    4. Objects database error: connect ECONNREFUSED
      jmyxa last edited by
      Hallo allerseits,
      seit heute stürtz der Admin-Adapter (und auch alle anderen) ohne "Fremdeinwirkung" permanent ab.
      Die wohl ausschlaggebende Fehlermeldung lautet
      2024-03-28 07:47:33.064  - ^[[31merror^[[39m: admin.0 (5015) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.094  - ^[[31merror^[[39m: shelly.0 (5063) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.102  - ^[[31merror^[[39m: tuya.0 (5048) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.123  - ^[[31merror^[[39m: tuya.0 (5048) States database error: connect ECONNREFUSED 0.0.0.0:9000
      2024-03-28 07:47:33.152  - ^[[31merror^[[39m: zigbee.0 (5033) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.183  - ^[[31merror^[[39m: telegram.0 (5022) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.199  - ^[[31merror^[[39m: discovery.0 (5081) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      2024-03-28 07:47:33.192  - ^[[31merror^[[39m: sonos.0 (5070) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
      Was läuft hier schief?
        arteck Developer Most Active @jmyxa last edited by
        @jmyxa platte voll ?
          @arteck sieht nicht danach aus
          /dev/root       29768136 4255180  24271328  15% /
          devtmpfs          340460       0    340460   0% /dev
          tmpfs             472044       0    472044   0% /dev/shm
          tmpfs             188820     988    187832   1% /run
          tmpfs               5120       4      5116   1% /run/lock
          /dev/mmcblk0p1    261108   51630    209478  20% /boot
          tmpfs              94408       0     94408   0% /run/user/1000
            @jmyxa
            iob fix
            dann
            iob diag
            und Ausgabe posten
              jmyxa @arteck last edited by
              @arteck bei fix:
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                  at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
                  at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
                  at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                  at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
              No relevant JSONL files found to compress, skip
              bei diag:
              			v.2023-10-10
                 Static hostname: raspberry
                       Icon name: computer
                          Kernel: Linux 6.1.21-v7+
                    Architecture: arm
              Installation: 		native
              Kernel: 		armv7l
              Userland: 		armhf
              Timezone: 		Europe/Berlin (CET, +0100)
              User-ID: 		1000
              X-Server: 		false
              Boot Target: 		multi-user.target
              Pending OS-Updates: 	84
              Pending iob updates: 	14
              /home/iobroker/.diag.sh: line 486: nodejs: command not found
              Nodejs-Installation:
              			/usr/bin/node 		v18.17.1
              			/usr/bin/npm 		9.6.7
              			/usr/bin/npx 		9.6.7
              			/usr/bin/corepack 	0.18.0
              *** nodejs is NOT correctly installed ***
              Wrong installation path detected. This needs to be fixed.
              Please check
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              for more information on how to fix these errors.
              MEMORY:
              Mem:            921M        429M         92M        0.0K        399M        428M
              Swap:            99M         14M         85M
              Total:          1.0G        443M        178M
              Active iob-Instances: 	8
              Active repo(s): stable
              ioBroker Core: 		js-controller 		5.0.19
              			admin 			6.13.16
              ioBroker Status: 	iobroker is running on this host.
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : raspberry                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.web.0                    : web                   : raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects: 		6710
              States: 		5425
              Size of iob-Database:
              12M	/opt/iobroker/iobroker-data/objects.jsonl
              36K	/opt/iobroker/iobroker-data/objects.jsonl.old2
              6.8M	/opt/iobroker/iobroker-data/states.jsonl
                Thomas Braun Most Active @jmyxa last edited by Thomas Braun
                @jmyxa sagte in Objects database error: connect ECONNREFUSED:
                Dringend ran an den Update-Stau.
                Zuvor:
                iob nodejs-update
                  jmyxa @Thomas Braun last edited by
                  Es lag daran, dass der Zugriff auf states.jsonl und objects.jsons durch Locks verhindert war. Lock-Verzeichnisse löschen und rebooten.
                  Thomas Braun W 2 Replies Last reply Reply Quote 0
                    @jmyxa
                    Den Update-Stau musst du aber dennoch beseitigen.
                      Wildbill @jmyxa last edited by
                      @jmyxa Dennoch hält man seine Installationen auf aktuellem Stand. Und das hier zeigt, dass bei Dir NodeJS eben falsch installiert ist:
                      @Thomas-Braun hat Dir den nötigen Befehl zum Reparieren ja bereits genannt.
                      Gruss, Jürgen
