    4. Windows "Der Name für den Dienst ist ungültig"
    • G
      gooflo last edited by
      Hallo, ich wollte iobroker zunächst mal auf Windwos kurz testen, bevor es auf einen Raspi geht. Leider schlägt die Installation fehl. Weiß jemand Rat?
      Npm prefix path exists: C:\Users\flori\AppData\Roaming\npm
      Windows installation starting... (fixing = false)
      NPM version: 10.2.4
      npm WARN config production Use --omit=dev instead.
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      added 568 packages, and audited 569 packages in 34s
      60 packages are looking for funding
      run npm fund for details
      25 vulnerabilities (1 low, 20 moderate, 4 high)
      To address issues that do not require attention, run:
      npm audit fix
      To address all issues (including breaking changes), run:
      npm audit fix --force
      Run npm audit for details.
      Write "iobroker start" to start the ioBroker
      npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
      up to date, audited 569 packages in 2s
      npm audit fix
      npm install dotenv@^16.0.3 --force --loglevel error --production --save --prefix "C:/ioBroker"
      changed 1 package, and audited 569 packages in 2s
      59 packages are looking for funding
      npm audit fix
      npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
      npm audit fix
      Written iobnodevars.bat successfully.
      Startmenu folder C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform created!
      loc: 'winsw.js ~line 77',
      xml: [
      { id: 'iobroker.exe' },
      { name: 'ioBroker' },
      { description: 'ioBroker service.' },
      { executable: 'C:\Program Files\nodejs\node.exe' },
      { argument: '--harmony' },
      argument: 'C:\ioBroker\node_modules\node-windows\lib\wrapper.js'
      config: {
      nodeOptions: '--harmony',
      script: 'C:\ioBroker\node_modules\node-windows\lib\wrapper.js',
      scriptOptions: '',
      wrapperArgs: [
      '--file',
      'C:\ioBroker\controller.js',
      '--scriptoptions=',
      '--log',
      'ioBroker wrapper',
      '--grow',
      0.25,
      '--wait',
      1,
      '--maxrestarts',
      3,
      '--abortonerror',
      'n',
      '--stopparentfirst',
      undefined
      description: 'ioBroker service.',
      logpath: null,
      env: { name: 'NODE_ENV', value: 'production' },
      execPath: null,
      logOnAs: {
      account: null,
      password: null,
      domain: 'SNOOPY4',
      mungeCredentialsAfterInstall: true
      workingdirectory: 'C:\ioBroker',
      stopparentfirst: undefined,
      stoptimeout: 30,
      logmode: 'rotate',
      logging: undefined,
      allowServiceLogon: undefined
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
      Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
      ioBroker started!
      Visit http://127.0.0.1:8081 to configure it.
      Running Admin shell
      ioBroker service name: ioBroker
      Der Name fr den Dienst ist ungltig.
      Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 2185 eingeben.
      ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
      To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      • sigi234
        sigi234 Forum Testing Most Active @gooflo last edited by
        @gooflo
        Warum nimmst du nicht den Installer?
        https://forum.iobroker.net/topic/63610/test-iobroker-unter-windows-installieren-2023-edition
