    4. Node-Red
    5. Muster Stromzähler RS232
      peterfido last edited by peterfido
      anbei mein Node-Red-Flow, welches per optischem Lesekopf den Stromzähler vom EVU abfragt.
      Der RS232-LAN-Adapter ist ein USRIOT USR-TCP232-T 2
      Der Stromzähler ist ein LOGAREX LK13BE, welcher per PIN geschwätziger geschaltet wurde.
      Der optische Lesekopf ist ein günstig bei eBay als Bausatz geschossener NoName.
              "id": "c587122ec79a200c",
              "type": "tab",
              "label": "Strom EVU",
              "disabled": false,
              "info": ""
              "id": "1ce291586779796c",
              "type": "catch",
              "z": "c587122ec79a200c",
              "name": "",
              "scope": [
                  "61dd23b258b802e6",
                  "bd2f6fb84b795289",
                  "472af7c34b784cef",
                  "8425fef0bf9f3b09",
                  "7e6496b30f82a733",
                  "8725b4dd7db48627",
                  "6bd2ac13e94179f9"
              "uncaught": false,
              "x": 90,
              "y": 680,
              "wires": [
                      "bc4e1c204c90a1a0"
              "id": "bc4e1c204c90a1a0",
              "type": "debug",
              "name": "",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "statusType": "auto",
              "x": 300,
              "y": 680,
              "wires": []
              "id": "61dd23b258b802e6",
              "type": "tcp in",
              "name": "Empfang EVU",
              "server": "server",
              "host": "",
              "port": "28234",
              "datamode": "stream",
              "datatype": "utf8",
              "newline": "",
              "topic": "",
              "base64": false,
              "tls": "",
              "x": 130,
              "y": 60,
              "wires": [
                      "8425fef0bf9f3b09"
              "id": "8425fef0bf9f3b09",
              "type": "split",
              "name": "",
              "splt": "!",
              "spltType": "str",
              "arraySplt": 1,
              "arraySpltType": "len",
              "stream": true,
              "addname": "",
              "x": 270,
              "y": 60,
              "wires": [
                      "472af7c34b784cef",
                      "15844dfdf721c9c4"
              "id": "472af7c34b784cef",
              "type": "function",
              "name": "Werte",
              "func": "var text = msg.payload;\ntext = text.replace(\"\\r\",\"\");\nconst myArray = text.split(\"\\n\");\nconst Pfad = '0_userdata.0.Zaehler.Strom.EVU.ist.';\nvar wertholen = function(datensatz) {\n    var beginn=text.indexOf(datensatz);\n    if(beginn > 0){\n        beginn=text.indexOf('(',beginn+1)+1;\n        var ende = text.indexOf('*',beginn);\n        if(ende > 0){\n            return parseFloat(text.substring(beginn,ende));    \n        }else{\n            return -99999;\n        }\n    }else{\n        return -99999;\n    }\n}\n\nvar kwhTotal = wertholen(':1.8.0*255');\nvar kwh = wertholen(':1.8.0*100');\nvar kwh1 = wertholen(':1.8.0*96');   //1 Tag\nvar kwh7 = wertholen(':1.8.0*97');  //7 Tage\nvar kwh30 = wertholen(':1.8.0*98');   //30 Tage\nvar kwh365 = wertholen(':1.8.0*99'); //365 Tage\nvar kwhPVTotal = wertholen(':2.8.0*255');\n\nvar u1 = wertholen(':32.7');\nvar u2 = wertholen(':52.7');\nvar u3 = wertholen(':72.7');\nvar i1 = wertholen(':31.7');\nvar i2 = wertholen(':51.7');\nvar i3 = wertholen(':71.7');\nvar w = wertholen(':16.7');\nvar f = wertholen(':14.7');\nvar w1 = (wertholen(':81.7.4'));   //Winkel L1\nvar w2 = (wertholen(':81.7.15'));  //Winkel L2\nvar w3 = (wertholen(':81.7.26'));  //Winkel L3\n\n\nvar p1 = Math.round(u1*i1*Math.cos(w1 * Math.PI / 180)*10)/10;\nvar p2 = Math.round(u2*i2*Math.cos(w2 * Math.PI / 180)*10)/10;\nvar p3 = Math.round(u3*i3*Math.cos(w3 * Math.PI / 180)*10)/10;\n\nvar s1 = Math.round(u1*i1*10)/10;\nvar s2 = Math.round(u2*i2*10)/10;\nvar s3 = Math.round(u3*i3*10)/10;\n\nvar q1 = Math.round(u1*i1*Math.sin(w1 * Math.PI / 180)*10)/10;\nvar q2 = Math.round(u2*i2*Math.sin(w2 * Math.PI / 180)*10)/10;\nvar q3 = Math.round(u3*i3*Math.sin(w3 * Math.PI / 180)*10)/10;\n\nvar i4 = Math.round((i1+i2+i3)*10)/10;  //Runden notwendig, da teilweise Werte mit zig Stellen rauskamen\nvar s4 = Math.round((s1+s2+s3)*10)/10;\nvar q4 = Math.round((q1+q2+q3)*10)/10;\nvar p4 = Math.round((p1+p2+p3)*10)/10;\n\nvar summe = Math.round(p1+p2+p3);\nsumme =  w-summe;\n/*\nif (summe < -0){\n    p1 = p1 * (-1);\n} \n*/\n\n/*\nvar w4 = (wertholen(':81.7.1*'));  //Winkel Spannung U2 U1\nvar w5 = (wertholen(':81.7.2*'));  //Winkel Spannung U3 U1\nw4 = 360 / w4;  //L2\nw5 = 360 / (w5-120);    //L3\n\nvar u12 = ((u1*Math.sqrt(3)+u2*Math.sqrt(w4))/2);\nvar u23 = ((u2*Math.sqrt(w4)+u3*Math.sqrt(w5))/2);\nvar u31 = ((u1*Math.sqrt(3)+u3*Math.sqrt(w5))/2);\n\nu12 = Math.round(u12*10)/10;\nu23 = Math.round(u23*10)/10;\nu31 = Math.round(u31*10)/10;\n\nnode.status({text:u12+\";\"+u23+\";\"+u31});\n*/\nvar cP1 = Math.round((p1/s1)*1000)/1000;\nvar cP2 = Math.round((p2/s2)*1000)/1000;\nvar cP3 = Math.round((p3/s3)*1000)/1000;\nvar cP4 = Math.round((p4/s4)*1000)/1000;\n\nnode.status({ text: \"Summe:\" + summe + \"; P:\" + w + \"; P0:\" + p4});\n\nreturn [\n    {\n        payload: kwhTotal, topic:Pfad+'Arbeit_Total', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwh, topic:Pfad+'Arbeit', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwh1, topic:Pfad+'Arbeit_001Tag', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwh7, topic:Pfad+'Arbeit_007Tage', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwh30, topic:Pfad+'Arbeit_030Tage', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwh365, topic:Pfad+'Arbeit_365Tage', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: w, topic:Pfad+'P', stateUnit: 'W', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: f, topic:Pfad+'F', stateUnit: 'Hz', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: u1, topic:Pfad+'U1', stateUnit: 'V', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: u2, topic:Pfad+'U2', stateUnit: 'V', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: u3, topic:Pfad+'U3', stateUnit: 'V', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: i1, topic:Pfad+'I1', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: i2, topic:Pfad+'I2', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: i3, topic:Pfad+'I3', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: i4, topic:Pfad+'I', stateUnit: 'A', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: p1, topic:Pfad+'P1', stateUnit: 'W', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: p2, topic:Pfad+'P2', stateUnit: 'W', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: p3, topic:Pfad+'P3', stateUnit: 'W', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: p4, topic:Pfad+'P0', stateUnit: 'W', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: s1, topic:Pfad+'S1', stateUnit: 'VA', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: s2, topic:Pfad+'S2', stateUnit: 'VA', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: s3, topic:Pfad+'S3', stateUnit: 'VA', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: s4, topic:Pfad+'S', stateUnit: 'VA', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: q1, topic:Pfad+'Q1', stateUnit: 'var', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: q2, topic:Pfad+'Q2', stateUnit: 'var', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: q3, topic:Pfad+'Q3', stateUnit: 'var', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: q4, topic:Pfad+'Q', stateUnit: 'var', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: cP1, topic:Pfad+'cosPhi1', stateUnit: '', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: cP2, topic:Pfad+'cosPhi2', stateUnit: '', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: cP3, topic:Pfad+'cosPhi3', stateUnit: '', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: cP4, topic:Pfad+'cosPhi', stateUnit: '', stateType: 'number', stateRole: 'value'\n    },\n    {\n        payload: kwhPVTotal, topic: Pfad + 'PV_Total', stateUnit: 'kWh', stateType: 'number', stateRole: 'value'\n    }\n];\n\n\n\n",
              "outputs": 32,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 450,
              "y": 300,
              "wires": [
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
                      "8725b4dd7db48627"
              "id": "7e6496b30f82a733",
              "type": "ioBroker out",
              "name": "",
              "topic": "",
              "ack": "true",
              "autoCreate": "true",
              "stateName": "",
              "role": "",
              "payloadType": "number",
              "readonly": "false",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1120,
              "y": 200,
              "wires": []
              "id": "8725b4dd7db48627",
              "type": "switch",
              "name": "Zahlen",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "istype",
                      "v": "number",
                      "vt": "number"
                      "t": "else"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 710,
              "y": 200,
              "wires": [
                      "6bd2ac13e94179f9"
              "id": "6bd2ac13e94179f9",
              "type": "switch",
              "name": "Gültig",
              "rules": [
                      "t": "lt",
                      "v": "-99990",
                      "vt": "num"
                      "t": "gt",
                      "v": "99999999",
                      "vt": "num"
                      "t": "else"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 890,
              "y": 200,
              "wires": [
                      "7e6496b30f82a733",
                      "da60cc6f5913df09"
              "id": "15844dfdf721c9c4",
              "type": "debug",
              "name": "",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "x": 850,
              "y": 40,
              "wires": []
              "id": "af6725d8ac794375",
              "name": "",
              "topic": "0_userdata.0.Zaehler.Strom.Timeout",
              "ack": "true",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1350,
              "y": 300,
              "wires": []
              "id": "da60cc6f5913df09",
              "type": "timeout",
              "name": "Timeout",
              "outtopic": "",
              "outsafe": "Stromzähler OK",
              "outwarning": "Warnung Verbindung Stromzähler",
              "outunsafe": "Fehler Verbindung Stromzähler",
              "warning": "60",
              "timer": "300",
              "repeat": false,
              "again": true,
              "x": 1080,
              "y": 320,
              "wires": [
                      "af6725d8ac794375"
              "id": "1d80687864318675",
              "type": "comment",
              "name": "LOGAREX LK13BE",
              "info": "",
              "x": 150,
              "y": 20,
              "wires": []
