    4. Probleme mit npm bei Iobroker installation
    • N
      NFTVirus last edited by
      Hallo
      ich versuche gerade mein iobroker neu auf zu setzen. Allerdings gibt es irgendwie immer Probleme mit der npm Installation hier mal mein iob diag File:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       16:33:53 up  1:59,  2 users,  load average: 0.18, 3.94, 12.29
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
                     Local time: Tue 2024-03-26 16:33:53 CET
                 Universal time: Tue 2024-03-26 15:33:53 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            951M        276M        486M        229K        255M        675M
      Swap:           104M         20M         84M
      Total:          1.1G        296M        570M
                907 M total memory
                263 M used memory
                226 M active memory
                119 M inactive memory
                464 M free memory
                 23 M buffer memory
                220 M swap cache
                 99 M total swap
                 19 M used swap
                 80 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  318M     0  318M   0% /dev
      tmpfs          tmpfs      91M  1.1M   90M   2% /run
      /dev/mmcblk0p2 ext4       29G  2.5G   25G  10% /
      tmpfs          tmpfs     454M     0  454M   0% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   63M  448M  13% /boot/firmware
      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
      [Tue Mar 26 14:34:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=192d7b3d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Mar 26 14:34:41 2024] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
      [Tue Mar 26 14:34:44 2024] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      513M    /var/
      203M    /var/cache
      197M    /var/cache/apt
      161M    /var/lib
      133M    /var/lib/apt/lists
      Archived and active journals take up 48.0M in the file system.
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      14M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2466692-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.1
      /usr/bin/node           v18.19.1
      /usr/bin/npm            10.2.4
      /usr/bin/npx            10.2.4
      nodejs:
        Installed: 18.19.1-1nodesource1
        Candidate: 18.19.1-1nodesource1
        Version table:
       *** 18.19.1-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      find: '/opt/iobroker/node_modules': No such file or directory
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-26T15_34_03_649Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1137
        throw err;
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.1
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.19.1
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.1
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.1
      javascript:
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-03-26T15_34_07_732Z-debug-0.log
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.1
        throw err;
        requireStack: []
      Node.js v18.19.1
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.19.1
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.19.1
      Objects and States
      Objects:        0
      States:         0
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5486       603/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       47117      11617/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       47110      11617/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44593      11654/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5488       603/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3049       436/avahi-daemon: r
      udp        0      0 0.0.0.0:36870           0.0.0.0:*                           104        3051       436/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        3050       436/avahi-daemon: r
      udp6       0      0 fe80::7aa9:1a5c:f94:546 :::*                                0          5044       505/NetworkManager
      udp6       0      0 :::59041                :::*                                104        3052       436/avahi-daemon: r
      2024-03-26 15:03:56.349  - info: host.raspberrypi iobroker.js-controller version 5.0.19 js-controller starting
      2024-03-26 15:03:56.369  - info: host.raspberrypi Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-03-26 15:03:56.372  - info: host.raspberrypi hostname: raspberrypi, node: v18.19.1
      2024-03-26 15:03:56.374  - info: host.raspberrypi ip addresses: 192.168.178.66 2001:9e8:afb1:6500:795a:2fed:21ad:69ae fd00::c4bf:562:3ef2:5b6f fe80::7aa9:1a5c:f94a:62f6
      2024-03-26 15:03:57.213  - info: host.raspberrypi connected to Objects and States
      2024-03-26 15:03:57.280  - info: host.raspberrypi Node.js version has changed from unknown to 18.19.1
      2024-03-26 15:03:57.404  - info: host.raspberrypi added notifications configuration of host
      2024-03-26 15:03:57.434  - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2024-03-26 15:03:58.508  - info: host.raspberrypi 2 instances found
      2024-03-26 15:03:58.524  - info: host.raspberrypi starting 2 instances
      2024-03-26 15:03:58.647  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 11654
      2024-03-26 15:04:02.595  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 11734
      2024-03-26 15:04:16.785  - info: discovery.0 (11734) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.1, js-controller: 5.0.19
      2024-03-26 15:04:17.239  - info: admin.0 (11654) starting. Version 6.13.16 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.1, js-controller: 5.0.19
      2024-03-26 15:04:17.400  - info: admin.0 (11654) requesting all objects
      2024-03-26 15:04:18.282  - info: admin.0 (11654) received all objects
      2024-03-26 15:04:52.087  - warn: admin.0 (11654) Cannot update news: timeout of 13000ms exceeded
      2024-03-26 15:05:01.808  - info: admin.0 (11654) socket.io server listening on port 8081
      2024-03-26 15:05:04.181  - info: admin.0 (11654) http server listening on port 8081
      2024-03-26 15:05:04.639  - info: admin.0 (11654) Use link "http://127.0.0.1:8081" to configure.
      2024-03-26 15:11:39.162  - warn: admin.0 (11654) Repository cannot be read: Active repo - stable
      2024-03-26 15:11:39.187  - warn: admin.0 (11654) Active repository "stable" cannot be read
      2024-03-26 16:25:13.982  - warn: admin.0 (11654) Cannot check node.js/npm version
      Hat jemand eine Idee was ich falsch mache?
      Schönen Gruß!
      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
      • crunchip
        crunchip Forum Testing Most Active @NFTVirus last edited by
        @nftvirus sagte in Probleme mit npm bei Iobroker installation:
        Fehlt da nicht eine?
        Netzwerk Probleme?
        Kenn ich so auch nicht
        Mem: 951M
        Damit lässt sich auch nur noch bedingt arbeiten, je nach Einsatzzweck
        • N
          NFTVirus @crunchip last edited by
          @crunchip
          Ja wegen Arbeitsspeicher ist eng aber bisher hatte das immer alles gepasst der Iobroker soll garnicht so viel machen ein paar Zigbee Geräte steuern und per Modbus die PV Anlage überwachen. Das hat alles mti dem Pi 3B+ in der Vergangenheit gut funktioniert aber jetzt ist gerade etwas der Wurm drin.
          Wegen Verbindungsprobleme muss ich mal im Fritz Box Log schauen der PI hängt direkt am LAN.
          Danke schonmal!
          • N
            NFTVirus @NFTVirus last edited by
            @nftvirus Hat niemand mehr eine Idee woran es liegen könnte?
              Thomas Braun Most Active @NFTVirus last edited by Thomas Braun
              /usr/bin/npm            10.2.4
              /usr/bin/npx            10.2.4
              Alles in Ordnung mit nodejs&Co.
              Deine Installation des ioBroker hängt schief. Wie genau machst du das?
              • N
                NFTVirus @Thomas Braun last edited by
                @thomas-braun habe ganz normal erst Bookworm per RPI Imager aufgespielt. Dann über
                curl -sLf https://iobroker.net/install.sh | bash -
                versucht den Iobroker zu installieren. Bei Punkt 3/4 iobroker installieren dauert es aber sehr lange. habe es jetzt schon mehrfach versucht immer mit den oben gezeigten Fehlermeldungen am Schluss.
                  Laufen lassen... Mit mageren 1GB dauert es eben sehr lange.
                  • N
                    @thomas-braun danke. ich werde die Karte nochmal formatieren und schauen ob es dann funktioniert.
