    4. Node-Red
    5. Muster Stromzähler per Modbus
      peterfido last edited by
      anbei mein Node-Red-Flow, welches mehrere Stromzähler an einem gemeinsamen Modbus abfragt.
      Der Modbus-LAN Adapter ist ein U.S.R. USR-TCP232-304
      Folgende Zähler hängen am Bus:
      • DZG DVH4013
      • EASTRON SDM72D-M
      • Orno OR-WE 14
              "id": "c24431d8.d16be",
              "type": "tab",
              "label": "Stromzaehler",
              "disabled": false,
              "info": ""
              "id": "eda79e7e.a523a",
              "type": "function",
              "z": "c24431d8.d16be",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL1\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA\"});   \n            flow.set(\"I1\",I);\n            flow.set(\"P1\",P);\n            flow.set(\"S1\",S);\n        }\n    }\n\n    return [\n        {\n            payload: I, topic:Pfad+'I1', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P1', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S1', stateUnit: 'VA'\n                \n        }\n    ];\n}\n/*    {\n        payload: i1, topic:Pfad+'I1', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n*/",
              "outputs": 3,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 300,
              "wires": [
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
              "id": "c52e1e95.b8f1f",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL2\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA\"});   \n            flow.set(\"I2\",I);\n            flow.set(\"P2\",P);\n            flow.set(\"S2\",S);\n        }\n    }\n\n    return [\n        {\n            payload: I, topic:Pfad+'I2', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P2', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S2', stateUnit: 'VA'\n                \n        }\n    ];\n}\n/*    {\n        payload: i1, topic:Pfad+'I1', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n*/",
              "outputs": 3,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 380,
              "wires": [
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
              "id": "9730857f.daf338",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar I=0;\nvar P=0;\nvar S=0;\nvar Ig=0;\nif(arr.length===2){\n    I=parseFloat(arr[1])/1000;\n    if(!isNaN(I)){\n        var PF=flow.get(\"PF\");\n        var U=flow.get(\"UL3\");\n        if(!isNaN(U) && !isNaN(PF)){\n            P=Math.round(I*U*PF *100)/100;\n            S=Math.round(I*U *100)/100;\n            Ig=Math.round((flow.get(\"I1\")+flow.get(\"I2\")+I) *100)/100\n            node.status({text:\"I:\"+I+\"A; P:\"+P+\"W; S:\"+S+\"VA; Ig:\"+Ig+\"A\"});\n            flow.set(\"I3\",I);\n            flow.set(\"P3\",P);\n            flow.set(\"S3\",S);\n        }\n    }\n    return [\n        {\n            payload: I, topic:Pfad+'I3', stateUnit: 'A'\n        },\n        {\n            payload: P, topic:Pfad+'P3', stateUnit: 'W'\n        },\n        {\n            payload: S, topic:Pfad+'S3', stateUnit: 'VA'\n                \n        },\n        {\n            payload: Ig, topic:Pfad+'I', stateUnit: 'A'\n                \n        }\n        \n    ];    \n    \n}\n",
              "outputs": 4,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 460,
              "wires": [
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
              "id": "822f53a0.e1937",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL1\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U1', stateUnit: 'V'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 120,
              "wires": [
                      "743b4448.e11c9c"
              "id": "59509a99.453d34",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL2\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U2', stateUnit: 'V', stateRole: 'value'\n        }\n    ];\n}   ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 180,
              "wires": [
                      "743b4448.e11c9c"
              "id": "d127f414.df7908",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/100;\n    flow.set(\"UL3\", wert);\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U3', stateUnit: 'V'\n        }\n    ];\n}   ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 240,
              "wires": [
                      "743b4448.e11c9c"
              "id": "c007e291.21884",
              "type": "function",
              "name": "Leistungen",
              "func": "var arr=msg.payload;\nconst Warngrenze = 2.5*60*60; //2,5 Stunden\nconst Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\nvar Pz = 0;\nif(arr.length === 2){\n    Pz=parseFloat(arr[1])/10;\n}\n\nvar S1 = parseFloat(flow.get(\"S1\"));\nvar S2 = parseFloat(flow.get(\"S2\"));\nvar S3 = parseFloat(flow.get(\"S3\"));\nvar S = parseFloat(Math.round(S1+S2+S3));\nvar Zk = parseFloat(flow.get(\"Zk\"));\nvar Zg = parseFloat(flow.get(\"Zg\"));\nvar Sk = parseFloat(flow.get(\"Sk\"));\nvar Sg = parseFloat(flow.get(\"Sg\"));\nvar Warnung = false;\n\nif (S > 1){\n    Zk = 60;\n    Sk = Sk + 10;    \n}else{    \n    if (Zk>10){\n        Zk = Zk - 10;\n        Sk = Sk + 10;\n    }else{\n        Zk = 0;\n        Sk = 0;\n    }\n}\n\n\nif (S > 100){\n    Zg = 180;\n    Sg = Sg + 10;    \n}else{    \n\n    if (Zg>10){\n        Zg = Zg -10;\n    }else{\n        Zg = 0;\n        Sg = 0;\n    }\n}\n\nflow.set(\"Zg\", Zg);\nflow.set(\"Zk\", Zk);\nflow.set(\"Sg\", Sg);\nflow.set(\"Sk\", Sk);\n\nvar Klein = new Date(Sk * 1000).toISOString().substr(11, 8);\nvar Gross = new Date(Sg * 1000).toISOString().substr(11, 8);\n\nWarnung = Zg > Warngrenze;\n\n//flow.set(\"UL1\", wert);\n\nnode.status({text:\"ausgelesen P:\"+Pz+\"W; S:\"+S+\"VA\"});\n//node.status({text:\"P1:\"+P1+\"; P2:\"+P2+\"; P3:\"+P3});\n//node.status({text:\"S1:\"+S1+\"; S2:\"+S2+\"; S3:\"+S3});\n//topic:Pfad+'CosPhi', stateUnit: '', stateType: 'number', stateRole: 'value'\nreturn [\n    {\n        payload: Pz, topic:Pfad+'P', stateUnit: 'W'\n    },\n    {\n        payload: S, topic:Pfad+'S', stateUnit: 'VA'\n    },\n    {\n        payload: Klein, topic:Pfad+'Sklein'\n    },\n    {\n        payload: Gross, topic:Pfad+'Sgross'\n    },\n    {\n        payload: Warnung, topic:Pfad+'Warnung'\n    }      \n    \n];",
              "outputs": 5,
              "noerr": 0,
              "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"Zg\", 0);\nflow.set(\"Zk\", 0);\nflow.set(\"Sg\", 0);\nflow.set(\"Sk\", 0);",
              "finalize": "",
              "libs": [],
              "x": 630,
              "y": 620,
              "wires": [
                      "743b4448.e11c9c"
                      "743b4448.e11c9c"
                      "101c66cccacac37f"
                      "101c66cccacac37f"
                      "66237a931617967c"
              "id": "743b4448.e11c9c",
              "type": "ioBroker out",
              "name": "ioB number",
              "topic": "",
              "ack": "true",
              "autoCreate": "true",
              "stateName": "",
              "role": "state",
              "payloadType": "number",
              "readonly": "false",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1010,
              "y": 320,
              "wires": []
              "id": "a0e8c509.265ee8",
              "type": "function",
              "name": "extract buffer data",
              "func": "let voltageL1 = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nlet voltageL2 = round(msg.payload.buffer.readFloatBE(4,4)) // 3,4\nlet voltageL3 = round(msg.payload.buffer.readFloatBE(8,4)) // 5,6\n\nlet currentL1 = round(msg.payload.buffer.readFloatBE(12,4)) // 7,8\nlet currentL2 = round(msg.payload.buffer.readFloatBE(16,4)) // 9,10\nlet currentL3 = round(msg.payload.buffer.readFloatBE(20,4)) // 11,12\n\nlet powerL1 = round(msg.payload.buffer.readFloatBE(24,4)) // 13,14\nlet powerL2 = round(msg.payload.buffer.readFloatBE(28,4)) // 15,16\nlet powerL3 = round(msg.payload.buffer.readFloatBE(32,4)) // 17,18\n\nlet spowerL1 = round(msg.payload.buffer.readFloatBE(36,4)) // 19,20\nlet spowerL2 = round(msg.payload.buffer.readFloatBE(40,4)) // 21,22\nlet spowerL3 = round(msg.payload.buffer.readFloatBE(44,4)) // 23,24\n\nlet voltageAVG = round(msg.payload.buffer.readFloatBE(84,8)) // 43-46\nlet currentAVG = round(msg.payload.buffer.readFloatBE(92,4)) // 47,48\n\nreturn [\n    {\n        payload: {\n            L1: {\n                voltage: voltageL1,\n                current: currentL1,\n                power: powerL1,\n                spower: spowerL1\n            },\n            L2: {\n                voltage: voltageL2,\n                current: currentL2,\n                power: powerL2,\n                spower: spowerL2\n            },\n            L3: {\n                voltage: voltageL3,\n                current: currentL3,\n                power: powerL3,\n                spower: spowerL3\n            },\n            voltageAVG: voltageAVG,\n            currentAVG: currentAVG,            \n        }\n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
              "outputs": "1",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 470,
              "y": 1300,
              "wires": [
                      "ab2b7f84.fff3b",
                      "9cc4ad2e.71602",
                      "ee889fb2.e024f"
              "id": "ab2b7f84.fff3b",
              "type": "function",
              "name": "Ströme",
              "func": "node.status({text:\"L1:\"+msg.payload.L1.current+\"; L2:\"+msg.payload.L2.current+\"; L3:\"+msg.payload.L3.current+\"; 0:\"+msg.payload.currentAVG});\n\n\nreturn [\n    {payload: msg.payload.L1.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I1'}, \n    {payload: msg.payload.L2.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I2'}, \n    {payload: msg.payload.L3.current, topic:'0_userdata.0.Wallbox.Strom.Auslese.I3'},\n    {payload: msg.payload.currentAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.I'}\n];",
              "outputs": "4",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 900,
              "y": 1160,
              "wires": [
                      "38b34ea4.11e192"
                      "38b34ea4.11e192"
                      "38b34ea4.11e192"
                      "38b34ea4.11e192"
              "id": "9cc4ad2e.71602",
              "type": "function",
              "name": "Spannungen",
              "func": "node.status({text:\"L1:\"+msg.payload.L1.voltage+\"; L2:\"+msg.payload.L2.voltage+\"; L3:\"+msg.payload.L3.voltage+\"; 0:\"+msg.payload.voltageAVG});\n\n\nreturn [\n    {payload: msg.payload.L1.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U1'}, \n    {payload: msg.payload.L2.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U2'}, \n    {payload: msg.payload.L3.voltage, topic:'0_userdata.0.Wallbox.Strom.Auslese.U3'},\n    {payload: msg.payload.voltageAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.ULN'}\n];",
              "outputs": "4",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 910,
              "y": 1240,
              "wires": [
                      "96217b86.779a28"
                      "96217b86.779a28"
                      "96217b86.779a28"
                      "96217b86.779a28"
              "id": "ee889fb2.e024f",
              "type": "function",
              "func": "node.status({text:\"L1:\"+msg.payload.L1.power+\"; L2:\"+msg.payload.L2.power+\"; L3:\"+msg.payload.L3.power});\n\n\nreturn [\n    {payload: msg.payload.L1.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P1'}, \n    {payload: msg.payload.L2.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P2'}, \n    {payload: msg.payload.L3.power, topic:'0_userdata.0.Wallbox.Strom.Auslese.P3'},\n    {payload: msg.payload.L1.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S1'}, \n    {payload: msg.payload.L2.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S2'}, \n    {payload: msg.payload.L3.spower, topic:'0_userdata.0.Wallbox.Strom.Auslese.S3'}    \n];\n",
              "outputs": 6,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 910,
              "y": 1340,
              "wires": [
                      "204b7607.8b4d5a"
                      "204b7607.8b4d5a"
                      "204b7607.8b4d5a"
                      "204b7607.8b4d5a"
                      "204b7607.8b4d5a"
                      "204b7607.8b4d5a"
              "id": "39853145.37685e",
              "type": "function",
              "func": "let currentSum = round(msg.payload.buffer.readFloatBE(0,8))\nlet powerSum = round(msg.payload.buffer.readFloatBE(8,8))\nif(powerSum < 0){\n    powerSum=0;\n}\n\nreturn [\n    {\n        payload: currentSum, topic:'0_userdata.0.Wallbox.Strom.Watt.StromTotal'\n    },\n    {\n        payload: powerSum, topic:'0_userdata.0.Wallbox.Strom.Watt.LeistungTotal'\n            \n    }\n];\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}\n\n",
              "outputs": 2,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 390,
              "y": 800,
              "wires": [
                      "7d6e2cb1.25cf94"
                      "7d6e2cb1.25cf94"
              "id": "525c624.e1e5b9c",
              "type": "function",
              "func": "let frequency = round(msg.payload.buffer.readFloatBE(0,4)) // 71,72\nlet ImportActiveEnergy = round(msg.payload.buffer.readFloatBE(4,4)) // 73,74\nlet ampHourSinceLastReset = round(msg.payload.buffer.readFloatBE(24,4)) // 83,84\nlet totalSystemPowerDemand = round(msg.payload.buffer.readFloatBE(28,4)) // 85,86\nlet maxTotalSystemPowerDemand = round(msg.payload.buffer.readFloatBE(32,4)) // 87,88\n\nreturn [\n    { \n        payload: frequency, topic:'0_userdata.0.Wallbox.Strom.Auslese.Frequenz'\n    },\n    { \n        payload: ImportActiveEnergy, topic:'0_userdata.0.Wallbox.Strom.Auslese.ArbeitT1'\n    },\n    {\n        payload: ampHourSinceLastReset / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.ampHourSinceLastReset'\n    },    \n    {\n        payload: totalSystemPowerDemand / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.totalSystemPowerDemand'\n    },\n    {\n        payload: maxTotalSystemPowerDemand / 1000.0, topic:'0_userdata.0.Wallbox.Strom.Watt.maxTotalSystemPowerDemand'\n    }\n];\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}\n",
              "outputs": 5,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 390,
              "y": 920,
              "wires": [
                      "5b800497.8d630c"
                      "5b800497.8d630c"
                      "5b800497.8d630c"
                      "5b800497.8d630c"
                      "5b800497.8d630c"
              "id": "2c8be1dc.543d2e",
              "type": "function",
              "func": "let voltageL12 = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nlet voltageL23 = round(msg.payload.buffer.readFloatBE(4,4)) // 3,4\nlet voltageL31 = round(msg.payload.buffer.readFloatBE(8,4)) // 5,6\nlet voltageAVG = round(msg.payload.buffer.readFloatBE(12,4)) // 7,8\n\nnode.status({text:\"L12:\"+voltageL12+\"; L23:\"+voltageL23+\"; L31:\"+voltageL31+\"; 0:\"+voltageAVG});\n\nreturn [\n    {payload: voltageL12, topic:'0_userdata.0.Wallbox.Strom.Auslese.U12'}, \n    {payload: voltageL23, topic:'0_userdata.0.Wallbox.Strom.Auslese.U23'}, \n    {payload: voltageL31, topic:'0_userdata.0.Wallbox.Strom.Auslese.U31'},\n    {payload: voltageAVG, topic:'0_userdata.0.Wallbox.Strom.Auslese.ULL'}\n];\n\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
              "outputs": 4,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 390,
              "y": 1020,
              "wires": [
                      "ee04a046.d40ac"
                      "ee04a046.d40ac"
                      "ee04a046.d40ac"
                      "ee04a046.d40ac"
              "id": "a4aa7b2f.ea6278",
              "type": "function",
              "func": "let arbeit = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nnode.status({text:\"Arbeit:\"+arbeit+\"kWh\"});\nreturn [\n    {\n        payload: arbeit, topic:'0_userdata.0.Wallbox.Strom.Auslese.Arbeit'\n        \n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
              "outputs": "1",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 430,
              "y": 1120,
              "wires": [
                      "2209a5e3.4e547a"
              "id": "38b34ea4.11e192",
              "name": "Ströme",
              "topic": "",
              "ack": "true",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1160,
              "y": 1140,
              "wires": []
              "id": "96217b86.779a28",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1170,
              "y": 1220,
              "wires": []
              "id": "204b7607.8b4d5a",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1170,
              "y": 1320,
              "wires": []
              "id": "7d6e2cb1.25cf94",
              "name": "I P Total",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 580,
              "y": 820,
              "wires": []
              "id": "ee04a046.d40ac",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 670,
              "y": 1020,
              "wires": []
              "id": "2209a5e3.4e547a",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 640,
              "y": 1120,
              "wires": []
              "id": "fa2c309d.e85bf",
              "type": "function",
              "func": "let lf = round(msg.payload.buffer.readFloatBE(0,4)) // 1,2\nif (lf < 0 ){\n    lf=0;\n}\nnode.status({text:\"LF:\"+lf});\nreturn [\n    {\n        payload: lf, topic:'0_userdata.0.Wallbox.Strom.Auslese.LF'\n        \n    }\n];\n\nfunction round(num) {\n    var m = Number((Math.abs(num) * 100).toPrecision(15));\n    return Math.round(m) / 100 * Math.sign(num);\n}",
              "outputs": "1",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 430,
              "y": 1180,
              "wires": [
                      "2209a5e3.4e547a"
              "id": "5b800497.8d630c",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 600,
              "y": 900,
              "wires": []
              "id": "513c1518.2442cc",
              "type": "catch",
              "name": "",
              "scope": [
                  "743b4448.e11c9c",
                  "38b34ea4.11e192",
                  "96217b86.779a28",
                  "204b7607.8b4d5a",
                  "7d6e2cb1.25cf94",
                  "ee04a046.d40ac",
                  "2209a5e3.4e547a",
                  "5b800497.8d630c",
                  "101c66cccacac37f",
                  "66237a931617967c",
                  "6b8bbc65.099ef4",
                  "f855b57f.5901a8",
                  "968d7a0b.0fe808",
                  "efab8902.f736e8",
                  "dfe61d4d.a1bfb",
                  "e9657bb2.688a58",
                  "cdf0c6e39f6fa40c",
                  "ddf59ada8cf40eec",
                  "9b3eeb1d11c036d1",
                  "14b581abc78ba857",
                  "c4f57b115fabadf1",
                  "ba122be31cfb23f3",
                  "ca5120478f8ce267",
                  "0ef7ac1c223df769",
                  "32187279838c66f9",
                  "0c430f6fd725e2e9",
                  "7e37843a9056e0ef",
                  "f4b12dc83ea99fe7",
                  "26670495e6e675c2"
              "uncaught": false,
              "x": 160,
              "y": 1880,
              "wires": [
                      "4c34a6dc.573be8"
              "id": "4c34a6dc.573be8",
              "type": "debug",
              "name": "",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "statusType": "auto",
              "x": 370,
              "y": 1880,
              "wires": []
              "id": "1e4ce668f6fc1d33",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nif(arr.length===2){\n    var wert=parseFloat(arr[1])/1000;\n    flow.set(\"PF\", wert);\n\n    node.status({text:\"Cos Phi:\"+wert});\n\n    return [\n        {\n            payload: wert, topic:'0_userdata.0.Zaehler.Strom.Herd.ist.LF'\n            \n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 610,
              "y": 60,
              "wires": [
                      "743b4448.e11c9c"
              "id": "101c66cccacac37f",
              "name": "ioB string",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "string",
              "payloadType": "string",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1000,
              "y": 480,
              "wires": []
              "id": "66237a931617967c",
              "name": "ioB boolean",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "state",
              "payloadType": "boolean",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1010,
              "y": 560,
              "wires": []
              "id": "f626796a7eedb661",
              "type": "delay",
              "name": "",
              "pauseType": "delay",
              "timeout": "5",
              "timeoutUnits": "seconds",
              "rate": "1",
              "nbRateUnits": "1",
              "rateUnits": "second",
              "randomFirst": "1",
              "randomLast": "5",
              "randomUnits": "seconds",
              "drop": false,
              "allowrate": false,
              "outputs": 1,
              "x": 120,
              "y": 720,
              "wires": [
                      "cdf0c6e39f6fa40c"
              "id": "777228346e35b408",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "10",
              "crontab": "",
              "once": true,
              "onceDelay": "1",
              "topic": "",
              "payload": "",
              "payloadType": "date",
              "x": 90,
              "y": 160,
              "wires": [
                      "f4b12dc83ea99fe7",
                      "f626796a7eedb661"
              "id": "168ad1b7fad7e8a2",
              "type": "function",
              "name": "Tariflos 1.8.0",
              "func": "const Pfad = '0_userdata.0.Zaehler.Strom.Herd.ist.';\n\nvar arr=msg.payload;\nvar T0=0;\n\nif(arr.length===2){\n    var f=parseFloat(arr[0])*65536;\n    f=f+parseFloat(arr[1]);\n    f=f/1000;\n    T0=f;\n}\nnode.status({text:\"Arbeit:\"+T0+\"kWh\"});\n\nreturn [\n    {\n        payload: T0,  topic:Pfad+'Arbeit', stateUnit: 'kWh'\n    }\n];\n\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 630,
              "y": 540,
              "wires": [
                      "743b4448.e11c9c"
              "id": "6b8bbc65.099ef4",
              "type": "modbus-getter",
              "name": "U2",
              "showStatusActivities": false,
              "showErrors": true,
              "logIOActivities": false,
              "unitid": "151",
              "dataType": "HoldingRegister",
              "adr": "6",
              "quantity": "2",
              "server": "f4e69f0c.3ab6c",
              "useIOFile": false,
              "ioFile": "",
              "useIOForPayload": false,
              "emptyMsgOnFail": false,
              "keepMsgProperties": false,
              "x": 310,
              "y": 200,
              "wires": [
                      "59509a99.453d34"
                      "f855b57f.5901a8"
              "id": "f855b57f.5901a8",
              "name": "U3",
              "showErrors": true,
              "unitid": "151",
              "adr": "8",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 260,
              "wires": [
                      "d127f414.df7908"
                      "968d7a0b.0fe808"
              "id": "968d7a0b.0fe808",
              "name": "I1",
              "showErrors": true,
              "unitid": "151",
              "adr": "10",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 320,
              "wires": [
                      "eda79e7e.a523a"
                      "efab8902.f736e8"
              "id": "efab8902.f736e8",
              "name": "I2",
              "showErrors": true,
              "unitid": "151",
              "adr": "12",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 400,
              "wires": [
                      "c52e1e95.b8f1f"
                      "dfe61d4d.a1bfb"
              "id": "dfe61d4d.a1bfb",
              "name": "I3",
              "showErrors": true,
              "unitid": "151",
              "adr": "14",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 460,
              "wires": [
                      "9730857f.daf338"
                      "26670495e6e675c2"
              "id": "e9657bb2.688a58",
              "name": "P",
              "showErrors": true,
              "unitid": "151",
              "adr": "0",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 620,
              "wires": [
                      "c007e291.21884"
              "id": "0ef7ac1c223df769",
              "name": "U1",
              "showErrors": true,
              "unitid": "151",
              "adr": "4",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 140,
              "wires": [
                      "822f53a0.e1937"
                      "6b8bbc65.099ef4"
              "id": "ba122be31cfb23f3",
              "name": "70+42",
              "showErrors": true,
              "unitid": "11",
              "dataType": "InputRegister",
              "adr": "70",
              "quantity": "42",
              "useIOFile": false,
              "ioFile": "",
              "x": 150,
              "y": 860,
              "wires": [
                      "525c624.e1e5b9c",
                      "ca5120478f8ce267"
              "id": "ca5120478f8ce267",
              "name": "200+12",
              "showErrors": true,
              "unitid": "11",
              "adr": "200",
              "quantity": "12",
              "useIOFile": false,
              "ioFile": "",
              "x": 160,
              "y": 940,
              "wires": [
                      "2c8be1dc.543d2e",
                      "32187279838c66f9"
              "id": "32187279838c66f9",
              "name": "1280+2",
              "showErrors": true,
              "unitid": "11",
              "adr": "1280",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 160,
              "y": 1060,
              "wires": [
                      "a4aa7b2f.ea6278",
                      "0c430f6fd725e2e9"
              "id": "0c430f6fd725e2e9",
              "name": "60+2",
              "showErrors": true,
              "unitid": "11",
              "adr": "60",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 150,
              "y": 1180,
              "wires": [
                      "fa2c309d.e85bf",
                      "7e37843a9056e0ef"
              "id": "7e37843a9056e0ef",
              "name": "0+50",
              "showErrors": true,
              "unitid": "11",
              "adr": "0",
              "quantity": "50",
              "useIOFile": false,
              "ioFile": "",
              "x": 150,
              "y": 1320,
              "wires": [
                      "ddf59ada8cf40eec"
                      "a0e8c509.265ee8"
              "id": "cdf0c6e39f6fa40c",
              "name": "48+8",
              "showErrors": true,
              "unitid": "11",
              "adr": "48",
              "quantity": "8",
              "useIOFile": false,
              "ioFile": "",
              "x": 170,
              "y": 780,
              "wires": [
                      "39853145.37685e",
                      "ba122be31cfb23f3"
              "id": "f4b12dc83ea99fe7",
              "name": "Cos Phi",
              "showErrors": true,
              "unitid": "151",
              "adr": "16",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 300,
              "y": 80,
              "wires": [
                      "1e4ce668f6fc1d33"
                      "0ef7ac1c223df769"
              "id": "26670495e6e675c2",
              "name": "kWh",
              "showErrors": false,
              "unitid": "151",
              "adr": "16384",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 310,
              "y": 540,
              "wires": [
                      "168ad1b7fad7e8a2"
                      "e9657bb2.688a58"
              "id": "ddf59ada8cf40eec",
              "name": "OR-WE 14 U",
              "showErrors": true,
              "unitid": "4",
              "adr": "305",
              "quantity": "1",
              "useIOFile": false,
              "ioFile": "",
              "x": 170,
              "y": 1500,
              "wires": [
                      "82950a49f8fc4c42",
                      "9b3eeb1d11c036d1"
              "id": "bf2809c2e7ae4ffd",
              "type": "debug",
              "name": "debug 3",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "x": 540,
              "y": 1820,
              "wires": []
              "id": "9b3eeb1d11c036d1",
              "name": "OR-WE 14 I",
              "showErrors": true,
              "unitid": "4",
              "adr": "313",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 170,
              "y": 1580,
              "wires": [
                      "14b581abc78ba857",
                      "cb050a79f5f96008"
              "id": "14b581abc78ba857",
              "name": "OR-WE 14 P",
              "showErrors": true,
              "unitid": "4",
              "adr": "320",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 170,
              "y": 1660,
              "wires": [
                      "7b030f2291475e82",
                      "0ed251949763c827",
                      "bf2809c2e7ae4ffd"
              "id": "c4f57b115fabadf1",
              "name": "OR-WE 14 kWh",
              "showErrors": true,
              "showWarnings": true,
              "unitid": "4",
              "adr": "40960",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "delayOnStart": false,
              "startDelayTime": "",
              "x": 180,
              "y": 1820,
              "wires": [
                      "07e78de48e963783",
                      "dfabf7acb25b33dc"
              "id": "82950a49f8fc4c42",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===1){\n    var wert=parseFloat(arr[0])/100;\n    node.status({text:wert+\"V\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'U1', stateUnit: 'V'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 370,
              "y": 1500,
              "wires": [
                      "8b4a362dc5bd1f51"
              "id": "cb050a79f5f96008",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n    \n    wert=wert/1000;\n    \n    node.status({text:wert+\"A\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'I1', stateUnit: 'A'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 370,
              "y": 1560,
              "wires": [
                      "8b4a362dc5bd1f51"
              "id": "7b030f2291475e82",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n   // wert = wert / 1000;\n    node.status({text:wert+\"W\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'P1', stateUnit: 'W'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 370,
              "y": 1640,
              "wires": [
                      "8b4a362dc5bd1f51"
              "id": "07e78de48e963783",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n    wert = wert / 100;\n\n    node.status({ text: wert + \"kWh\"});\n    return [\n        {\n            payload: wert, topic:Pfad+'Arbeit', stateUnit: 'kWh'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 370,
              "y": 1780,
              "wires": [
                      "8b4a362dc5bd1f51"
              "id": "8b4a362dc5bd1f51",
              "topic": "",
              "ack": "true",
              "stateName": "",
              "role": "state",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 650,
              "y": 1640,
              "wires": []
              "id": "0ed251949763c827",
              "name": "OR-WE 14 S",
              "showErrors": true,
              "unitid": "4",
              "adr": "336",
              "quantity": "2",
              "useIOFile": false,
              "ioFile": "",
              "x": 170,
              "y": 1740,
              "wires": [
                      "d4116f75baeadc71",
                      "c4f57b115fabadf1"
              "id": "d4116f75baeadc71",
              "type": "function",
              "name": "Faktor",
              "func": "var arr=msg.payload;\nconst Pfad = '0_userdata.0.Zaehler.PV.ist.';\nif(arr.length===2){\n    var wert = parseFloat(arr[0]) * 65536 + parseFloat(arr[1])\n   // wert = wert / 1000;\n    node.status({text:wert+\"VA\"});\n\n    return [\n        {\n            payload: wert, topic:Pfad+'S1', stateUnit: 'VA'\n        }\n    ];\n}    ",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 370,
              "y": 1700,
              "wires": [
                      "8b4a362dc5bd1f51"
              "id": "dfabf7acb25b33dc",
              "type": "debug",
              "name": "debug 7",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 540,
              "y": 1860,
              "wires": []
              "id": "f8bd2c635d269c86",
              "type": "comment",
              "name": "DZG DVH4013",
              "info": "",
              "x": 320,
              "y": 20,
              "wires": []
              "id": "59f5de91d229a142",
              "type": "comment",
              "name": "EASTRON SDM72D-M",
              "info": "EASTRON SDM72D-M",
              "x": 400,
              "y": 720,
              "wires": []
              "id": "49f1bbf094d20d2c",
              "type": "comment",
              "name": "Orno OR-WE 14",
              "info": "",
              "x": 180,
              "y": 1440,
              "wires": []
              "id": "f4e69f0c.3ab6c",
              "type": "modbus-client",
              "name": "USRIOT",
              "clienttype": "tcp",
              "bufferCommands": true,
              "stateLogEnabled": false,
              "queueLogEnabled": true,
              "failureLogEnabled": false,
              "tcpHost": "192.168.2.96",
              "tcpPort": "502",
              "tcpType": "TELNET",
              "serialPort": "/dev/ttyUSB",
              "serialType": "RTU-BUFFERD",
              "serialBaudrate": "9600",
              "serialDatabits": "8",
              "serialStopbits": "1",
              "serialParity": "none",
              "serialConnectionDelay": "100",
              "serialAsciiResponseStartDelimiter": "",
              "unit_id": "1",
              "commandDelay": "300",
              "clientTimeout": "1000",
              "reconnectOnTimeout": true,
              "reconnectTimeout": "5000",
              "parallelUnitIdsAllowed": true
