    4. [gelöst] Discovery-Adapter findet keine Services
    • G
      GerdSo last edited by
      durch den c't-Artikel bin ich auf den discovery-Adapter gestoßen und wollte den ausprobieren. Er findet zwar Geräte aber bei der Servicesuche steigt er aus.
      Auszug aus dem Log
      host.DauerlaufLaptop	2017-08-25 09:22:08.425	info	Restart adapter system.adapter.discovery.0 because enabled
      host.DauerlaufLaptop	2017-08-25 09:22:08.409	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
      discovery.0	2017-08-25 09:22:08.191	info	terminating
      discovery.0	2017-08-25 09:22:07.769	warn	Mihome err: timeout
      discovery.0	2017-08-25 09:22:07.285	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      discovery.0	2017-08-25 09:22:07.285	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
      discovery.0	2017-08-25 09:22:07.285	error	at _handle.lookup (dgram.js:226:7)
      discovery.0	2017-08-25 09:22:07.285	error	at startListening (dgram.js:121:10)
      discovery.0	2017-08-25 09:22:07.285	error	at Socket.emit (events.js:185:7)
      discovery.0	2017-08-25 09:22:07.285	error	at emitNone (events.js:91:20)
      discovery.0	2017-08-25 09:22:07.285	error	at Socket.g (events.js:292:16)
      discovery.0	2017-08-25 09:22:07.285	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:369:19)
      discovery.0	2017-08-25 09:22:07.285	error	at Socket.addMembership (dgram.js:506:11)
      discovery.0	2017-08-25 09:22:07.285	error	at exports._errnoException (util.js:1020:11)
      discovery.0	2017-08-25 09:22:07.285	error	Error: addMembership EHOSTUNREACH
      discovery.0	2017-08-25 09:22:07.269	error	uncaught exception: addMembership EHOSTUNREACH
      discovery.0	2017-08-25 09:22:05.019	info	Found 8 addresses
      discovery.0	2017-08-25 09:22:05.003	info	Done discovering ping devices. 2 packages received
      discovery.0	2017-08-25 09:21:22.394	info	Done discovering upnp devices. 4 packages received
      discovery.0	2017-08-25 09:21:21.925	info	Done discovering mdns devices. 23 packages received
      discovery.0	2017-08-25 09:21:07.377	info	Discovering UPnP devices...
      discovery.0	2017-08-25 09:21:06.862	info	Discovering ping devices...
      discovery.0	2017-08-25 09:21:06.846	info	Discovering mDNS devices...
      discovery.0	2017-08-25 09:20:19.487	info	starting. Version 0.4.4 in C:/Program Files/ioBroker/node_modules/iobroker.discovery, node: v6.11.2
      Ich habe dabei folgende Einstellungen aktiv:
      • Folgende Methoden benutzen:
      [x] mDNS
      [x] Ping
      [ ] Serial
      [ ] TR-064(Fritzbox)
      [x] UPnP
      [ ] WiFi Mi-Light
      • apollon77
        apollon77 last edited by
        Habs mal verschoben weil es ja nix mit vis zu tun hat …
        Versuch bitte mal die Version vom Github (0.4.5)
        • G
          @apollon77:
          Versuch bitte mal die Version vom Github (0.4.5) `
          Danke fürs verschieben, da wollte ich es auch reinstellen.
          Update hat leider nichts gebracht
          host.DauerlaufLaptop	2017-08-25 10:05:09.453	info	Restart adapter system.adapter.discovery.0 because enabled
          host.DauerlaufLaptop	2017-08-25 10:05:09.453	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
          discovery.0	2017-08-25 10:05:08.921	warn	Mihome err: timeout
          discovery.0	2017-08-25 10:05:08.484	error	at process._tickCallback (internal/process/next_tick.js:104:9)
          discovery.0	2017-08-25 10:05:08.484	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
          discovery.0	2017-08-25 10:05:08.484	error	at _handle.lookup (dgram.js:226:7)
          discovery.0	2017-08-25 10:05:08.484	error	at startListening (dgram.js:121:10)
          discovery.0	2017-08-25 10:05:08.484	error	at Socket.emit (events.js:185:7)
          discovery.0	2017-08-25 10:05:08.484	error	at emitNone (events.js:91:20)
          discovery.0	2017-08-25 10:05:08.484	error	at Socket.g (events.js:292:16)
          discovery.0	2017-08-25 10:05:08.484	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:369:19)
          discovery.0	2017-08-25 10:05:08.484	error	at Socket.addMembership (dgram.js:506:11)
          discovery.0	2017-08-25 10:05:08.484	error	at exports._errnoException (util.js:1020:11)
          discovery.0	2017-08-25 10:05:08.484	error	Error: addMembership EHOSTUNREACH
          discovery.0	2017-08-25 10:05:08.468	error	uncaught exception: addMembership EHOSTUNREACH
          discovery.0	2017-08-25 10:05:07.781	info	Found 11 addresses
          discovery.0	2017-08-25 10:05:07.750	info	Done discovering ping devices. 7 packages received
          host.DauerlaufLaptop	2017-08-25 10:05:00.812	info	instance system.adapter.yr.0 started with pid 9020
          discovery.0	2017-08-25 10:04:16.624	info	Done discovering upnp devices. 4 packages received
          discovery.0	2017-08-25 10:04:15.609	info	Done discovering mdns devices. 12 packages received
          discovery.0	2017-08-25 10:04:01.359	info	Discovering UPnP devices...
          discovery.0	2017-08-25 10:04:00.593	info	Discovering ping devices...
          discovery.0	2017-08-25 10:04:00.578	info	Discovering mDNS devices...
          discovery.0	2017-08-25 10:03:50.703	info	starting. Version 0.4.5 in C:/Program Files/ioBroker/node_modules/iobroker.discovery, node: v6.11.2
          • apollon77
            Kannst du Adapter bitte mal auf Debug stellen und laufen lassen und dann log schicken ?!
            • G
              @apollon77:
              Kannst du Adapter bitte mal auf Debug stellen und laufen lassen und dann log schicken ?! `
              host.DauerlaufLaptop	2017-08-25 10:26:38.410	info	instance system.adapter.discovery.0 started with pid 5016
              host.DauerlaufLaptop	2017-08-25 10:26:08.394	info	Restart adapter system.adapter.discovery.0 because enabled
              host.DauerlaufLaptop	2017-08-25 10:26:08.394	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
              discovery.0	2017-08-25 10:26:07.721	warn	Mihome err: timeout
              discovery.0	2017-08-25 10:26:07.315	error	at process._tickCallback (internal/process/next_tick.js:104:9)
              discovery.0	2017-08-25 10:26:07.315	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
              discovery.0	2017-08-25 10:26:07.315	error	at _handle.lookup (dgram.js:226:7)
              discovery.0	2017-08-25 10:26:07.315	error	at startListening (dgram.js:121:10)
              discovery.0	2017-08-25 10:26:07.315	error	at Socket.emit (events.js:185:7)
              discovery.0	2017-08-25 10:26:07.315	error	at emitNone (events.js:91:20)
              discovery.0	2017-08-25 10:26:07.315	error	at Socket.g (events.js:292:16)
              discovery.0	2017-08-25 10:26:07.315	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:369:19)
              discovery.0	2017-08-25 10:26:07.315	error	at Socket.addMembership (dgram.js:506:11)
              discovery.0	2017-08-25 10:26:07.315	error	at exports._errnoException (util.js:1020:11)
              discovery.0	2017-08-25 10:26:07.315	error	Error: addMembership EHOSTUNREACH
              discovery.0	2017-08-25 10:26:07.315	error	uncaught exception: addMembership EHOSTUNREACH
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 yamaha
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 wifilight
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 upnp
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 tr-064
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 squeezebox
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 sql
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 sonos
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 samsung
              discovery.0	2017-08-25 10:26:07.221	debug	Test 169.254.5.82 ping DETECTED!
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 ping
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 openhab
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 nut
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 musiccast
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 mihome
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 miele
              discovery.0	2017-08-25 10:26:07.205	debug	Test 169.254.5.82 megad
              discovery.0	2017-08-25 10:26:07.096	debug	Test 169.254.5.82 maxcube
              discovery.0	2017-08-25 10:26:07.096	debug	Test 169.254.5.82 lightify
              discovery.0	2017-08-25 10:26:07.096	debug	Test 169.254.5.82 lgtv
              discovery.0	2017-08-25 10:26:07.096	debug	Test 169.254.5.82 landroid
              discovery.0	2017-08-25 10:26:07.080	debug	Test 169.254.5.82 knx
              discovery.0	2017-08-25 10:26:07.080	debug	Test 169.254.5.82 influxdb
              discovery.0	2017-08-25 10:26:07.080	debug	Test 169.254.5.82 hue
              discovery.0	2017-08-25 10:26:07.080	debug	Test 169.254.5.82 hm-rpc
              discovery.0	2017-08-25 10:26:06.799	debug	Test 169.254.5.82 fronius
              discovery.0	2017-08-25 10:26:06.799	debug	Test 169.254.5.82 firetv
              discovery.0	2017-08-25 10:26:06.799	debug	Test 169.254.5.82 daikin
              discovery.0	2017-08-25 10:26:06.799	debug	Test 169.254.5.82 chromecast
              discovery.0	2017-08-25 10:26:06.799	debug	Test 169.254.5.82 broadlink
              discovery.0	2017-08-25 10:26:05.268	info	Found 14 addresses
              discovery.0	2017-08-25 10:26:05.236	info	Done discovering ping devices. 7 packages received
              discovery.0	2017-08-25 10:26:02.143	debug	ping: 92%, devices - 7
              discovery.0	2017-08-25 10:25:56.861	debug	ping: 85%, devices - 7
              discovery.0	2017-08-25 10:25:52.596	debug	ping: 77%, devices - 7
              discovery.0	2017-08-25 10:25:48.393	debug	ping: 69%, devices - 7
              host.DauerlaufLaptop	2017-08-25 10:25:47.409	info	instance system.adapter.yr.0 terminated with code 0 (OK)
              discovery.0	2017-08-25 10:25:43.986	debug	ping: 62%, devices - 7
              yr.0	2017-08-25 10:25:41.159	info	got weather data from yr.no
              yr.0	2017-08-25 10:25:37.205	info	starting. Version 1.0.6 in C:/Program Files/ioBroker/node_modules/iobroker.yr, node: v6.11.2
              discovery.0	2017-08-25 10:25:34.877	debug	ping: 54%, devices - 7
              discovery.0	2017-08-25 10:25:28.924	debug	ping: 46%, devices - 7
              discovery.0	2017-08-25 10:25:24.611	debug	ping: 38%, devices - 7
              discovery.0	2017-08-25 10:25:23.424	debug	main.addDevice: ip=192.168.178.46 source=ping
              discovery.0	2017-08-25 10:25:23.424	debug	found 192.168.178.46
              discovery.0	2017-08-25 10:25:21.502	debug	main.addDevice: ip=192.168.178.38 source=ping
              discovery.0	2017-08-25 10:25:21.502	debug	found 192.168.178.38
              discovery.0	2017-08-25 10:25:18.127	debug	ping: 31%, devices - 5
              discovery.0	2017-08-25 10:25:16.064	info	Done discovering upnp devices. 4 packages received
              discovery.0	2017-08-25 10:25:15.518	debug	main.addDevice: ip=192.168.178.28 source=ping
              discovery.0	2017-08-25 10:25:15.518	debug	found 192.168.178.28
              discovery.0	2017-08-25 10:25:15.518	debug	main.addDevice: ip=192.168.178.21 source=ping
              discovery.0	2017-08-25 10:25:15.518	debug	found 192.168.178.21
              discovery.0	2017-08-25 10:25:15.080	info	Done discovering mdns devices. 25 packages received
              discovery.0	2017-08-25 10:25:13.721	debug	main.addDevice: ip=192.168.178.22 source=ping
              discovery.0	2017-08-25 10:25:13.721	debug	found 192.168.178.22
              discovery.0	2017-08-25 10:25:13.127	debug	ping: 23%, devices - 2
              discovery.0	2017-08-25 10:25:11.033	debug	main.addDevice: ip=192.168.178.14 source=ping
              discovery.0	2017-08-25 10:25:11.033	debug	found 192.168.178.14
              discovery.0	2017-08-25 10:25:07.299	debug	ping: 15%, devices - 1
              discovery.0	2017-08-25 10:25:04.096	debug	ping: 8%, devices - 1
              discovery.0	2017-08-25 10:25:02.314	debug	main.addDevice: ip=192.168.178.1 source=ping
              discovery.0	2017-08-25 10:25:02.314	debug	found 192.168.178.1
              discovery.0	2017-08-25 10:25:02.314	debug	main.addDevice: ip=192.168.178.16 source=mdns
              discovery.0	2017-08-25 10:25:01.955	debug	main.addDevice: ip=192.168.178.12 source=upnp
              discovery.0	2017-08-25 10:25:01.955	debug	UPNP Answer from 192.168.178.12
              discovery.0	2017-08-25 10:25:01.611	debug	main.addDevice: ip=192.168.178.24 source=upnp
              discovery.0	2017-08-25 10:25:01.611	debug	UPNP Answer from 192.168.178.24
              discovery.0	2017-08-25 10:25:01.611	debug	main.addDevice: ip=169.254.87.120 source=mdns
              discovery.0	2017-08-25 10:25:01.596	debug	main.addDevice: ip=192.168.178.12 source=mdns
              discovery.0	2017-08-25 10:25:01.518	debug	main.addDevice: ip=192.168.178.12 source=mdns
              discovery.0	2017-08-25 10:25:01.518	debug	main.addDevice: ip=169.254.5.82 source=mdns
              discovery.0	2017-08-25 10:25:01.518	debug	main.addDevice: ip=192.168.178.16 source=upnp
              discovery.0	2017-08-25 10:25:01.518	debug	UPNP Answer from 192.168.178.16
              discovery.0	2017-08-25 10:25:01.518	debug	main.addDevice: ip=192.168.178.16 source=mdns
              discovery.0	2017-08-25 10:25:01.502	debug	main.addDevice: ip=192.168.178.16 source=mdns
              discovery.0	2017-08-25 10:25:01.502	debug	main.addDevice: ip=169.254.87.120 source=mdns
              discovery.0	2017-08-25 10:25:01.502	debug	main.addDevice: ip=169.254.5.82 source=mdns
              discovery.0	2017-08-25 10:25:01.455	debug	main.addDevice: ip=192.168.178.13 source=mdns
              discovery.0	2017-08-25 10:25:01.455	debug	main.addDevice: ip=192.168.178.1 source=upnp
              discovery.0	2017-08-25 10:25:01.455	debug	UPNP Answer from 192.168.178.1
              discovery.0	2017-08-25 10:25:01.049	info	Discovering UPnP devices...
              discovery.0	2017-08-25 10:24:59.752	debug	ping: 0%, devices - 0
              discovery.0	2017-08-25 10:24:59.689	info	Discovering ping devices...
              discovery.0	2017-08-25 10:24:59.627	info	Discovering mDNS devices...
              discovery.0	2017-08-25 10:24:59.549	debug	Received "browse" event
              host.DauerlaufLaptop	2017-08-25 10:25:00.080	info	instance system.adapter.yr.0 started with pid 2532
              discovery.0	2017-08-25 10:24:59.549	debug	inMem message messagebox.system.adapter.discovery.0 messagebox.system.adapter.discovery.0 command=browse, message=[mdns, ping, upnp], from=system.adapter.admin.0, message=[mdns, ping, upnp], id=39,
              discovery.0	2017-08-25 10:24:57.018	debug	sendTo "listMethods" to system.adapter.admin.0 from system.adapter.discovery.0
              discovery.0	2017-08-25 10:24:56.971	debug	Received "listMethods" event
              discovery.0	2017-08-25 10:24:56.955	debug	inMem message messagebox.system.adapter.discovery.0 messagebox.system.adapter.discovery.0 command=listMethods, message=null, from=system.adapter.admin.0, message=null, id=38, ack=false, time=1503649
              discovery.0	2017-08-25 10:24:53.721	info	starting. Version 0.4.5 in C:/Program Files/ioBroker/node_modules/iobroker.discovery, node: v6.11.2
              discovery.0	2017-08-25 10:24:53.643	debug	statesDB connected
              discovery.0	2017-08-25 10:24:53.564	debug	objectDB connected
              host.DauerlaufLaptop	2017-08-25 10:24:49.283	info	instance system.adapter.discovery.0 started with pid 7848
              • apollon77
                Ok, bitte nochmal versuchen (Hab blind was geändert ohne testing, schau mal …)
                Ingo F
                • G
                  @apollon77:
                  Ingo F `
                  Hallo Ingo,
                  leider noch nicht erfolgreich:
                  host.DauerlaufLaptop	2017-08-25 14:21:33.709	info	instance system.adapter.discovery.0 started with pid 14120
                  host.DauerlaufLaptop	2017-08-25 14:21:03.678	info	Restart adapter system.adapter.discovery.0 because enabled
                  host.DauerlaufLaptop	2017-08-25 14:21:03.678	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
                  discovery.0	2017-08-25 14:21:03.210	warn	Mihome err: timeout
                  discovery.0	2017-08-25 14:21:02.710	error	at process._tickCallback (internal/process/next_tick.js:104:9)
                  discovery.0	2017-08-25 14:21:02.710	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
                  discovery.0	2017-08-25 14:21:02.710	error	at _handle.lookup (dgram.js:226:7)
                  discovery.0	2017-08-25 14:21:02.710	error	at startListening (dgram.js:121:10)
                  discovery.0	2017-08-25 14:21:02.710	error	at Socket.emit (events.js:185:7)
                  discovery.0	2017-08-25 14:21:02.710	error	at emitNone (events.js:91:20)
                  discovery.0	2017-08-25 14:21:02.710	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:388:19)
                  discovery.0	2017-08-25 14:21:02.710	error	at Socket.send (dgram.js:346:8)
                  discovery.0	2017-08-25 14:21:02.710	error	at Socket._healthCheck (dgram.js:528:11)
                  discovery.0	2017-08-25 14:21:02.710	error	Error: Not running
                  discovery.0	2017-08-25 14:21:02.710	error	uncaught exception: Not running
                  discovery.0	2017-08-25 14:21:02.710	debug	Test 169.254.5.82 yamaha
                  discovery.0	2017-08-25 14:21:02.710	debug	Test 169.254.5.82 wifilight
                  discovery.0	2017-08-25 14:21:02.710	debug	Test 169.254.5.82 upnp
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 tr-064
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 squeezebox
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 sql
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 sonos
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 samsung
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 ping DETECTED!
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 openhab
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 nut
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 musiccast
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 mihome
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 miele
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 megad
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 maxcube
                  discovery.0	2017-08-25 14:21:02.694	debug	Test 169.254.5.82 lightify
                  discovery.0	2017-08-25 14:21:02.600	debug	Test 169.254.5.82 lgtv
                  discovery.0	2017-08-25 14:21:02.600	debug	Test 169.254.5.82 landroid
                  discovery.0	2017-08-25 14:21:02.600	debug	Test 169.254.5.82 knx
                  discovery.0	2017-08-25 14:21:02.600	debug	Test 169.254.5.82 influxdb
                  discovery.0	2017-08-25 14:21:02.600	debug	Test 169.254.5.82 hue
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 hm-rpc
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 fronius
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 firetv
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 daikin
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 chromecast
                  discovery.0	2017-08-25 14:21:02.585	debug	Test 169.254.5.82 broadlink
                  discovery.0	2017-08-25 14:21:02.100	info	Found 13 addresses
                  discovery.0	2017-08-25 14:21:02.085	info	Done discovering ping devices. 6 packages received
                  discovery.0	2017-08-25 14:21:00.210	debug	ping: 92%, devices - 6
                  discovery.0	2017-08-25 14:20:55.038	debug	ping: 85%, devices - 6
                  discovery.0	2017-08-25 14:20:51.381	debug	ping: 77%, devices - 6
                  discovery.0	2017-08-25 14:20:48.975	debug	ping: 69%, devices - 6
                  discovery.0	2017-08-25 14:20:44.991	debug	ping: 62%, devices - 6
                  discovery.0	2017-08-25 14:20:40.444	debug	ping: 54%, devices - 6
                  discovery.0	2017-08-25 14:20:36.006	debug	ping: 46%, devices - 6
                  discovery.0	2017-08-25 14:20:32.288	debug	ping: 38%, devices - 6
                  discovery.0	2017-08-25 14:20:28.584	debug	ping: 31%, devices - 6
                  discovery.0	2017-08-25 14:20:28.116	debug	main.addDevice: ip=192.168.178.46 source=ping
                  discovery.0	2017-08-25 14:20:28.116	debug	found 192.168.178.46
                  discovery.0	2017-08-25 14:20:25.538	debug	ping: 23%, devices - 5
                  discovery.0	2017-08-25 14:20:25.100	debug	main.addDevice: ip=192.168.178.38 source=ping
                  discovery.0	2017-08-25 14:20:25.100	debug	found 192.168.178.38
                  discovery.0	2017-08-25 14:20:25.084	info	Done discovering upnp devices. 4 packages received
                  discovery.0	2017-08-25 14:20:23.084	debug	main.addDevice: ip=192.168.178.22 source=ping
                  discovery.0	2017-08-25 14:20:23.084	debug	found 192.168.178.22
                  discovery.0	2017-08-25 14:20:23.069	info	Done discovering mdns devices. 25 packages received
                  host.DauerlaufLaptop	2017-08-25 14:20:21.521	info	instance system.adapter.yr.0 terminated with code 0 (OK)
                  Viele Grüße Gerd.
                  • apollon77
                    Aber andere Stelle 🙂
                    Retry please.
                    Irgendwie reagiert dein netzwerk böse auf UDP … wo läuft der ioBroker?
                    • G
                      @apollon77:
                      Retry please.
                      Irgendwie reagiert dein netzwerk böse auf UDP … wo läuft der ioBroker? `
                      Weiterhin nicht erfolgreich:
                      host.DauerlaufLaptop	2017-08-25 16:39:54.580	info	Restart adapter system.adapter.discovery.0 because enabled
                      host.DauerlaufLaptop	2017-08-25 16:39:54.580	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
                      discovery.0	2017-08-25 16:39:53.798	warn	Mihome err: timeout
                      discovery.0	2017-08-25 16:39:53.423	error	at process._tickCallback (internal/process/next_tick.js:104:9)
                      discovery.0	2017-08-25 16:39:53.423	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
                      discovery.0	2017-08-25 16:39:53.423	error	at _handle.lookup (dgram.js:226:7)
                      discovery.0	2017-08-25 16:39:53.423	error	at startListening (dgram.js:121:10)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket.emit (events.js:185:7)
                      discovery.0	2017-08-25 16:39:53.423	error	at emitNone (events.js:91:20)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:392:23)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket.emit (events.js:188:7)
                      discovery.0	2017-08-25 16:39:53.423	error	at emitOne (events.js:96:13)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket. (C:\Program Files\ioBroker\node_modules\iobroker.discovery\lib\tools.js:362:19)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket.close (dgram.js:422:8)
                      discovery.0	2017-08-25 16:39:53.423	error	at Socket._healthCheck (dgram.js:528:11)
                      discovery.0	2017-08-25 16:39:53.423	error	Error: Not running
                      discovery.0	2017-08-25 16:39:53.423	error	uncaught exception: Not running
                      discovery.0	2017-08-25 16:39:53.314	debug	Test 169.254.5.82 yamaha
                      discovery.0	2017-08-25 16:39:53.314	debug	Test 169.254.5.82 wifilight
                      discovery.0	2017-08-25 16:39:53.314	debug	Test 169.254.5.82 upnp
                      discovery.0	2017-08-25 16:39:53.314	debug	Test 169.254.5.82 tr-064
                      discovery.0	2017-08-25 16:39:53.314	debug	Test 169.254.5.82 squeezebox
                      discovery.0	2017-08-25 16:39:53.298	debug	Test 169.254.5.82 sql
                      discovery.0	2017-08-25 16:39:53.298	debug	Test 169.254.5.82 sonos
                      discovery.0	2017-08-25 16:39:53.298	debug	Test 169.254.5.82 samsung
                      discovery.0	2017-08-25 16:39:53.298	debug	Test 169.254.5.82 ping DETECTED!
                      discovery.0	2017-08-25 16:39:53.282	debug	Test 169.254.5.82 openhab
                      discovery.0	2017-08-25 16:39:53.282	debug	Test 169.254.5.82 nut
                      discovery.0	2017-08-25 16:39:53.282	debug	Test 169.254.5.82 musiccast
                      discovery.0	2017-08-25 16:39:53.282	debug	Test 169.254.5.82 mihome
                      discovery.0	2017-08-25 16:39:53.282	debug	Test 169.254.5.82 miele
                      discovery.0	2017-08-25 16:39:53.251	debug	Test 169.254.5.82 megad
                      discovery.0	2017-08-25 16:39:53.251	debug	Test 169.254.5.82 maxcube
                      discovery.0	2017-08-25 16:39:53.235	debug	Test 169.254.5.82 lightify
                      discovery.0	2017-08-25 16:39:53.235	debug	Test 169.254.5.82 lgtv
                      discovery.0	2017-08-25 16:39:52.704	debug	Test 169.254.5.82 landroid
                      discovery.0	2017-08-25 16:39:52.423	debug	Test 169.254.5.82 knx
                      discovery.0	2017-08-25 16:39:52.407	debug	Test 169.254.5.82 influxdb
                      discovery.0	2017-08-25 16:39:52.407	debug	Test 169.254.5.82 hue
                      discovery.0	2017-08-25 16:39:52.407	debug	Test 169.254.5.82 hm-rpc
                      discovery.0	2017-08-25 16:39:52.392	debug	Test 169.254.5.82 fronius
                      discovery.0	2017-08-25 16:39:52.392	debug	Test 169.254.5.82 firetv
                      discovery.0	2017-08-25 16:39:52.392	debug	Test 169.254.5.82 daikin
                      discovery.0	2017-08-25 16:39:52.376	debug	Test 169.254.5.82 chromecast
                      discovery.0	2017-08-25 16:39:52.376	debug	Test 169.254.5.82 broadlink
                      discovery.0	2017-08-25 16:39:50.110	info	Found 13 addresses
                      discovery.0	2017-08-25 16:39:50.079	info	Done discovering ping devices. 5 packages received
                      discovery.0	2017-08-25 16:39:44.360	debug	ping: 92%, devices - 5
                      discovery.0	2017-08-25 16:39:09.190	debug	ping: 85%, devices - 5
                      discovery.0	2017-08-25 16:39:03.189	debug	ping: 77%, devices - 5
                      discovery.0	2017-08-25 16:38:52.580	debug	ping: 69%, devices - 5
                      discovery.0	2017-08-25 16:38:48.814	debug	ping: 62%, devices - 5
                      discovery.0	2017-08-25 16:38:46.689	info	Done discovering upnp devices. 5 packages received
                      discovery.0	2017-08-25 16:38:46.377	info	Done discovering mdns devices. 25 packages received
                      discovery.0	2017-08-25 16:38:45.486	debug	ping: 54%, devices - 5
                      discovery.0	2017-08-25 16:38:42.861	debug	ping: 46%, devices - 5
                      discovery.0	2017-08-25 16:38:40.643	debug	ping: 38%, devices - 5
                      discovery.0	2017-08-25 16:38:38.018	debug	ping: 31%, devices - 5
                      discovery.0	2017-08-25 16:38:36.330	debug	main.addDevice: ip=192.168.178.38 source=ping
                      discovery.0	2017-08-25 16:38:36.330	debug	found 192.168.178.38
                      discovery.0	2017-08-25 16:38:36.127	debug	ping: 23%, devices - 4
                      discovery.0	2017-08-25 16:38:34.189	debug	ping: 15%, devices - 4
                      discovery.0	2017-08-25 16:38:33.674	debug	main.addDevice: ip=192.168.178.22 source=ping
                      discovery.0	2017-08-25 16:38:33.674	debug	found 192.168.178.22
                      discovery.0	2017-08-25 16:38:33.439	debug	main.addDevice: ip=192.168.178.21 source=ping
                      discovery.0	2017-08-25 16:38:33.439	debug	found 192.168.178.21
                      discovery.0	2017-08-25 16:38:32.814	debug	ping: 8%, devices - 2
                      discovery.0	2017-08-25 16:38:32.705	debug	main.addDevice: ip=192.168.178.16 source=mdns
                      discovery.0	2017-08-25 16:38:32.627	debug	main.addDevice: ip=192.168.178.14 source=ping
                      discovery.0	2017-08-25 16:38:32.627	debug	found 192.168.178.14
                      discovery.0	2017-08-25 16:38:32.346	debug	main.addDevice: ip=192.168.178.1 source=ping
                      discovery.0	2017-08-25 16:38:32.346	debug	found 192.168.178.1
                      discovery.0	2017-08-25 16:38:31.736	debug	main.addDevice: ip=169.254.87.120 source=mdns
                      discovery.0	2017-08-25 16:38:31.736	debug	main.addDevice: ip=169.254.5.82 source=mdns
                      discovery.0	2017-08-25 16:38:31.736	debug	main.addDevice: ip=192.168.178.12 source=mdns
                      discovery.0	2017-08-25 16:38:31.674	debug	main.addDevice: ip=192.168.178.46 source=upnp
                      discovery.0	2017-08-25 16:38:31.674	debug	UPNP Answer from 192.168.178.46
                      discovery.0	2017-08-25 16:38:31.674	debug	main.addDevice: ip=192.168.178.28 source=upnp
                      discovery.0	2017-08-25 16:38:31.674	debug	UPNP Answer from 192.168.178.28
                      discovery.0	2017-08-25 16:38:31.674	debug	main.addDevice: ip=192.168.178.16 source=upnp
                      discovery.0	2017-08-25 16:38:31.674	debug	UPNP Answer from 192.168.178.16
                      discovery.0	2017-08-25 16:38:31.658	debug	main.addDevice: ip=169.254.87.120 source=mdns
                      discovery.0	2017-08-25 16:38:31.658	debug	main.addDevice: ip=192.168.178.16 source=mdns
                      discovery.0	2017-08-25 16:38:31.658	debug	main.addDevice: ip=169.254.5.82 source=mdns
                      discovery.0	2017-08-25 16:38:31.658	debug	main.addDevice: ip=192.168.178.1 source=upnp
                      discovery.0	2017-08-25 16:38:31.658	debug	UPNP Answer from 192.168.178.1
                      discovery.0	2017-08-25 16:38:31.658	debug	main.addDevice: ip=192.168.178.13 source=mdns
                      discovery.0	2017-08-25 16:38:31.643	debug	main.addDevice: ip=192.168.178.12 source=upnp
                      discovery.0	2017-08-25 16:38:31.643	debug	UPNP Answer from 192.168.178.12
                      discovery.0	2017-08-25 16:38:31.611	info	Discovering UPnP devices...
                      discovery.0	2017-08-25 16:38:31.377	debug	ping: 0%, devices - 0
                      discovery.0	2017-08-25 16:38:31.361	info	Discovering ping devices...
                      discovery.0	2017-08-25 16:38:31.346	info	Discovering mDNS devices...
                      discovery.0	2017-08-25 16:38:31.330	debug	Received "browse" event
                      discovery.0	2017-08-25 16:38:31.330	debug	inMem message messagebox.system.adapter.discovery.0 messagebox.system.adapter.discovery.0 command=browse, message=[mdns, ping, upnp], from=system.adapter.admin.0, message=[mdns, ping, upnp], id=88,
                      discovery.0	2017-08-25 16:38:26.033	debug	sendTo "listMethods" to system.adapter.admin.0 from system.adapter.discovery.0
                      discovery.0	2017-08-25 16:38:26.002	debug	Received "listMethods" event
                      discovery.0	2017-08-25 16:38:26.002	debug	inMem message messagebox.system.adapter.discovery.0 messagebox.system.adapter.discovery.0 command=listMethods, message=null, from=system.adapter.admin.0, message=null, id=87, ack=false, time=1503671
                      iobroker läuft auf Win10-32bit
                      • apollon77
                        Und next try please 🙂
                        • G
                          @apollon77:
                          Und next try please 🙂 `
                          Hallo Ingo,
                          funktioniert jetzt! DANKE!
                          Viele Grüße Gerd.
                          1767
