    4. Node-Red
    5. [Gelöst] Farbe in Text node ändern
      matthesjimte last edited by matthesjimte
      Guten Abend
      Ich versuche über Node Red meine Wallbox auszulesen und in Abhängig, ob aktiv oder pause, die Farbe des eingestellten Ladestrom im Dashboard anzuzeigen
      Generell den Ladestrom anzeigen ist ja kein Problem
      Versuche nun über das hier die Farbe zu ändern, komischerweise wird dann aber der angezeigte Wert in der richtigen Farbe hochgezählt
              "id": "59c32b5bc1facdbb",
              "type": "ioBroker get",
              "z": "da4e1b55.2906b",
              "name": "WB_load",
              "topic": "kecontact.0.currentUser",
              "attrname": "payload",
              "payloadType": "value",
              "x": 480,
              "y": 660,
              "wires": [
                      "3568d48737df6395"
              "id": "3568d48737df6395",
              "type": "function",
              "name": "f_WB_load",
              "func": "const str = msg.payload\nmsg.payload = str;\nreturn msg;",
              "outputs": 1,
              "timeout": "",
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 650,
              "y": 660,
              "wires": [
                      "b12b5ae3ad3944c8"
              "id": "1092b1c72d1424d3",
              "name": "Enable User",
              "topic": "kecontact.0.enableUser",
              "attrname": "incolor",
              "errOnInvalidState": "nothing",
              "x": 490,
              "y": 720,
              "wires": [
                      "b12b5ae3ad3944c8"
              "id": "b12b5ae3ad3944c8",
              "type": "switch",
              "name": "",
              "property": "incolor",
              "propertyType": "msg",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 730,
              "y": 720,
              "wires": [
                      "2d21dd1c28d55a2b"
                      "b3142ddf6e6058e9"
              "id": "2d21dd1c28d55a2b",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "fcolor",
                      "pt": "msg",
                      "to": "blue",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 920,
              "y": 700,
              "wires": [
                      "5a457c3ab9243da4"
              "id": "b3142ddf6e6058e9",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "fcolor",
                      "pt": "msg",
                      "to": "green",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 920,
              "y": 740,
              "wires": [
                      "5a457c3ab9243da4"
              "id": "5a457c3ab9243da4",
              "type": "ui_text",
              "group": "291784c0.74fa7c",
              "order": 20,
              "width": 0,
              "height": 0,
              "name": "",
              "label": "WB_load",
              "format": "<font face='arial'><font size=4><font color={{fcolor}}>{{msg.payload}}",
              "layout": "row-spread",
              "className": "",
              "style": false,
              "font": "",
              "fontSize": 16,
              "color": "#000000",
              "x": 1120,
              "y": 680,
              "wires": []
              "id": "291784c0.74fa7c",
              "type": "ui_group",
              "name": "TWS",
              "tab": "ff1df1fe.ccf768",
              "order": 1,
              "disp": true,
              "width": "6",
              "collapse": true
              "id": "ff1df1fe.ccf768",
              "type": "ui_tab",
              "name": "Home",
              "icon": "dashboard",
              "disabled": false,
              "hidden": false
      Wenn ich das jetzt nochmal umstelle, wird der Wert richtig angezeigt
      wenn ich jetzt die Farben hinzunehme
      kommt das dabei raus
      Was mache ich falsch?
        matthesjimte @matthesjimte last edited by matthesjimte
        @matthesjimte
        Habe es jetzt nochmal geändert
        und es sieht so aus als wenn es jetzt funktionieren würde.
        Mal schauen ob es dann morgen grün wird, wenn die Wallbox aus ihrer Pause erwacht
        So geht es jetzt
        1.1k
        node-red
