    4. Javascript Adapter 7.8.0 stuerzt ab
      Hawkiobroker 0 last edited by
      FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
      Plattform: docker (official image - v9.1.1)
      Betriebssystem: linux
      Architektur: x64
      CPUs: 4
      Geschwindigkeit: 1501 MHz
      Modell: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      RAM: 15.4 GB
      System-Betriebszeit: 1 T. 05:32:39
      Node.js: v18.19.1
      time: 1710096680638
      timeOffset: -60
      NPM: 10.2.4
      Adapter-Anzahl: 534
      Datenträgergröße: 7145.1 GB
      Freier Festplattenspeicher: 4743.5 GB
      Aktive Instanzen: 16
      Pfad: /opt/iobroker/
      Betriebszeit: 01:14:32
      aktiv
      • Adaptername: javascript
      • Adapterversion: 7.8.0
      • js.controller: 5.0.19
      • admin: 6.13.16
                              v.2023-10-10
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.1
      Installation:           Docker
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     1
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                              /usr/bin/node           v18.19.1
                              /usr/bin/npm            10.2.4
                              /usr/bin/npx            10.2.4
      Recommended versions are nodejs 18.19.1 and npm 10.2.4
      MEMORY:
      Mem:             16G        6.3G        2.9G        157M        7.9G         10G
      Swap:            12G        193M         11G
      Total:           28G        6.5G         14G
      Active iob-Instances:   17
      Active repo(s): stable
                              admin                   6.13.16
      ^[[B^[[BioBroker Status:        iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobrokerSchozach01                       -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : iobrokerSchozach01                       -  enabled, port: 8082, bind: 0.0.0.0, run as: iobrokerhawk
      Objects:                16473
      States:                 13760
      Size of iob-Database:
      304M    /opt/iobroker/iobroker-data/objects.jsonl
      9.0M    /opt/iobroker/iobroker-data/objects.json.migrated
      9.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      12M     /opt/iobroker/iobroker-data/states.jsonl
      1.3M    /opt/iobroker/iobroker-data/states.json.migrated
      1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Thomas Braun Most Active @Hawkiobroker 0 last edited by
        @hawkiobroker-0 sagte in Javascript Adapter 7.8.0 stuerzt ab:
        Da hast du dir offenbar ein Skript falsch zusammen gebaut.
        H 1 Reply Last reply Reply Quote 2
          Hawkiobroker 0 @Thomas Braun last edited by
          @thomas-braun : ich habe alle Skripte deaktiviert. Trotzdem kommt es zum Absturz.
            Schau ins Log.
            Oder in die Langfassung von
            iob diag
              Homoran Global Moderator Administrators @Hawkiobroker 0 last edited by
              hast du mal die Instanz neu gestartet. Möglicherweise können da irgendwelche timeouts nicht mehr gestoppt werden o.ä.
                Hawkiobroker 0 @Homoran last edited by
                @homoran mehrfach Instanz neu gestartet. Auch andere Instanzen/ Adapter deaktiviert. Bei Aktivierung von Javascript immer dasselbe verhalt: Absturz.
                  Schau ins Log...
                    @thomas-braun Danke fuer den Hinweis. Das habe ich mir angeschaut. Ich bin bei weitem kein Experte und kann da nichts erkennen. Irgend eine Idee?
                      Ich auch nicht. Scheint geheim zu sein.
                        @homoran Nur zur Vollstaendigkeit: Auch iobroker und den Synology Server habe ich beim troubleshooting mehrfach neu gestartet.
                          @thomas-braun Na dann trotzdem Danke fuer die Muehe.
                            @hawkiobroker-0
                            Poste das geheime Log halt, dann kann man da vielleicht auch was sehen.
                            Alternativ die Langfassung von
                            iob diag
                            halt.
                              @thomas-braun wie gesagt, ich bin kein Profi. In meinem orginaeren Post habe ich folgenden Log-Ausschitt mitgeliefert.
                              Was waere noch hilfreich (ausser der Langversion von iob diag.
                              DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
                              • DJMarc75
                                DJMarc75 @Hawkiobroker 0 last edited by
                                nur diese Ausgabe in der Langfassung.
                                Ist doch kein Hexenwerk.
                                In der Konsolse
                                iob diag
                                eingeben und dann einfach alles in Codetags hier posten, dann kann man da besser helfen 😉
                                  Was ist das für ein Log?
                                  Und als Screenshot kann man damit auch nix anfangen.
                                    Hawkiobroker 0 @DJMarc75 last edited by
                                    @djmarc75 hier ist das Log aus iobroker und der output aus iob diag. Beides habe ich erstellt nach einem iobroker Neustart (davor javascript instance ausgeschaltet) und danach javascript Instanz wieder aktiviert.
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                    Hardware Vendor : Synology
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Docker          : v9.1.1
                                    Virtualization  : Docker
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    Systemuptime and Load:
                                     20:22:29 up 2 days,  6:03,  0 user,  load average: 3.04, 1.87, 1.65
                                    CPU threads: 4
                                    *** Time and Time Zones ***
                                    Mon Mar 11 19:22:29 UTC 2024
                                    Mon Mar 11 20:22:29 CET 2024
                                    CET +0100
                                    Etc/UTC
                                    *** User and Groups ***
                                    root
                                    *** X-Server-Setup ***
                                    X-Server:       false
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:             16G        8.8G        1.8G        151M        6.6G        7.9G
                                    Swap:            12G        351M         11G
                                    Total:           28G        9.1G         13G
                                            15854 M total memory
                                             8359 M used memory
                                             9125 M active memory
                                             3649 M inactive memory
                                             1681 M free memory
                                               39 M buffer memory
                                             6246 M swap cache
                                            11563 M total swap
                                              334 M used swap
                                            11229 M free swap
                                    *** FILESYSTEM ***
                                    Filesystem             Type   Size  Used Avail Use% Mounted on
                                    /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /
                                    tmpfs                  tmpfs   64M     0   64M   0% /dev
                                    tmpfs                  tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
                                    shm                    tmpfs   64M     0   64M   0% /dev/shm
                                    /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /opt/iobroker
                                    /dev/mapper/cachedev_0 btrfs  7.0T  2.4T  4.7T  34% /etc/hosts
                                    sudo: unable to resolve host iobrokerSchozach01: Name or service not known
                                    [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                    [Sat Mar  9 14:19:51 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                    [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                    [Sat Mar  9 14:19:53 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                    [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): couldn't mount as ext3 due to featur
                                    [Sat Mar  9 14:19:53 2024] EXT4-fs (loop0): mounted filesystem with ordered data
                                    [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                    [Sat Mar  9 14:19:57 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                    [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature
                                    [Sat Mar  9 14:19:58 2024] EXT4-fs (md0): mounted filesystem with ordered data m
                                    [Sat Mar  9 14:20:25 2024] EXT4-fs (loop0): mounted filesystem with ordered data
                                    TARGET             SOURCE
                                    IONS
                                    /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/7fc7ee
                                    nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,s
                                    606484219300d6f0f94a804c3a4ccf9de8fa57950133361b70e104e
                                    |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobrokerSchozach01]
                                    |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                    0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/resolv.conf
                                    |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                    0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hostname
                                    `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/b7031f18c8ab
                                    0577f801f8ba9fc9c72e03eb707055b3233e3162eacd3d52/hosts
                                    /var:
                                    34M     /var/
                                    32M     /var/lib
                                    19M     /var/lib/apt/lists
                                    19M     /var/lib/apt
                                    13M     /var/lib/dpkg
                                    /opt/iobroker/backups:
                                    14G     /opt/iobroker/backups/
                                    0       /opt/iobroker/backups/redistmp
                                    /opt/iobroker/iobroker-data:
                                    16G     /opt/iobroker/iobroker-data/
                                    15G     /opt/iobroker/iobroker-data/history
                                    295M    /opt/iobroker/iobroker-data/files
                                    97M     /opt/iobroker/iobroker-data/backup-objects
                                    89M     /opt/iobroker/iobroker-data/files/echarts.admin
                                    130M    /opt/iobroker/iobroker-data/objects.jsonl
                                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7
                                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.
                                    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.m
                                    USB-Devices by-id:
                                    USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always
                                    *** NodeJS-Installation ***
                                    /usr/bin/npm            10.2.4
                                    /usr/bin/npx            10.2.4
                                    nodejs:
                                      Installed: 18.19.1-1nodesource1
                                      Candidate: 18.19.1-1nodesource1
                                      Version table:
                                     *** 18.19.1-1nodesource1 1001
                                           1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                            100 /var/lib/dpkg/status
                                         18.19.0+dfsg-6~deb12u1 500
                                            500 http://deb.debian.org/debian-security bookworm-security/main amd64 P
                                         18.19.0-1nodesource1 1001
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0+dfsg1-1 500
                                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  5.0.19
                                    admin:          6.13.16
                                    javascript:     7.8.0
                                    Adapters from github:   1
                                    Adapter State
                                    n as: admin
                                    + system.adapter.backitup.0               : backitup              : iobrokerScho
                                    + system.adapter.bydhvs.0                 : bydhvs                : iobrokerScho
                                    + system.adapter.daikin.1                 : daikin                : iobrokerScho
                                    + system.adapter.daikin.2                 : daikin                : iobrokerScho
                                    + system.adapter.daikin.3                 : daikin                : iobrokerScho
                                      system.adapter.daswetter.1              : daswetter             : iobrokerScho
                                      system.adapter.discovery.0              : discovery             : iobrokerScho
                                      system.adapter.echarts.0                : echarts               : iobrokerScho
                                    + system.adapter.email.0                  : email                 : iobrokerScho
                                      system.adapter.flot.0                   : flot                  : iobrokerScho
                                      system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobrokerScho
                                    + system.adapter.fronius.0                : fronius               : iobrokerScho
                                      system.adapter.gruenbeck.0              : gruenbeck             : iobrokerScho
                                    + system.adapter.history.0                : history               : iobrokerScho
                                    + system.adapter.hmip.0                   : hmip                  : iobrokerScho
                                      system.adapter.javascript.0             : javascript            : iobrokerScho
                                      system.adapter.javascript.1             : javascript            : iobrokerScho
                                    + system.adapter.modbus.0                 : modbus                : iobrokerScho
                                    + system.adapter.modbus.1                 : modbus                : iobrokerScho
                                    + system.adapter.modbus.2                 : modbus                : iobrokerScho
                                      system.adapter.modbus.3                 : modbus                : iobrokerScho
                                    + system.adapter.modbus.4                 : modbus                : iobrokerScho
                                      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobrokerScho
                                      system.adapter.parser.0                 : parser                : iobrokerScho
                                      system.adapter.porsche.0                : porsche               : iobrokerScho
                                      system.adapter.pvforecast.0             : pvforecast            : iobrokerScho
                                    + system.adapter.sonoff.0                 : sonoff                : iobrokerScho
                                      system.adapter.statistics.0             : statistics            : iobrokerScho
                                      system.adapter.weatherunderground.0     : weatherunderground    : iobrokerScho
                                    iobrokerhawk
                                      system.adapter.wmswebcontrol.0          : wmswebcontrol         : iobrokerScho
                                    + instance is alive
                                    n as: admin
                                    iobrokerhawk
                                    ioBroker-Repositories
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
                                    Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
                                    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                                    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                                    Adapter    "email"        : 1.2.2    , installed 1.2.2
                                    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
                                    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                                    Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
                                    Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                                    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                    Adapter    "parser"       : 2.1.0    , installed 2.1.0
                                    Adapter    "porsche"      : 0.0.3    , installed 0.2.0
                                    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                                    Adapter    "wmswebcontrol": 0.0.5    , installed 0.0.5
                                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                    Objects and States
                                    Objects:        16479
                                    States:         13775
                                    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                    Reading package lists...
                                    Pending Updates: 1
                                    *** Listening Ports ***
                                    Proto Recv-Q Send-Q Local Address           Foreign Address         State
                                    tcp        0      0 127.0.0.1:512           0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:161           0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:6690            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.5:49160     0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:5000            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:5001            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:9900            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:9901            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:5357            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.5:50001     0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:50002           0.0.0.0:*               LISTEN
                                    tcp        0      0 192.168.178.5:49170     0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:915           0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:33300         0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:725             0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:5432          0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN
                                    tcp        0      0 127.0.0.1:18617         0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:6011            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:6012            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:6013            0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
                                    tcp        0      0 0.0.0.0:6014            0.0.0.0:*               LISTEN
                                    tcp6       0      0 :::3264                 :::*                    LISTEN
                                    tcp6       0      0 :::3265                 :::*                    LISTEN
                                    tcp6       0      0 :::6690                 :::*                    LISTEN
                                    tcp6       0      0 :::5000                 :::*                    LISTEN
                                    tcp6       0      0 :::5001                 :::*                    LISTEN
                                    tcp6       0      0 :::139                  :::*                    LISTEN
                                    tcp6       0      0 :::9900                 :::*                    LISTEN
                                    tcp6       0      0 :::9901                 :::*                    LISTEN
                                    tcp6       0      0 :::5357                 :::*                    LISTEN
                                    tcp6       0      0 :::1935                 :::*                    LISTEN
                                    tcp6       0      0 :::80                   :::*                    LISTEN
                                    tcp6       0      0 :::8081                 :::*                    LISTEN
                                    tcp6       0      0 :::5201                 :::*                    LISTEN
                                    tcp6       0      0 :::8082                 :::*                    LISTEN
                                    tcp6       0      0 :::725                  :::*                    LISTEN
                                    tcp6       0      0 :::443                  :::*                    LISTEN
                                    tcp6       0      0 :::3261                 :::*                    LISTEN
                                    tcp6       0      0 :::445                  :::*                    LISTEN
                                    tcp6       0      0 :::3263                 :::*                    LISTEN
                                    udp        0      0 0.0.0.0:35136           0.0.0.0:*
                                    udp        0      0 127.0.0.1:60185         0.0.0.0:*
                                    udp        0      0 0.0.0.0:19996           0.0.0.0:*
                                    udp        0      0 0.0.0.0:19997           0.0.0.0:*
                                    udp        0      0 0.0.0.0:19998           0.0.0.0:*
                                    udp        0      0 0.0.0.0:3702            0.0.0.0:*
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*
                                    udp        0      0 192.168.178.5:55900     0.0.0.0:*
                                    udp        0      0 192.168.178.5:55901     0.0.0.0:*
                                    udp        0      0 192.168.178.5:55902     0.0.0.0:*
                                    udp        0      0 127.0.0.1:47750         0.0.0.0:*
                                    udp        0      0 172.17.0.1:123          0.0.0.0:*
                                    udp        0      0 192.168.178.10:123      0.0.0.0:*
                                    udp        0      0 192.168.178.5:123       0.0.0.0:*
                                    udp        0      0 127.0.0.1:123           0.0.0.0:*
                                    udp        0      0 0.0.0.0:123             0.0.0.0:*
                                    udp        0      0 192.168.178.255:137     0.0.0.0:*
                                    udp        0      0 192.168.178.5:137       0.0.0.0:*
                                    udp        0      0 192.168.178.10:137      0.0.0.0:*
                                    udp        0      0 0.0.0.0:137             0.0.0.0:*
                                    udp        0      0 192.168.178.255:138     0.0.0.0:*
                                    udp        0      0 192.168.178.5:138       0.0.0.0:*
                                    udp        0      0 192.168.178.10:138      0.0.0.0:*
                                    udp        0      0 0.0.0.0:138             0.0.0.0:*
                                    udp        0      0 127.0.0.1:161           0.0.0.0:*
                                    udp        0      0 127.0.0.1:58098         0.0.0.0:*
                                    udp        0      0 0.0.0.0:59087           0.0.0.0:*
                                    udp        0      0 0.0.0.0:9997            0.0.0.0:*
                                    udp        0      0 0.0.0.0:9998            0.0.0.0:*
                                    udp        0      0 0.0.0.0:9999            0.0.0.0:*
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*
                                    udp6       0      0 :::3702                 :::*
                                    udp6       0      0 :::5353                 :::*
                                    udp6       0      0 :::38969                :::*
                                    udp6       0      0 2003:c9:6f14:6200:2:123 :::*
                                    udp6       0      0 fe80::6006:26ff:fea:123 :::*
                                    udp6       0      0 fe80::48d5:c1ff:fec:123 :::*
                                    udp6       0      0 fe80::10c3:75ff:fe5:123 :::*
                                    udp6       0      0 fe80::42:97ff:fe5f::123 :::*
                                    udp6       0      0 fe80::211:32ff:fea6:123 :::*
                                    udp6       0      0 ::1:123                 :::*
                                    udp6       0      0 :::123                  :::*
                                    2024-03-11 20:23:25.222  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    2024-03-11 20:23:25.222  - silly: javascript.0 (1530)   creating new file with v
                                    2024-03-11 20:23:25.240  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    true
                                    2024-03-11 20:23:25.241  - silly: javascript.0 (1530)   creating new file with v
                                    2024-03-11 20:23:25.241  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    e
                                    2024-03-11 20:23:25.245  - debug: javascript.0 (1530) Loaded TypeScript definiti
                                    types/request/index.d.ts"]
                                    2024-03-11 20:23:25.245  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    2024-03-11 20:23:25.245  - silly: javascript.0 (1530)   creating new file with v
                                    2024-03-11 20:23:25.246  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    2024-03-11 20:23:25.246  - silly: javascript.0 (1530)   creating new file with v
                                    2024-03-11 20:23:25.247  - silly: javascript.0 (1530) writeFile(filename: "node_
                                    2024-03-11 20:23:25.247  - silly: javascript.0 (1530)   creating new file with v
                                    2024-03-11 20:23:25.301  - silly: javascript.0 (1530) redis psubscribe cfg.o.*
                                    2024-03-11 20:23:25.306  - silly: javascript.0 (1530) States system redis pmessa
                                    :{"val":"silly","ack":true,"ts":1710185005251,"q":0,"from":"system.adapter.javas
                                    2024-03-11 20:23:25.410  - info: javascript.0 (1530) requesting all states
                                    2024-03-11 20:23:25.411  - info: javascript.0 (1530) requesting all objects
                                    2024-03-11 20:23:49.823  - silly: javascript.0 (1530) Objects user redis pmessag
                                    mmon":{"name":"Plugin States"},"native":{},"_id":"system.host.iobrokerSchozach01
                                    em.user.admin","ownerGroup":"system.group.administrator"}}
                                    2024-03-11 20:23:49.825  - silly: javascript.0 (1530) Objects user redis pmessag
                                    te","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":tru
                                    sentry.enabled","acl":{"object":1636,"state":1636,"file":1632,"owner":"system.us
                                      Hawkiobroker 0 @Hawkiobroker 0 last edited by
                                      @hawkiobroker-0 und hier der iobroker log Auszug von javascript nach Aktivierung.
                                      240311 iobroker javascript log.txt
                                      Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                                        @hawkiobroker-0
                                        2024-03-11 20:41:05.745	error	Caught by controller[0]: FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
                                        Da dürfte ein Skript schief sein.
                                        • DJMarc75
                                          @hawkiobroker-0
                                          die ganzen SILLY musste mal weg machen, das macht Dein System platt.
                                          Stell das bitte auf mindestens INFO um 😉
                                            @thomas-braun Danke! Warum habe ich Probleme, wenn ich alle Skripte deaktiviert habe?
                                            2629
