberrypi:~/esphome $ npm -v
      10.2.4
      (venv) pi@raspberrypi:~/esphome $ lsb_release -a
      No LSB modules are available.
      Distributor ID: Debian
      Description:    Debian GNU/Linux 12 (bookworm)
      Release:        12
      Codename:       bookworm
      (venv) pi@raspberrypi:~/esphome $ esphome version
      Version: 2024.2.2
