    4. OpenKNX Adapter startet nicht mehr nach System-Update
      rsw2004 last edited by
      Moin moin,
      ich habe Heute das System geupdatet und seitdem startet der OpenKNX Adapter nicht mehr.
      Node.js: v18.20.0
      NPM: 10.5.0
      js-controller: 5.0.19
      Das Update ist sauber durchgelaufen, allerdings habe ich irgendwann festgestellt, dass der OpenKNX Adapter nicht mehr startet.
      Hatte mal zu Testzwecken eine neue Instanz installiert, aber gleiches Problem.
      Beim Starten sagt das LOG-File folgendes:
      host.raspberrypi4
      2024-03-30 09:32:48.944	info	iobroker npm-rebuild: Rebuilding native modules ...
      host.raspberrypi4
      2024-03-30 09:32:47.583	info	iobroker rebuild
      host.raspberrypi4
      2024-03-30 09:32:47.582	warn	adapter "openknx" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.raspberrypi4
      2024-03-30 09:32:47.581	info	system.adapter.openknx.0 will be rebuilt
      host.raspberrypi4
      2024-03-30 09:32:47.581	info	Adapter system.adapter.openknx.0 needs rebuild and will be restarted afterwards.
      host.raspberrypi4
      2024-03-30 09:32:47.581	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi4
      2024-03-30 09:32:47.580	error	Caught by controller[0]: Node.js v18.20.0
      host.raspberrypi4
      2024-03-30 09:32:47.580	error	Caught by controller[0]: }
      host.raspberrypi4
      2024-03-30 09:32:47.580	error	Caught by controller[0]: ]
      host.raspberrypi4
      2024-03-30 09:32:47.580	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
      host.raspberrypi4
      2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
      host.raspberrypi4
      2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
      host.raspberrypi4
      2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
      host.raspberrypi4
      2024-03-30 09:32:47.579	error	Caught by controller[0]: requireStack: [
      host.raspberrypi4
      2024-03-30 09:32:47.578	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi4
      2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
      host.raspberrypi4
      2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.raspberrypi4
      2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.raspberrypi4
      2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.raspberrypi4
      2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.raspberrypi4
      2024-03-30 09:32:47.576	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
      host.raspberrypi4
      2024-03-30 09:32:47.576	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.raspberrypi4
      2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.raspberrypi4
      2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
      host.raspberrypi4
      2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: Require stack:
      host.raspberrypi4
      2024-03-30 09:32:47.575	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
      host.raspberrypi4
      2024-03-30 09:32:47.574	error	Caught by controller[0]: ^
      host.raspberrypi4
      2024-03-30 09:32:47.574	error	Caught by controller[0]: throw err;
      host.raspberrypi4
      2024-03-30 09:32:47.573	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
      host.raspberrypi4
      2024-03-30 09:32:46.315	info	instance system.adapter.openknx.0 started with pid 8774
      Hatte in einem anderen Forum die vermeintliche Lösung für das Problem gefunden, allerdings hat das bei mir nicht funktioniert mit:
      npm install iobroker/adapter-core
      Was habe ich falsch gemacht? / Was ist zu tun?
      Danke euch
        Thomas Braun Most Active @rsw2004 last edited by
        @rsw2004
        cd /opt/iobroker
        npm ls ipaddr.js
        Und die Ausgabe von
        iob diag
          rsw2004 @Thomas Braun last edited by
          @thomas-braun said in OpenKNX Adapter startet nicht mehr nach System-Update:
          cd /opt/iobroker
          npm ls ipaddr.js
          robin@raspberrypi4:~ $ cd /opt/iobroker
          npm ls ipaddr.js
          iobroker.inst@3.0.0 /opt/iobroker
          ├─┬ iobroker.admin@6.13.16
          │ └─┬ express@4.18.2
          │   └─┬ proxy-addr@2.0.7
          │     └── ipaddr.js@1.9.1
          └─┬ iobroker.openknx@0.7.2
            └─┬ knx@2.5.2
              └── ipaddr.js@1.2.0
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi4
                 Icon name: computer
                    Kernel: Linux 6.6.20+rpt-rpi-v8
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           11:36:17 up  2:42,  2 users,  load average: 0.36, 0.40, 0.36
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2024-03-30 11:36:17 CET
                     Universal time: Sat 2024-03-30 10:36:17 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          robin
          /home/robin
          robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.0G        1.6G        1.3G        1.2M        1.2G        2.4G
          Total:          4.1G        1.6G        1.4G
                   3791 M total memory
                   1482 M used memory
                   1717 M active memory
                    664 M inactive memory
                   1207 M free memory
                    118 M buffer memory
                   1058 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  378M   1% /run
          /dev/sda2      ext4      459G  5.7G  430G   2% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sat Mar 30 08:53:19 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e253307-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sat Mar 30 08:53:22 2024] EXT4-fs (sda2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
          [Sat Mar 30 08:53:23 2024] EXT4-fs (sda2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,noatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.3G    /var/
          660M    /var/log
          659M    /var/log/journal/1752ab92354a4fbe8ab5b2bd3f56c61e
          369M    /var/cache
          Archived and active journals take up 658.3M in the file system.
          /opt/iobroker/backups:
          /opt/iobroker/iobroker-data:
          385M    /opt/iobroker/iobroker-data/
          286M    /opt/iobroker/iobroker-data/files
          142M    /opt/iobroker/iobroker-data/files/vis-2
          81M     /opt/iobroker/iobroker-data/files/vis-2/static
          80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
          15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.0
          /usr/bin/node           v18.20.0
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.0-1nodesource1
            Candidate: 18.20.0-1nodesource1
            Version table:
           *** 18.20.0-1nodesource1 500
                  100 /var/lib/dpkg/status
               18.19.1-1nodesource1 500
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 500
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi4                             -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
            system.adapter.openknx.0                : openknx               : raspberrypi4                             -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : raspberrypi4                             -  enabled
          + system.adapter.solax.0                  : solax                 : raspberrypi4                             -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi4                             -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi4                             -  enabled
            system.adapter.vis-2.0                  : vis-2                 : raspberrypi4                             - disabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.0                  : yahka                 : raspberrypi4                             -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Adapter    "openknx"      : 0.7.2    , installed 0.7.2
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "solax"        : 0.9.6    , installed 0.9.6
          Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
          Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
          Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
          Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects:        2579
          States:         2188
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:40331           0.0.0.0:*               LISTEN      1001       29572      9139/io.yahka.0
          tcp        0      0 127.0.0.1:43343         0.0.0.0:*               LISTEN      1001       32228      9139/io.yahka.0
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       29544      9102/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6464       684/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31136      8646/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31129      8646/iobroker.js-co
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        4759       753/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31196      8664/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31589      9005/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6466       684/sshd: /usr/sbin
          tcp6       0      0 :::3000                 :::*                    LISTEN      106        6538       800/grafana
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1929       533/avahi-daemon: r
          udp        0      0 0.0.0.0:50513           0.0.0.0:*                           104        1931       533/avahi-daemon: r
          udp6       0      0 :::33890                :::*                                104        1932       533/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        1930       533/avahi-daemon: r
          2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
          2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
          2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
          2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
          2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
          2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
          2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
          2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
          2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
          2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
          2024-03-30 11:35:25.907  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19) {
          2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
          2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   requireStack: [
          2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
          2024-03-30 11:35:25.912  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
          2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
          2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/main.js'
          2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]:   ]
          2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]: }
          2024-03-30 11:35:25.915  - error: host.raspberrypi4 Caught by controller[0]: Node.js v18.20.0
          2024-03-30 11:35:25.915  - error: host.raspberrypi4 instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          2024-03-30 11:35:25.916  - info: host.raspberrypi4 Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
          2024-03-30 11:35:56.805  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
          2024-03-30 11:36:57.902  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
          code_text
            @rsw2004
            Nichts auffälliges.
            Installier den openknx nochmal frisch darüber.
              wie gesagt, hatte bereits eine neue Instanz installiert, brachte aber den gleichen Fehler.
                @rsw2004
                Den ganzen Adapter, keine Instanz installieren.
                  also wie folgt?
                  cd /opt/iobroker
                  iobroker stop adapterName
                  npm install iobroker.adapterName
                  iobroker upload adapterName
                  iobroker start adapterName
                  Ändert sich nix
                    @rsw2004
                    Jein
                    iobroker update
                    iobroker upgrade openknx@0.7.2
                    Rückmeldungen im Terminal hier bekannt machen.
                      robin@raspberrypi4:~ $ iobroker update
                      Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
                      Update openknx from @0.7.2 to @0.7.2
                      NPM version: 10.5.0
                      Installing iobroker.openknx@0.7.2... (System call)
                      up to date in 7s
                      102 packages are looking for funding
                        run `npm fund` for details
                      upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
                      upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
                      upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
                      upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
                      upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
                      upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
                        rsw2004 @rsw2004 last edited by
                        @rsw2004
                        Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
                        Kann ich einfach die ältere Version das drüberbügeln?
                        Einfach die Versionsnummer ändern?
                          @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                          Dann mach ein Issue dazu auf, wenn du dir sicher bist.
                          Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
                            @rsw2004
                            Wobei das auf meinem System direkt durchläuft:
                            echad@chet:~ $ iob add openknx
                            NPM version: 10.5.0
                            Installing iobroker.openknx@0.7.3... (System call)
                            added 15 packages in 12s
                            117 packages are looking for funding
                            host.chet install adapter openknx
                            host.chet object system.adapter.openknx created/updated
                            host.chet create instance openknx
                            host.chet object system.adapter.openknx.0.alive created
                            host.chet object system.adapter.openknx.0.connected created
                            host.chet object system.adapter.openknx.0.compactMode created
                            host.chet object system.adapter.openknx.0.cpu created
                            host.chet object system.adapter.openknx.0.cputime created
                            host.chet object system.adapter.openknx.0.memHeapUsed created
                            host.chet object system.adapter.openknx.0.memHeapTotal created
                            host.chet object system.adapter.openknx.0.memRss created
                            host.chet object system.adapter.openknx.0.uptime created
                            host.chet object system.adapter.openknx.0.inputCount created
                            host.chet object system.adapter.openknx.0.outputCount created
                            host.chet object system.adapter.openknx.0.eventLoopLag created
                            host.chet object system.adapter.openknx.0.sigKill created
                            host.chet object system.adapter.openknx.0.logLevel created
                            host.chet object openknx.0.info created
                            host.chet object openknx.0.info.connection created
                            host.chet object openknx.0.info.busload created
                            host.chet object openknx.0.info.messagecount created
                            host.chet Set default value of openknx.0.info.connection: false
                            host.chet Set default value of openknx.0.info.busload: 0
                            host.chet Set default value of openknx.0.info.messagecount: 0
                            host.chet object system.adapter.openknx.0 created
                            echad@chet:~ $
                              es hat sich meiner Meinung nach nix geändert.
                              host.raspberrypi4
                              2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                              host.raspberrypi4
                              2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                              host.raspberrypi4
                              2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                              host.raspberrypi4
                              2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                              host.raspberrypi4
                              2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                              host.raspberrypi4
                              2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                              host.raspberrypi4
                              2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                                bei dir wurde die 0.7.3 installiert.
                                Habe das nun auch mal manuell geupdatet.
                                Der Log bleibt gleich.
                                  Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                                    Könnte das weiterhelfen?
                                    Welches Verzeichnis wäre denn hier das richtige?
                                    /opt/iobroker/iobroker-data/files/openknx.admin ?
                                      @rsw2004
                                      cd /opt/iobroker/node_modules/iobroker.openknx
                                      npm install --omit=dev
                                      müsste das sein. Der Befehl mit --production ist veraltet.
                                        Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                                        Erst Downgrade auf die ursprüngliche Version (laut LOG)
                                        iobroker update
                                        iobroker upgrade openknx@0.6.3
                                        danach
                                        Mit der aktuellen 0.7.2 funktioniert das nicht.
                                        Ich danke dir für deine Mühe
                                          Meldungen?
                                          526
