    4. Iobroker Admin nach Update nicht zu erreichen
    • I
      iotowago last edited by
      Guten Abend,
      nach dem Update der Admin-Instanz ist ein Zugriff auf diese nicht mehr möglich.
      Nachfolgenden Fehler liefert Kommando "iob diag"
      Wo liegt mein Fehler? Vielen Dank im Voraus.
      2024-03-24 20:58:05.684  - info: host.HP-ProDesk-600-G2-DM instance system.adapter.modbus.1 started with pid 1777
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: /opt/iobroker/node_modules/iobroker.modbus/main.js:16
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     adapter = new utils.Adapter(options);
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:               ^
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: TypeError: utils.Adapter is not a constructor
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.modbus/main.js:16:15)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.modbus/main.js:945:5)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
      2024-03-24 20:58:06.083  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at node:internal/main/run_main_module:28:49
      2024-03-24 20:58:06.084  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: Node.js v18.19.1
      2024-03-24 20:58:06.084  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.modbus.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-03-24 20:58:06.084  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.modbus.1 because enabled
      2024-03-24 20:58:06.295  - warn: shelly.0 (1159) [authEnabled] 192.168.2.44 (shellyplus2pm / shellyplus2pm-d48afc760bb4 / shellyplus2pm#d48afc760bb4#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-03-24 20:58:06.324  - warn: shelly.0 (1159) [authEnabled] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-03-24 20:58:06.379  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.44 (shellyplus2pm / shellyplus2pm-d48afc760bb4 / shellyplus2pm#d48afc760bb4#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2024-03-24 20:58:06.464  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2024-03-24 20:58:06.525  - warn: shelly.0 (1159) [authEnabled] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-03-24 20:58:06.601  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2024-03-24 20:58:09.015  - warn: shelly.0 (1159) [authEnabled] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-03-24 20:58:09.086  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.27 (shellyplus2pm / shellyplus2pm-d48afc768a84 / shellyplus2pm#d48afc768a84#1): "General Status Notifications" are disabled (see adapter documentation for details)
      2024-03-24 20:58:11.798  - warn: shelly.0 (1159) [authEnabled] 192.168.2.198 (shellyswitch25 / shellyswitch25-98CDAC2C6600 / SHSW-25#98CDAC2C6600#1): This device is not protected via restricted login (see adapter documentation for details)
      Thomas Braun Samson71 Codierknecht 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @iotowago last edited by
        @iotowago sagte in Iobroker Admin nach Update nicht zu erreichen:
        Und was liefert das noch?
        Vollständige Ausgabe der Langfassung.
        • Samson71
          Samson71 Global Moderator @iotowago last edited by
          @iotowago
          Ging es beim anderen Post nicht schnell genug?
          https://forum.iobroker.net/topic/73684/iobroker-admin-nicht-mehr-erreichbar/5
          I 1 Reply Last reply Reply Quote 1
          • Codierknecht
            Codierknecht Developer Most Active @iotowago last edited by
            @iotowago
            Darin dass Du nur einen Teil des Log und nicht die Ausgabe von iob diag zeigst.
            • I
              iotowago @Codierknecht last edited by Homoran
              @codierknecht @Thomas-Braun
              Teil 1
              Skript v.2023-10-10
              *** BASE SYSTEM ***
               Static hostname: HP-ProDesk-600-G2-DM
                     Icon name: computer-desktop
                       Chassis: desktop 🖥️
              Operating System: Ubuntu 23.10
                        Kernel: Linux 6.5.0-26-generic
                  Architecture: x86-64
               Hardware Vendor: HP
                Hardware Model: HP ProDesk 600 G2 DM
              Firmware Version: N22 Ver. 02.18
                 Firmware Date: Mon 2017-03-27
              model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
              Docker          : false
              Virtualization  : none
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               21:02:25 up 5 min,  3 users,  load average: 0.13, 0.40, 0.24
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Sun 2024-03-24 21:02:25 CET
                         Universal time: Sun 2024-03-24 20:02:25 UTC
                               RTC time: Sun 2024-03-24 20:02:24
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              iobroker
              /home/iobroker
              iobroker adm tty dialout cdrom sudo audio dip video plugdev users bluetooth lpadmin
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.2G        966M        6.5G        2.0M        966M        7.2G
              Swap:           4.3G          0B        4.3G
              Total:           12G        966M         10G
                       7813 M total memory
                        922 M used memory
                        810 M active memory
                        499 M inactive memory
                       6227 M free memory
                         69 M buffer memory
                        852 M swap cache
                       4095 M total swap
                          0 M used swap
                       4095 M free swap
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              tmpfs          tmpfs     782M  1.6M  780M   1% /run
              /dev/sda2      ext4      116G   17G   94G  16% /
              tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
              efivarfs       efivarfs  118K   53K   61K  47% /sys/firmware/efi/efivars
              /dev/sda1      vfat      1.1G  6.1M  1.1G   1% /boot/efi
              tmpfs          tmpfs     782M   60K  782M   1% /run/user/1000
              [Sun Mar 24 20:56:29 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
              [Sun Mar 24 20:56:29 2024] EXT4-fs (sda2): mounted filesystem fe2c8c46-6ceb-46c0-8153-bae82b9b0c7c ro with ordered data mode. Quota mode: none.
              [Sun Mar 24 20:56:30 2024] EXT4-fs (sda2): re-mounted fe2c8c46-6ceb-46c0-8153-bae82b9b0c7c r/w. Quota mode: none.
              TARGET                                   SOURCE                         FSTYPE      OPTIONS
              /                                        /dev/sda2                      ext4        rw,relatime
              |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |-/snap/bare/5                           /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/core20/2105                      /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
              |-/snap/core22/1033                      /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/core22/1122                      /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/core20/2182                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/curl/1754                        /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/firefox/3941                     /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/firefox/3972                     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/firmware-updater/121             /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/gnome-42-2204/141                /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/gnome-42-2204/172                /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/gtk-common-themes/1535           /dev/loop11                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/snap-store/1113                  /dev/loop13                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/snap-store/959                   /dev/loop12                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/snapd/21184                      /dev/loop15                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/snapd/20671                      /dev/loop14                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              |-/snap/snapd-desktop-integration/83     /dev/loop16                    squashfs    ro,nodev,relatime,errors=continue,threads=single
              `-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime
              /var:
              4.2G    /var/
              3.4G    /var/lib
              3.1G    /var/lib/snapd
              2.2G    /var/lib/snapd/snaps
              934M    /var/lib/snapd/seed/snaps
              Archived and active journals take up 229.4M in the file system.
              /opt/iobroker/backups:
              32M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              211M    /opt/iobroker/iobroker-data/
              158M    /opt/iobroker/iobroker-data/files
              57M     /opt/iobroker/iobroker-data/files/javascript.admin
              38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
              38M     /opt/iobroker/iobroker-data/backup-objects
              22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
              11M     /opt/iobroker/iobroker-data/objects.jsonl
              8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.1
              /usr/bin/node           v18.19.1
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              nodejs:
                Installed: 18.19.1-1nodesource1
                Candidate: 18.19.1-1nodesource1
                Version table:
               *** 18.19.1-1nodesource1 600
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.19.0-1nodesource1 600
                   18.18.2-1nodesource1 600
                   18.18.1-1nodesource1 600
                   18.18.0-1nodesource1 600
                   18.17.1-1nodesource1 600
                   18.17.0-1nodesource1 600
                   18.16.1-1nodesource1 600
                   18.16.0-1nodesource1 600
                   18.15.0-1nodesource1 600
                   18.14.2-1nodesource1 600
                   18.14.1-1nodesource1 600
                   18.14.0-1nodesource1 600
                   18.13.0+dfsg1-1ubuntu2.1 500
                      500 http://de.archive.ubuntu.com/ubuntu mantic-updates/universe amd64 Packages
                      500 http://security.ubuntu.com/ubuntu mantic-security/universe amd64 Packages
                   18.13.0+dfsg1-1ubuntu2 500
                      500 http://de.archive.ubuntu.com/ubuntu mantic/universe amd64 Packages
                   18.13.0-1nodesource1 600
                   18.12.0-1nodesource1 600
                   18.11.0-1nodesource1 600
                   18.10.0-1nodesource1 600
                   18.9.1-1nodesource1 600
                   18.9.0-1nodesource1 600
                   18.8.0-1nodesource1 600
                   18.7.0-1nodesource1 600
                   18.6.0-1nodesource1 600
                   18.5.0-1nodesource1 600
                   18.4.0-1nodesource1 600
                   18.3.0-1nodesource1 600
                   18.2.0-1nodesource1 600
                   18.1.0-1nodesource1 600
                   18.0.0-1nodesource1 600
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     7.8.0
              Adapters from github:   1
              Adapter State
                system.adapter.admin.0                  : admin                 : HP-ProDesk-600-G2-DM                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : HP-ProDesk-600-G2-DM                     -  enabled
                system.adapter.discovery.0              : discovery             : HP-ProDesk-600-G2-DM                     - disabled
                system.adapter.goodwe.0                 : goodwe                : HP-ProDesk-600-G2-DM                     - disabled
                system.adapter.goodwe.1                 : goodwe                : HP-ProDesk-600-G2-DM                     - disabled
                system.adapter.javascript.0             : javascript            : HP-ProDesk-600-G2-DM                     - disabled
                system.adapter.modbus.0                 : modbus                : HP-ProDesk-600-G2-DM                     -  enabled
                system.adapter.modbus.1                 : modbus                : HP-ProDesk-600-G2-DM                     -  enabled
                system.adapter.node-red.0               : node-red              : HP-ProDesk-600-G2-DM                     -  enabled, port: 1880, bind: 0.0.0.0
              + system.adapter.shelly.0                 : shelly                : HP-ProDesk-600-G2-DM                     -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.vis.0                    : vis                   : HP-ProDesk-600-G2-DM                     - disabled
                system.adapter.web.0                    : web                   : HP-ProDesk-600-G2-DM                     - disabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : HP-ProDesk-600-G2-DM                     -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "backitup"     : 2.10.11  , installed 2.10.11
              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Adapter    "modbus"       : 6.1.0    , installed 6.1.0
              Adapter    "node-red"     : 5.1.0    , installed 5.1.0
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "web"          : 6.2.3    , installed 6.2.3
              Adapter    "ws"           : 2.5.10   , installed 2.5.10
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Objects and States
              Objects:        1316
              States:         951
              Hit:1 http://de.archive.ubuntu.com/ubuntu mantic InRelease
              Hit:2 http://security.ubuntu.com/ubuntu mantic-security InRelease
              Hit:3 http://de.archive.ubuntu.com/ubuntu mantic-updates InRelease
              Hit:4 http://de.archive.ubuntu.com/ubuntu mantic-backports InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       27196      943/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       27189      943/iobroker.js-con
              tcp        0      0 127.0.0.1:45639         0.0.0.0:*               LISTEN      1000       37126      1418/io.yahka.0
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          28022      942/cupsd
              tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      996        26639      688/systemd-resolve
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      996        26637      688/systemd-resolve
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       27417      1159/io.shelly.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          742        1/init
              tcp6       0      0 :::36609                :::*                    LISTEN      1000       29881      1418/io.yahka.0
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          28021      942/cupsd
              tcp6       0      0 :::111                  :::*                    LISTEN      0          2412       1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          26887      1/init
              udp        0      0 127.0.0.54:53           0.0.0.0:*                           996        26638      688/systemd-resolve
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           996        26636      688/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17486      1/init
              udp        0      0 0.0.0.0:58080           0.0.0.0:*                           110        26993      817/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       29886      1418/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       29885      1418/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           110        26991      817/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          743        1/init
              udp6       0      0 :::53430                :::*                                110        26994      817/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                110        26992      817/avahi-daemon: r
              2024-03-24 21:02:38.889  - info: host.HP-ProDesk-600-G2-DM instance system.adapter.modbus.1 started with pid 3480
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: /opt/iobroker/node_modules/iobroker.modbus/main.js:16
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     adapter = new utils.Adapter(options);
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:               ^
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: TypeError: utils.Adapter is not a constructor
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at startAdapter (/opt/iobroker/node_modules/iobroker.modbus/main.js:16:15)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.modbus/main.js:945:5)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]:     at node:internal/main/run_main_module:28:49
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM Caught by controller[0]: Node.js v18.19.1
              2024-03-24 21:02:39.215  - error: host.HP-ProDesk-600-G2-DM instance system.adapter.modbus.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-03-24 21:02:39.215  - info: host.HP-ProDesk-600-G2-DM Restart adapter system.adapter.modbus.1 because enabled
              2024-03-24 21:02:43.536  - warn: shelly.0 (1159) [authEnabled] 192.168.2.44 (shellyplus2pm / shellyplus2pm-d48afc760bb4 / shellyplus2pm#d48afc760bb4#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-03-24 21:02:43.611  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.44 (shellyplus2pm / shellyplus2pm-d48afc760bb4 / shellyplus2pm#d48afc760bb4#1): "General Status Notifications" are disabled (see adapter documentation for details)
              2024-03-24 21:02:44.484  - warn: shelly.0 (1159) [authEnabled] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-03-24 21:02:44.628  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.128 (shellyplus2pm / shellyplus2pm-d48afc76158c / shellyplus2pm#d48afc76158c#1): "General Status Notifications" are disabled (see adapter documentation for details)
              2024-03-24 21:02:47.351  - warn: shelly.0 (1159) [authEnabled] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-03-24 21:02:47.496  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.199 (shellyplus2pm / shellyplus2pm-d48afc4139f0 / shellyplus2pm#d48afc4139f0#1): "General Status Notifications" are disabled (see adapter documentation for details)
              2024-03-24 21:02:47.749  - warn: shelly.0 (1159) [authEnabled] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): This device is not protected via restricted login (see adapter documentation for details)
              2024-03-24 21:02:47.815  - warn: shelly.0 (1159) [Mqtt.statusNotifications] 192.168.2.8 (shellypro4pm / shellypro4pm-34987a67e348 / shellypro4pm#34987a67e348#1): "General Status Notifications" are disabled (see adapter documentation for details)
              2024-03-24 21:02:49.521  - warn: shelly.0 (1159) [authEnabled] 192.168.2.198 (shellyswitch25 / shellyswitch25-98CDAC2C6600 / SHSW-25#98CDAC2C6600#1): This device is not protected via restricted login (see adapter documentation for details)
                                      v.2023-10-10
                       Chassis: desktop 🖥️
               Hardware Vendor: HP
              Userland:               amd64
              User-ID:                1000
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                      /usr/bin/npm            10.2.4
                                      /usr/bin/npx            10.2.4
              MEMORY:
              Mem:            8.2G        1.0G        6.5G        2.0M        968M        7.1G
              Swap:           4.3G          0B        4.3G
              Total:           12G        1.0G         10G
              Active iob-Instances:   4
                                      admin                   6.13.16
              Objects type: jsonl
              States  type: jsonl
              Objects:                1316
              States:                 951
              Size of iob-Database:
              5.9M    /opt/iobroker/iobroker-data/states.jsonl
              • I
                iotowago @Samson71 last edited by
                @samson71
                Nein, ich vermute jedoch, dass bei mir ein anderer Fehler vorliegt und habe das ganze in einem neuen Thread veröffentlicht, um nicht zwei Sachverhalte zu vermischen. Hoffe, dass dies in Ordnung ist.
                  @iotowago
                  Da hat es Dateien gefetzt:
                  Und Ubuntu 23.10 ist für einen Serverbetrieb auch eine schlechte Wahl, da verwendet man nur LTS-Versionen. Und auch die in der Server-Variante, nicht als Desktop-Version.
                  • I
                    iotowago @Thomas Braun last edited by
                    ok, schon mal vielen Dank für die Info, sowas dachte ich mir schon, das heißt einmal Iobroker neu aufsetzen, oder?
                    welches Betriebssystem würdest du mir für den Rechner empfehlen? Ubuntu Server LTS 22.04.4
                    Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
                    • Codierknecht
                      @iotowago
                      Warum Ubuntu und nicht das Original?
                      Debian 12 „bookworm“ … ohne Desktop.
                      • I
                        @codierknecht
                        Ich bin offen für Vorschläge, da jegliche Systeme außerhalb von Windows und SPS-Programmen weit entfernt von meinem täglichen Brot sind.
                        Danke für den Tipp und einen schönen Abend.
                          Debian 12 'Bookworm'.
                          465
