    4. Backup auf Fritzbox klappt nicht
      Pistus @drsnuggles1982 last edited by
      Ich will manuell ein Backup durchführen, was früher automatisch funktionierte. Jetzt kommt folgende Fehlermeldung. Vorher hatte ich noch ein
      iob node js-update
      gemacht, weil ich das Backup auf einen neuen Rasperry wiederherstellen möchte
      2024-03-21 09:33:12.374 - info: admin.0 (7281) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:33:28.801 - info: admin.0 (7281) <== Disconnect system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:33:32.059 - error: backitup.0 (7396) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
      2024-03-21 09:33:32.061 - error: backitup.0 (7396) [iobroker/mount] mount error(13): Permission denied
      2024-03-21 09:33:32.063 - error: backitup.0 (7396) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      2024-03-21 09:33:44.204 - error: backitup.0 (7396) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2024-03-21 09:33:47.345 - info: admin.0 (7281) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:34:11.585 - info: admin.0 (7281) <== Disconnect system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:34:19.354 - info: admin.0 (7281) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:34:46.788 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2024-03-21 09:34:46.802 - info: backitup.0 (7396) Got terminate signal TERMINATE_YOURSELF
      2024-03-21 09:34:46.806 - info: backitup.0 (7396) cleaned everything up...
      2024-03-21 09:34:46.810 - info: backitup.0 (7396) terminating
      2024-03-21 09:34:46.816 - info: backitup.0 (7396) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-03-21 09:34:46.851 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
      2024-03-21 09:34:46.922 - info: admin.0 (7281) <== Disconnect system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:34:47.322 - info: backitup.0 (7396) terminating
      2024-03-21 09:34:47.438 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-03-21 09:34:49.972 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 7451
      2024-03-21 09:34:50.674 - info: admin.0 (7281) ==> Connected system.user.admin from ::ffff:192.168.178.37
      2024-03-21 09:34:54.899 - info: backitup.0 (7451) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.1, js-controller: 5.0.19
      2024-03-21 09:34:55.068 - info: backitup.0 (7451) [iobroker] backup will be activated at 02:40 every 1 day(s)
        Homoran Global Moderator Administrators @Pistus last edited by Homoran
        @pistus sagte in [Gelöst] Backup auf Synologie NAS:
        wie sieht denn deine cifs/NAS konfig in backitup aus?
        Hat aber doch nichts mit Synology zu tun, oder ?
          Pistus @Homoran last edited by Pistus
          Das wird im Backupfenster, während Backup läuft angezeigt
          Started iobroker ...
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups"
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups"
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          [DEBUG] [mount] - Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          [DEBUG] [iobroker] - host.raspberrypi 343 states saved
          [DEBUG] [iobroker] - host.raspberrypi 472 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_21-10_11_24_backupiobroker.tar.gz
          [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
          [DEBUG] [iobroker] - done
          [DEBUG] [cifs] - used copy path: /fritz.nas/TREKSTOR/Backup-ioBroker
          [DEBUG] [cifs] - done
          [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
          [DEBUG] [clean] - done
          [DEBUG] [historyHTML] - new history html values created
          [DEBUG] [historyHTML] - done
          [DEBUG] [historyJSON] - new history json values created
          [DEBUG] [historyJSON] - done
          2024-03-21 10:11:11.280 - info: backitup.0 (8467) [iobroker] backup will be activated at 02:40 every 1 day(s)
          2024-03-21 10:11:13.359 - error: backitup.0 (8467) Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          2024-03-21 10:11:23.988 - error: backitup.0 (8467) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
          2024-03-21 10:11:23.991 - error: backitup.0 (8467) [iobroker/mount] mount error(13): Permission denied
          2024-03-21 10:11:23.992 - error: backitup.0 (8467) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          2024-03-21 10:11:36.003 - error: backitup.0 (8467) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
          2024-03-21 10:14:50.630 - info: admin.0 (7773) <== Disconnect system.user.admin from ::ffff:192.168.178.37
            @pistus du hast für die Fritzbox noserverino und cache loose nicht angehakt.
            Für die Synoligy brauchst du das nicht!
            warum bist du hier im Syno Thread?
              Wenn ich die Häkchen einfüge passiert überhaupt nichts. Die waren vorher drin.
              Häkchen eingefügt.
              Er bleibt immer an der gleichen Stelle im Backup hängen.
              [DEBUG] [iobroker] - host.raspberrypi 341 states saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_03_21-10_35_22_backupiobroker.tar.gz
              Die Bacupdatei ist dann nur 1MB groß
              Homoran P 2 Replies Last reply Reply Quote 0
                @pistus und was steht jetzt im debug log?
                  Pistus @Pistus last edited by
                  @Homoran
                  2024-03-21 10:35:11.198 - error: backitup.0 (8720) Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
                  2024-03-21 10:35:22.599 - error: backitup.0 (8720) [iobroker/mount] [undefined Error: Command failed: sudo mount -t cifs -o username=Fritz1221,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker /opt/iobroker/backups
                  2024-03-21 10:35:22.601 - error: backitup.0 (8720) [iobroker/mount] mount error(13): Permission denied
                  2024-03-21 10:35:22.602 - error: backitup.0 (8720) [iobroker/mount] Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                  2024-03-21 10:35:34.639 - error: backitup.0 (8720) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                  2024-03-21 10:42:39.863 - info: admin.0 (7773) <== Disconnect system.user.admin from ::ffff:192.168.178.37
                    Thomas Braun Most Active @Pistus last edited by Thomas Braun
                    @pistus
                    Leg dir auf der FritzBox einen user für das Backup an und vergib dem die entsprechenden Rechte auf das NAS zuzugreifen.
                    Die Optionen 'noserverino' und 'cache loose' müssen bei Verwendung des FritzNAS gesetzt werden.
                    Und im Pfad dürfte das Volume fehlen.
                      @pistus sagte in Backup auf Fritzbox klappt nicht:
                      auch wenn das kein debug-log ist, jetzt steht das wenigstens drin.
                      Ist denn das Verzeichnis für den User freigegeben?
                        @thomas-braun sagte in Backup auf Fritzbox klappt nicht:
                        Den hat @Pistus leider abgeschnitten 😡
                          @homoran sagte in Backup auf Fritzbox klappt nicht:
                          Deswegen ja auch nur eine Vermutung. Im Log steht der Pfad aber auch falsch drin.
                            Pistus @Thomas Braun last edited by
                            Diese Backups sind nicht auf der Festplatte angekommen
                            Hier ist die festplatte zu zehen und das die automatischen früheren Backups funktioniert haben
                              @Thomas-Braun
                              192.168.178.1/fritz.nas/TREKSTOR/Backup-ioBroker/opt/iobroker/backups
                              Hallo Thomas, wo kommt denn jetzt in dem Pfad zum speichern am Ende das
                              her
                              Richtig ist doch
                                Copy to Clipboard/opt/iobroker/backups
                                her
                                Das ist der Mountpunkt, an dem das Dateisystem der FritzBox eingehängt wird.
                                €dit: Typos
                                  Pistus @Thomas Braun last edited by Pistus
                                  Ich raffe das einfach nicht.
                                  der Pfad vom Trekstor ist doch
                                  und nicht
                                  siehe oben im Bild Festplatte
                                  Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
                                    wenn das so ist, wird dieser über /opt/iobroker/backups "verlinkt" (korrekt: gemountet)
                                      und nicht
                                      Das steht ja auch nicht da. Es steht
                                      drin. Man beachte das Leerzeichen.
                                        @pistus
                                        Hier mal reingeschaut?
                                        https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup
                                        Da gibt es einen Punkt für FritzNAS.
                                          Hatte ich und auch gemacht. Das Backup hatte doch auch immer funktioniert siehe Bilder wo die Dateien auf dem NAS abgelegt sind.
                                          Ich denke gerade darüber nach, dass ich ja mit zwei Raspberry im gleichen Verzeichnis Backups ablegen will. Könnte das ein Grund sein?
                                          Thomas Braun P 2 Replies Last reply Reply Quote 0
                                            Gleichzeitig über zwei verschiedene Protokolle geht das natürlich nicht. Ist da auch noch FTP im Spiel?
                                            Ich würde auch pro System ein eigenes Verzeichnis anlegen und da rein sichern.
                                            2120
