    4. Zigbee Adapter mit Error "Class extends value"
      kanonidom last edited by
      Hallo liebe Profis!
      ich habe eine frische Docker-Installation á la buanet heute gemacht.
      Schon ein paar Jahre her seit meiner letzten Begegnung mit iob.
      Der Zigbee-Adapter macht nun allerdings nicht mit.
      Er wirft direkt beim starten die Fehler im Log auf, siehe weiter unten:
      host.iobroker 2024-03-24 15:34:56.116	info	"system.adapter.zigbee.0" disabled
      host.iobroker 2024-03-24 15:34:41.445	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker 2024-03-24 15:34:41.445	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker 2024-03-24 15:34:41.444	error	Caught by controller[0]: Node.js v18.19.1
      host.iobroker 2024-03-24 15:34:41.444	error	Caught by controller[0]: at node:internal/main/run_main_module:28:49
      host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
      host.iobroker 2024-03-24 15:34:41.443	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
      host.iobroker 2024-03-24 15:34:41.442	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      host.iobroker 2024-03-24 15:34:41.442	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
      host.iobroker 2024-03-24 15:34:41.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:58:28)
      host.iobroker 2024-03-24 15:34:41.441	error	Caught by controller[0]: TypeError: Class extends value #<Object> is not a constructor or null
      host.iobroker 2024-03-24 15:34:41.440	error	Caught by controller[0]: ^
      host.iobroker 2024-03-24 15:34:41.440	error	Caught by controller[0]: class Zigbee extends utils.Adapter {
      host.iobroker 2024-03-24 15:34:41.439	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/main.js:58
      admin.0       2024-03-24 15:34:38.754	info	<== Disconnect system.user.admin from ::ffff:192.168.188.52
      host.iobroker 2024-03-24 15:34:33.112	info	instance system.adapter.zigbee.0 started with pid 563
      host.iobroker 2024-03-24 15:34:28.258	info	Restart adapter system.adapter.zigbee.0 because enabled
      NPM, node.js etc. ist eigentlich alles auf stand, siehe weiter unten.
      ich habe die devices sauber durchgereicht an docker, daran kann es nicht liegen meiner Meinung nach.
      Irgendwelche Ideen, was ich machen kann?
      System schon neu gestartet, nochmals neu das stack deployed, auch schon den Adapter de-installiert und wieder installiert. bislang ohne Erfolg.
      Danke vorab!
      • Adaptername: zigbee
      • Link zu Adapterrepository: http://download.iobroker.net/sources-dist.json
      • Adapterversion: 1.10.1
      • js-controller Version: 5:0:19
      • Admin Version: 6.13.16
      • Hardwaresystem: Pi4
      • Arbeitsspeicher: 8GB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: linux debian
      • Nodejs-Version: v18.19.1
      • NPM-Version: 10.2.4
      • Installationsart: docker compose
      • Image, Docker genutzt: ja
      • Ort, Name der Imagedatei: buanet/docker:v9.1.1
        arteck Developer Most Active @kanonidom last edited by arteck
        @kanonidom deinstalliere den Adapter und installiere den nochmal mal neu.. da gabs eine kleine Unschärfe
          kanonidom @arteck last edited by
          @arteck Danke Dir! Das hat funktioniert!
