    4. IoBrocker Installation seit Stunden an der gleichen Stelle
    • G
      gerritlo last edited by
      ich versuche gerade mal ioBroker zu installieren und zu schauen, wie es im Vergleich zu OpenHAB 2 ist. Leider steht die Installation auf meinem PI 2 mit openHABian seit mehreren Stunden an der gleichen Stelle. Die letzte Ausgabe war:
      [11:33:10] root@openHABianPi:~# cd /opt/iobroker
      [11:33:40] root@openHABianPi:/opt/iobroker# sudo npm install iobroker --unsafe-perm
      > iobroker@1.0.1 install /opt/iobroker/node_modules/iobroker
      > node lib/setup.js
      npm install iobroker.discovery --production --prefix /opt/iobroker
      node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-seria                   lport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.11.2 (node-v48 ABI)                    (falling back to source compile with node-gyp)
      ../src/serialport.cpp: In function ‘int getIntFromObject(v8::Local<v8::object>, std::string)’:
      ../src/serialport.cpp:90:52: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is depreca                   ted (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-d                   eclarations]
         return getValueFromObject(options, key)->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘double getDoubleFromObject(v8::Local<v8::object>, std::string)                   ’:
      ../src/serialport.cpp:102:53: warning: ‘v8::Local <v8::number>v8::Value::ToNumber() const’ is depr                   ecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8173): Use maybe version [-Wdeprecate                   d-declarations]
         return getValueFromObject(options, key)->ToNumber()->NumberValue();
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      ../src/serialport.cpp:174:31: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprec                   ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-                   declarations]
           int fd = argv[1]->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’                   :
      ../src/serialport.cpp:193:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprec                   ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-                   declarations]
         int fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp:217:116: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is depre                   cated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated                   -declarations]
         baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalC                   hecked()->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Write(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:252:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt32() const’ is deprec                   ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe version [-Wdeprecated-                   declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN
      ../src/serialport.cpp:369:32: warning: ‘v8::Local <v8::int32>v8::Value::ToInt3                                       ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe ve                                       declarations]
         baton->fd = info[0]->ToInt32()->Int32Value();
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN
      ../src/serialport.cpp:480:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt3                                       ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe ve                                       declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_M
      ../src/serialport.cpp:528:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt3                                       ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe ve                                       declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN
      ../src/serialport.cpp:585:29: warning: ‘v8::Local <v8::int32>v8::Value::ToInt3                                       ated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use maybe ve                                       declarations]
      ../src/serialport_unix.cpp: In function ‘OpenBatonPlatformOptions* ParsePlatfo                                       Local<v8::object>&)’:
      ../src/serialport_unix.cpp:44:109: warning: ‘v8::Local <v8::int32>v8::Value::T                                       eprecated (declared at /root/.node-gyp/6.11.2/include/node/v8.h:8209): Use may                                       ated-declarations]
         result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecke                                       )->ToInt32()->Int32Value();
      ../src/serialport_unix.cpp:45:111: warning: ‘v8::Local<v8::i eprecated/(declared/at/root/.node-gyp/6.11.2/include/node/v/ated-declarations]/result-="">vtime = Nan::Get(options, Nan::New<v8::string>("v                                                         d()->ToInt32()->Int32Value();
      ../src/serialport_poller.cpp: In static member function ‘sta                                                         portPoller::New(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport_poller.cpp:86:31: warning: ‘v8::Local<v8:: deprecated/(declared/at/root/.node-gyp/6.11.2/include/node/cated-declarations]/obj-="">fd_ = info[0]->ToInt32()->Int32Value();
      npm WARN enoent ENOENT: no such file or directory, open '/op
      npm WARN iobroker No description
      npm WARN iobroker No repository field.
      npm WARN iobroker No README data
      npm WARN iobroker No license field.
      npm install iobroker.admin --production --prefix /opt/iobrok
      npm install iobroker.js-controller --production --prefix /op</v8::></v8::string></v8::i></v8::string></v8::int32></v8::object></v8::int32></v8::int32></v8::int32></v8::int32></v8::int32></v8::string></v8::int32></v8::int32></v8::int32></v8::number></v8::object></v8::int32></v8::object>
      Ich bin nach der Anleitung vorgegangen. Hat jemand eine Idee??
      Grüße!
      • eric2905
        eric2905 last edited by
        Welche Anleitung (bitte Link) hast Du verwendet?
        Hast Du ein Original OS draufgemacht und dann ioBroker nachinstalliert? Oder hast Du ein fertiges Image von der Webseite?
        Gruß,
        Eric
          Hallo und Willkommen im Forum!
          Ist openHABian, wie ich vermute, ein Betriebssystem für OpenHAB?
          Dann muss die ioBroker Installation darauf nicht unbefingt funktionieren.
          Lade dir Raspbian auf die Sd Karte und installiere ioBroker nach der Anleitung
          http://www.iobroker.net/docu/?page_id=5106&lang=de
          Oder lade dir direkt ein fertiges Image mit Raspbian und ioBroker heeunter
          http://www.iobroker.net/docu/?page_id=2563&lang=de
