    4. Bekomme öfters "warn get state error: Connection is closed"
    • Chris76e
      Chris76e last edited by
      was beudetet die Warnung? Bekomme das sehr oft, meistens bei ical instanzen.
      iceroad.0	2024-03-11 18:00:52.080	warn	get state error: Connection is closed.
      iceroad.0	2024-03-11 18:00:51.576	info	Terminated (NO_ERROR): Without reason
      iceroad.0	2024-03-11 18:00:50.814	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.iceroad, node: v18.19.0, js-controller: 5.0.19
      ical.4	2024-03-11 18:34:09.387	warn	get state error: Connection is closed.
      ical.4	2024-03-11 18:34:08.880	info	Terminated (NO_ERROR): Without reason
      ical.4	2024-03-11 18:34:03.719	info	processing URL: Musikverein https://calendar
      ical.4	2024-03-11 18:34:03.635	info	processing URL: Abfall https://calendar.google.
      ical.4	2024-03-11 18:34:03.469	info	processing URL: Christian https://calendar
      ical.4	2024-03-11 18:34:03.373	info	processing URL: Geburtstage https://calendar.google.com
      ical.4	2024-03-11 18:34:03.189	info	processing URL: Feiertage https://calendar.google.com/
      ical.4	2024-03-11 18:34:02.526	info	starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
      ical.7	2024-03-11 18:00:25.369	warn	get state error: Connection is closed.
      ical.7	2024-03-11 18:00:24.801	info	Terminated (NO_ERROR): Without reason
      ical.7	2024-03-11 18:00:19.659	info	processing URL: calendar1 https:/
      ical.7	2024-03-11 18:00:19.113	info	starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
      • Codierknecht
        Codierknecht Developer Most Active last edited by Codierknecht
        Ich bringe den Beitrag mal wieder nach vorne.
        Tritt bei mir ebenfalls regelmäßig auf:
        ical.0    2024-05-03 06:02:06.328	warn	get state error: Connection is closed.
        ical.1    2024-05-03 00:04:07.050	warn	get state error: Connection is closed.
        Da wird wohl versucht etwas zu lesen, nachdem die Verbindung zur DB bereits geschlossen wurde.
        Das passende Issue dazu hat @wendy2702 ja bereits erzeugt:
        https://github.com/iobroker-community-adapters/ioBroker.ical/issues/630
        wendy2702 created this issue in iobroker-community-adapters/ioBroker.ical
        open get state error: Connection is closed #630
